Like Tree349Likes
 Old 03-12-2015, 04:42 AM   #1
RE-ACTIONENGSPEED3's Avatar
Posts: 401   (View Stats)
Neutral  :  +3 score
Default Pte 6466 & AWD conversion
I have been collecting parts for a lot of time , and after i sell my previous engine into a friends cx-7.I decided to make something big. Now that i`m writing my car is ready and working but i will make a rewind...
So lets start with the engine parts
Sp63 87.5 stok cr pistons
Manley I-beam with arp 625+
L.A. sleeves
Oem brand new head gasket
12mm Head bolts
11mm main bolts
New oil pump
I also make some upgrades to crank girdle (i will attach photos)
For the cylinder Head
Supertech intake valves +1
Supertech exhaust valves +1
Supertech valve guides
Supertech single 55lbs spring kit(i will soon upgrade it to dual spring)
Big Head port with handjob(because there is no cnc for heads in my country)it is made by one of my country`s best(attached flow bench results)
Dcr vv-t
Sp63 stage 2 cams
Other parts
Pte 6466 V-band 0.82
cp-e maniford
Jmf V2 Intake
Htp 4~ inch maf
4X 1250cc bosh style Deutshwerks injectors
Oil cooler with relocation & spin on filter
Corksport seals (great desighn)
Custom 3.5inch Dp
Custom 3.5inch aluminium exhaust
7.25 Twin disk Clutch (quarter master with sintered discs) and custom made billet flywheel
As for the AWD conversion
I buy a rear subframe from a cx-7, and gearbox and transfercase from speed6.The 2 rear axles are custom made from driveshaft and the front rear right(passenger side) is from totalmps . I also make a custom fuel tank witch seats in the oem location and it is feed from the oem fuel tap .It need some modification at rear subframe to fit all these into the speed3 but nothing serius the lower arms ,camper arms & toe arms need to be machined.
I have also put a switch for the awd .When it is on, the car is 50-50 and when it is off is 100-0 .In future I will put a switch with 3 options and I will put a 3rd option for 70-30 .
My goal is to make a nice 9sec pass(with 4 slicks) and make 750whp,i just hope that all will handle good.
Lets see how it works .
I have already made some miles about 100 everything looks great
I will change oil at 250 miles then at 450miles and then i will start to give her some boost.
P.S. Soory for my poor english -I`m open to all coments
2008 speed3
True red.
Pte 6466 & AWD Mode on !!!!
The Following 152 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post:
09TrueRedGTX (03-12-2015), 2eatV8everyday (06-24-2015), 37371118 (05-02-2015), 3starmagnum (04-01-2015), 5doorsoffury (03-12-2015), 802MS3 (03-12-2015), acidplant (11-11-2016), acousticdefbot (06-24-2015), Addikted To Boost (06-24-2015), Agent_Orange (03-13-2015), Alpha (03-27-2015), Amnesiac (03-12-2015), andrewz17 (11-15-2015), ArmanRus (03-12-2015), ASHMS3 (03-12-2015), AveryPlaysBass (10-29-2016), B4RK3R (03-12-2015), BigjohnB20 (03-12-2015), BlackFlag (11-09-2015), blackmicamps6 (03-12-2015), blakjak0271 (03-12-2015), BLKSTIG (03-13-2015), Boost_creep (01-27-2016), brandon3212 (03-12-2015), brandonf (12-28-2015), brandonnicholson (03-12-2015), BrandonRKD (03-12-2015), btstarcher (09-06-2015), ButtholeRedMS3 (01-06-2016), Cevaes_64 (10-05-2015), chaser27 (03-12-2015), chris323 (03-16-2015), cld12pk2go (03-15-2015), Code Monkey (03-12-2015), Cpt_Rum-bo (03-12-2015), cshunter (03-12-2015), CWP_MS3 (03-12-2015), Cyclops (03-12-2015), daafisch (06-24-2015), dagrimey1 (12-02-2015), dale_gribble (03-12-2015), dan7225 (03-12-2015), Dano (06-19-2015), DaUberSchwebel (12-10-2015), dereeek (03-12-2015), derek13p (03-12-2015), derp_ms6 (03-16-2015), DevinS (12-28-2015), Dimenus (03-12-2015), DingoDave (12-25-2015), donjohnk (03-12-2015), Easter Bunny (03-12-2015), Erick13Speed3 (03-12-2015), Etipp98 (03-15-2015), Frnchplayr15 (03-12-2015), g00s3y (03-12-2015), gsrtype1 (09-01-2015), Hargarbl (03-15-2015), harryclay (03-21-2015), HawkeyeGeoff (03-12-2015), Hush (03-12-2015), IamJamen (03-12-2015), impossible (03-15-2015), ink28 (04-09-2015), ItsNox (03-15-2015), Jackis (05-09-2015), jack_hammer (03-12-2015), Jester2552 (07-10-2015), JgamB (03-12-2015), JSmith (03-12-2015), Jtaylor (03-13-2015), Justin@Freektune (03-12-2015), jweller (12-31-2015), kolosok17 (11-02-2015), k_kid (03-15-2015), Lex (03-12-2015), littleloogy (07-15-2015), lnumbp (03-12-2015), lolwrx (03-12-2015), magicka (04-01-2015), maisonvi (03-12-2015), manu (12-15-2016), Matt H. (03-12-2015), Mattyhawk1 (03-16-2015), MattyP617 (04-09-2015), Mauro_Penguin (03-12-2015), mazdakaps (03-14-2015), Mazdazilla6 (03-12-2015), MBalik (03-13-2015), MD1032 (07-02-2015), meelo88 (03-12-2015), meicalnissyen (09-04-2016), mituc (04-09-2015), Mr Wilson (03-12-2015), Mr. T (04-09-2015), ms3blackmica (03-13-2015), ms6mil (03-12-2015), mxlplx71 (03-12-2015), mzr0818 (12-06-2015), nekret (03-14-2015), Neverlift (03-12-2015), NoRegrets (04-09-2015), nybe0010 (03-12-2015), PapaSmurf (03-13-2015), PhillyCheese (09-13-2015), predapio (04-09-2015), Pu Manchu (03-12-2015), Qwik6 (03-11-2016), Raider (03-13-2015), redneck4Christ (07-10-2015), Rich990 (08-13-2015), rigor (06-08-2019), robbspeed (09-27-2016), roguemazda (10-31-2015), ryguy 3 (03-27-2015), SamiChicago (12-24-2015), Scare Dem (03-12-2015), shaneski (03-13-2015), Shwaykid (03-12-2015), smoogs12 (03-27-2015), Snyeed (03-28-2015), SofaKingAwesome (05-03-2016), some call me...Tim (03-27-2015), SparkySparks (09-01-2015), speed23 (03-12-2015), Speed3Pedro (11-13-2016), SpeedRebirth (03-12-2015), speed_freak91 (03-12-2015), SpencerC (03-13-2015), squats (03-12-2015), stanley0910 (03-15-2015), Swinger13 (03-12-2015), Tacheny (04-09-2015), taf0422 (03-12-2015), tegxsi (03-12-2015), thems3driver (03-28-2015), TiGraySpeed6 (03-12-2015), Tokay444 (04-01-2015), Tomas (09-01-2015), torquemaniac (04-11-2015), twincitySPEED6 (03-12-2015), UnknownSuperhero (03-13-2015), Vader (03-12-2015), Vadim aka ScooteR (03-12-2015), Varomnia (11-14-2016), WA_MS6 (04-01-2015), WetzMS3 (03-12-2015), Z32_MS3 (03-14-2015), Zachms3 (11-14-2015), Zdraveca (06-19-2015), zooomMPS3 (12-28-2015), [R]usty (09-14-2015)
 Old 03-12-2015, 05:08 AM   #2
maisonvi's Avatar
Posts: 3,490   (View Stats)
Groans: 75
Wow, you are going big, I like it. Keep up the good work.
 Old 03-12-2015, 05:56 AM   #3
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
That... is... BEAUTIFUL
 Old 03-12-2015, 06:02 AM   #4
IamJamen's Avatar
Posts: 789   (View Stats)
Tasty
The Following User Says Thank You to IamJamen For This Useful Post:
 Old 03-12-2015, 06:10 AM   #5
ASHMS3's Avatar
Posts: 1,362   (View Stats)
Groans: 126
I came....
