> 2010 MS3 - Build Diaries
Like Tree3Likes
  • 1 Post By Format
  • 2 Post By himurax13
 Old 10-01-2013, 06:49 PM   #1
Format's Avatar
Posts: 130   (View Stats)
Format is the leader of the worldFormat is the leader of the worldFormat is the leader of the worldFormat is the leader of the worldFormat is the leader of the worldFormat is the leader of the worldFormat is the leader of the worldFormat is the leader of the worldFormat is the leader of the worldFormat is the leader of the worldFormat is the leader of the world
Default Format's MS3
Hello everyone, Charles here. I got a silver 2013 Genpu and love it! Using this thread as a diary so I have something to look back on. I bought the car brand new with 8 miles on it when I left the dealer. It actually had less because I put a couple on it during the test drive. The second I drove it I fell in love and decided to buy it.
23 Aug 2013: Car was Bought left with 16 miles on it
30 Aug 2013: CorkSport SRI & TIP arrived & Installed
27 Sept 2013: Cp-E stage 2 RMM installed, this mount makes such a huge difference!
29 Sept 2013: JBR SSP installed, Block8Head pod installed, Gauges wires routed, boost gauge installed (awaiting pressure sensor for Oil pressure gauge)
3 Oct 2013: AutoTech HPFP internals installed, EGR Delete, and tune started
19 Oct 2013: First Oil Change at 1345 Miles
23 Oct 2013: Ebay M2 Downpipe installed (1440 miles)
25 Oct 2013: Synapse DV installed (1500 miles)
NGK one step colders waiting to be installed, going to wait until I install my FMIC to get them in. Damond Motorsports OCC w/ sight tube is still on back order but from what I hear it is well worth the wait! Synapse DV, grimmspeed EBCS, Bosch 3 Bar map, Bitwise PNP connector, and TR6 FMIC core w/ CX racing pipe are all waiting to be installed.. Once everything is installed going to finish my tune then start working on a tune for an E85 mix.
Observations:
After installing the SRI and the TIP it really made it so you can hear the BPV and get that “turbo” sound although not as loud as a VTA BOV. Additionally, you can really hear the air getting sucked into the turbo and it raised my average MPG from about 24 mpg to around 28 mpg. The RMM has been by far one of my favorite mods done to this car. It turned it into something new, before I would spin into 2nd and wheel hop in 1st was bad too, with the power I am making it the wheel hop and 2nd gear traction issues have been eliminated. I bought mount used so I did not see any high vibes that anyone talks about. For the first day I had it installed in the car I noticed it vibing a little at really low rpms or when starting it but it really didn’t bother me. The SSP was cake to install, barely took any time and I love it! Although I have noticed twice going into 3rd was a little weird and also once going from 4th to 3rd felt off, it was most likely driver error but may have been due to the SSP. The block8head dual pod is definitely a quality product with excellent craftsmanship, my glowshift gauges fit nice in them. I used a soldering iron on the plastic in the vent to melt it for routing the wires/vac tube. The oil pressure wires and the vac tube were pushed through the hood release hole in the firewall. I taped them to a coat hanger and fed it through which made it extremely easy and the gauges are powered from the fuse box with add-a-circuits that I got a vatozone/oreilly’s. I had help with the HPFP internals but overall the install was fairly easy. Once they were installed I started getting my tune. The tune made the car feel like a whole different beast, throttle response is amazing now and my gas mileage has increased when I’m not getting on it. Averaging 32-35 mpg on the highway and 28ish city. When I get on it I get about 22mpg.
During the Downpipe install make sure you are very careful with the top sensor, they strip out very easily. Also if you purchase an ebay downpipe you will need to have a new bung welded in or have the extended bung shortened. It cost me $30 to have a new one welded in (including the bung). Also when you get it welded in go a little higher (maybe 1 to 2 inches above the extended) so that when installing the old sensor your wires aren't to short.
MS3fiend likes this.
2013 GenPu
- There are no obstacles only opportunities for excellence.
