Like Tree6Likes
  • 2 Post By Turbojocky13
  • 1 Post By Mazdazilla6
 Old 10-05-2016, 07:00 PM   #1
Turbojocky13's Avatar
Posts: 96   (View Stats)
Turbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant futureTurbojocky13 has a brilliant future
Groaned at 32 Times in 13 Posts
Default The build so far 700+
So maybe some of you remember me, some not. The "drier vent hood dump" Mazdaspeed3 3
(Not actual drier vent, just wrapped) has been a very long time since I have posted on these forums. Just an update on how the car is going.
New mods.
S366 Borgwarner twins scroll turbo
RaceRoots T4 turbo manifold
LSX intake tube
JMF fuel ported intake manifold
SPeedperformanc3 8th port Aux fuel kit
4in 5.9L Cummins downpipe.
Twin disc clutch
All solid steel motor mounts
No methanol
E85 fueling
Fuel surge tank
Dual 300lph fuel pumps
Supra T4 quick spool valve
26x10.5 micky slicks
Not much of pictures yet but as the next few weeks + go on I will keep everyone updated on the site.
I still have to buy raxles and finish some other mild things (like put the motor back in)
darkmx-6 and djrich26 like this.
- Forged eagle rods - Wiseco pistons - AutoTech CDFP - 4in TIH - 4in Mrp Maf housing - Custom Fiberglass RamAir - Accessport purpledrank tune - Stiffy Torque Damper - S366 Borgwarner Turbo -SureMotorsports Balance shaft delete - Air to Water intercooler - Arp headstuds - Spark plugs itv22 -RaceRoots T4 turbo manifold - 3in downpipe dump - Egr delete - 3 bar map sensor (Bosch) - Focus ST Direct Port Meth Intake Manifold- No BOV - Tial 38mm wastegate -GrimSpeed 3 port boost controller - Torque solutions rear engine mount - Torque solutions short shift plate - Torque solutions shifter counter weight - DEI heat shielding - 100% Gutted - 245/40/18 street radials- Streetunit Solid Motor Mounts- 3in Intercooler piping- etc etc...
Turbojocky13 is offline   Reply With Quote
The Following 9 Users Say Thank You to Turbojocky13 For This Useful Post:
CMajor (10-06-2016), Code Monkey (10-07-2016), Djohns (10-05-2016), djrich26 (10-09-2017), Hush (10-06-2016), KiwiFlavor (10-06-2016), Mazdazilla6 (10-05-2016), Tomas (12-08-2016), torquemaniac (12-09-2016)
 Old 10-05-2016, 07:14 PM   #2
Interesting. Curious to see how that quick spool valve will work for you. Also keep an eye on your boost once you get it running, that wastegate placement looks pretty prone to induce creep.
 Old 10-05-2016, 07:40 PM   #3
Yea me as well with the quick spool valve, was considering adding another wastegate oppisite side equal length as the other. But really just waiting to see how much boost I'm going Going to be at. At the start as for tuning if I request 10psi and it goes for 15psi then I will probably add a wastegate. Very curious! its a completely different bolt on setup... Cheers!!!!
I'm assuming the quick spool valve should be 600 rpm sooner than non existence. And throwing a ton of fuel at that turbo . Hopefully I don't run out of rpm.
 Old 10-05-2016, 07:43 PM   #4
You'll be fine on RPM. My twinscroll S362 leaves me a pretty decent powerband revving out to 7k.
Turbojocky13 likes this.
 Old 10-05-2016, 07:49 PM   #5
Perfect!! If there was anything I was worried about it was turbo spooling. And being useless. Also who tuned you?? I'm with purpledrank at the moment.
 Old 10-05-2016, 08:05 PM   #6
Self tuned. Still midway thru my 93 tune.
Turbojocky13 (05-03-2017)
 Old 10-06-2016, 08:17 PM   #7
sheston's Avatar
Posts: 1,847   (View Stats)
Wow, I'm assuming you've stripped the interior and wear earplugs? Solid motor mounts - I thought I was a real man going to the stiffest duro.
Looks like a lot of fun
 Old 10-07-2016, 09:42 AM   #8
SIXual Panda's Avatar
Posts: 2,363   (View Stats)
Groans: 56
looks like a badass build... but, why have a twin scroll turbo if you arent going to have a twin scroll turbo manifold? unless im missing something.
I envy your ass raping.
 Old 10-07-2016, 10:07 AM   #9
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
quick spool plate will block off one runner and funnel all exhaust through half of the turbine housing until a certain point, then both runners are open to the manifold for top end power. It's not as efficient on the top end as a true twin scroll but should spool even faster.
