> 2010 MS3 - Big Turbo Builds
Like Tree4Likes
  • 1 Post By SSinstaller
  • 1 Post By Fstrnyou
 Old 11-05-2018, 11:21 AM   #1
achulz's Avatar
Posts: 94   (View Stats)
achulz has a spectacular aura aboutachulz has a spectacular aura aboutachulz has a spectacular aura about
Default PCV Questions
Alright, I’ve been having some problems with my PCV system. It’s completely OEM and with 25 PSI on a CS turbo it’s forcing oil through my valve cover breather and through all my charge pipes. I’ve lost about half a quart of oil in 500 miles, need to fix it ASAP.
Only thing is I’m not really sure what to put in there. I am going to buy a Kozmic vented catch can kit but I’m not sure if I need a new PCV plate as well or a breather cap, etc. I have a new PCV valve ready to go in as I’m sure it’s either clogged or broken, but I’m not sure if that will fix the crankcase pressure.
I don’t really understand how all the plumbing works and if I even need a PCV valve after the catch can install, or if the catch can replaces the PCV valve entirely.
Any help, need some guidance.
achulz is offline   Reply With Quote
 Old 11-05-2018, 11:28 AM   #2
JSmith's Avatar
Posts: 707   (View Stats)
Groans: 106
Yes, you need a PCV valve, even after a catch can install. You dont need a vented catch can either.
Sealed catch can with a check valve between Intake manifold and catch can is a good place to start.
 Old 11-05-2018, 11:36 AM   #3
achulz's Avatar
Can I still use the stock oil separator plate?
 Old 11-05-2018, 11:38 AM   #4
JSmith's Avatar
Groans: 106
Yes. You just interrupt the hose exiting the PCV valve and route it to the CC, the CV, then back to the IM like normal.
 Old 11-06-2018, 09:32 AM   #5
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
A sealed can between the PCV plate and intake manifold does NOTHING to vent crankcase pressure in when in boost unless it's connected to the turbo inlet pipe.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 11-06-2018, 10:16 AM   #6
achulz's Avatar
So how would I route a vented catch can? From the PCV to the can then to the intake? Or back into the manifold?
 Old 11-06-2018, 10:19 AM   #7
shamie's Avatar
Posts: 952   (View Stats)
Go with a Damond Motorsports dual catch can setup with a stock PCV (new) and you'll be golden.
 Old 11-06-2018, 04:25 PM   #8
BuddySpeed3's Avatar
Posts: 479   (View Stats)
Groaned at 7 Times in 4 Posts
Are u getting any oil past the turbo seal burning up in the exhaust? Without good crankcase pressure relief mods my BNR S4 would burn oil like crazy, and shoot plumes of smoke out the tailpipe at WOT, although I wasn't getting oil out the valve cover breather which makes me think the S4 might be more suseptible to smoking than the CS turbo without good crankcase pressure relief.
Running an oil restrictor bolt as a first resort may have starved my S4 of oil causing slight damage, because even to this day with a dual vented catch can setup, and sp63 oil breather cap, my S4 still smokes, but not nearly as bad as when I had no crankcase pressure relief.
Many have mentioned that running an oil restrictor bolt on journal bearing turbos is not a good idea. Start with CC pressure relief first.
The simplest setup would be to try a Gen 2 VC with SP63 oil breather cap
 Old 11-06-2018, 04:50 PM   #9
achulz's Avatar
Corksport includes their own oil feed bolt when you buy their turbo. That’s what I’ve been using, not a single hint of smoke even with all the crankcase pressure. Just the classic black smoke outs cars make when you put your foot down.
I have a Gen 2 lol, what I’m going to do is have a single vented catch can with two ports, one for the valve cover breather and one for the PCV. Then plug off the intake manifold port and the inlet pipe port. That should bring my crank case pressure way down and completely eliminate the possibility of oil getting into my intake.
What I think is happening is because I’m running so much boost it shuts the PCV valve closed and builds crank case pressure, forcing oil out through the valve cover breather and into my intake.
 Old 11-06-2018, 06:11 PM   #10
shamie's Avatar
Your going to put a can between your valve cover and PCV valve?
 Old 11-06-2018, 07:13 PM   #11
achulz's Avatar
A vented can yes. They both emit crankcase pressure so leading them to a vent to atmosphere can seems like a wise idea. I know a sealed can pulls pressure from vacuum but my priority is to rid the oil and vapors from my intake. I guarantee it will still have lower crankcase pressures than the stock PCV system. I don’t even have a vented oil cap.
 Old 11-06-2018, 08:44 PM   #12
shamie's Avatar
I think your going to create more problems with that setup.
 Old 11-06-2018, 11:56 PM   #13
Fstrnyou's Avatar
Sealing the manifold port & TIP port and plumbing the VC & PCV plate to a single VTA OCC won't be a problem. Bonus, you won't need any restrictive check valves.
Other rides:
History:
 Old 11-07-2018, 05:48 AM   #14
Oh I didn't realize the CS turbo came with it's own oil feed bolt. Good to hear it's holding up at 25 psi with the stock PCV configuration without smoking.
In regards to your PCV considerations, I think keeping both the valve cover and intake manifold vacuum sources in place will benefit much more at both part throttle and wide open throttle.
If you remove the oil cap with the engine idling, you can feel quite a bit of pressure (although this may all be in my head as I haven't actually measured CC pressure). Now imagine removing all the vacuum sources :/
This is the setup I run. I've done some editing in paint to show my exact setup. It's quite over kill in most cases, but this was when I was trying everything I could to stop my S4 from smoking, and found that running an oil restrictor bolt may have been the first mistake that prolonged issue.
