Like Tree4Likes
  • 1 Post By PhillyCheese
  • 2 Post By PhillyCheese
 Old 01-23-2015, 05:04 PM   #1
PhillyCheese's Avatar
Posts: 226   (View Stats)
Default My ZZB Experience and Upcoming Build
This is just to get a thread going for today. About 6 weeks ago while logging my engine decided it only need 3 connecting rods. I actually sent the log to @Lex; and he said it looked safe tune wise. I'd assume that it was just old and tired at 98k. Had the extended warranty when I purchased it 63k from a Mazda/Ford dealer in Albany. Called up my local dealer in Keene, NH as I have received great service from them. I had it towed with the mods in my sig on it because fuck these cold as New England winters with no garage. Luckily they have a hard one for my car there and the service manager assisted in the stocking out. Handed over oil change records and waited. Got the call today that it was denied. Which I fully expected when I found out that they wanted ECU freeze frame data. As of now I know I'm going Freekbuilt for sure. I'll be putting the log up tomorrow for your viewing pleasure of my engines last breath
THE GO FAST PARTS:
-JMF Intake Mani/Tapped for meth
-Bosch 3 BAR Map Sensor w/PNP Harness
-COBB 3-Port EBCS
-AP V3
-CS FP Internals
-Injector Seals and Stud Kit
- Scored an epic deal on a used ATP down pipe
-CX Racing IC piping
-Treadstone TR8 core
-Snow Performance meth kit w/safeinjection and flow gauge
-JBR 3.5" Intake w/4in turbo flange
-AEM AFR Failsafe
-Corksport cams
-Boost Junkyz stock location manifold
OTHER:
-Damond Motorsports Vented OCC
-HTP Battery Trunk Relocation (need room for activities)
-Damond Motorsports powersteering cooler
-RD Motorsportz crash bar
- @jbarone; Trilogy
-Prosport EVO series gauges. Hopefully the sending units hold up
-AUX fan controller
-A/C delete
-CS diff brace
-Transfer case bearing caps
-Spin on oil filter conversion w/ Prosport adapter plate
-GFB Respons BOV/BPV
-Damond Motorsports SSP
-WW Front motor mount and front diff brace
-Speedperformance TC bearing caps
SUSPENSION:
-H&R Springs paired with Koni shocks
-Corksport Rear camber arms
-Whiteline Rear sway bar
-Racing Beat rear endlinks
-AWR front endlinks
@CorkSport; front upper control arms
-Racing Beat front sway bar
Things I need:
-Engine (duh)
-Clutch (looking at the South Bend Clutch kit)
-Turbo (keeping an eye on the new BNR setup in the works)
I will be replacing any other worn parts also
I'm sure I am missing things on the need list. Plus there's always those surprises that come up
I don't have any photos of the real carnage but once i start taking it apart when spring arrives there will be photos. The hole is on the backside of the block
File Type: jpg 1380442_10205501975049149_79059600284376586_n.jpg (197.3 KB, 84 views)
File Type: jpg 961126_10205491171059056_774604719_n.jpg (80.6 KB, 75 views)
File Type: jpg 10836186_10205491438345738_318441623_n.jpg (56.1 KB, 72 views)
File Type: jpg 1779264_10205992922882538_4399248428376224830_n.jpg (62.3 KB, 69 views)
File Type: jpg 10868272_10205992923242547_400843233071888526_n.jpg (61.2 KB, 56 views)
File Type: jpg 10393943_10206057651100703_4750604913625016825_n.jpg (57.0 KB, 52 views)
File Type: jpg 10959592_10206057650580690_8223532245866018808_n.jpg (71.9 KB, 53 views)
File Type: jpg 10986685_10206072217144845_5578775420634739948_n.jpg (78.6 KB, 48 views)
File Type: jpg 1459708_10206064375468808_3657925770566957580_n.jpg (73.1 KB, 47 views)
File Type: jpg 1508082_10206096379508889_6644027042117274362_n.jpg (75.1 KB, 47 views)
File Type: jpg 10169436_10206111195479279_7658958843888853622_n.jpg (66.9 KB, 49 views)
File Type: jpg 10313512_10206103040115400_7754765866077535906_n.jpg (68.6 KB, 44 views)
File Type: jpg 10426223_10206103040555411_7186011376142343973_n.jpg (84.1 KB, 48 views)
File Type: jpg 10430411_10206111192359201_4833192582470602668_n.jpg (106.2 KB, 43 views)
File Type: jpg 11209534_10207232923641782_140834111126622249_n.jpg (109.2 KB, 37 views)
File Type: jpg 12118698_10208088218663623_8959586485983914114_n.jpg (47.6 KB, 23 views)
File Type: jpg 12274738_10208319076354921_8205691291458707600_n.jpg (71.8 KB, 20 views)
File Type: jpg 12278905_10208319076834933_7129643915381302304_n.jpg (78.6 KB, 19 views)
File Type: jpg 12279198_10208319075914910_265275577177993997_n.jpg (72.0 KB, 22 views)
File Type: jpg 12316136_10208319075314895_798865770794354219_n.jpg (47.9 KB, 19 views)
MOD LIST
UNDER CONSTRUCTION
The Following 6 Users Say Thank You to PhillyCheese For This Useful Post:
Code Monkey (01-23-2015), Design (05-25-2015), LumberJack (01-23-2015), MazdaBoy2.3 (02-19-2015), taf0422 (01-23-2015), Tedspeed6 (06-30-2015)
 Old 01-23-2015, 05:07 PM   #2
LumberJack's Avatar
Great choice with the Freekbuilt option.