Blue Pu.
SIXual Panda (10-07-2016)
 Old 10-07-2016, 10:34 AM   #10
Groans: 56
hmmm, yeah, i just looked into that quick spool valve. seems pretty interesting. i've never heard of them before.
 Old 10-09-2016, 05:52 AM   #11
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
2nd gen RX7's had them. They don't look fancy, but got the job done. Many people would remove it though for more top end.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 10-13-2016, 11:02 AM   #12
Yea it's completely gutted, doors are gutted, plexi windows, solid steel motor mounts aren't as bad as I thought they would be. I ran them on the old setup. It vibrates but not as bad as one would think. Also the frame were the motors mounts bolt to have NOT started cracking (yet). Once it makes some real power the frame might start to crack in those spots, so I'll be welding in steel reinforcements plates in those areas. Haven't worked on it in a week or two will post up some more pics when I'm further in.
The Following 2 Users Say Thank You to Turbojocky13 For This Useful Post:
jtday (10-13-2016), Yamahafreak (11-17-2016)
 Old 11-17-2016, 11:14 AM   #13
Yamahafreak's Avatar
Posts: 84   (View Stats)
Yamahafreak has a reputation beyond reputeYamahafreak has a reputation beyond reputeYamahafreak has a reputation beyond reputeYamahafreak has a reputation beyond reputeYamahafreak has a reputation beyond reputeYamahafreak has a reputation beyond reputeYamahafreak has a reputation beyond reputeYamahafreak has a reputation beyond reputeYamahafreak has a reputation beyond reputeYamahafreak has a reputation beyond reputeYamahafreak has a reputation beyond repute
Nice build, looking forward to your updates!!
Send from my HUAWEI P9 using Tapatalk
2006 Mazda MPS 6, ZZB († 13th of May 2016 ), @ 312hp, 454Nm at the wheels
Engine Built:
Specs: @ xxx wHp, xxxNm at wheels
Wiseco, Manley H beam Rods, ARP Head studs, ARP Main studs, JBR Balance shaft removal, Total-MPS injector seals.
CS hpfp internals, CS TIP, CS Rear Diff Mount, CS 3.5bar MAP, JBR SRI, JBR EGR Delete, 3" Downpipe (De-Cat) Custom build by local shop, Custom built FMIC, PERM PVC, 3 port JBR EBCS, ACT HD Clutch 6-Pad Solid w/ Streetlite Flywheel, NGK LTR7IX-11, JBR Oil Pan Baffle.
Custom tuned/build K04 turbo by https://www.turbochargers.nl/
Saving for additional bolt ons (aux fuel, intake mani)
RX-8 Wheels 225/40-R18 Toyo T1R, 3cm lowerd Eibach kit.
initial dyno tuned by BR-performance. new tune by ????? versatuner
Hope to reach 400whp in the future, first goal is to get my car driving again
insta: @sp_shiningdreams
www.shiningdreams.nl
Yamahafreak is offline   Reply With Quote
The Following User Says Thank You to Yamahafreak For This Useful Post:
 Old 12-07-2016, 06:26 PM   #14
UPDATE!
Ok just got time to work on the car and have been doing a lot of thinking, so the plan basically stands the same. Only some minor changes. Originally I planned to use the CPE or JMF manifold, instead today I just ordered Damond Motorsports focus ST Portinjection manifold spacer/adapter to run the focus st intake manifold as well as ordering the ST manifold from Pro-Meth with the direct port methenol infection built into the manifold. So that being said there will be a total of 12 injection points on the manifold and the head including the meth. Sounds cool, probably will be a pain in the ASS. So once this IS all done I will tell every one exactly how it was done and wired.
Air to water intercooler core will be 11x12x4.5 should be PLENTY! Top mount. Will also send pics on the piping setup (3in piping. 1x 120 degree pipe 1x 90 degree pipe 1x 180 degree pipe 1x 3" to 2.75" coupler 1x 3" coupler)
Exhaust will be SLEEPER AS FUCK! I sugguest this to everybody! It will be s366 turbo the 3" adapter-to-3" vibrant tight radius 180 degree-to-OBX cat back exhaust... bahahaha. Will send pics of this as well. I know 3" sounds crazy on a s366 butttt it should actually help the turbo spool by a couple hundred rpm.
Everything being said should be done end of December January time frame 2016-2017
Important notes
-will be running 50% 50/50 meth, 50% Ethanol in meth tank.
