  • 1 Post By erudus
  • 1 Post By erudus
 Old 09-28-2019, 08:14 AM   #1
erudus's Avatar
Posts: 9   (View Stats)
erudus is a glorious beacon of lighterudus is a glorious beacon of lighterudus is a glorious beacon of lighterudus is a glorious beacon of lighterudus is a glorious beacon of light
Default Erudus' 2008 MS3 build
We just finished a full engine build and power upgrades on my MazdaSpeed 3. My 16 year old son and I did all of the work except the machine shop work, and we learned a lot along the way. I've been a shade-tree mechanic most of my life but have never done a full engine tear-down and build. I'll try to add as many posts as I can about the process more or less in chronological order, and will put up plenty of pictures. I'm also working on a very detailed post about how we did the timing which I hope to get posted soon.
I've also got a blog that I am updating with content which you can view here:
https://mazdaspeedbuild.wordpress.com
Meanwhile, I've attached a couple of pics from along the way!
eroler1 likes this.
My MS3 Build Diary: https://mazdaspeedbuild.wordpress.com
2008 MS3 GT BNR S3, Corksport 3.5" CAI, Corksport Turbo-back, cp-e TMIC, EGR delete, cp-e RMM, JBR OCC, Edge Autosport 91 Tune
2018 Focus RS Race Red
2013 Audi S5, APR Stage 1, AWE Track Edition Cat-Back
2019 Tesla Model 3 Dual Motor LR
erudus is offline   Reply With Quote
The Following 2 Users Say Thank You to erudus For This Useful Post:
Db09ms3 (09-30-2019), whatsabrooklyn (09-29-2019)
 Old 09-29-2019, 01:21 AM   #2
whatsabrooklyn's Avatar
Posts: 147   (View Stats)
whatsabrooklyn has much to be proud ofwhatsabrooklyn has much to be proud ofwhatsabrooklyn has much to be proud ofwhatsabrooklyn has much to be proud ofwhatsabrooklyn has much to be proud ofwhatsabrooklyn has much to be proud ofwhatsabrooklyn has much to be proud ofwhatsabrooklyn has much to be proud of
very cool man! keep us posted
whatsabrooklyn is offline   Reply With Quote
 Old 09-29-2019, 01:01 PM   #3
eroler1's Avatar
Posts: 133   (View Stats)
eroler1 is just really niceeroler1 is just really niceeroler1 is just really niceeroler1 is just really nice
hey man, nice build thread pretty informative.
But for the headstuds, are you using ARP2000? the black headstuds. the one that costs $180+ ?
those have a 99% failure rate as they arent made to withstand the pressure in the cylinder for Forced induction car.
AFAIR it was made for the N/A 2.3
not sure if you want to change it but its suggested to replace it with a better stud
like L19 (edgeauto sells it) or freektune custom headstuds and lastly SP63 CA 625+ (speedperformance)
those are the only 3 headstuds that works well with this platform.
eroler1 is offline   Reply With Quote
 Old 09-29-2019, 09:44 PM   #4
erudus's Avatar
That's a bit scary! I got these from Edge - hopefully they are the right ones...at least on the Edge site it says for Mazdaspeed?
 Old 09-30-2019, 08:58 AM   #5
Jeff23spl's Avatar
Posts: 2,237   (View Stats)
Those bolts fit there but some older thread talk about the oem bolts that could hold better than arp2000 if you go high boost. Peoples going high boost are using larger stud from ARP but the thread needs to be machine worked....
https://edgeautosport.com/arp-l19-he...-st-2013-2017/
I never personally used ARP2000 but ran new oem bolt up to 27psi without any problems using a perfectly machined head and block face....
If i remember right, the stories behind lifted heads with arp2000 doesn't specify if both surface have been machined before install and there was something about using factory torque spec instead of ARP specs....
Documented list of all head lifting failures
Lets Talk About Head Studs
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
Last edited by Jeff23spl; 09-30-2019 at 08:58 AM. Reason: MSF Database - Automerged Doublepost
whatsabrooklyn (09-30-2019)
 Old 10-02-2019, 07:15 AM   #6
erudus's Avatar
We're "only" running 20 psi so a relatively mild tune but still putting out about 320wtq/320whp, so all I can do now is hope the ARP studs will hold. We did get the block and head surface machined so hopefully that will help also. We used the ARP torque spec, not the OEM one. Those L19 studs are crazy expensive!
Attached is the dyno graph from Alan at Edge Autosport. One note is that when we took it down to Edge for the tune we realized that we still had 4 month old gas in the car from May when we started the build. Alan was getting some knock so he had to pull a degree of timing to keep the knock under control. We should be getting a 340whp but I'll need to bring it back down for a tweak if we want to get that. Once I filled it up with a fresh tank of gas the knock retard almost totally went away.
Jeff23spl likes this.
The Following User Says Thank You to erudus For This Useful Post:
Db09ms3 (10-02-2019)
 Old 10-02-2019, 02:27 PM   #7
Jeff23spl's Avatar
anyway, it's too late to change anything about the bolts. even just the torque would need cams removal and the pita timing job and front cover sealant replacement....
Wife drive 2010 CX7
Mr_Bill's DSP AutoX Build - 2008 MS3 Mr_Bill Members Rides Gallery 139 02-25-2017 08:22 PM
2008.5 BM ms3 build pmartz16 MazdaSpeed 3/6 - Build Diaries 83 04-06-2016 08:31 AM
2008 Black ms3 starting Build Zoorah12 MazdaSpeed 3/6 - Build Diaries 12 12-03-2012 09:39 AM
24 Hours of LeMons 2008: Part III - The build Haltech Automotive News 0 12-15-2008 10:40 AM
Page generated in 0.30736 seconds with 24 queries
