Like Tree38Likes
 Old 01-08-2016, 02:04 AM   #121
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
60-100?
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 01-08-2016, 07:13 AM   #122
sho
sho's Avatar
Posts: 537   (View Stats)
sho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the world
60-100?
Low 4 seconds last time I data logged in 4th gear (4.3s). Need to replace a few things and have Mark finish the tune
2007 ms3 GT, sunlight silver
Manley platinum series 88mm pistons, Manley h beam rods, L19 head studs, custom cometic mlx head gasket, massive speed balance shaft delete, massive speed oil pan baffle, OEM Rod and Main bearings, vband pte 5862 .82AR journal bearing turbo, Cp-e exhaust manifold, custom 3" vband downpipe, 3" cnt Catback, pw46 ewg, tr1235 fmic, tial Q BOV on hotside pipe, 3" cold side piping, JMF V2 w/ PI, CS big TB, PERM pcv plate with jbr sealed can and ebay VTA can, custom VC vent with VTA can, SP63 gen 1 vc breather cap, Cp-e injector seals, mazdaspeed accessory coilovers, Hotchkis 32mm fsb and rsb, Damond Motorsports RMM, TMM & PMM.
FD wheels
E48 mix
Tuned by Realgib3
Purchased 8/3/12 - 25,314 miles on chassis and motor
6/21/18- 234,700 miles on chassis, 73,200 on built motor
sho is offline   Reply With Quote
The Following User Says Thank You to sho For This Useful Post:
Realgib3 (01-08-2016)
 Old 01-08-2016, 08:29 AM   #123
blackms3_71's Avatar
Posts: 2,250   (View Stats)
What does the car sitting have to do with the meth system? My car sits sometimes a week at a time and never had a issue. I think sometimes it may drip a little but no real issues from it.
 Old 01-08-2016, 08:34 AM   #124
sho
sho's Avatar
Being my Only car, I didn't want to take the risk of having a check valve fail and have a drip for a week and come back to a flooded motor. Plus I don't like the idea of my car sitting in my sketchy was neighborhood unattended for a week.
FD wheels
E48 mix
Tuned by Realgib3
 Old 05-12-2016, 09:39 PM   #125
impossible's Avatar
Posts: 733   (View Stats)
Groans: 30
Bump for updates! How's the stock longblock holding up? Mark's tune seems damn solid on this car and you're making me want to run a JB 5862 over a JB 6266 lol
 Old 05-12-2016, 09:48 PM   #126
sho
sho's Avatar
I ran a 5858 on the stock block at 22psi from 124k to 161.5 miles. The block was fine, but I wanted more and was scared to with that high mileage. The stock block was pulled with 180 psi compression across all cylinders at 161.5k and transplanted into another car, which is still running great today.
My friend had a spare block and head and built me a bottom end (88mm Manley platinum series pistons, Manley h beams) and refreshed the head. We left the balance shaft in tact and just did all new oem gaskets, bolts, head studs, head gaskets, water pump and timing gear, etc.
That was done in a weekend and the built motor went in a day after the stock block was pulled at 161.5k. My car is now at 196k miles or 34.5k on the built motor. The 5862 and meth went in 25k miles ago and has been running 28psi since. Taking it to the dyno early next month to have Mark dial it in a little more and then I'll leave it be. With stock head studs and a stock clutch (because I drive 1000 miles a week for work and need life out of the clutch and put 50k on my old 6 puck in 11 months before it quit), we have to keep the tq down. But whatever. It's fast enough for me, and has been reliable for the most part. Sitting right around 475/400 right now according to VD, which I take with a grain of salt.
FD wheels
E48 mix
Tuned by Realgib3
 Old 05-12-2016, 09:52 PM   #127
impossible's Avatar
Groans: 30
Word man, I'm going to be running it on stock bottom end and pump gas with some meth for maybe a glory pull on the dyno while I have a stock longblock built. Hoping for 550whp with 6th Port, Freek headstuds and a new OEM clutch and Fidanza f/w setup. Any new vids of this thing pulling on the built longblock?
 Old 06-11-2016, 09:38 AM   #128
sho
sho's Avatar
Tune is complete. HTP 3.5 inch intake is damn near maxed out. Slow boost ramp down low to preserve my clutch as long as possible until I get a daily and can upgrade (stock clutch lololol) . Completely stock head including head studs. Crank isn't keyed, either. Very pleased with the outcome.
Realgib3 and wes3id like this.
FD wheels
E48 mix
Tuned by Realgib3
The Following 6 Users Say Thank You to sho For This Useful Post:
CMajor (07-11-2017), CWP_MS3 (01-25-2017), impossible (06-12-2016), Mazdazilla6 (01-25-2017), mituc (07-06-2016), Snyeed (06-11-2016)
 Old 06-12-2016, 08:39 AM   #129
sho
sho's Avatar
Owned the car 2 months shy of 4 years, now. Low mileage pic was taken a few days of taking delivery. 200k shot, last night..
FD wheels
E48 mix
Tuned by Realgib3
The Following 2 Users Say Thank You to sho For This Useful Post:
impossible (06-12-2016), wes3id (06-12-2016)
 Old 06-13-2016, 02:42 PM   #130
sho
sho's Avatar
Pic from the local hard Park meet on Sunday, was a beautiful night. Friend Shane's bnr s4 pu next to mine
Realgib3 likes this.
FD wheels
E48 mix
Tuned by Realgib3
 Old 07-06-2016, 10:29 PM   #131
sho
sho's Avatar
Probably the most nerve racking moment I've had in a while. First compression test since the motor was broken in.