The reason why I like this setup is because there are several places for pressure to vent and it retains all OEM style vacuum sources on the crankcase. But the real kicker is that during WOT, the inlet pipe pulls a strong vacuum
the crankcase through the can on the right side.
 Old 11-07-2018, 08:55 AM   #15
Fstrnyou's Avatar
I don't have a catch can between my VC and TIP. I used to and it never had oil in it, so I took it out. Figured if it's not catching anything then all that extra tubing and a baffled catch can is hurting flow.
The other catch can drawn above is how mine is plumbed, except I don't use the PCV valve. I put a cap over the PCV and hooked the OCC hose to the center port. This provides a wide open/unrestricted flow to the VTA catch can, although it still has to flow through another restrictive check valve to vent out.
Gen2 VC would be nice to have in order to use the VTA oil fill cap/breather.
Other rides:
History:
 Old 11-07-2018, 06:42 PM   #16
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
How are you not getting a massive amount of unmetered air through the intake port?
BuddySpeed3 likes this.
 Old 11-07-2018, 07:04 PM   #17
Fstrnyou's Avatar
I don't see any leak potential.
Other rides:
History:
 Old 11-07-2018, 07:10 PM   #18
I take it you're still using the check valve in between the IM and the PCV plate right?
I'm wondering if using just a check valve without the PCV valve actually pulls more vacuum on the crankcase due to potentially less restriction, and if it might correct my smoking turbo issue.
Sorry to thread jack, but it's PCV related so I'll continue
With my over kill PCV setup posted above, WOT pulls don't look to be smoking nearly as bad as they used to.
I'm not sure if running the restrictor bolt for quite a while caused damage to the turbo or not, but with this over kill PCV setup switching back to the stock oil feed bolt seems to have reduced the smoking.
I've noticed that the smoking issue seems worse during mid to high rpm deceleration, whether I go into boost or not, I will see quite a bit of blueish white smoke out the tailpipe in my rear view.
I can get it to happen easily by slowly bringing the rpm up to about 5k, and then letting off the gas.
As soon as it starts decelerating, about 2 seconds go by, and then smoke starts trailing out behind me for a few seconds before it dissipates.
I will say that although this turbo is a great value and performs well, I have been spending quite a bit of time and money trying to totally stop it from smoking.
I'm almost at the point of accepting the fact that I will just have to carry around a 5 liter jug of Rotella T6 for top up's lol, or send it out to BNR to get rebuilt/inspected and hope it doesn't smoke after that.
My guess as to why this is happening during deceleration is simply because I have a full 3" catless high flow turboback exhaust.
During deceleration the injectors turn off, causing only air to be pumped through the engine.
Without sufficient back pressure from combustion in the downpipe, a potential venturi effect from only air flowing through might be pulling oil past the turbine seal causing it to burn up.
Many other internet sources have suggested valve seals, but I doubt it since the car doesn't have any other smoking issues other than in he circumstances of deceleration and WOT pulls.
I'm thinking that maybe by using just a check valve instead of the PCV valve, a stronger vacuum can be pulled on the turbos oil drain that might over come the strength of that potential venturi effect in the exhaust during deceleration.
 Old 11-07-2018, 07:16 PM   #19
Fstrnyou's Avatar
Yes, still using check valve at the intake manifold...which makes the PCV valve redundant and an unnecessary restriction.
Other rides:
History:
BuddySpeed3 (11-07-2018)
 Old 11-07-2018, 07:33 PM   #20
Each vented OCC has a one way check valve on top.
Thanks man I might have to try this out and hope it stops my smoking during deceleration. What did you use to cap off the PCV valve?
Last edited by BuddySpeed3; 11-07-2018 at 07:33 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-07-2018, 07:55 PM   #21
Fstrnyou's Avatar
Generic nipple cap. It came in an assortment pack from Advance Auto.
Other rides:
History:
 Old 11-07-2018, 08:01 PM   #22
Ouuu my favorite kind of cap, Thanks man!
 Old 11-08-2018, 10:28 AM   #23
Ds_06_Speed6's Avatar
Posts: 38   (View Stats)
Ds_06_Speed6 will become famous soon enoughDs_06_Speed6 will become famous soon enough
https://www.ecwid.com/store/store947...late-p99309430
06 Speed6
AP V3| CS TIP/SRI |CS 50/50 BPV |CS Test Pipe |CS FP internals|CS high pressure SS fuel line |CPE EGR delete |CPE TMIC |JBR Boost Tubes |JBR Trilogy race mounts |JBR short shift kit |Grimmspeed EBCS |GA V3|Custom FREEK tune
Ds_06_Speed6 is offline   Reply With Quote
The Following User Says Thank You to Ds_06_Speed6 For This Useful Post:
BuddySpeed3 (11-09-2018)
 Old 11-09-2018, 10:09 AM   #24
Do u notice any negative side effects with this setup?
 Old 11-09-2018, 01:34 PM   #25
Fstrnyou's Avatar
No
Other rides:
History:
 Old 11-23-2018, 06:14 AM   #26
Fstrnyou's Avatar
Hararious.
Other rides:
History:
Salt questions and carpet questions ikyn Gen2 MS3 General Discussion 33 03-14-2016 10:56 AM
Used questions Jonb82 Gen2 MS3 General Discussion 46 08-31-2015 10:19 AM
Looking to buy a new MS3, few questions first woodfloor Gen2 MS3 General Discussion 82 09-10-2012 09:19 AM
Page generated in 0.46611 seconds with 27 queries