 Old 03-12-2015, 06:13 AM   #6
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Awesome! Glad to see someone is doing it, and doing it BIG. In for huge HP AWD MS3.
Can't wait to see it run.
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
The Following 3 Users Say Thank You to CWP_MS3 For This Useful Post:
ASHMS3 (03-12-2015), Downmented (03-13-2015), harryclay (03-21-2015)
 Old 03-12-2015, 06:25 AM   #7
dev
dev's Avatar
Posts: 325   (View Stats)
dev is the leader of the worlddev is the leader of the worlddev is the leader of the worlddev is the leader of the worlddev is the leader of the worlddev is the leader of the worlddev is the leader of the worlddev is the leader of the worlddev is the leader of the worlddev is the leader of the worlddev is the leader of the world
Wow...
Stock as Fuck
dev is offline   Reply With Quote
 Old 03-12-2015, 06:27 AM   #8
maisonvi's Avatar
Groans: 75
Plus he has driver mod. Thing is going to move (if it stays together, always seems the awd mzrs like to not stay running)
 Old 03-12-2015, 06:29 AM   #9
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Aww, why you got to shit on his parade already...?
Rich Tuned
330WHP and 363TQ
The Following 2 Users Say Thank You to CWP_MS3 For This Useful Post:
cshunter (03-12-2015), RalliartRsX (03-12-2015)
 Old 03-12-2015, 06:51 AM   #10
Scare Dem's Avatar
Posts: 1,505   (View Stats)
Subbed for results.
A lot of hard work went into this.
2008 Mazdaspeed3 GT
GTX2867r
 Old 03-12-2015, 06:56 AM   #11
maisonvi's Avatar
Groans: 75
Haha dont get me wrong, Im hoping for the best. But Ive been around long enough to know how it goes. Hell, Im jealous of his fab skills. I would love to do an AWD swap.
 Old 03-12-2015, 07:13 AM   #12
speed_freak91's Avatar
Posts: 1,189   (View Stats)
Groans: 34
This is awesome... Shit, I would be happy with just adding AWD to the MS3.
speed_freak91 is offline   Reply With Quote
 Old 03-12-2015, 07:24 AM   #13
I understand and i have the same concerns....especially for the transfercase and the rear diff...
Thanks everyone for the good words...
2008 speed3
True red.
The Following 13 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post:
chaser27 (03-12-2015), CWP_MS3 (03-12-2015), daafisch (06-24-2015), Easter Bunny (03-12-2015), harryclay (03-21-2015), Hush (03-12-2015), impossible (03-15-2015), JgamB (03-12-2015), maisonvi (03-12-2015), Mauro_Penguin (03-12-2015), Scare Dem (03-12-2015), WA_MS6 (04-01-2015), WetzMS3 (03-12-2015)
 Old 03-12-2015, 07:32 AM   #14
lolwrx's Avatar
Posts: 217   (View Stats)
lolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the worldlolwrx is the leader of the world
Looks like a beast. 2015 has to show a 10 sec pass
BNR s3, Freek 3.5", Autotech internals, depo racing catless dp, TR6, JBR FMIC piping, 80a rmm, OCC, TIGs, EGR delete and Coolant bypass
FREEKTUNED
lolwrx is offline   Reply With Quote
 Old 03-12-2015, 07:38 AM   #15
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
Here I am sweating in a dark corner pretending like im not fapping furiously to this thread. Greece is going big
RE-ACTIONENGSPEED3 likes this.
Silver 2007 Speed3 GT
 Old 03-12-2015, 08:04 AM   #16
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Very very cool!
Custom prop shaft? (drive shaft)
340hp / 371tq
 Old 03-12-2015, 08:11 AM   #17
POE
POE's Avatar
Posts: 46   (View Stats)
POE is a glorious beacon of lightPOE is a glorious beacon of lightPOE is a glorious beacon of lightPOE is a glorious beacon of lightPOE is a glorious beacon of lightPOE is a glorious beacon of light
I want to hear this thing! Video?
