> 2010 MS3 - Big Turbo Builds
Like Tree18Likes
 Old 08-20-2017, 09:59 AM   #1
VoodooJef's Avatar
Posts: 144   (View Stats)
VoodooJef has a reputation beyond reputeVoodooJef has a reputation beyond reputeVoodooJef has a reputation beyond reputeVoodooJef has a reputation beyond reputeVoodooJef has a reputation beyond reputeVoodooJef has a reputation beyond reputeVoodooJef has a reputation beyond reputeVoodooJef has a reputation beyond reputeVoodooJef has a reputation beyond reputeVoodooJef has a reputation beyond reputeVoodooJef has a reputation beyond repute
Default Voodoo`s S4v2 build
Just gonna do the quick and dirty as this is already chronicled on another site. Happy to answer questions as they come up.
Got the car nearly stock. All it had on it was an intake (and one from a brand I am not at all fond of at that). Within a month I had the magnaflow exhaust, test pipe, a different and bigger intake (3" JBR aluminum), CPe TMIC, and of course hpfp internals and the AP, and got a map from Lex, tuned to an E85 blend. It was quick and gave up 330whp and 375ish torque. It was fun and quick and sounded great.
But it wasn`t enough. Been hotrodding cars for almost three decades and I`ve had some cars much faster than this little FWD scooter could ever hope to be, but I knew it had more potential. And so the lust for a new, bigger turbo started.
I searched high and low for what would get me where I wanted to be. I wanted solid, reliable 425whp. It really looked like the GTX2971 would be the one but it was expensive and no one really had any info on it. Right about that time the S4v2 came along and I learned that it was for the most part a 3076. Not a fancy 3076, but it would blow enough air to get what I wanted. Done. Bought it and a catless DP and a methanol kit. The build took on a whole new attitude. I wanted to break 400whp on parts many people said couldn`t do it.
Got the whole thing installed in a few hours and it ran great but was overboosting like a mf`er. As we`ve come to find out, the S4 wastegate actuator has a wicked strong spring in it. 22psi at spring pressure was more than we were looking for. A very simple swap and we`re back in business.
Tuned it up, dialed in the meth, tuned some more. Put it on the rollers and got 406whp with the top mount. Goal #1 accomplished. About that time I got a killer deal on a front mount intercooler so forward I went. The FMIC flowed much more than the TMIC and was putting me over load targets, so back into the tune we went. Got that squared away, 424whp now, and pretty much out of fuel with 12gph of methanol. Upped the methanol to 20gph and pushed the tune ever further. The last clean log I got resulted in a vdyno of 462whp. I will never claim vdyno as gospel but it was a clean pull so I suspect it was at least close. Two days later I turned a connecting rod into a boomerang. Got VERY lucky. I was 25 miles from home. Did not ventilate the block, in fact babied it home and it didn`t so much as get hot.
When we tore the motor down it was really nothing but the best news in a bad situation kind of deal. Block was fine, crank was fine, bearings and cylinder head all fine. Not a spec of metal shavings in the oil. Machine shop confirmed the block was in perfect condition and would require minimal machining. Took the block out to 88mm. Manley rods, Mahle 4032 pistons, XS V3 exhaust mani, a clutch to handle it all, and an ST intake mani going on it soon. Haven`t even picked it up from the shop yet, but I did opt for them to beak it in on the dyno (a three hour process and the car comes off the dyno ready for whatever you can throw at it) so I can get to tuning it again as soon as I get it back (they did in fact give me the option of dyno tuning after the break in so it would be completely done when I pick it up but for a few reasons I declined).
I`m not going for huge numbers. The S4 will do 460 pretty comfortably and if you`ve seen any of the dyno charts I`ve posted in different places you`ll know it responds remarkably well. We`ll tune it up a little more aggressively and bring on the torque a little earlier but honestly, at 460whp/420tq these cars haul ASS. There won`t be many cars out there I`ll worry about in the occasional Stop Light Grand Prix or trips through Mexico, and at that point the cars I`ll lose to would beat me even with another 100hp. I don`t street race very often, and I`ve done all the drag racing a lifetime needs. Got into track racing so we`ll see where that leads.
I`ll put up a dyno chart once it`s all tuned up with the new motor. If I left interesting or pertinent info out, just ask.
NJsean0 and Bexar like this.
