 Old 02-26-2016, 08:40 AM   #1
Jeff23spl's Avatar
Posts: 2,237   (View Stats)
Default My standard and slow build thread...
It took me a bit long to get ready to do it.
The car had the first issue in 2014 and the compression on #3 was about 20-25psi lower than average. My mother also started fighting a lung cancer. We are close in the family so i put this aside and continued using it. It was my first DD but i switched using my beater a little more.
My mother finally lost it, last fall. My father started having too much spare time to tell just this so he is helping me with the rebuild.
I ordered the parts during boxing day sales. With the low value of our can$ against us $ i limited my list to this:
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
The Following 3 Users Say Thank You to Jeff23spl For This Useful Post:
sh4d0w (04-22-2016), speed23 (02-26-2016), torquemaniac (03-07-2016)
 Old 02-26-2016, 09:06 AM   #2
Jeff23spl's Avatar
I checked the parts weight:
Pistons where about 0.5g average. The rods where like shown on the box. I don't have the hanger for individually weight the rods ends but the 2 heavier ones was also the ones with the heavier big ends. So i removed 1 gram of the 2 heavier big end. I polished the side and belt sanded just a little bit the cap bolts to remove that small amount of material. I did it slowly to avoid overheating them and I didn't messed with the rod integrity. I will match the heavier piston with the lighter small ends insted of sanding anywhere else. It will end up being within 0.5g average, it should be enough...
Wife drive 2010 CX7
 Old 02-26-2016, 09:14 AM   #3
Jeff23spl's Avatar
A lot of parts on the floor:
Wife drive 2010 CX7
 Old 02-26-2016, 09:18 AM   #4
Jeff23spl's Avatar
I didn't had any real problems taking it out by the bottom. Just the A/C bolt were a bit jammed.
The clutch is still in good shape.
Wife drive 2010 CX7
 Old 02-26-2016, 09:27 AM   #5
Jeff23spl's Avatar
Clutch looks thin but it is build this way.
Wife drive 2010 CX7
 Old 02-26-2016, 10:05 AM   #6
Jeff23spl's Avatar
The A/C clutch was making some noise...i don't know why...
When it is too cold, i take time to paint some parts too:
Wife drive 2010 CX7
 Old 02-29-2016, 10:36 AM   #7
Jeff23spl's Avatar
more pics and the damages. #3 got the broken ringland problem and we can see the spot on the bearing that is probably when the knock even happenned. I have it on all rods but only #3 piston seem craked.
Wife drive 2010 CX7
 Old 02-29-2016, 10:42 AM   #8
Jeff23spl's Avatar
The bloc have compression leaks but it looks like a fresh bore could get rid of them. The machinist will tell me.
#2 or #3 :
Only cylinder #4 was looking almost new.
Wife drive 2010 CX7
robbspeed (02-29-2016)
 Old 02-29-2016, 02:49 PM   #9
Jeff23spl's Avatar
I made a tool to hold the crank pulley while removing the crank bolt. Not shinny but works fine!
Wife drive 2010 CX7
The Following 2 Users Say Thank You to Jeff23spl For This Useful Post:
impossible (05-07-2016), torquemaniac (03-07-2016)
 Old 03-01-2016, 03:10 PM   #10
Jeff23spl's Avatar
I marked the crank and the timing gear while it was at TDC, Then put back the front cover to align the pulley with the M6 bolt and marked the pulley damper to get all them keyed. Here is picture of my marks:
(On the crank roll, there is just paint mark...)
Wife drive 2010 CX7
impossible (05-07-2016), torquemaniac (04-18-2016)
 Old 03-01-2016, 03:29 PM   #11
Jeff23spl's Avatar
i have few question if someone read it :
Is the ring around the exaust port there for good reasons or i can port to match the gasket and exaust manifold to make it flow more? It is very strange because it seam to have been especially made this way...? but it also look very restrictive....? First pic is with the gasket removed, we can see the mark of gasket size...
Wife drive 2010 CX7
 Old 03-01-2016, 03:33 PM   #12
Jeff23spl's Avatar
is that marks normal on the retainer? it seem to comes from the tapet casting ?