FD wheels
E48 mix
Tuned by Realgib3
CWP_MS3 (01-25-2017), Snyeed (07-07-2016)
 Old 08-23-2016, 04:23 PM   #132
sho
sho's Avatar
Stock clutch finally started slipping at the end of last month when I hit peak tq. Not bad considering it spent 152k miles in an ms6 before being put in my car at the last minute to get to ENM 2015. It's been in my car for almost another 75k miles.
Picked up another act 6 puck. Went with the prolite flywheel. Had no issues with the Streetlite Flywheel for the first go around with a 6 puck, so Fuck it.
Clutch is here! Install date is tentative for Sept 10th.
FD wheels
E48 mix
Tuned by Realgib3
 Old 01-23-2017, 07:27 PM   #133
sho
sho's Avatar
Holy smokes, surprised this thread was still on the 1st page of all the build diaries, I haven't posted here in forever
Anyways, meth kit, Cobb FMIC were pulled recently.
Replaced with 6th port with Bosch 2200cc injectors, and aeromotive 325 stealth pump, and a tr1235. Car needs retuned and a grill made for the bumper and I'll see if I can stay happy til end of summer lol.
FD wheels
E48 mix
Tuned by Realgib3
The Following 4 Users Say Thank You to sho For This Useful Post:
CMajor (07-11-2017), CWP_MS3 (01-25-2017), Mazdazilla6 (01-25-2017), Snyeed (01-24-2017)
 Old 01-25-2017, 05:33 AM   #134
Looking good man. Time to dump that stock intake mani!
sho (01-26-2017)
 Old 01-25-2017, 06:35 AM   #135
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Looks awesome yo!
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
 Old 03-05-2017, 05:48 PM   #136
sho
sho's Avatar
First pull with the 6th port turned on. Time to get dialed in for when the weather wants to stay warm
FD wheels
E48 mix
Tuned by Realgib3
 Old 03-05-2017, 10:50 PM   #137
mituc's Avatar
Groans: 111
The graph looks like you lost traction at around 6300rpm...
 Old 03-06-2017, 06:59 AM   #138
sho
sho's Avatar
Yeah... I lost traction in 4th gear at 100mph on 255's...
Has nothing to do with the boost curve as it sits right now...with it holding 20psi to 5500, then climbing to 30 by 7200.
FD wheels
E48 mix
Tuned by Realgib3
The Following 3 Users Say Thank You to sho For This Useful Post:
CMajor (07-11-2017), Etipp98 (03-07-2017), mituc (03-06-2017)
 Old 03-06-2017, 07:10 AM   #139
sho
sho's Avatar
Anyways, this is just a rough map to make sure the 6th port was working as it should. No we gotta dial the fuel in and boost curve back to where it was last summer on the meth. Looking forward to getting the mid range back. If we can make a similar curve to what I made last year at 500/391, I'll be happy
FD wheels
E48 mix
Tuned by Realgib3
 Old 06-04-2017, 09:04 PM   #140
sho
sho's Avatar
Realgib3 and mituc like this.
FD wheels
E48 mix
Tuned by Realgib3
CWP_MS3 (06-05-2017), mituc (06-05-2017)
 Old 06-11-2017, 12:03 PM   #141
sho
sho's Avatar
Made a grill for my bumper yesterday to somewhat protect the tr1235. Kinda hard to see... But it works
FD wheels
E48 mix
Tuned by Realgib3
CWP_MS3 (06-12-2017)
 Old 06-12-2017, 05:01 AM   #142
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Do those RS3's hook up well for you? I've always thought of those as more of a turning tire.
Rich Tuned
330WHP and 363TQ
 Old 06-12-2017, 08:04 AM   #143
sho
sho's Avatar
I'm load limited to hit super low boost in 1st and 2nd gear, and have no traction issues there. 3rd gear it'll spin up top if I dont have some heat in the tires, as it see's full power there. 4th hooks fine, though.
For me, they work as my tune is setup well for traction, and I do take the car through the twisties locally. For others, maybe not so much.
FD wheels
E48 mix
Tuned by Realgib3
 Old 09-08-2017, 11:40 AM   #144
sho
sho's Avatar
On some 255/50/16 mickey Thompson ET street on fd wheels
User Media - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
mituc likes this.
FD wheels
E48 mix
Tuned by Realgib3
mituc (09-08-2017)
 Old 09-08-2017, 12:07 PM   #145
Dennisms3's Avatar
Posts: 198   (View Stats)
Dennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant futureDennisms3 has a brilliant future
That torque curve tho!
sho likes this.
Dennisms3 is offline   Reply With Quote
The Following User Says Thank You to Dennisms3 For This Useful Post:
sho (09-08-2017)
 Old 07-18-2018, 10:17 PM   #146
sho
sho's Avatar
Wow, 10 months since I last updated this.
Grabbed a jmf v2, added PI, upgraded to L19 head studs, went to a stiffer wg spring over the winter and spring
Tune not 100% finished, but hopped on the dyno to see where I'm at. 87* ambient and 108* charge temps
Solid power for this tired motor and turbo
https://youtu.be/kYsvYooxwO4
Dennisms3 likes this.
FD wheels
E48 mix
Tuned by Realgib3
impossible (10-16-2018), mituc (07-23-2018)
Why would I not want a K04 for my project? sac02 Mazdaspeed3/6 General Discussion 52 09-09-2014 02:28 PM
Project 11s 2XS (From OZ) MazdaSpeed 3 - Engine, Transmission & Driveline 33 07-27-2010 04:05 AM
Page generated in 0.45076 seconds with 26 queries
