| 2010 MS3 - Big Turbo Builds Genpu - Big Turbo Builds. All discussions about big turbos, hybrids and builds belong here. |
![]() | | #41 | ![]() |
![]() Join Date: Feb 2011 Location: Waterford,CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,169
Groans: 423
| Not Ranked : 0 score
__________________ -Pat 2008 True Red MS3 GT3071R 'n Stuff SOLD 1999 Jeep XJ 6.5" Lift | Armor | 33" Tires | Bumpers 1996 Jeep XJ 3.5" Lift | 31" GY Duratracs | Bumpers 1994 Miata 15x8's w/NT05's | KYB AGX | Hardog Roll Bar | 70D Engine Mounts |
| The Following User Says Thank You to smoogs12 For This Useful Post: | rfinkle2 (05-15-2014) |
![]() | | #42 | ![]() |
It is hard to say exactly because each set-up is a little different. In this case, I feel like we can hit Matt's goals on a 3" maf housing. I think Matt's goal is to have 350 hp on tap with a very stock appearing car. We are trying to do that and stay on a budget. Some things may need to be swapped down the road, but for now, I think we are OK with the CS housing. | |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | smoogs12 (05-15-2014) |
![]() | | #43 | ![]() |
![]() Join Date: Mar 2012 Location: Westampton, NJ
Rep Power: 1412 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,551
Groans: 61
| Not Ranked : 0 score Was just curious. Good luck with everything...I can't wait to FINALLY pull the trigger on a bigger snail
__________________ Precision: PTE 5858 Kozmic: Downpipe//Dumptube//Oil Return&Feed//EGR Delete Tial: 44mm EWG HTP: 3.5" Intake + 51r Battery Tray CPE: Stage 2 RMM//Manifold JBR: SSP//Shifter Bushings//Knob//TMM//OCC UR: CBE HKS: SSQV4 CS: Springs NGK 1-Step Colder POWERED BY PURPLE DRANK I'm from Jersey...the Drama State. |
| The Following User Says Thank You to PUGENE For This Useful Post: | rfinkle2 (05-15-2014) |
![]() | | #44 | ![]() |
| Not Ranked : 0 score Fuel guys... I hate to keep driving this home, but fuel should be somewhere in the budget. In the cold weather, you are gonna need fuel. Meth, aux port kit... |
![]() | | #45 | ![]() |
Groans: 61
__________________ Precision: PTE 5858 Kozmic: Downpipe//Dumptube//Oil Return&Feed//EGR Delete Tial: 44mm EWG HTP: 3.5" Intake + 51r Battery Tray CPE: Stage 2 RMM//Manifold JBR: SSP//Shifter Bushings//Knob//TMM//OCC UR: CBE HKS: SSQV4 CS: Springs NGK 1-Step Colder POWERED BY PURPLE DRANK I'm from Jersey...the Drama State. | |
![]() | | #46 | ![]() |
![]() Join Date: Jul 2012 Location: Clifton Springs NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,398
Groans: 51
(Thread Starter) | Not Ranked : 0 score I have a dd/work car, but there are plenty of cold spring/fall days that could sneak up on me in the ms3. So meth will most likely be in my future this fall.
__________________ I used to go zoom zoom with my speed.... Now i drive a slow stockish Focus ST... |
| The Following User Says Thank You to MazdaBoy2.3 For This Useful Post: | smoogs12 (05-15-2014) |
![]() | | #47 | ![]() |
Groans: 61
| Not Ranked : 0 score Yeah. That's one thing I can't stand right now is the amount of miles I put on my car. 3-400 a week...I know there are guys that put on way more than that, but to me that's a lot and I hate it lol.
![]() | | #48 | ![]() |
Groans: 423
Only thing I might buy one of these days is a failsafe. But honestly im not worried.