Wife drive 2010 CX7
 Old 03-02-2016, 06:45 PM   #13
xfrank98x's Avatar
Posts: 5   (View Stats)
xfrank98x has a spectacular aura aboutxfrank98x has a spectacular aura about
Interresting,i'll follow this !!!
xfrank98x is offline   Reply With Quote
The Following User Says Thank You to xfrank98x For This Useful Post:
Jeff23spl (03-03-2016)
 Old 03-22-2016, 11:39 PM   #14
rodger14s's Avatar
Posts: 13   (View Stats)
rodger14s is an unknown quantity at this point
Looks like a really good write up, keep it coming!
rodger14s is offline   Reply With Quote
 Old 03-23-2016, 01:40 PM   #15
Jeff23spl's Avatar
it is moving slow.
I got the bloc bored to 88mm. I cleaned the head and send it to be slightly ported and planned 0.008'' to rise compression up to 9.7:1 and have a fresh surface.
I cleaned and painted few parts. The crank got keyed too and it is out to be balanced tomorrow.
Wife drive 2010 CX7
 Old 03-23-2016, 01:41 PM   #16
Jeff23spl's Avatar
bloc and oil pan paint
Wife drive 2010 CX7
 Old 03-23-2016, 01:45 PM   #17
Jeff23spl's Avatar
timing cover
Keep in ming the car has run 8 winters in north east of Canada so everything was rusty aroud there. I had to brush it before applying any paint.
Rambo likes this.
Wife drive 2010 CX7
 Old 03-23-2016, 01:46 PM   #18
Jeff23spl's Avatar
the bored bloc
Wife drive 2010 CX7
 Old 03-23-2016, 01:49 PM   #19
Jeff23spl's Avatar
My poor's man flow bench Leaf blower flowing thru a Mazda 2.0l MAF and reading 0-5V
I was just checking about how much oem part was unbalance.
I measured a 10% lower flow from the #4 intake path and obviously it was the one with less wear.
Wife drive 2010 CX7
 Old 03-23-2016, 01:51 PM   #20
Jeff23spl's Avatar
At the moment i'm looking to find how much play it is allowed for the valve guide. Once cleaned, it seem a bit loose..not sure if it need to be dry or covered with an oil film to be checked/measured...
Wife drive 2010 CX7
 Old 04-06-2016, 03:35 PM   #21
Jeff23spl's Avatar
valves where good, i just did a little lapping with paste
Wife drive 2010 CX7
 Old 04-06-2016, 03:37 PM   #22
Jeff23spl's Avatar
head got ported a little bit
Wife drive 2010 CX7
 Old 04-06-2016, 03:37 PM   #23
Jeff23spl's Avatar
Made the ring gap to the spec of 15 to 30 psi so 0.024''
Wife drive 2010 CX7
 Old 04-06-2016, 03:43 PM   #24
Jeff23spl's Avatar
checked the new bearing and rod clearance to make sure there is no error even if the crank is perfect.
Wife drive 2010 CX7
 Old 04-06-2016, 03:45 PM   #25
Jeff23spl's Avatar
crank got balanced to 1/3of a gram not a big deal if you look at what he did. The larger hole was factory and we added the smaller ones.
Damper got the same.
My collegue wasn't able to put the FW on the machine so i will keep it like ACT made it...
Wife drive 2010 CX7
 Old 04-07-2016, 06:23 PM   #26
sheston's Avatar
Posts: 1,847   (View Stats)
Looks like a fun build. Lots of details
Can't wait to see some numbers
Good luck
Jeff23spl (04-07-2016)
 Old 04-22-2016, 06:36 AM   #27
Jeff23spl's Avatar
My low cost dual PCV plate. I first tryied it as a test on a spare plate but i was surprise how solid is the plastic. I filtered 3/4'' npt and screwed the nozzle in with locktite. Then added a layer of epoxy to add a little strenght. IT is not as shinny as the aluminium model but it will do the work. Anyway once in the car with everything installed, it is hard to see it...
Wife drive 2010 CX7
torquemaniac (04-29-2016)
 Old 04-22-2016, 06:39 AM   #28
Jeff23spl's Avatar
some other pictures
Wife drive 2010 CX7
 Old 04-22-2016, 07:18 AM   #29
Jeff23spl's Avatar
What it will look like
Wife drive 2010 CX7
impossible (05-07-2016), torquemaniac (04-29-2016)
 Old 04-22-2016, 07:29 AM   #30
sh4d0w's Avatar
Posts: 565   (View Stats)
Groans: 45
Groaned at 7 Times in 4 Posts
I'm powder coating my subbie engine bay black and gold right now basically I'll be doing the mazda after... Looks good man loving the colors.
