> 2010 MS3 - Build Diaries
Like Tree3Likes
 Old 12-05-2015, 06:38 AM   #41
You could always use the corksport can with the jbr routing. If you don't need the ramps send them here.
Also you are up really fucking early. Or still up not sure of the time difference. Its 8:30 am here.
 Old 12-05-2015, 06:41 AM   #42
Fonsi's Avatar
Posts: 236   (View Stats)
Fonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond reputeFonsi has a reputation beyond repute
You're right. But then I need a check valve and I dont know were to get it in Germany. I have the JBR one, but than I can install the whole JBR kit anyways .
You can have those ramps if you pay the shipping which should be like 500USD .
Btw. its 14:40 here in Germany .
2012 Mazdaspeed 3
CS SRI, BNR S1, CS TMIC w/ Boost Tubes, GrimmSpeed EBCS, CS RMM, Stratified tuned, Cobb DP, 3" Catback, H&R coilovers, Tanabe strut & other parts
Fonsi is offline   Reply With Quote
 Old 12-05-2015, 08:07 AM   #43
Aww fuck i was going the wrong way on the time difference. It is too early here.....
 Old 12-19-2015, 01:09 PM   #44
Fonsi's Avatar
Installed the JBR OCC today:
2012 Mazdaspeed 3
 Old 12-29-2015, 12:51 PM   #45
Fonsi's Avatar
Last spring, we forgot to throw out the mount of the oem downpipe when installing the COBB downpipe.
Since there is a lift now in our workshop, I immediately uninstalled the mount which makes a lot more room behind the engine from underneath:
2012 Mazdaspeed 3
 Old 01-01-2016, 03:59 PM   #46
Fonsi's Avatar
A new year - new resolutions: more cars, more boost, more tuning
We started with our traditional new year's eve meeting in the workshop and installed the CorkSport Hood Struts.
They give you plenty of room when working in the engine bay.
This leads me to an updated spec list:
Mazda 3 MPS BL (european Mazdaspeed)
black mica, tech package, navi
currently 50.500km
Engine, Exhaust & Transmission
- CorkSport Stage II SRI
- CorkSport Airbox
- BNR S1 turbo
- CorkSport Boost Tubes
- CorkSport Top Mount Intercooler
- GFB BOV
- CorkSport Bypass Valve Hose
- insulating mats delete
- COBB AccessPort (tuned by Stratified)
- HG HPFP Internals
- EGR Block Off
- JBR Oil Catch Can
- GrimmSpeed EBCS
- 3" COBB Downpipe
- 3" VAST Catback
- CorkSport Race RMM
- MME Short Shift Plate
- CorkSport Shifter Bushings
Suspension, Tires & Brakes
- H&R Monotube coilovers
- Tanabe strut (coated in matt black)
- Sparco Assetto Gara 8x18, 225/40 Goodyear Eagle F1 (summer)
- OEM Gen2 rims (coated in green) 7.5x18, 225/40 Nokian WR A3 (winter)
- black RAYS Lugnuts
Exterior
- CorkSport Hood Strut Kit
- black Mazda emblems
- black front grille without MPS emblem
- green brake calipers
- black exhaust pipes
- black/white rear fog light
- some green decals
Interior
- new steering wheel
- black interior
robbspeed likes this.
2012 Mazdaspeed 3
 Old 01-12-2016, 02:02 PM   #47
BAT-man's Avatar
Posts: 719   (View Stats)
BAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the world
Groaned at 29 Times in 14 Posts
Was ist mit der strutbar passiert? Zu viel understeer?
I drive fast, I turn fast, I do everything fast. I even breakfast. I tend to confuse people with my sudden changes of heart. Sometimes I even confuse myself, which tends to cause problems.
"... if u can't find' em - grind 'em"
- old Chinese proverb
http://www.mazdamotorsports.com/
BAT-man is offline   Reply With Quote
 Old 01-12-2016, 02:26 PM   #48
Fonsi's Avatar
Wieder eingebaut. War nur kurz ausgebaut, damit ich besser an den Turbolader rankomme
2012 Mazdaspeed 3
 Old 01-13-2016, 10:24 AM   #49
Fonsi's Avatar
Threw the fog lights out ... didnt see a difference between on and off and I've never used them anyways.
So ... because racecar. Took the car on our lift and took them out. Drivers side was easy as there is plenty of space behind. Passenger side sucks because of the washer reservoir which is straight behind the fog light.
At the weekend I'll put a cold air hose behind the driver's side opening which leads some fresh air to the airbox box.
2012 Mazdaspeed 3
The Following User Says Thank You to Fonsi For This Useful Post:
Easter Bunny (01-15-2016)
 Old 01-14-2016, 09:13 AM   #50
Fonsi's Avatar
Cold air hose. I will make some logs soon to see if it's worth.
2012 Mazdaspeed 3
 Old 01-29-2016, 11:59 AM   #51
Fonsi's Avatar
Changed the spark plugs today after 51.000km. It wasn't unnecessary . The Denso ITV-22 are now in.
But the main reason I took off the TMIC was the throttle body coolant delete. I also cleaned the throttle body.
BAT-man likes this.
2012 Mazdaspeed 3
Mazdaspeed3 Gen2 tune and tuners Moraitis87 Gen2 MS3 General Discussion 2 11-25-2013 07:45 AM
Mazdaspeed3 Gen2 tune and tuners Moraitis87 MazdaSpeed 3 - How-To's 3 11-25-2013 07:33 AM
VersaTuner for Gen2 Mazdaspeed3/3MPS now available Steve@VersaTune 2010 MS3 - ECU Computer Tuning 6 03-07-2013 05:57 AM
How I Refinished my Stock wheels Gen2 mazdaspeed3 MazSpd3Jase 2010 MS3 - How-To's 60 05-03-2010 11:56 PM
cp-e™ MazdaSPEED3 Gen2 3" SS Cat Back - Released Adam is so pro 2010 MS3 - Engine, Transmission & Driveline 13 05-03-2010 07:48 PM
Page generated in 0.31848 seconds with 22 queries
