Like Tree26Likes
 Old 10-03-2016, 05:22 PM   #1
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Default Because Build Threads Are A Thing
So far, mostly stock as I've just recently started my build. I don't have a lot of cash flow right now, so mods are few and far between. The pace should pick up some when my divorce is final. Ha.
Mods so far in the order of purchase:
CS LED fog lights
CS LED light kit
JBR boost tubes and recirc hose (black)
JBR EGR block off & valve - not installed yet
CS RMM - ordered a month ago and should have it soon.
- cancelled CS mount. Ordered DM RMM
CS MZR bypass valve
JBR PMM 70 duro - coming back off. Might try AWR 70 for less vibes
Is Versatuner a mod? Sure, why not.
Planned mods: in somewhat of an order
Possibly AWR TMM if I try and like the PMM
HPFP - Autotech probably
Injector seals when I swap in a clean set of injectors
Intake TIG and TB coolant bypass or TB TIG
OCC kit of some kind
Diff mount & RSB
JBR Tru-3.0 Wide Path silicone intake. Maybe 3.5 - kinda depends on if my end goal changes
L2A intercooler
EBCS if needed
Possibly CS turbo upgrade
WMI if my end goal changes
Better clutch if the OE takes a crap
Still up in the air if I want to do exhaust or not.
Possibly catted DP
4 piston calipers or larger (really just for looks) w/ braided lines
Slotted rotors maybe
SPC ball joints
Maybe a set of coilovers w/ adjustable dampers if one day I decide to hit the track.
I may have missed a few things but you get the gist.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
Where are the Gen 1 1/4mi threads? TurboGhost Mazdaspeed3/6 General Discussion 3 04-16-2013 11:40 PM
Stock Block BT build threads xcoldricex MazdaSpeed 3/6 - Big Turbo Builds 50 07-13-2010 08:37 AM
Page generated in 0.73317 seconds with 29 queries
