> 2010 MS3 - Build Diaries
Like Tree83Likes
 Old 08-22-2015, 08:03 AM   #161
865ms3's Avatar
Posts: 2,602   (View Stats)
What size and offset are the wheels you're trying to fit
Fd wheels. They are 16x8 +50
High offset is my problem
Brent
-Built Block-5858-Meth
Dragon Slayer Setup
FreekTuned
 Old 08-28-2015, 02:00 PM   #162
865ms3's Avatar
Maybe this will get it....245/50/16 nt555 drag radials. Extended studs and 15mm spacers. MAY have to raise the coils up a tad. We will see.
Waiting on a tee fitting for my dual meth nozzles. Current one is leaking so meth is off. Then time to see what they will hold.
senor blanco ms3 likes this.
Brent
Dragon Slayer Setup
FreekTuned
The Following 4 Users Say Thank You to 865ms3 For This Useful Post:
cshunter (08-28-2015), Easter Bunny (08-29-2015), NCspecV81 (08-28-2015), TRBLSM (08-29-2015)
 Old 08-28-2015, 10:54 PM   #163
senor blanco ms3's Avatar
Posts: 1,353   (View Stats)
senor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the worldsenor blanco ms3 is the leader of the world
Which coilovers are you on and why not slicks?
2008.5 Crystal White Pearl MS3
A lot of mods
Check out my big turbo build!
senor blanco ms3 is offline   Reply With Quote
 Old 08-29-2015, 09:26 AM   #164
865ms3's Avatar
ISC n1.
no slicks because i plan to rarely go to the drag strip. we only have 1/8 mile here so meh. the nt555 drag radials seemed like a good compromise to put traction down on the street and the rare chance i hit the strip.
senor blanco ms3 and ItsNox like this.
Brent
Dragon Slayer Setup
FreekTuned
 Old 08-29-2015, 09:33 AM   #165
NCspecV81's Avatar
Posts: 2,867   (View Stats)
Well there is a good compromise of wet traction as well. I've hit the rain in mine and as long as you keep it at 65 on the highway and don't intentionally go diving into puddles they work.
2013 CWP and Stock
865ms3 (08-29-2015), Easter Bunny (08-29-2015)
 Old 08-29-2015, 10:07 AM   #166
ISC n1.
Nice!!! I have ISC's too and already have to run a 10mm spacer for my rpf1's and was hoping someone else would figure out a drag wheel set up that worked. Lol
Looking forward to see how the radials work out for you.
A lot of mods
The Following User Says Thank You to senor blanco ms3 For This Useful Post:
865ms3 (08-29-2015)
 Old 08-29-2015, 10:16 AM   #167
865ms3's Avatar
Fds are 16x8 +50 if that helps
Brent
Dragon Slayer Setup
FreekTuned
 Old 08-29-2015, 12:38 PM   #168
865ms3's Avatar
got the meth fixed. i had another tee laying around and i re routed a few things. appears to be leak free. did some pulls on the "daily" map 510/420 and the tires held.
flashed the all out map and they held 3rd gear as well. tried a pull from 2nd and they seemed to hold too. they may just make minimal noise when spinning, but even if they are its a VAST improvement from what i had. ill call it a success.
i plan to go out and play some tonight. see how it does. coilovers needs raised a tad. i rubbed over a few large bumps.
Brent
Dragon Slayer Setup
FreekTuned
BigBoostMS3 (08-30-2015), cshunter (08-29-2015), Hammology (08-29-2015), ItsNox (08-30-2015)
 Old 08-29-2015, 03:52 PM   #169
865ms3's Avatar
Launched the car at 4500 with a slight slip then bog. Very surprising. Time to bump up lc
ItsNox likes this.
Brent
Dragon Slayer Setup
FreekTuned
 Old 08-29-2015, 04:09 PM   #170
Not worried about snapping an axle?
A lot of mods
 Old 08-29-2015, 05:08 PM   #171
865ms3's Avatar
Nah. If it breaks it breaks.
Brent
Dragon Slayer Setup
FreekTuned
The Following 3 Users Say Thank You to 865ms3 For This Useful Post:
802MS3 (08-30-2015), Justin@Freektune (08-30-2015), SpeedRebirth (08-29-2015)
 Old 08-30-2015, 08:37 AM   #172
Justin@Freektune's Avatar
Posts: 954   (View Stats)
We launch full slicks at 6k+ rpms and there have only been a couple people that broke axles. Dead hook is when you will break the axle. You want the tires to spin slightly on a launch.
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
865ms3 (08-30-2015), ItsNox (08-30-2015), taf0422 (08-30-2015)
 Old 08-30-2015, 11:47 AM   #173
ItsNox's Avatar
Posts: 3,076   (View Stats)
This is a golden nugget right here for ms3s. I did a lot of liking the last page. Wish I wasn't scared of blowing my transfer case again lol.
@865ms3; where was your meth leaking? At the T? And how did you know? I think I've noticed the sweet smell of meth on a couple 4ths.
'06 Mazdaspeed 6 GT
- Miltuned
Georgia Motherfucking Nator
865ms3 (08-30-2015)
 Old 08-30-2015, 07:30 PM   #174
865ms3's Avatar
At the tee. It didn't go lean enough to trigger the failsafe. But bats were not droping like normal.
Also I saw some puddled up on the splashshield.