2010 Black MS3
The Following User Says Thank You to sh4d0w For This Useful Post:
Jeff23spl (04-22-2016)
 Old 04-22-2016, 08:42 AM   #31
Jeff23spl's Avatar
Top plate brace and caliper are also gold. I may look for blacl silicone coupler because the red ones i have make a bit too much colors. I would also need a gold oil cap but i won't paint the Msspeed one...
Unfortunately, the car will probably run during winter so it may not remain clean for long...
Wife drive 2010 CX7
 Old 05-07-2016, 08:28 AM   #32
impossible's Avatar
Posts: 733   (View Stats)
Groans: 30
Looks great man, is it in the car running yet?
 Old 05-10-2016, 06:24 AM   #33
Jeff23spl's Avatar
Thanks
Just started last sunday, run perfectly fine. A bit rought before getting up to operating temperature but overall quieter than my used stock bloc lol
Not sure if it was the accessory bearing replaced or the timing chain ...maybe both but it is a lot more quieter than before the rebuild. I was afraid forged piston could make a slapping noise at cold but it don't.
I will also have to do a new maff cal because everything seem off in neutral.
Just 1 thing, my radiator fan do not seem to want to run. It was a used one and maybe it isn't working anymore or i have a connector not installed. Temperature gage works and obd coolant temp also...
I plan to drive it soon.
Wife drive 2010 CX7
torquemaniac (05-10-2016)
 Old 05-10-2016, 08:53 AM   #34
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
where in QC are you?
'08 CWP MS3 w/ T3 3071r
 Old 05-10-2016, 10:22 AM   #35
Jeff23spl's Avatar
near Qc city ...but why ?
Wife drive 2010 CX7
 Old 05-10-2016, 10:25 AM   #36
Gribbs1469's Avatar
Posts: 112   (View Stats)
Gribbs1469 is a name known to allGribbs1469 is a name known to allGribbs1469 is a name known to allGribbs1469 is a name known to allGribbs1469 is a name known to allGribbs1469 is a name known to all
subscribed
2007 MS6 FMIC, Garrett turbo, 3" Magna Flow TBE, 4" Intake, HP Fuel pump, COBB AP V3
Gribbs1469 is offline   Reply With Quote
 Old 05-11-2016, 03:44 PM   #37
Jeff23spl's Avatar
Body isn't cleaned but the engine is in
Wife drive 2010 CX7
torquemaniac (05-20-2016)
 Old 05-12-2016, 06:53 AM   #38
rabble rabble
802MS3's Avatar
Groans: 221
Just curious, I'm close to the CA border, hoping to make it to a couple meets up there this summer.
 Old 05-12-2016, 08:50 AM   #39
Jeff23spl's Avatar
Oh i see. I even drive to Burlington airport once to catch a cheaqper flight from there but it was about 4hrs drive. Quebec is more to the east side and a little bit more north than Montreal. Montreal is closer...
I know that some of us will do a Mazda trip to M Washington on august 13th. Not sure how close they will pass from Burlington but it is almost on their way...
I dont think to be part of the group but it is not confirmed yet.
Some goes to Napierville racetrack often.
There should be a an annual mustang dyno day at the end of summer around Montreal.
You can check meet events from our French forum and i can help if you don't understand french (Mazda3Quebec)
Wife drive 2010 CX7
 Old 05-16-2016, 02:31 PM   #40
rotormike's Avatar
Posts: 19   (View Stats)
rotormike will become famous soon enoughrotormike will become famous soon enough
Im really digging that leaf blower idea
rotormike is offline   Reply With Quote
Slow paced build Dizzy Turbo MazdaSpeed 3/6 - Build Diaries 11 06-26-2013 05:06 PM
BlackSpeed303's slow Build BlackSpeed303 Appearance - BLACK 0 03-19-2013 10:14 PM
What will be a verry slow build SwizzleSpd MazdaSpeed 3/6 - Build Diaries 5 08-24-2012 11:41 AM
Page generated in 0.57894 seconds with 29 queries
