  • 1 Post By Thor Hammer
 Old 11-14-2018, 03:13 AM   #1
Kentozer's Avatar
Posts: 11   (View Stats)
Kentozer is an unknown quantity at this point
Default High Mileage Motor Build or not to Build
My current motor has 175,000 miles, runs great. I was needing some input on weather or not it's worth rebuilding and going bt? Should i find another lower mileage motor? any input would be appreciated i know i need to donate and will sooner or later.
Kentozer is offline   Reply With Quote
 Old 11-14-2018, 11:25 AM   #2
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Why wouldn't it be worth rebuilding if it runs fine? Doesn't make sense. An engine is not worth rebuilding when you vent the block or some other catastrophic failure.
LenSpeed6 likes this.
 Old 11-14-2018, 03:19 PM   #3
LenSpeed6's Avatar
Posts: 164   (View Stats)
LenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud ofLenSpeed6 has much to be proud of
What @Thor Hammer; said
06 Speed6
White/Black interior
Sure Diff Mounts, JBR Intake, JBR I/C Hoses, Wiesco pistons .5mm over, Molnar H-Beam Rods, King bearings, New to me Cylinder Block, CS turbo, CS catted turbo back exhaust, CS HPFP, CS EBCS, CS injector seals, AP v3, FREEKTUNE, rebuilt clutch from Falcon Clutch with kevlar lining, DM PCV plate, DM stage 1 OCC, EcoBoost oil pump, vented oil cap with baffle, Speed Solutions PTO bearing caps, All Damond mounts
To think... this is suppose to be my winter car... because,
'72 AMC Javelin AMX 366 CI, 4speed 13.13 quickest 1/4 mile et so far
'12 1/2 Triumph Daytona 675R stock some how
'79 AMC Spirit AMX, 4.6L stroker I6
LenSpeed6 is offline   Reply With Quote
 Old 11-15-2018, 05:59 PM   #4
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
If it's not your daily, rebuild the motor you have.
If it is your daily, find a motor to build and then swap them out over a weekend. This is what I did. I still have my "old/good" motor...just in case.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
What You Need to Know to Build a Motor TWOptSL0W Mazda MZR DISI Engine Builds (2006-2013) 73 07-26-2019 03:57 PM
Mazdafreak's High Compression Build! mazdafreak Mazda MZR DISI Engine Builds (2006-2013) 159 06-04-2015 06:44 AM
BNR S3 motor build mikey32235 MazdaSpeed 3/6 - Big Turbo Builds 74 04-19-2014 09:09 AM
What You Need to Know to Build a Motor TWOptSL0W MSF KB - Mazdaspeed 3/6 - Engine/Turbo Builds 14 09-26-2012 03:33 PM
high capacity tranny build!! 0sixmazda6 MazdaSpeed 6 - Engine, Transmission & Driveline 29 04-24-2012 06:13 PM
Page generated in 0.27671 seconds with 24 queries