Brent
Dragon Slayer Setup
FreekTuned
ItsNox (08-30-2015)
 Old 08-31-2015, 12:12 PM   #175
Found a set of FD's with 255/50 Mickey Thompson's drag radials with only a few passes on them for $300...sounds like a winner.
A lot of mods
865ms3 (08-31-2015)
 Old 09-01-2015, 10:02 AM   #176
865ms3's Avatar
well....the locals have talked me into going to the drag strip friday night for test and tune. never been before so might as well. 1/8 is all we have local so not sure what to expect. my only goal is to not break the car and have fun. also, not embarrassing myself would be good as well.
Brent
Dragon Slayer Setup
FreekTuned
BigBoostMS3 (09-01-2015), cshunter (09-01-2015), Justin@Freektune (09-01-2015)
 Old 09-01-2015, 10:28 AM   #177
ItsNox's Avatar
We will require videos!
'06 Mazdaspeed 6 GT
- Miltuned
865ms3 (09-01-2015)
 Old 09-01-2015, 01:56 PM   #178
Does your car know how to drive in straight line?
865ms3 likes this.
PTE 6062
633HP/523TQ
865ms3 (09-01-2015)
 Old 09-01-2015, 01:58 PM   #179
NCspecV81's Avatar
don't do what I done on them. 5500rpm clutch dumps to the tune of 4.065s 60'.
2013 CWP and Stock
The Following 3 Users Say Thank You to NCspecV81 For This Useful Post:
865ms3 (09-01-2015), cshunter (09-01-2015), Hammology (09-01-2015)
 Old 09-01-2015, 02:24 PM   #180
865ms3's Avatar
does yours know how to corner?? lol. showed me that indeed it can. even convinced me to go 5858 in doing so!
Car is 100% capable, but im not so sure about the driver.
you need to get right with the FWD gods. less power or better tires lol.
i launched at 4500 on the street and it hooked well, but bogged. this was also on brand new pavement with 3 people in the car. i plan to start here then bump up to 5000 if i get the same result at the track.
ive never been to the drag strip before and dont expect to make it a new hobby. so dont expect greatness out of me lol.
Raising up front coils when i get home. im rubbing everywhere.
Justin@Freektune likes this.
Brent
Dragon Slayer Setup
FreekTuned
cshunter (09-01-2015), ItsNox (09-01-2015), Justin@Freektune (09-01-2015)
 Old 10-02-2015, 02:45 PM   #181
865ms3's Avatar
been a month...might as well update.
no issues...no problems. car still kicks ass. ive got a pesky slow o2 response code and p2096 popping up. been there before. replace the o2 sensor and all was fine again. ive been mobbing around daily duty with the drag radials on the front. they have handled anything i can throw at them.
i had to raise the coilovers 10mm in the front for everything to quit rubbing. did the same in the rear to equal it out.
never did make it to the drag strip a few weeks ago. planned to go today, but rain. its on the list, but not high priority. right now im set on fall dragon camp and getting some tires for it. i killed my rs3s at the last auto-x style event i went to.
all ive done to the car is add meth to the tank. cant complain about that.
edit: got home and couldnt wait. RS3s are backordered until 10/12. not willing to risk the wait and not have tires for camp. Re71rs ordered. @phate; lets see how they do with this heavy pig at the dragon
ItsNox likes this.
Brent
Dragon Slayer Setup
FreekTuned
cshunter (10-02-2015), impossible (06-01-2016), ItsNox (10-03-2015), TRBLSM (10-02-2015)
 Old 10-03-2015, 01:57 AM   #182
MSP611's Avatar
Posts: 2,291   (View Stats)
man great update. no problems is a wat were lookin for. Im hopin i dont run into a shit load of problems.. What did u use to tack ur silicone couplers for installation?
In progress:
 Old 10-03-2015, 07:08 AM   #183
865ms3's Avatar
Nothing. Just slid them on and tightened the clamps. Boost leak test and good to go.
Brent
Dragon Slayer Setup
FreekTuned
 Old 06-01-2016, 12:54 AM   #184
impossible's Avatar
Posts: 733   (View Stats)
Groans: 30
Sick build man, saw your kill map made 565/464 on the dyno video. How do you think this turbo would be on a stock bottom end DISI with reasonable boost levels? I see you auto x and were having to fight the violent spool up when the turbo hits full tilt but curious how different the JB 5862 would be.
 Old 06-01-2016, 05:34 AM   #185
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
Right, I can answer that having been in a 350 whp 5858 MS3 tuned on 93. This turbo is a dog on the stock bottom end...way too big and a waste of its potential. Not even worth it IMO. 3076/S4 is the largest I'd go on the stock bottom end (if only because the pistons get PO'd at high power levels) and I prefer more in the 3071/2871/S3 vicinity personally. Justin and Brent may feel differently.
2007 Mazdaspeed3 GT
865ms3's GT3071R 865ms3 2010 MS3 - Big Turbo Builds 133 06-05-2015 07:48 AM
Pte 5858 build STiKiLLa MazdaSpeed 3/6 - Big Turbo Builds 74 03-13-2015 06:12 AM
Frankie's ghey pte 5858 build ms3driver213 2010 MS3 - Big Turbo Builds 17 04-18-2014 08:11 AM
PTE 5858 BT build!! katoom17 MazdaSpeed 3/6 - Big Turbo Builds 3 02-22-2014 02:48 PM
865ms3 E85 FreekTune 865ms3 2010 MS3 - Dyno Sheets/Discussions 43 06-01-2012 09:35 AM
Page generated in 0.44367 seconds with 28 queries