-will NOT be running a BOV
-3in intercooler piping
-4" LS2 k&N intake pipe
-4" MAF housing
-Will be using the SnowPerformance stage 2 VC-50 meth kit for direct port meth
-will be using 4x 175ML meth nozzles
-single vband tial wastegate (38mm)
Any questions ask away!!
The Following User Says Thank You to Turbojocky13 For This Useful Post:
Tomas (12-08-2016)
 Old 12-08-2016, 11:14 PM   #15
impossible's Avatar
Posts: 733   (View Stats)
Groans: 30
38mm wastegate for a T4 66mm turbo? I think it's way undersized for the goals and big flow mods will likely have a hard time making big power but hey what do I know. Subbed for results
 Old 12-09-2016, 05:05 AM   #16
torquemaniac's Avatar
I would not put the air/water intercooler over the engine like a TMIC...it will heat soak...my air/water intercooler is at the stock airbox position and it heat soak in heavy traffic...anything standing in the engine bay will heat soak eventually, but over the negine is the worst place IMO (I plan on insulating my intercooler next summer)
I would suggest the Aquamist HFS-4 for the meth injection system...this is the best system out there
2011 CX-7 AWD 2.3 turbo
The Following 3 Users Say Thank You to torquemaniac For This Useful Post:
impossible (02-09-2017), MS3Shadow (12-09-2016), Turbojocky13 (05-03-2017)
 Old 12-09-2016, 06:02 AM   #17
Wastegate sizing is determined by engine size and desired boost. A larger engine needs larger gates because more displacement equals more exhaust gas. Running less boost also requires larger gates. Less boost means more exhaust gas has to bypass the turbine via the wastegate. Thus, large engines running low boost (most V8s) need large valves and small engines running high boost can get away with smaller valves. As long as he doesn't try to run low boost he should be fine.
He miiight run into part throttle creep but overall not much to worry about. I was able to run 9 psi on my S362 (same size as 6266) with two 38mm gates which is about equal to a 60mm gate. Running a larger A/R turbine housing helps a tad too.
 Old 05-03-2017, 07:31 PM   #18
Default Updates!!!!
OOOKKKKKK sooo far the original plan has changed. The car is finally finished! started tuning today with PurpleDrank (for like the 4th time, lol). No longer shooting for that 700+ hp rating, just could not justify running aux fuel the way I wanted to (8th port) especially since it seems that speedperf6rmanc3 discontinued their 8th port kit. Would have been around $3800 my way.
I went a more practical route with direct port meth injection.
-100% meth
-4x 225 ml/mn meth nozzles
-stage 2 VC-50 Controller
-DamondMotorsports manifold adapter
-Focus ST intake manifold
-3in intercooler pipe
-3in air to water intercooler
-4in intake pipe and Maf housing
-23in circumference wheels
I took the first two logs today with a fairly base tune.
21.9 psi
400+ grams Per sec
Start injection 10psi max injection 20psi
ill post some logs in a bit
Car is completely gutted all the way down to the steering lock. Not even window regulators, I mean everything... plugged in the data to virtual dyno.
-22.97 wheels
-2800lbs (not sure but its lower than I think it is)
-90 degrees
-4th gear
with VVT - 482hp
without VVT- 447hp
Not sure if I believe that until it's on a real dyno. Now that the car is completely finished I will keep everyone updated with (actual) Weight, HP, TQ, Logs, 1/4 ets, Trying to go for "The Fastest NON-AUX FUEL mazdaspeed3" although that is probably going to be hard to beat...
The Following 4 Users Say Thank You to Turbojocky13 For This Useful Post:
Code Monkey (05-03-2017), Mauro_Penguin (10-07-2017), torquemaniac (05-04-2017), xfeejayx (05-05-2017)
 Old 05-03-2017, 08:06 PM   #19
Just some other pics. logs coming in hot!
The Following 7 Users Say Thank You to Turbojocky13 For This Useful Post:
brandon3212 (05-04-2017), Code Monkey (05-03-2017), CWP_MS3 (10-05-2017), KiwiFlavor (05-04-2017), Mauro_Penguin (10-07-2017), torquemaniac (05-04-2017), xfeejayx (05-05-2017)
 Old 05-03-2017, 08:46 PM   #20
Most power made on meth I'm pretty sure is still Eric's old car @708whp
 Old 05-03-2017, 08:53 PM   #21
HOLY HELL! Well I just started tuning soo we will see what happens. He must have been spraying the HOUSE DOWN! like 400+ml/min nozzles... mother of god. Not sure if I'm gonna make that lol
 Old 05-03-2017, 09:00 PM   #22
Anything is possible with enough meth. Read that however you want.
