 Old 06-09-2019, 10:31 AM   #1
Guzguz.0's Avatar
Posts: 6   (View Stats)
Guzguz.0 is an unknown quantity at this point
Default Buying A 2007 Mazdaspeed3
It was tuned by freaktune, but he says it does not have the tunning device.
More info: car has 1480,000 and hes only asking for $2000? Is it worth it? Testing it later tonight around 12am central american time
List of mods:
-Corksport tokay injector seals
-EBC front rotors with yellow stuff pads all around
-autotech high pressure fuel pump
-borla catback exhaust(loud)
-damond motorsport rear motor mount
-aftermarket mazdaspeed cold air intake
-custom performence engineering turbo inlet pipe
-forge v2 motorsport bypass vave
-hotchkis rear swaybars
-james barone racing aluminum sway bracket
-sure motorsport short shift plate v2 and solid shift bushings
-ngk laser iridium spark plugs
-throttle body and maf sprayed and clean
-corksport shifter
Any advice?
Guzguz.0 is offline   Reply With Quote
 Old 06-09-2019, 10:48 AM   #2
GohanX's Avatar
Posts: 62   (View Stats)
GohanX is a splendid one to beholdGohanX is a splendid one to beholdGohanX is a splendid one to beholdGohanX is a splendid one to beholdGohanX is a splendid one to beholdGohanX is a splendid one to beholdGohanX is a splendid one to behold
That price is so low it sounds really fishy. That's the price you'd get for one with a blown motor, a fully working one would be $6000+. Proceed with caution.
GohanX is offline   Reply With Quote
The Following User Says Thank You to GohanX For This Useful Post:
Guzguz.0 (06-09-2019)
 Old 06-14-2019, 01:07 PM   #3
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
$2000 sounds high for 1,480,000 miles.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 06-14-2019, 01:34 PM   #4
Jeff23spl's Avatar
Posts: 2,233   (View Stats)
Maybe it was hauled coast to coast behind a 53feet truck every week lol
but yes the price is low but it depends of the body too, if it is from north with rust or dent everywhere...???
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 06-18-2019, 12:08 PM   #5
Reds3's Avatar
Posts: 31   (View Stats)
Reds3 is a jewel in the roughReds3 is a jewel in the roughReds3 is a jewel in the roughReds3 is a jewel in the rough
Bring a compression tester with you.
2007 Mazdaspeed 3 / Cobb SRI / 219K and Counting
1995 EG6 B16A3 78K *sold*
Reds3 is offline   Reply With Quote
 Old 06-19-2019, 12:40 AM   #6
whatsabrooklyn's Avatar
Posts: 147   (View Stats)
whatsabrooklyn has much to be proud ofwhatsabrooklyn has much to be proud ofwhatsabrooklyn has much to be proud ofwhatsabrooklyn has much to be proud ofwhatsabrooklyn has much to be proud ofwhatsabrooklyn has much to be proud ofwhatsabrooklyn has much to be proud ofwhatsabrooklyn has much to be proud of
any update?? how was the test drive?
that is a great price but be careful about something being fishy.
does that person have the titles etc...?
whatsabrooklyn is offline   Reply With Quote
help buying a MS3 2007 fuzionbranz Mazdaspeed3/6 General Discussion 5 01-13-2015 05:22 AM
Buying a used 2007 MS3. What do look for? dimitry Mazdaspeed3/6 General Discussion 31 04-21-2009 06:21 PM
Page generated in 0.26609 seconds with 25 queries