Installed: CS TIP, SRI, Boost Tubes ¤ Cobb AP ¤ Cp-E RMM ¤ Block8Head Dual vent pod ¤ JBR SSP, SSB ¤ AT Internals ¤ GlowShift Boost/OP Gauges ¤ EGR Delete ¤ M2 DP ¤ Synapse DV
In the mail/awaiting install: NGK Plugs ¤ DM OCC ¤ Grimmspeed EBCS ¤ Bosch 3Bar ¤ Bitwise PNP ¤ TR6 FMIC core w/ CXracing pipe
Format is offline   Reply With Quote
The Following User Says Thank You to Format For This Useful Post:
Koke382 (10-11-2013)
 Old 10-01-2013, 07:06 PM   #2
Format's Avatar
Some photos
2013 GenPu
 Old 10-06-2013, 01:30 AM   #3
steevieg's Avatar
Posts: 155   (View Stats)
steevieg has a reputation beyond reputesteevieg has a reputation beyond reputesteevieg has a reputation beyond reputesteevieg has a reputation beyond reputesteevieg has a reputation beyond reputesteevieg has a reputation beyond reputesteevieg has a reputation beyond reputesteevieg has a reputation beyond reputesteevieg has a reputation beyond reputesteevieg has a reputation beyond reputesteevieg has a reputation beyond repute
wish i had the tools/know how to be confident enough to work on my own car other than changing oil and break pads lol
2013 Mazdaspeed3 CWP + Tech Package
CPE Catback | Cobb Downpipe | JBR SRI | JBR TIP | JBR RMM
steevieg is offline   Reply With Quote
 Old 10-10-2013, 09:58 PM   #4
Format's Avatar
Haha, practice!! Get involved with your Nator guys and be a second hand for install days. Everything I've learned has been from reading/researching and helping others.
2013 GenPu
 Old 10-11-2013, 06:28 AM   #5
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
Sure is a pretty color Charles.
Let me ask you, why are you putting in NSC's ?
The Following User Says Thank You to pzr2874 For This Useful Post:
Format (10-11-2013)
 Old 10-11-2013, 06:56 AM   #6
BooSTed_Hatch's Avatar
Posts: 169   (View Stats)
BooSTed_Hatch has a reputation beyond reputeBooSTed_Hatch has a reputation beyond reputeBooSTed_Hatch has a reputation beyond reputeBooSTed_Hatch has a reputation beyond reputeBooSTed_Hatch has a reputation beyond reputeBooSTed_Hatch has a reputation beyond reputeBooSTed_Hatch has a reputation beyond reputeBooSTed_Hatch has a reputation beyond reputeBooSTed_Hatch has a reputation beyond reputeBooSTed_Hatch has a reputation beyond reputeBooSTed_Hatch has a reputation beyond repute
NGK one step colders waiting to be installed, going to wait until I install my FMIC to get them in. Damond Motorsports OCC w/ sight tube is still on back order but from what I hear it is well worth the wait! Synapse DV, grimmspeed EBCS, Bosch 3 Bar map, Bitwise PNP connector, and TR6 FMIC core have been ordered. Ordering ebay DP on the 15th when I get paid. Once everything is installed going to finish my tune then start working on a tune for an E85 mix.
Nice write up dude, and a great idea. Why didn't I think to do this
I bought my car on the same day with 13 miles on..... Ordered all my parts in my sig the next week, and installed them all at the same time 3 weeks later.
2013 CWP MS3 w/Tech Pkg
Performance Mods
Cobb AP V3 ~ JBR 3" WP Intake + Turbo inlet ~ JBR IC Boost tubes ~ AT hpfp Internals ~ ETS TMIC ~ CS Catless DP ~ CS Race pipe ~ CS Catback ~ CP-E Stg2 RMM ~
NGK Iridium IX's (1 step colder) ~ Turbosmart 50/50 ~ KSport Pro Coilovers
[SIGPIC][/SIGPIC]on 93
307whp 339lbft
Exterior mods: ESM 004s - Hankook Ventus V12 Evo2 225/40/18 - Gloss Black Vinyl Roof - Gloss Black emblems - 15% tint - Rear Wiper delete - OEM window visors
On Order: GT2871r, Freektune 3.5" Intake, Bosch 3.5 Bar Map sensor, Cobb EBCS
BooSTed_Hatch is offline   Reply With Quote
The Following User Says Thank You to BooSTed_Hatch For This Useful Post:
Format (10-11-2013)
 Old 10-11-2013, 11:08 AM   #7
Format's Avatar
I went with the NGKs over Denso ITVs because the densos were out of stock, after some more research and chatting with some of the guys in shout it seems NGKs are the better route. I got one step colder plugs because as you add power it increases the heat, colder plugs dissipate that heat better preventing predetination. I have them just sitting on the side for now because I'm not making enough power to actually need them, but I figure once the FMIC and downpipe go on and along with a new tune they will be a helping factor in reducing or mitigating any possible KR.