He was running the same turbo as you but with a better compressor wheel. Should still be pretty attainable on your setup. You're only at 22psi, that turbo is still asleep. You will need to get a 4 bar map sensor though.
AwAfrican likes this.
 Old 05-03-2017, 09:07 PM   #23
Hell Yea man... That's what I like to HEAR! I do like power buuttt I am more worried about 1/4 ets and 60 to 150 times ( If you know what I mean I am gutted so I'm willing to sacrifice a little power. Thanks for the help... CHEERS!
 Old 05-03-2017, 09:12 PM   #24
Well if you're looking to get down the 1320 quickly you're gonna want to get off those tiny 23" tires. Should be able to fit 26" on stock fenders, I think you'll have to cut them a bit to fit 28"
That will make a world of difference on our short ass gears.
 Old 05-03-2017, 09:17 PM   #25
LOL its funny you say that... a couple of months ago I put on my 26x10.5 Mickys. and this was the result with the suspension all the way up. I wasn't quite ready to cut the fenders just yet, looks like I might have to.
Biobandit and Liquidsilver like this.
CWP_MS3 (05-04-2017)
 Old 05-04-2017, 05:52 AM   #26
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Looks like a pretty nasty full racecar build.
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
 Old 05-05-2017, 09:43 AM   #27
brandon3212's Avatar
Posts: 425   (View Stats)
Love these stripped race setups, nice work
07 Speed 3
 Old 10-03-2017, 08:30 PM   #28
Shottachris's Avatar
Posts: 31   (View Stats)
Shottachris is infamous around these partsShottachris is infamous around these partsShottachris is infamous around these partsShottachris is infamous around these partsShottachris is infamous around these partsShottachris is infamous around these partsShottachris is infamous around these partsShottachris is infamous around these partsShottachris is infamous around these partsShottachris is infamous around these partsShottachris is infamous around these parts
Groaned at 64 Times in 26 Posts
nice build
TopFlightInc! NYC
2011 speed 3 GT daily driver
Mods: big turbo , fuel internals , sure short shifter , forge BOV , FMIC , JBR motor mounts all around , BC coil overs , staggered advan wheels 18 x9.5 25+ offset front 18x 10.5 15+ offset rear , 3in catless down pipe , occ , Custom 3inch intake , Cobb strut bar ,Cobb v3 ,vtcs delete stock intake mani ,
Shottachris is offline   Reply With Quote
The Following 2 Users Say NO Thank You to Shottachris For This Un-useful Post:
Mauro_Penguin (10-14-2017), Pu Manchu (10-11-2017)
 Old 10-04-2017, 12:27 PM   #29
Thor Hammer's Avatar
Groans: 211
Originally Posted by Shottachris View Post
nice build
You must be new around here.
 Old 10-05-2017, 07:11 AM   #30
Fstrnyou's Avatar
Nah. He's been around since 2015. Got flamed for not searching, went MIA for 5 months, asked a question, then went MIA for 15 more months. Then tries to get back in the crowd by reviving old threads with useful posts like, "nice build".
Other rides:
History:
Thor Hammer (10-05-2017)
 Old 10-11-2017, 05:35 PM   #31
Bad ass build
TopFlightInc! NYC
The Following 3 Users Say NO Thank You to Shottachris For This Un-useful Post:
Mauro_Penguin (10-14-2017), Pu Manchu (10-11-2017), zenit (10-12-2017)
 Old 10-15-2017, 08:35 PM   #32
PearlySpeed's Avatar
Posts: 122   (View Stats)
PearlySpeed has much to be proud ofPearlySpeed has much to be proud ofPearlySpeed has much to be proud ofPearlySpeed has much to be proud ofPearlySpeed has much to be proud ofPearlySpeed has much to be proud ofPearlySpeed has much to be proud ofPearlySpeed has much to be proud ofPearlySpeed has much to be proud ofPearlySpeed has much to be proud of
We shall link up in a few weeks when my car is tuned. I'm pretty sure we will have the fastest Mazdaspeed's in swfl unless there's other 600+hp speeds lurking
1 slow speed
PearlySpeed is offline   Reply With Quote
Build me a BIG Turbo Build for MS3 NCspecV81 2010 MS3 - Big Turbo Builds 14 04-15-2013 02:16 PM
Report: Fiat to build Alfa Romeo SUV alongside Jeeps in America, build small car in Italy Haltech Automotive News 0 09-02-2011 07:20 AM
Theory: Build before Build demonspeed MazdaSpeed 6 - Engine, Transmission & Driveline 5 02-10-2009 06:52 PM
Page generated in 0.52976 seconds with 34 queries