What components did you decide on for the build?
10.36@148 Fastest Gen 2
PhillyCheese (01-24-2015)
 Old 01-24-2015, 09:56 AM   #3
I'm Undecided on what turbo I want currently. I've got a few months to decide I'll be definitely be keeping the thread up to date on what my decisions are. My goal will most likely be around 400hp. I'll be checking youtube videos out for various turbos and reading the build threads on here.
MOD LIST
UNDER CONSTRUCTION
 Old 01-24-2015, 12:04 PM   #4
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
Sorry about the shitty luck. Shoot me a PM when you do the install, I'll see if I can swing down and help turn some wrenches. Good luck man!
'08 CWP MS3 w/ T3 3071r
 Old 01-24-2015, 12:49 PM   #5
Thanks man. Fortunately I hung onto my Protege when i bought the speed so i have something to drive during the down time. More than likely the installation will take place spring of 2016. I'll be slowly buying parts until November when my work bonus comes into play.
MOD LIST
UNDER CONSTRUCTION
 Old 01-24-2015, 04:24 PM   #6
rabble rabble
802MS3's Avatar
Groans: 221
Ha damn! I store my car for the winter, I'd be really sad if I had to go that long without mine.
 Old 01-24-2015, 04:26 PM   #7
Yeah. I'm having boost withdrawals already haha. It's going to be a long wait but worth it
MOD LIST
UNDER CONSTRUCTION
 Old 01-24-2015, 04:28 PM   #8
mr.speedy3's Avatar
Posts: 1,690   (View Stats)
Good luck with the build, wish I had a speed6 instead of fail wheel drive!
For reference, here is my built speed3 with a GTX3076r. Good luck with the research
https://www.youtube.com/watch?v=cAK291vitko
The Following User Says Thank You to mr.speedy3 For This Useful Post:
 Old 01-31-2015, 05:12 PM   #9
Just ordered up TB spacer and Vented OCC from @Matt@DamondMotorsports;
MOD LIST
UNDER CONSTRUCTION
 Old 02-19-2015, 03:46 PM   #10
Well I figured since I was doing all of this work that I might as well do the suspension work while it's down because fuck it haha
MOD LIST
UNDER CONSTRUCTION
 Old 02-19-2015, 06:55 PM   #11
sheston's Avatar
Posts: 1,847   (View Stats)
Your list looks like your goals are way more than 400 hp. You should make that easy. I would think if that is all you want, you should go smaller turbo and have a flatter torque and hp curve....
Just my opinion
 Old 02-19-2015, 06:59 PM   #12
Just my opinion
I'm actually shooting for 500 now haha.
MOD LIST
UNDER CONSTRUCTION
 Old 04-30-2015, 05:52 PM   #13
Finally had this bitch towed home today now that spring is here. I'd say 2 weeks for carnage pics of how destroyed the engine is.
MOD LIST
UNDER CONSTRUCTION
 Old 05-02-2015, 07:08 PM   #14
sheston's Avatar
Is your hp goal now 600hp?
 Old 05-02-2015, 07:14 PM   #15
Negative. 500 is all I'm looking for
MOD LIST
UNDER CONSTRUCTION
 Old 05-02-2015, 07:23 PM   #16
Did start getting ready to pull the engine today. Need to put up my 20x12 canopy first
MOD LIST
UNDER CONSTRUCTION
The Following User Says Thank You to PhillyCheese For This Useful Post:
Code Monkey (05-02-2015)
 Old 05-21-2015, 05:14 PM   #17
Should have the hunk of scrap pulled out this weekend finally. Taking my time since I have it haha. Then I'll work on dropping the rear sub frame so I can replace the shocks, do the diff mounts, and replace anything else that looks fucked. Prepare for carnage pics when I pull the engine apart.