__________________ -Pat 2008 True Red MS3 GT3071R 'n Stuff SOLD 1999 Jeep XJ 6.5" Lift | Armor | 33" Tires | Bumpers 1996 Jeep XJ 3.5" Lift | 31" GY Duratracs | Bumpers 1994 Miata 15x8's w/NT05's | KYB AGX | Hardog Roll Bar | 70D Engine Mounts | |
| The Following 3 Users Say Thank You to smoogs12 For This Useful Post: |
![]() | | #49 | ![]() |
| The Following 3 Users Say Thank You to rfinkle2 For This Useful Post: |
![]() | | #50 | ![]() |
![]() Join Date: May 2013 Location: Mejico, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,088
Groans: 30
| Not Ranked : 0 score 360-370hp on stock diameter intakes? Is this possible @rfinkle2 ?
__________________ 2009 Mazdaspeed 3 w/ Manley bottom end, keyed and lightened crank, CNC ported head, 2018 JMF v2 port injection fueled, CM twin disk clutch and Precision 6466 turbo, Kozmic built gen2 transmission with final drive swap. Tuning by PD Tuning |
| The Following User Says Thank You to impossible For This Useful Post: | rfinkle2 (05-16-2014) |
![]() | | #51 | ![]() |
Groans: 51
@rfinkle2; and I have been talking about this and think with a 3" maf housing we should be "ok".
__________________ I used to go zoom zoom with my speed.... Now i drive a slow stockish Focus ST... | |
![]() | | #52 | ![]() |
| Not Ranked : 0 score Matt has a number in mind, and a particular way he wants the car to feel. Until the install is done, and we start tuning, it is hard to say what we will / won't need. Matt has a budget for his build, and rather than accumulate parts that we aren't sure we need, he is getting the essentials first. I was talking to Matt and we agreed that there is really no end if you want to increase the efficiency of a given set-up, meaning that a larger intake may very well be beneficial, but I don't think we will need it. We are going to try to hit 350 with minimal modifications to the battery box, ecu location etc. |
![]() | | #53 | ![]() |
Groans: 51
![]() | | #54 | ![]() |
![]() Join Date: Jan 2012 Location: COLUMBIA MISSOURI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 63
| Not Ranked : 0 score Was reading through your thread and I just remembered that when @atvfreak; installed his BNR he was on the Corksport intake to about 360-370 HP maybe a little more but like Finkle has said different setups will be different. just some food for thought. |
| The Following User Says Thank You to Matt H. For This Useful Post: | rfinkle2 (05-16-2014) |
![]() | | #55 | ![]() |
Groans: 51
(Thread Starter) | Not Ranked : 0 score I'm going to assume he had an aftermarket dp on his car. We will soon find out the limitations of my stocker!
| The Following User Says Thank You to MazdaBoy2.3 For This Useful Post: | rfinkle2 (05-16-2014) |
![]() | | #56 | ![]() |
![]() Join Date: Jul 2012 Location: Rochester, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 487
__________________ 2012 MS3 CWP- Cobb AP, CS CBE, CS SRI/TIH, UR testpipe, Corksport Downpipe, JBR 88 duro RMM, NGK step colder plugs, Autotech HPFP, ETS TMIC, Koni Yellows, Swift Spec-R Springs, Forge V1, Corksport Hoodscoop (cooler BATs, yo) Enkei RPF1 (gold) 17x9 +45 w/ Conti procontacts 245/45 Freektuned- E85 4/8gal mix Last edited by white'swhiteMPS; 05-16-2014 at 02:02 PM. | |
| The Following 3 Users Say Thank You to white'swhiteMPS For This Useful Post: |
![]() | | #57 | ![]() |
| Not Ranked : 0 score This is correct without going through his thread to verify i believe he was on the V1 Ultimate racing two piece pipe. At the time he was making the power figures stated above he was on simple full bolt on status with a meth kit. |
![]() | | #58 | ![]() |
| Not Ranked : 0 score This is of course before he changed up a couple of things and made 400+HP. |
![]() | | #59 | ![]() |
Groans: 51
(Thread Starter) | Not Ranked : 0 score Then I would assume I should be able to pull 350 ish without the dp.