Built motor w/ Manley rods & Mahle 4032 pistons,BNR S4v2, 3.5" JBR tru-wide, XS power V3 exhaust mani, ST intake mani, CNT catless dp, Magnaflow 3" exhaust, autotech hpfp, Coolingmist progressive (lots of methanol), Cobb FMIC, Cobb RMM, DM PMM, JBR shifter w/ Maisonvi knob, 255/35/18 Pilot Super Sports, Bilstein coilovers (f), Bilstein cartridges in (r) with BC linear spring conversion, GFB valve w/ a GA, Versatune so I can be a rebel, just a little north of 500whp.
And Yeah, that`s Steve Vai playing my arm in my avatar.
VoodooJef is offline   Reply With Quote
 Old 08-20-2017, 10:20 AM   #2
tmillner's Avatar
Posts: 621   (View Stats)
tmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the world
Wait you did 460whp with out auxiliary fueling and just meth? Glad to hear no additional damage to block too
Sent from my SM-T587P using Tapatalk
VoodooJef likes this.
UR TBE/JBR RMM/UNKNOWN HPFP INTERNALS/COBB V2 AP/CS SRI + TIH/CXRACING FMIC
tmillner is offline   Reply With Quote
 Old 08-20-2017, 10:48 AM   #3
VoodooJef's Avatar
20gph of methanol is more than considered aux fuel. It`s just not delivered by mechanical fuel injectors. In fact, 20gph can be officially considered "a shitload" LOL. To be technical, at full pump pressure it delivers about 21.8gph, which is nearly identical to running a 1300cc 5th port injector.
I debated adding a full PI setup but for my power goals it isn`t the overwhelming advantage it would be at >500whp. **IF** I jump to a bigger turbo next year I`ll do it because I`m running 130hp worth of methanol as it is, and that`s about as fringe as I want to get with it. The setup now would survive a methanol failure (unless I was just a jackass and stayed in the loud pedal with the afr too lean) but if I were making another 100hp and relying on methanol for it I suspect it would be a bad time if it failed.
 Old 08-20-2017, 11:18 AM   #4
ProChargedLS2's Avatar
Posts: 129   (View Stats)
ProChargedLS2 is a jewel in the roughProChargedLS2 is a jewel in the roughProChargedLS2 is a jewel in the rough
Groaned at 5 Times in 2 Posts
That looks like a really solid setup, subbing! Don't forget to post pictures once you complete it all
Sent from my Pixel XL using Tapatalk
Upon this rock I will build my church
BNR S4 V3, JMF Intake Manifold, XSP Exhaust Manifold V3, ATP Catless DP, SU TMIC, JBR Tru- 3.5 intake, DM Stage 3 DOCC via route 4, JBR Intake Manifold + Throttle Body Insulating Gaskets, CS EBCS, CS High Pressure Fuel Line, CS HPFP Internals, CS Injector Seals, JBR BSD + Baffle Kit, CS RMM, CS SSB, JBR SSP, Forge BPV, 3 BAR MAP Sensor (for now), DM EGR Delete, NGK 6510 Plugs, DM PCV Plate
TUNEDBYNISHAN!!
ProChargedLS2 is offline   Reply With Quote
 Old 08-20-2017, 12:11 PM   #5
NJsean0's Avatar
Posts: 28   (View Stats)
NJsean0 is a jewel in the roughNJsean0 is a jewel in the roughNJsean0 is a jewel in the rough
Can't wait to see the finished product and pics!
NJsean0 is offline   Reply With Quote
 Old 08-20-2017, 03:53 PM   #6
manu's Avatar
Posts: 80   (View Stats)
manu is a glorious beacon of lightmanu is a glorious beacon of lightmanu is a glorious beacon of lightmanu is a glorious beacon of lightmanu is a glorious beacon of lightmanu is a glorious beacon of light
Groaned at 7 Times in 5 Posts
Interested in this setup myself, my goals would be very similar
Sounds like ure rods handled way more than well at over 400hp
Sent from my SM-G955U using Tapatalk
manu is offline   Reply With Quote
 Old 08-20-2017, 05:07 PM   #7
VoodooJef's Avatar
Just a few "before" pics. Not much will change other than the blue couplers going away for black and all of the IC piping will be the same flat black as the turbo outlet pipe. Oh, and a different intake and exhaust manifold. Couple of random pics from along the way as well:
http://www.mazdaspeedforum.org/forum/foru...1&d=1503270169
manu and NJsean0 like this.
 Old 08-21-2017, 09:36 AM   #8
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Nice build! Can't wait to see final results. Post up some footage of pulls when it's done. Would love to see what this machine traps in the 60'.
