| MazdaSpeed 3/6 - Build Diaries MazdaSpeed 3/6 - General Build Threads/Diaries |
![]() | | #161 | ![]() |
![]() Join Date: Nov 2015 Location: Colorado
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() Thanks: 45
But the shaking turns out to be the front lower control arm that I just replaced in the last year. The ball joint failed from the broken lug and has about a quarter inch of movement in and out. They couldn't align it. So I parked it. I already replaced the rear control arm, but it's been cold as shit so I haven't had a chance to drop subframe yet but I already replaced lug and I have new control arm. But I had a question... I'm having a issue where the cars ebrake is sticking. I've only had this problem after replacing the right rear caliper because it had been eatting thru pads, but only on right side. But after I put new one in the ebrake doesn't seem to disengage sometimes. Like when u go to put ebrake down and When u pull it back up. It moved freely for more then half of travel (normally it has tension almost right away.) When I replaced the upper control arm on the right rear I noticed the whole caliper is slightly red like it got really hot. I've already had that caliper warranty replaced and put on and same thing. I'm lost.. I Appreciate Your Help Bro!!
__________________ 06 MS6 GT / Black \ Moonroof - Sure Torq Motor Mounts All(Aggressive) - Sure Diff Mounts - Sure Thermal Gaskets - DM Stage 3 Dual OCC'S - DM Pcv Vent Plate - Magnetic Oil Plug - BNR S4 V2 - Speed Proformence Tranfer Case Bearing Caps - Guardian Angel - Grimmspeed EBCS - JBR Egr Delete - Turbosmart Dual Port BOV(100% To Air) - HTP 3.5" Full Intake W/Recir. Hose Blocked - Strut Tower Bar Front - Whiteline Rear Sway Bar W/Adjustable Links - EBC Stage 4 Brake Kit F&B - Bosch 3.5 Bar Map -Autotech HPFP - CX Racing FMIC Pipe Kit W/ Tr6 Core FMIC - South Bend /Stage 2 Daily Clutch W/ Lightweight Flywheel - Continental Extreme Contact DWS06 - Block8Head Custom Triple Vent Gauge Pod - 3in1 Glow Shift Gauge (Boost/Oil Temp/Oil Pressure) - Glow Shift Gauge (Oil Pressure W/Alarm) - One Step Colder Denso Plugs - Escort Max Radar Detector - Mazda 3(S6 Oil Cooler Delete) Oil Filter Housing - Rev 5 Front Mount Oil Cooler - Thermostatic Controlled Oil Filter Sandwich Plate W/Sensor and Oil Cooler Connections - Rotella T6 Oil - Versatuner w/Tablet - Reinforced Clutch Pedal Assembly ![]() | |
![]() | | #162 | ![]() |
Groans: 111
| Not Ranked : 0 score If the calliper moves freely then the next thing to check is the handbrake cable. Maybe it is sticky on that side, anywhere from where it splits into that Y, maybe it's kinked, or was hit, or simply needs some silicone spray.
| Stock Block, Internals and Turbo Max Hp Safe Extraction Help | Juschiln19 | Mazdaspeed3/6 General Discussion | 55 | 06-01-2017 10:29 PM |
| Forged internals on stock block | SweetPuff | MazdaSpeed 6 - Engine, Transmission & Driveline | 5 | 09-30-2012 08:34 AM |
| Video: Pushing the limits with Robbie Maddison, 311 feet above the Corinth Canal | Haltech | Automotive News | 0 | 04-15-2010 09:10 AM |
| 2011 Lexus LFA Test Drive: Pushing the Limits of This 552-hp Supercar Prototype | Haltech | Automotive News | 0 | 10-21-2009 09:20 AM |
| So...Turbo/motor limits on stock block & internals? | 94jedi | MazdaSpeed 3/6 - Turbo Induction | 26 | 05-31-2008 08:01 AM |