POE is offline   Reply With Quote
 Old 03-12-2015, 08:15 AM   #18
Very very cool!
The front half is from speed6 the rest custom
I attached a video at the first post...
2008 speed3
True red.
Last edited by RE-ACTIONENGSPEED3; 03-12-2015 at 08:15 AM. Reason: MSF Database - Automerged Doublepost
The Following 3 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post:
lolwrx (03-12-2015), Scare Dem (03-12-2015), TiGraySpeed6 (03-12-2015)
 Old 03-12-2015, 08:24 AM   #19
dgiannitakis's Avatar
Posts: 31   (View Stats)
dgiannitakis is a glorious beacon of lightdgiannitakis is a glorious beacon of lightdgiannitakis is a glorious beacon of lightdgiannitakis is a glorious beacon of lightdgiannitakis is a glorious beacon of light
Thumbs up
Greek State of Art after Parthenon...
tom3mps likes this.
http://​www.linkedin.com/in/​dgiannitakis
dgiannitakis is offline   Reply With Quote
 Old 03-12-2015, 08:57 AM   #20
Jarods7920's Avatar
Posts: 1,415   (View Stats)
why did you go with the custom fuel tank vs using an S40 fuel tank?
 Old 03-12-2015, 09:19 AM   #21
Justin@Freektune's Avatar
Posts: 954   (View Stats)
Love it man! Can't wait to see what you can lay down at the track. Keep us updated with the progress too!
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
 Old 03-12-2015, 10:20 AM   #22
smr87's Avatar
Posts: 1,288   (View Stats)
smr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the worldsmr87 is the leader of the world
Groaned at 6 Times in 4 Posts
That...is...awesome! Are the rear axles a custom length? Not sure if the rear track width is the same on the 3 and the cx7.
Ill be interested to see how the driveline holds up with the locked front/rear ratios.
1999 Cosmos M3
turning bits and more better suck, squish, bang, and blow
FREEK'D 2012 Liquid Silver Genpu-sold
We were young, and we were fearless and, after all, nobody had ever told us young engineers that we couldn't successfully land humans on another planet. So we did it.
smr87 is offline   Reply With Quote
 Old 03-12-2015, 10:25 AM   #23
Because it is difficult to find it in my country and i also want to reduce weight.
Yes it is custom length
smr87 likes this.
2008 speed3
True red.
Last edited by RE-ACTIONENGSPEED3; 03-12-2015 at 10:25 AM. Reason: MSF Database - Automerged Doublepost
 Old 03-12-2015, 10:27 AM   #24
Jarods7920's Avatar
Speed 6 axles work in this set up...so custom axles aren't required.
I hope youre talking about fuel weight lol.
Last edited by Jarods7920; 03-12-2015 at 10:27 AM. Reason: MSF Database - Automerged Doublepost
 Old 03-12-2015, 01:01 PM   #25
JgamB's Avatar
Posts: 2,566   (View Stats)
All of this engine porn and awesome fab work.. and I can still only chuckle about
"Big Head port with handjob"
I wish you the best with this amazing build.
manu likes this.
The Following 9 Users Say Thank You to JgamB For This Useful Post:
Agent_Orange (03-13-2015), daafisch (06-24-2015), Easter Bunny (03-12-2015), impossible (03-15-2015), jack_hammer (03-12-2015), lolwrx (03-12-2015), Mauro_Penguin (03-12-2015), Putin 2.3T (03-12-2015), RE-ACTIONENGSPEED3 (03-12-2015)
 Old 03-12-2015, 02:25 PM   #26
Xerxes's Avatar
Posts: 27   (View Stats)
Xerxes is an unknown quantity at this point
This is amazing. Glad to see others putting in hard work for the love of this Mazda. Cannot wait to see this thing run a quarter.
I'd be doing this in a second if I had the cash to do so freely with time. Awesome work man
Xerxes is offline   Reply With Quote
 Old 03-12-2015, 02:35 PM   #27
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
Yeah and the MS6 axles have been proven to be dog shit and bust on many cars so he made much stronger ones from drive shafts., Which I think he was smart in looking ahead to see that as an issue.