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
 Old 08-21-2017, 09:46 AM   #9
VoodooJef's Avatar
I have been keeping an eye out for some sticky tires. The PSS are a great tire, probably the best street tire I`ve ever used but they`re not a drag tire and even before the new motor I could break them loose in 3rd if I wanted to. I just don`t drag race much so it hasn`t been a priority. We`ll see if I can turn up a set of cheapie 16" wheels and real race tires.
 Old 08-21-2017, 03:18 PM   #10
manu's Avatar
What about upgraded brakes now ,having or reaching double the stock factory power?
 Old 08-21-2017, 03:30 PM   #11
VoodooJef's Avatar
Definitely next on the list. The suspension is done, the motor is done. Just gotta figure out where I want to go with them.
 Old 08-21-2017, 03:46 PM   #12
manu's Avatar
I saw some no upgraded brakes systems made by KSport, not cheap tho..this was from jmautosports.com ,they 've got a range from13mm to 16.5mm pretty insane with 8piston calipers
 Old 08-21-2017, 03:55 PM   #13
VoodooJef's Avatar
I`ve seen talks of a CTSV kit in the works, so that may be an option if the price comes in at a reasonable point. I can do "better" brakes without going to "bigger" for a very reasonable price. I`ll start shopping around once I figure out what I want, there`s bound to be a good deal out there.
 Old 08-21-2017, 03:59 PM   #14
manu's Avatar
Oh yeah the are so many reasonable deals the "better " while the "bigger"
"are like quadruple $$
 Old 08-22-2017, 03:34 AM   #15
JakeMS3's Avatar
I upgraded a few months ago to a BBK by wilwood for $1100. Lightweight 6 pots, 2 piece rotors, brake pads, and stainless lines were all included. It was bolt that on with their supplied brackets. Great improvement over stock and they look amazing!
2013 LSM w/tech
Cobb AP V3, CBE
DM OCC/TMM
Forge V2 BPV
Wilwood 6 pot BBK
 Old 08-22-2017, 06:31 AM   #16
2008mazdaspeed3!'s Avatar
Posts: 18   (View Stats)
2008mazdaspeed3! will become famous soon enough2008mazdaspeed3! will become famous soon enough
Are you still running the E85 blend with the big turbo and methanol?
2008mazdaspeed3! is offline   Reply With Quote
 Old 08-22-2017, 06:34 AM   #17
drive_sideways's Avatar
Posts: 120   (View Stats)
drive_sideways is just really nicedrive_sideways is just really nicedrive_sideways is just really nicedrive_sideways is just really nice
That much power on a speed3 haha must get some wheel spin lol
drive_sideways is offline   Reply With Quote
 Old 08-22-2017, 08:32 AM   #18
VoodooJef's Avatar
Yeah. Been on the fence about going back to just 93 in the tank for fuel headroom and letting the methanol handle octane but with E85 in the tank it buys me a little bit of buffer if the methanol fails. I`d rather it just go lean for a second than to have it go lean AND go into detonation.
Wheelspin was a problem WAY before now LOL. I run a good tire in a pretty meaty size and first gear is there just for comic relief but it hooks well enough through the rest. The advantage of a BT is that the torque doesn`t come on like you were rear ended by a bus, so it`s a little easier to manage traction.
 Old 08-27-2017, 07:44 PM   #19
andale927's Avatar
Posts: 193   (View Stats)
andale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant future
It's good to see what's in my future lol. Is a 4032 piston enough for a reliable 460whp?
2013 Mazdaspeed 3 w/ Tech - Purchased Jan 2017
Power:
BNR S4 v2 Turbocharger | JBR 3.5" Aluminum Intake | JBR Battery Box | GFB Respons BPV |Depo Racing Catless Downpipe | Bosch 3 BAR MAP | JBR 3 Port EBC | Treadstone TR8 Kit w/ Piping | Autotech HPFP Internals | Ultimate Racing Catback | Cobb Accessport V3 | Devils Own Meth Kit (D05) | Custom Tru-Cool Oil Cooler | FREEKTUNED E30 Mix+Meth
Handling:
KW V3 Coilovers | CS Camber Plates | SPC Rear Camber Arms | Michelin Pilot Sport 4S 235/40/18 | Full Damond Motor Mounts | JBR Weighted Shift Knob | JBR Shift Bushings | JBR Rear Sway Bar | Damond Short Shift Plate
Other:
Cobb Polyurethane Exhaust Hangers | Speedline Hood Struts | Corksport CF Hood Scoop | Damond OCC Stage 1 | Corksport E-Brake | Corksport Steering Wheel | Avid.1 AV-20 Wheels 18x8 +35
andale927 is offline   Reply With Quote
 Old 08-27-2017, 07:56 PM   #20
VoodooJef's Avatar
Absolutely. 4032`s will support nearly any HP you can thrown at them (good for 500+, straight from the folks at Mahle who make them). 4032`s are a better choice for a daily driver, their "weakness" is they are less resistant to detonation. You can drive a 2618 into knock and detonation and it`ll hardly whimper but 4032s are a harder alloy and don`t absorb the forces of detonation as well. I run a shitload of alcohol so detonation and knock aren`t really an issue so they will do me just fine. I`m more interested in the 100K+ miles life expectancy. It`s not like they are any cheaper than 2618`s.