MOD LIST
UNDER CONSTRUCTION
 Old 05-21-2015, 05:27 PM   #18
Speedling6's Avatar
Posts: 155   (View Stats)
Speedling6 has a reputation beyond reputeSpeedling6 has a reputation beyond reputeSpeedling6 has a reputation beyond reputeSpeedling6 has a reputation beyond reputeSpeedling6 has a reputation beyond reputeSpeedling6 has a reputation beyond reputeSpeedling6 has a reputation beyond reputeSpeedling6 has a reputation beyond reputeSpeedling6 has a reputation beyond reputeSpeedling6 has a reputation beyond reputeSpeedling6 has a reputation beyond repute
You get any insight as to what caused the zzb/how or if you could have prevented it? Your build seems modest pre-zzb.
(and yeah i wanna see this monster once its built)
2006 Black Mica Mazdaspeed 6 GT
Power: JBR Tru 3" aluminium wide path intake; CP-e TMIC; Autotech HPFP internals
Tuning: Cobb Acessport V3; Custom FREEKTUNE
Support: Corksport RMM; Corksport Rear Diff Brace; Sure Jugg
Speedling6 is offline   Reply With Quote
 Old 05-21-2015, 05:39 PM   #19
I'm not sure if I'll ever find the exact cause. I was doing a data log when it blew. E-mailed the log to Lex at Stratified since I was running and OTS+ map from them and everything looked good. I had 98k on it when it went. I'm not sure how it was treated the previous 63k miles but I stayed on top of the basic maintenance for the 35k I put on it.
MOD LIST
UNDER CONSTRUCTION
 Old 05-25-2015, 05:12 PM   #20
Finally removed the scrap today. Now it's time to remove and cleanup the usable parts. Next up is dropping the rear sub frame to replace shocks, diff mounts, and probably a whiteline rsb
MOD LIST
UNDER CONSTRUCTION
802MS3 (05-26-2015)
 Old 08-05-2015, 05:30 PM   #21
Finally pulled the head off today. Almost time to haul this pile of scrap to the scrapyard. Damage is snapped rod, chunk blown off of the crank cradle, 2 holes in the block, 2 intake valves snapped and a partridge in a pear tree.
MD1032 likes this.
MOD LIST
UNDER CONSTRUCTION
ItsNox (08-05-2015)
 Old 08-05-2015, 06:05 PM   #22
sheston's Avatar
You did it good. I don't suppose you'd like to post the log for those of us that are curious?
 Old 08-05-2015, 06:12 PM   #23
I knew I forgot to post something.
MOD LIST
UNDER CONSTRUCTION
 Old 08-05-2015, 06:37 PM   #24
Datalog uploaded to OP. Beware it is rather long because I was trying to get the car home 3 miles on a dark cold rainy night in December with no safe place to stop. I already knew it was fucked.
MOD LIST
UNDER CONSTRUCTION
 Old 08-06-2015, 07:31 PM   #25
sheston's Avatar
Doesn't look like you were pushing it like everyone has said. KR just went to 5, AFRs tanked, etc, etc.... Looks like it still tried to run for 500 or so rpms
Interesting how fast your BATs go up when you're not flowing any air
Thanks for posting it up
PhillyCheese (08-06-2015)
 Old 09-02-2015, 03:38 PM   #26
Finished getting my canopy together this past weekend. If anyone needs good lighting I would recommend LED shop lights. Purchased on Amazon. Now when the weather sucks I can get to work on this thing. Next on my list is to upgrade the TC bearing caps, replace the pivot shaft seal , and some leaky old sensors on the transmission so that I can get them stored away
File Type: jpg 11951256_10207744907641062_6310550294910836252_n.jpg (90.0 KB, 42 views)
MOD LIST
UNDER CONSTRUCTION
 Old 12-03-2015, 04:21 PM   #27
Well........I have a rebuildable long block now. Picked it up on Tuesday from a local member. Had low compression and roughly 100k when it was replaced by Mazda through a warranty. I'm assuming that It was either never modded or a really good stocking out job to get it replaced
File Type: jpg 12316074_10208319896455423_3494839172440222181_n.jpg (72.1 KB, 35 views)
MOD LIST
UNDER CONSTRUCTION
The Following 2 Users Say Thank You to PhillyCheese For This Useful Post:
Doucems6 (12-04-2015), ItsNox (12-03-2015)
 Old 12-03-2015, 04:31 PM   #28
ItsNox's Avatar
Posts: 3,076   (View Stats)
Very nice. How was the bearing cap install?
