| 2010 MS3 - Big Turbo Builds Genpu - Big Turbo Builds. All discussions about big turbos, hybrids and builds belong here. |
![]() Join Date: Jul 2017 Location: Houston
(Thread Starter) | Not Ranked : 0 score Currently I’m in the stock motor, CS turbo 25 PSI E30 + 100% meth w/ 1 1000cc nozzle. So I’m already running the methanol using AEM’s MAP based controller. With the benefits of meth injection, my BATs are in the 30F range! What is the need for an intercooler? Even with my TR10 front mount it doesn’t get anywhere close to that, no intercooler can. My thought process is - Use a Split Second additional fuel controller with a 5th/6th port injection setup, running 100% methanol from a (large) fuel cell. That way with tuning you are able to fine control the injection from idling in traffic to WOT, not only using it for aux fueling but also to eiminate the need of an IC. Not to mention the benefits of no IC: -less weight -lower water temps by not having a giant fmic -much simpler routing -shorter piping and thus -less lag This is just experimental if anything, I’m not extremely familiar with how the Split Second controller works so I don’t know if you can have the injectors running at idle, which would probably be required with this especially in hot climates. Some feedback on why this is a bad idea or hasn’t been done before is much appreciated |
| Not Ranked : 0 score @phate; has been running without an intercooler on his autocross car for a while now I think. Much lower power than your goals though. @Matt@DamondMotorsports; also ran their drag car without intercooler for a short while.
| Not Ranked : 0 score Not sure. Check out Damond's drag car thread.
![]() Join Date: Aug 2012 Location: Toronto, Ontario, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 165
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score How does a non intercooler setup handle during regular cruising / part throttle conditions? I'd imagine bat's getting pretty high no?
__________________ - 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 3 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress) |
| Not Ranked : 0 score Normal driving around/cruising would be considered "low boost". Turbo outlet temperatures shouldn't be that bad. Considering my WOT intercooled BATs would top out above 150 in the summer, I don't see non-intercooled part throttle BATs getting close to that. In the early days of turbos, they didn't run intercoolers because they were only making upwards of 10psi.
But then again that's just me
__________________ - 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 3 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress) Last edited by BuddySpeed3; 11-12-2018 at 02:24 PM. Reason: MSF Database - Automerged Doublepost | ||
![]() Join Date: Oct 2015 Location: Central Jerz
| Not Ranked : 0 score I dont think heatsoak would even matter if its constantly being sprayed. Gonna be running thru jugs of meth lol by that alone i'm sure it wouldnt be a dd
__________________ 2010 MS3 - Tuned By Nishan Autotech Fuel Pump Internals OBX R Custom Exhaust Cobb SF Intake & TIH w. Blitz Filter CP-e TMIC Corksport Dual VTA BPV JBR 88 Duro RMM |
| Not Ranked : 0 score Heat soaking what? How can a non-existent intercooler get heatsoak?
| Not Ranked : 0 score Non-intercooled, I see cruise temps around 180°, and it jumps near instantly to 240°+ at the hint of boost. I do not recommend it if you plan to run 93 at any point in its life.
| The Following 2 Users Say Thank You to phate For This Useful Post: | BuddySpeed3 (11-13-2018), Code Monkey (11-13-2018) |
![]() Join Date: Aug 2018
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 14
| Not Ranked : 0 score How much weight would you realistically save doing this vs. a TMIC from CS or CP-E? I just don’t see the constant meth injection as a substitute for just an passably efficient TMIC and save the meth for high boost. Or are you just wanting to be different just because? |
I do this by running ethanol, not WMI. With an aux fueling setup with meth, it's going to be crazy expensive to run it all the time. The actual intake temp doesn't matter, it's what's going on in the cylinder that is important.
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. | |
| The Following User Says Thank You to phate For This Useful Post: | BuddySpeed3 (11-13-2018) |
| Not Ranked : 0 score If you're curious about turbo outlet temps at different pressures, click below. Granted the turbo efficiency at very low boost is up for debate since it's probably off the chart. Stealth 316 - Turbo Outlet Temperature It doesn't take much boost to get very hot. Also keep in mind that the manifold air temp sensor is mostly measuring the temperature of the manifold itself when there is a very low volume or air flowing across it. That's why BATs go down during the first phase of a pull. The incoming rush of air is cooling off the thermistor sensor from being heatsoaked by the manifold. When you see 180 degree BATs while cruising, the air isn't 180. The sensor is.
| Not Ranked : 0 score for the same benefit of reduced lag and radiator airflow, i would at least use a water cooled ic. Put a small radiator in the back or somewhere else not in front of the car for the cooling fluid. Since you want to do a good part of the job with meth, for DD the water cooler would work at low boost and under high boost when the ic fluid get limited, the meth would take over ?
| Doing the math: Methanol Fueling Calcs | cld12pk2go | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 115 | 08-30-2012 10:10 AM |
| Fueling | 06Speed6 | Mazdaspeed3/6 General Discussion | 1 | 08-31-2008 03:16 PM |