 Old 08-27-2017, 08:19 PM   #21
andale927's Avatar
Gotcha. I read a lot of conflicting information online about the 4032 alloy and I guess that made me overthink it. Can't go wrong if Mahle themselves say they can handle that much!
Looking forward to seeing more from you lol. The s4 has the perfect spool, it definitely makes sense to push it to the limit and not go any bigger.
Power:
Handling:
Other:
 Old 08-27-2017, 08:26 PM   #22
VoodooJef's Avatar
There are a few of us on here running the 4032s. I believe Goosey has them in Florida maybe, and hasn`t had an issue. I`ve got some friends at my house because of the flooding down in Houston so I haven`t even gone to pick my own car up yet but I`ll get it wednesday. I suspect it`ll do just fine. The S4, like I`ve said, is just BNR`s version of a 3076 and does the 450-460 range pretty easily and that`s plenty for a DD FWD car.
The Following User Says Thank You to VoodooJef For This Useful Post:
andale927 (08-28-2017)
 Old 08-31-2017, 03:23 PM   #23
VoodooJef's Avatar
Drove her today. Didn`t go far, just a quick test drive. I`ll pick it up tomorrow. A few little detail thing will change ie; the blue couplers go away in favor of the black/red and all of the intercooler piping will be the same flat black. I`ve got the Focus ST mani going on in a few weeks but for now I`m good with just having it running again. http://www.mazdaspeedforum.org/forum/foru...1&d=1504214389
andale927 (08-31-2017)
 Old 08-31-2017, 03:26 PM   #24
tmillner's Avatar
Is that the ecu between the intake and battery box?
Sent from my SM-N930P using Tapatalk
 Old 08-31-2017, 03:31 PM   #25
andale927's Avatar
Nice, I bet that felt good! That seems like pretty quick turnaround, when did you take your car off the road?
Power:
Handling:
Other:
 Old 08-31-2017, 04:29 PM   #26
VoodooJef's Avatar
No, it's just sitting where it is for the moment. It's been on top of the fuse box but I'm fabbing up a panel to mount it to.
Quick? Hahaha it's been down for three months.
 Old 08-31-2017, 04:48 PM   #27
andale927's Avatar
Oh damn, still not too bad compared to a lot of other motor builds haha.
Power:
Handling:
Other:
 Old 08-31-2017, 04:57 PM   #28
tmillner's Avatar
Took me 6+ months
 Old 08-31-2017, 08:25 PM   #29
VoodooJef's Avatar
Took me 6+ months
Yeah that would have made for a bad time. My only car, and it was scheduled to be done in 4 weeks. As soon as I recover from the build I will most definitely pick up a cheap beater LOL.
 Old 08-31-2017, 08:26 PM   #30
tmillner's Avatar
Wife and I shared a car and I had a work Truck I could use so not that bad. Bought a RUNNING Toyota sequoia for $200
 Old 08-31-2017, 09:19 PM   #31
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Screaming deal on the 'yota. I paid $500 for my running Taco. 350k+ miles.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 09-01-2017, 12:08 PM   #32
voodoo2crue's Avatar
Posts: 371   (View Stats)
voodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the worldvoodoo2crue is the leader of the world
Anybody down to line up the beaters, high 19 second car here
Sent from my SAMSUNG-SM-G890A using Tapatalk
2012 MS3 VRM/w Tech
Self Tuned BNR S4/SP63 4032 88mm pistons/Manley Rods/Power XS Manifold/JBR BSD with Baffle Plate/Cobb APv3/Cobb XLE BPV/CMGS Stg2 w/DO14/CPE TMIC/Autotech HPFP internals/JBR Tru-3 Intake/JBR Boost tubes/JBR EGR delete/Custom
1liter OCC/CPE xflex RMM/CPE Injector Seals/Eibach Pro Springs/Ebay Downpipe/Custom 3" TBE with Vibrant Resonator/Magnaflow Muffler/TB Coolant Bypass/Bosch 3 bar map/ACT 6 puck/GS EBCS 3port interrupt/SP63 VC breather
Plugs-NGK LTR7IX-11(6510)
Oil-RP 10/30
Tires-235 40 18 Federal 595 rsrr
Brakes-EBC Yellow pads with ATE 200 fluid
Check out my wheelwell page here. If your a member hit me up.