The Following 4 Users Say Thank You to Nitr0EngiE For This Useful Post:
Downmented (03-13-2015), Easter Bunny (03-12-2015), RE-ACTIONENGSPEED3 (03-12-2015), redneck4Christ (07-10-2015)
 Old 03-12-2015, 03:05 PM   #28
A litle update
I just went to the alighment today..everything is perfect and i setup it as i wanted...
Furthermore, i forgot to write about the re-inforcments i have done to the transfercase.
I put the upgraded bearings caps from 06speed6 , i have replace all the bolts with arp`s and i have made an extra re-inforce like a handcuff (photos below)
2008 speed3
True red.
The Following 32 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post:
802MS3 (03-12-2015), ASHMS3 (03-12-2015), aviator79 (04-09-2015), blackmicamps6 (03-12-2015), brandon3212 (03-12-2015), ButtholeRedMS3 (01-06-2016), Code Monkey (03-12-2015), Cpt_Rum-bo (03-13-2015), daafisch (06-24-2015), Dano (06-19-2015), Downmented (03-13-2015), Easter Bunny (03-12-2015), Hargarbl (03-15-2015), Hush (03-12-2015), impossible (03-15-2015), ItsNox (03-15-2015), JgamB (03-13-2015), Jtaylor (03-13-2015), Lex (03-12-2015), magicka (04-01-2015), Mauro_Penguin (03-13-2015), Mazdazilla6 (03-12-2015), mxlplx71 (03-12-2015), Pu Manchu (03-13-2015), Reactorpwr (04-19-2019), redneck4Christ (07-10-2015), robry (02-04-2016), smr87 (03-12-2015), Swinger13 (03-12-2015), Tokay444 (04-01-2015), torquemaniac (04-11-2015), WA_MS6 (04-01-2015)
 Old 03-12-2015, 04:49 PM   #29
Nicely done! How does the car handle in the turns? Understeer, oversteer or neutral?
 Old 03-12-2015, 05:05 PM   #30
brandon3212's Avatar
Posts: 425   (View Stats)
Best of luck with this crazy build, I will be following closely.
07 Speed 3
 Old 03-12-2015, 06:07 PM   #31
Very awesome!
I have three questions:
1. Why did you go to 11mm main studs? I've seen no one having issues with 10mm.
2. What caused you to put on crank girdle straps?
3. How much was it for the LA sleeves and where did you get them?
 Old 03-12-2015, 06:22 PM   #32
Holy shIt. Go big or go home. I assume this means that The 3 is not available in Greece as awD?
 Old 03-12-2015, 08:15 PM   #33
Jarods7920's Avatar
Ya and you can buy upgraded ms6 axles just like he did and just like I did....in case you have forgot, I did this too.
 Old 03-12-2015, 08:38 PM   #34
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
in case you have forgot, you have a build thread that's laid dormant for 3 years.
Downmented and derek13p like this.
94 M
MS6
IS350
The Following 3 Users Say Thank You to Pu Manchu For This Useful Post:
Easter Bunny (03-13-2015), Jarods7920 (03-13-2015), RE-ACTIONENGSPEED3 (03-13-2015)
 Old 03-12-2015, 08:41 PM   #35
Swinger13's Avatar
Posts: 3,480   (View Stats)
Groans: 53
what 12mm head studs do you have?
Performance:
Stratified Tune in progress
 Old 03-12-2015, 11:04 PM   #36
B4RK3R's Avatar
Posts: 193   (View Stats)
B4RK3R has a reputation beyond reputeB4RK3R has a reputation beyond reputeB4RK3R has a reputation beyond reputeB4RK3R has a reputation beyond reputeB4RK3R has a reputation beyond reputeB4RK3R has a reputation beyond reputeB4RK3R has a reputation beyond reputeB4RK3R has a reputation beyond reputeB4RK3R has a reputation beyond reputeB4RK3R has a reputation beyond reputeB4RK3R has a reputation beyond repute
Truly amazing!