'06 Mazdaspeed 6 GT
- Miltuned
Georgia Motherfucking Nator
 Old 12-03-2015, 04:35 PM   #29
Haven't done them yet. Just arrived Monday. Probably tackle that the next weekend. I did find the rtv on amazon and I believe I need a couple seals also. Need to give the how to another rundown
MOD LIST
UNDER CONSTRUCTION
 Old 12-03-2015, 04:47 PM   #30
ItsNox's Avatar
We will require pictars.
'06 Mazdaspeed 6 GT
- Miltuned
PhillyCheese (12-03-2015)
 Old 12-12-2015, 03:11 PM   #31
Separated the TC today. Everything appears to be good. Installing the caps tomorrow
MD1032 and ItsNox like this.
MOD LIST
UNDER CONSTRUCTION
Code Monkey (12-12-2015)
 Old 12-12-2015, 04:03 PM   #32
ItsNox's Avatar
@PhillyCheese; how many miles and what kind of gear oil you used? Looks good.
Sent from my SM-N910T using Tapatalk
'06 Mazdaspeed 6 GT
- Miltuned
 Old 12-12-2015, 04:09 PM   #33
98k I cant remember what was put in it when I had it done. I bought it with 63k and first thing I did was have all of the fluids changed out
MOD LIST
UNDER CONSTRUCTION
ItsNox (12-12-2015)
 Old 12-11-2016, 09:49 AM   #34
Still in progress. Just to lazy to upload photos and shit. It will be finished April 2018 though
MOD LIST
UNDER CONSTRUCTION
 Old 04-23-2017, 04:57 PM   #35
Haven't updated this in a bit. It will be getting finished up by this time next year. Going to most likely be getting Shed Built (not sure on your user name here) later this year. Rear sub frame will be dropping soon to install all the new goodies. Also Go-Autoworks is now making exhaust manifolds for our platform now. Waiting for the new BNR turbo to be released also.
MOD LIST
UNDER CONSTRUCTION
BLKSTIG (04-26-2017)
 Old 12-21-2017, 08:42 PM   #36
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Updates?
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
PhillyCheese (01-20-2018)
 Old 01-20-2018, 02:51 PM   #37
Pokes with stick. Is u ded?
I have acquired almost everything I need to finish this bitch. Just need to purchase the clutch kit and rear axles from DSS. Also need to make final arrangements to have the motor assembled. I don't have a clean area or the confidence to do assembly of the motor. May attempt a rebuild on my Protege. Something way less expensive than the MZR. Ended up replacing majority of the rear end parts because fuck New England winters. I have pics to upload at some point
danb likes this.
MOD LIST
UNDER CONSTRUCTION
 Old 01-26-2018, 12:48 PM   #38
flylike2kites's Avatar
Posts: 64   (View Stats)
flylike2kites has much to be proud offlylike2kites has much to be proud offlylike2kites has much to be proud offlylike2kites has much to be proud offlylike2kites has much to be proud offlylike2kites has much to be proud offlylike2kites has much to be proud offlylike2kites has much to be proud offlylike2kites has much to be proud of
Assembling the MZR motor is peanuts compared to other performance turbo motors, like the 2.7L V6 from the Audi B5 S4's......that one gives me nightmares.....
If you need a clean room, then you can buy a HEPA filter, purify the air in your kitchen, and assemble it in there. All of the parts will be clean minus some assembly lube, so use lots of gloves and keep a trash can nearby to contain the lube.
OR, you can drop the block off at the machine shop with the parts and have them assemble the entire rotating assembly. It shouldn't cost more than 500.
flylike2kites is offline   Reply With Quote
The Following User Says Thank You to flylike2kites For This Useful Post:
PhillyCheese (01-27-2018)
SURE upcoming products? dadderllama Mazdaspeed3/6 General Discussion 30 01-16-2012 11:50 PM
Chrysler's upcoming 6.4L V8 only for SRT, not for Ram? Haltech Automotive News 1 03-14-2010 11:35 AM
Upcoming Mods! azokaei MazdaSpeed 3 - Engine, Transmission & Driveline 5 01-23-2010 03:38 PM
Page generated in 0.57693 seconds with 29 queries