https://www.wheelwell.com/profile/558b073762d1852928f23712/garage/
voodoo2crue is offline   Reply With Quote
 Old 09-01-2017, 12:09 PM   #33
tmillner's Avatar
I'll put up the price of the yota! Bad head gasket and all
voodoo2crue likes this.
 Old 09-01-2017, 12:14 PM   #34
Fstrnyou's Avatar
I have no doubts that you all have me beat.
Bexar likes this.
Other rides:
History:
 Old 09-01-2017, 12:28 PM   #35
tmillner's Avatar
Definition of a beater
 Old 09-01-2017, 01:54 PM   #36
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
I HAVE TO TURN THE AC OFF TO PASS PEOPLE BEAT THAT!
The other side of bumper is duct taped. The rear bumper is falling off there is no carpet in the car. No fender liners and an exhaust leak. I hit a orange highway barrel that blew onto the road doing 60 so since the bags didn't blow i kept on going like a boss.
Other then the leak it's rock auto top to bottom. Great commuter car.
MECP
2012 BM
Rfinkle tune in progress
voodoo2crue (09-01-2017)
 Old 09-01-2017, 02:31 PM   #37
Fstrnyou's Avatar
I have to leave extra early to get to work because it's not fast enough to pull out into rush hour traffic.
Also an exhaust leak
Primary O2 is dead
Tires rotten and about to blow
Crap alignment which is currently eating up one of my front tires
Shocks are blown
Radio was stolen which busted up most of the dash
Rear window IS busted from the radio theft. Now filled with a foamboard window, lol.
Drivers rear quarter window latch is missing
Drivers door from a donor vehicle. I only have 1 key, and it's for the passenger door/ignition
Ebay/ricer tail lights that function improperly
Ebay/ricer intake pipe with holes in it...after the MAF!
There's no fuel tank fill cap
The rear exhaust is held up with metal coat hanger.
Rear seat and belt hardware is missing.
Front seat headrest inner framework is poking thru the padding.
Shall I continue?
Other rides:
History:
 Old 09-01-2017, 09:13 PM   #38
Primary O2 is dead
Shocks are blown
Shall I continue?
Pics or this doesn't exist :-) Sorry voodoojef, we'll get back on topic soon brother.
2012 MS3 VRM/w Tech
Oil-RP 10/30
 Old 09-02-2017, 06:42 AM   #39
Fstrnyou's Avatar
Originally Posted by voodoo2crue View Post
Pics or this doesn't exist :-) Sorry voodoojef, we'll get back on topic soon.
If you insist.
Check engine light was on when I bought it, but it drove, so that was enough. Had to jump it off because the battery wouldn't take a charge. Drove it like that for a few days and finally got a new battery. Expected a lengthy list of codes, but it was just the Bank 1 Sensor 1 code for O2. It's a wideband.
The sad part is, I bought PlastiDip before I bought the O2 (which I've had sitting on my kitchen counter for the last week or so)
Didn't realize the front tires were quite that bad, so getting 2 new ones today. Putting rear tires on front and new tires out back, yadda yadda.
The last pic is how the exhaust sat before the coat hanger mod. Resting on the rear axle.
I will say though, the A/C blows cold and it's currently faster than my 6. Can't complain.
Other rides:
History:
voodoo2crue (09-02-2017)
 Old 09-02-2017, 07:28 AM   #40
VoodooJef's Avatar
No, no...please....turn my build thread into a junkyard find thread. LOL.
whatsabrooklyn (09-03-2017)
BNR S4v2 NJsean0 2010 MS3 - Big Turbo Builds 23 08-16-2017 09:25 PM
Voodoo's BNR S4 Tune in progress voodoo2crue 2010 MS3 - ECU Computer Tuning 36 06-18-2016 06:37 AM
LA 2010: 2011 Scion xB Release Series 8.0 dabbles in Voodoo Haltech Automotive News 0 11-18-2010 01:00 PM
Photoshop voodoo gives close-up view of Chevy Volt Haltech Automotive News 1 08-29-2008 11:09 AM
Page generated in 0.63122 seconds with 32 queries