![]() | | #60 | ![]() |
| Not Ranked : 0 score I would 100% agree with a well sorted out tune which is without question in your case. There has also been a couple people on hear that has had some results with gutted stock pipes. I personally am not to informed on results in this department but this may be one of those options right up the budget alley!!! |
| The Following User Says Thank You to Matt H. For This Useful Post: | rfinkle2 (05-17-2014) |
![]() | | #61 | ![]() |
Groans: 51
(Thread Starter) | Not Ranked : 0 score HTP coolant hose extension on the way!
__________________ I used to go zoom zoom with my speed.... Now i drive a slow stockish Focus ST... Last edited by MazdaBoy2.3; 05-16-2014 at 07:53 PM. Reason: MSF Database - Automerged Doublepost | |
| The Following 2 Users Say Thank You to MazdaBoy2.3 For This Useful Post: | impossible (05-25-2014), rfinkle2 (05-17-2014) |
![]() | | #62 | ![]() |
| Not Ranked : 0 score And again I would agree with you! |
| The Following 2 Users Say Thank You to Matt H. For This Useful Post: | MazdaBoy2.3 (05-16-2014), rfinkle2 (05-17-2014) |
![]() | | #63 | ![]() |
Groans: 51
(Thread Starter) | Not Ranked : 0 score Fun new parts arrived! Coupler, dp gasket, coolant hose extension.
![]() | | #64 | ![]() |
![]() Join Date: May 2011 Location: Chicago Illinois
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 508
| Not Ranked : 0 score Can you post the link of the gaskets? I'm doin the 3076 and was gonna re use oem ones but fuck it
__________________ 2013 Velocity red Mazdaspeed 3 tech. BT 2011 Velocity red Mazdaspeed 3-SOLD. FreeKtuned fitty fitty |
![]() | | #65 | ![]() |
Groans: 51
The top is the dp gasket and the middle is the turbo to manifold gasket. Disregard the bottom number, that is for my bumper guard.
| The Following User Says Thank You to MazdaBoy2.3 For This Useful Post: | 2011speed (05-26-2014) |
![]() | | #66 | ![]() |
![]() Join Date: Jan 2013 Location: Buffalo/NYC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 122
| Not Ranked : 0 score The gaskets can be purchased from edge auto and you might be able to use the discount code and save a few dollars. I image edge would take the return, but dealer might be the way to go if you intend to return them if yours are ok. Sent from my iPhone using Tapatalk
__________________ Current 2013 Ingot Silver Focus ST - ST3 Injen: 3in SES Exhaust TT Tips SOLD! 2008 Sunlight Silver MS3: BNR: S3 V2 Cobb: V3 AccessPort CNT: Catted Downpipe / Cat-Back Exhaust Damond Motorsports: RMM Eibach: Prokit HTP: 3" Intake System (One-piece) JBR: Rear Sway Bar Koni: Yellows MAC: 3-Port EBCS Morimoto: HID Kit / The Retrofit Source clear lens swap. NATOR FMIC: Cx Racing piping / Treadstone TR8 |
![]() | | #67 | ![]() |
Groans: 51
(Thread Starter) | Not Ranked : 0 score Making an oil return line!
| The Following User Says Thank You to MazdaBoy2.3 For This Useful Post: | rfinkle2 (05-31-2014) |
![]() | | #68 | ![]() |
Groans: 51
(Thread Starter) | Not Ranked : 0 score Manifold Gasket is here! As well as parts for the oil return line I am making.
![]() | | #69 | ![]() |
Groans: 51
(Thread Starter) | Not Ranked : 0 score Looking for any input on something i might be missing for the install day. Any last minute items i should order up?? @kritz; @Tokay444; @rfinkle2; @thricestrat; Here is what I have: 1. ATP GT2871 Turbo - $1425 - arrived! 2. 3 BAR MAP Sensor - $90 - installed 3. 4in to 2.25in coupler (turbo to CS TIP) - $17 - arrived! 4. Antifreeze - not ordered 5. Turbo to manifold gasket (just in case) - $67 - arrived! 6. Turbo to DP gasket (just in case) - $20 - arrived! 7. HTP heater core hose extension - $16 - arrived! 8. Oil return line - creating 9. 4'' clamp - on the way!