2013 GenPu
pzr2874 (10-11-2013)
 Old 10-11-2013, 01:10 PM   #8
pzr2874's Avatar
Groans: 146
That's why I was asking.... Didn't know you had a DP going on soon. Just saw yur sig.
 Old 10-11-2013, 01:28 PM   #9
Format's Avatar
Yea, I ended up ordering it last night, haha. I have the plugs sitting on the side right now, everything should be arriving mid next week with the exception of the OCC, Matt said he is super backed up on them but I don't mind waiting.
2013 GenPu
 Old 10-11-2013, 02:00 PM   #10
lk250f's Avatar
Posts: 253   (View Stats)
lk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the worldlk250f is the leader of the world
Nice car bud! How do you like your glowshift gauge? Just ordered a mechanical one. Also who is tuning you? Good luck my friend!
2013 CWP Mazdaspeed3
lk250f is offline   Reply With Quote
The Following User Says Thank You to lk250f For This Useful Post:
Format (10-11-2013)
 Old 10-11-2013, 02:07 PM   #11
Format's Avatar
I like the blowshift gauge, the boost that it reads is accurate with my logs and when looking at other individuals vacuum mine seems to be right where theirs is so definitely no complaints from me yet. Hopefully it will last for a bit but for now I feel it's performing a lot better than what I had expected. @sleepyspeed6; is tuning me and teaching me the ropes. Extremely knowledgeable and very humble guy! Once I get the parts in that I have on order and my tune finished I am going to do a couple dyno runs to see where I am at then onwards to a 30/70 e98/91 oct gas mix.
2013 GenPu
lk250f (10-12-2013)
 Old 10-11-2013, 02:17 PM   #12
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Don't be embarrased. I can do big and stock turbo swaps and suspension work and I don't know how to do brakes, haha.
Pickles Tune in progress
 Old 10-11-2013, 02:32 PM   #13
[R]usty's Avatar
Posts: 2,204   (View Stats)
Hmm, I think breaking in a motor is a pretty important step that is too often overlooked. You may want to cool it with running your engine too hard. Parts need to settle in with each other before you start beating on your car. Better to be safe.
2010 Mazdaspeed3 w/tech
 Old 10-11-2013, 02:58 PM   #14
pzr2874's Avatar
Groans: 146
Rings should be sat how you will drive your car.
I think all the other jazz is an old wives tale..... my 2¢
 Old 10-11-2013, 03:33 PM   #15
himurax13's Avatar
Groans: 255
I drove like an asshole to break my new engine in. That is the way I plan on driving it.
pzr2874 and Format like this.
 Old 10-11-2013, 03:57 PM   #16
[R]usty's Avatar
didn't you blow your first motor?
lilred (10-11-2013)
 Old 10-11-2013, 04:08 PM   #17
Format's Avatar
I didn't quite drive like I stole it when I took it off the lot; I did a lot of talking a research on our motors and break in procedures. From what I have learned Mazda does a pretty good job with them before they ship it out but getting your rings to seat is still required and recommended. For my break in I was pretty easy on it for the first 500 miles and would take it up the mountains and follow normal break in procedures for the rings. Your first 250 is generally the most crucial times for rings to seat so I made sure I went up to the mountains to ensure my rings would be seated to the best of my ability. As far as the rest of the parts I’m not too concerned, especially with this platform and the technological advances that have been made in the automotive world over the last decade. That’s just my outlook on it though, other people may feel differently. If I blow my motor then I blow my motor, when modding cars it’s just something you need to accept knowing it can happen.
2013 GenPu
 Old 10-11-2013, 04:08 PM   #18
himurax13's Avatar
Groans: 255
Well the first motor and turbo were defective and was promptly replaced with a newer, better non 2010 versions.
MotoGP to return to 1000cc format, MotoCzysz back in the mix? Haltech Automotive News 0 12-17-2009 06:10 AM
REPORT: F1 scraps new winner-take-all format after teams protest Haltech Automotive News 0 03-22-2009 07:40 AM
Dead format rises from the grave Haltech Computers & Technology News 0 04-11-2008 08:30 AM
Microsoft Wins Document Format Standards Battle Haltech Computers & Technology News 0 04-02-2008 03:30 PM
Tony George proposes name, format change to welcome Champ Car migrants Haltech Automotive News 0 04-02-2008 12:10 PM
Page generated in 0.39528 seconds with 26 queries