2013 CWP W/Tech Package: Cobb Tuning Accessport //Cobb Tuning SF Intake //Cobb Tuning Turbo Inlet Pipe //Corksport TMIC //M2 Test pipe //Autotech HPFP Internals //JBRacing 1.25'' Rear Sway Bar //JBRacing 88A RMM //JBRacing Short Shifter Plate //Swift Spec R springs// Bilstein B8's //Resonator delete //35% window tint// Rally Armor Mudflaps// Go Fast Bits BOV// NGK Step Colder Plugs
B4RK3R is offline   Reply With Quote
 Old 03-12-2015, 11:43 PM   #37
lobitoPU's Avatar
Posts: 3,205   (View Stats)
Groans: 42
Threads like this makes me wanna go balls deep in my speed
But then i remember im a college student on a budget
Keep it up sir. Truly amazing job
Fuck mazdaspeeds
Fuck shayne
 Old 03-13-2015, 12:45 AM   #38
shaneski's Avatar
Posts: 505   (View Stats)
Great work, this is pure dedication to achieve his goals with a MZR powered car.
 Old 03-13-2015, 01:22 AM   #39
I steel have not push it a lot but i have not mension something weird or unusual(when i have feedback i will let you know)
Very awesome!
I go to 11mm main studs and crank girdle straps because i have in mind to rev it 8500 or more (when versatune make it happen of course) so i want it to be ready for whatever needs
The L.A. sleeves i bought them direct from them (500$ if i remeber correct) i get them on a local engine builder
Nice question they are from Nissan Gtr R35 (they are almost identical)
No Awd speed 3 in my country...
2008 speed3
True red.
Last edited by RE-ACTIONENGSPEED3; 03-13-2015 at 01:22 AM. Reason: MSF Database - Automerged Doublepost
The Following 8 Users Say Thank You to RE-ACTIONENGSPEED3 For This Useful Post:
Agent_Orange (03-13-2015), impossible (03-15-2015), maisonvi (03-13-2015), Mauro_Penguin (03-13-2015), Mazdazilla6 (03-15-2015), redneck4Christ (07-10-2015), SamiChicago (12-24-2015), Swinger13 (03-13-2015)
 Old 03-13-2015, 03:03 AM   #40
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
That is all I have to say.
The Following 18 Users Say Thank You to Agent_Orange For This Useful Post:
ArmanRus (03-13-2015), ASHMS3 (03-13-2015), BigjohnB20 (03-13-2015), blackmicamps6 (03-13-2015), ButtholeRedMS3 (01-06-2016), Cpt_Rum-bo (03-13-2015), cshunter (03-13-2015), Easter Bunny (03-13-2015), Erick13Speed3 (04-06-2015), harryclay (03-21-2015), impossible (03-15-2015), ItsNox (03-15-2015), JgamB (03-13-2015), lolwrx (03-13-2015), MattyP617 (04-09-2015), Mauro_Penguin (03-13-2015), SamiChicago (12-24-2015), WA_MS6 (04-01-2015)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f541/pte-6466-awd-conversion-185595/
ClubC4 ? Vezi subiect - Fun This thread Refback 12-19-2015 01:37 AM
Articole interesante despre masini - Pagina 46 - Cafenea - Club Mazda This thread Refback 12-18-2015 10:34 PM
Pte 6466 & AWD conversion - Page 3 - Mazdaspeed Forums This thread Refback 06-24-2015 04:14 AM
?????? ?????? ?? Mazda 3 mps AWD This thread Refback 05-07-2015 04:11 AM
Articole interesante despre masini - Pagina 36 - Cafenea - Club Mazda This thread Refback 04-09-2015 12:46 PM
? View topic - Trying for a 9 !! 1/4 Mile in a MPS3 This thread Refback 03-15-2015 05:11 AM
Çàåçäû (÷àñòü 2 - íîâûé ñåçîí!) (Ñòð.314) / ×åëÿáèíñê — FFClub This thread Refback 03-12-2015 08:30 AM
di to pi conversion cbspeed3 MazdaSpeed 3 - Engine, Transmission & Driveline 7 04-05-2009 09:48 PM
HID Conversion Kit SpdFreak MazdaSpeed 3/6 - Car Audio & Electronics 62 01-27-2009 05:18 AM
Page generated in 0.64352 seconds with 50 queries