![]() | | #70 | ![]() |
![]() Join Date: Jun 2010 Location: Cedar Rapids, IA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
![]() | | #71 | ![]() |
![]() | | #72 | ![]() |
| jbr makes fall-a-parts. ![]() Join Date: Jan 2011 Location: Cambridge Ontario Canada
Rep Power: 13536 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,744
Groans: 793
| Not Ranked : 0 score Pb blaster. As many swivels as you can find and multiple different depth 14mm sockets.
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals |
| The Following 2 Users Say Thank You to Tokay444 For This Useful Post: | MazdaBoy2.3 (06-08-2014), thricestrat (06-09-2014) |
![]() | | #73 | ![]() |
![]() Join Date: Oct 2011 Location: FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 601
Groans: 106
| Not Ranked : 0 score Arent the ATP nuts 15 mm? Are you aware of the new position of the compressor outlet? Its about 3 inches lower than the K04. A closed ended slightly offset 14mm wrench will help alot the manifold removal/install. 15 mm open ended wrench for the bottom nut on the downpipe to turbo. Also, while you have everything out, don't forget a bit of heat management. Blanket or coat. |
| The Following User Says Thank You to JSmith For This Useful Post: | MazdaBoy2.3 (06-08-2014) |
![]() | | #74 | ![]() |
Groans: 51
I am hoping to do this install without pulling the exhaust manifold....
![]() | | #75 | ![]() |
![]() Join Date: Nov 2010 Location: Lido Beach,NY
Rep Power: 8624 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,845
Groans: 95
| Not Ranked : 0 score Some side mounts, silicone vacuum hose, for oil drain use pushlock.
__________________ Nator is what it does. |
| The Following User Says Thank You to kritz For This Useful Post: | MazdaBoy2.3 (06-08-2014) |
![]() | | #76 | ![]() |
Groans: 51
(Thread Starter) | Not Ranked : 0 score Got these for the drain thanks to Rob's advice! @donjohnk; - do you or do I have the vacuum hose i bought?
![]() | | #77 | ![]() |
![]() Join Date: May 2012 Location: Syracuse
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,585
| Not Ranked : 0 score Yea I guess I can wait on my ebcs. Ill bring it back
__________________ |
![]() | | #78 | ![]() |
Groans: 793
| Not Ranked : 0 score ATP nuts are 15mm, but he has to get all the stock ones off first. Bottom nut on dp to turbo? 15mm? What?
![]() | | #79 | ![]() |
Groans: 51
(Thread Starter) | Not Ranked : 0 score I need like 18" of it... not the whole thing...
__________________ I used to go zoom zoom with my speed.... Now i drive a slow stockish Focus ST... Last edited by MazdaBoy2.3; 06-09-2014 at 06:22 AM. |
![]() | | #80 | ![]() |
![]() Join Date: Apr 2013 Location: Tonawanda, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 74
I would have on hand 2 sets of impact swivels 3/8" and 1/2" (and various extensions). Also, I assume ATP turbo came with new crush washers for oil and coolant lines (2) sizes 8 total, may wanna check just to be sure
__________________ Koni Yellows / Eibach Pro Springs / CX & Treadstone FMIC / HTP 3.5" / PowerSlot Rotors / Moog Rear Endlinks / ProSport Boost Gauge / CP-E Defrost Vent Pod / Autotech HPFP / Cobb AP V3 / BNR S1->S3->Modded S3 / CP-E Stage 2 RMM / JBR Boost Tubes / JBR Recirc Tube / JBR EGR Block Off / | |
| The Following User Says NO Thank You to thricestrat For This Un-useful Post: | Thepedigree13 (07-07-2014) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f540/mazdaboy2-3-s-gt2871-build-170081/ | ||||
| GTX2867r part-out - Page 2 - Mazda 3 Quebec | This thread | Refback | 07-27-2014 03:55 PM | |
| gt2871 best $? | myfirstturbo | MazdaSpeed 3/6 - Turbo Induction | 4 | 06-04-2013 07:10 PM |
| Reworked K04 or GT2871 | manofhonor24 | MazdaSpeed 3/6 - Turbo Induction | 76 | 09-23-2009 05:41 PM |
