> 2010 MS3 - Build Diaries
 Old 11-18-2012, 08:39 PM   #41
Jhornbrook's Avatar
Posts: 708   (View Stats)
Jhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the world
Groaned at 6 Times in 4 Posts
It's boost based logic. It's a better OTS map but its not as good as an e-tune
Ultimate Racing // testpipe, catback // TWM // Full Replacement Shifter, Short Shift Boot // Cobb// AP // Sure aeros, sidewinder, shortcut, ags SS knob, return, chargetubes, countershift // Corksport // License Plate Relocate, Fog Light LED's, Interior LED's, Poly Exhaust Hangers, Oil Catch Can // PTP// HPFP Upgrade, 2150 rail valve // H&R // SS Coilovers // SPC// Adjustable Camber Arms // Hawk// HPS Brake Pads // Ebay Chargespeed Lip 06-07 STI Lip // DDM 8K 55W HIDs // JBR// Rear Sway Bar, 88D RMM, AP Mount //WHITELINE// Front End Links // ETS// TMIC//
Jhornbrook is offline   Reply With Quote
The Following User Says Thank You to Jhornbrook For This Useful Post:
Hush (11-18-2012)
 Old 11-18-2012, 11:22 PM   #42
HardHitter's Avatar
Posts: 313   (View Stats)
HardHitter has a reputation beyond reputeHardHitter has a reputation beyond reputeHardHitter has a reputation beyond reputeHardHitter has a reputation beyond reputeHardHitter has a reputation beyond reputeHardHitter has a reputation beyond reputeHardHitter has a reputation beyond reputeHardHitter has a reputation beyond reputeHardHitter has a reputation beyond reputeHardHitter has a reputation beyond reputeHardHitter has a reputation beyond repute
Thanks guys, I went ahead and downloaded the v231 map and flashed it.
It was a nice cold night tonight and I wanted to see what kind of a difference the car is and wow, I am pleasantly surprised. I logged a 1st-2nd run and I was spinning tired in both first and second gear.
The log was more for me to see where I am at my fuel pressure in relationship to my boost/WOT. I'm no expert, but from what I can see on my first run (datalog4.csv) the fuel pressure is fine. However, in my second log (datalog5.csv) rows 90-102 may be a little bit of a worry. I notice that my throttle position is at 75% (from my searches that actually means WOT) and my fuel pressure ranges in the 1300-1500 range and I was still pulling 14-15psi. Don't quite know what happened there.
I've attached the pulls for if anyone would like to take a look at them.
HardHitter is offline   Reply With Quote
 Old 11-18-2012, 11:48 PM   #43
Hush's Avatar
Posts: 520   (View Stats)
Hush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the worldHush is the leader of the world
Groans: 156
Yes, throttle at 75-77% = WOT.
Not sure how you are doing your logs, (and I may not be doing them all together right!) but you want to be consistent, and in this case, what you only care about is WOT engine performance, in third or fourth, fourth is best.
Use a clear, flat road. I use the same road all the time.
Car needs to be warmed up.
Pick what gear you want to log, third or fourth. I use third, fourth if your state does not consider over 80 reckless endangerment and pull your license. First and Second gears are not loading the engine enough to get a good read.
When you are in your gear, do not start your WOT till you are above 3000 RPM. I usually ramp up to my shift to third @ 3400, thinking it is prepping the hpfp for a big pull. Don't know if this is what it does.
Start log, and hold peddle to floor till you hit 6,500. Stop log. My logs are usually less than 6 seconds.
Then, you can analyze your hpfp and see what its up to. Remember you only care about hpfp at WOT.
Sounds like you are on your way - apologies if you already knew some of this stuff, not trying to preach.
Hush is offline   Reply With Quote
The Following User Says NO Thank You to Hush For This Un-useful Post:
jack_hammer (11-19-2012)
 Old 11-19-2012, 10:04 AM   #44
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
oh boy... this is the blind leading the blind. start your logs as low as 2600rpm up to 3000rpm. i know of one guy who goes as low as 2000rpm. set your AP to flash at 6500 so you can watch the road and not your tach. display KR while doing your logs and let off if you see >2.0.
it's not complicated to pull a log and there's lots of info on how to do it properly.
it's fun to do bad things
The Following 2 Users Say Thank You to jack_hammer For This Useful Post:
Easter Bunny (11-19-2012), sidekick (02-13-2013)
 Old 11-19-2012, 10:20 AM   #45
Hush's Avatar
Groans: 156
^ Ouch!
Might want to research that start RPM a little more.
 Old 11-19-2012, 01:19 PM   #46
Groans: 549
^ Ouch!
lol...
Hush (11-19-2012), sidekick (02-13-2013)
 Old 11-19-2012, 01:30 PM   #47
Hush's Avatar
Groans: 156
I still stand by suggestions - 3000 RPM min. - as I have seen my car dip into the 15's when I did a WOT....at 2800 RPM. Once you get some logs under your belt, lower if you want and you are assured hpfp looks safe. Do not see why lower RPM is good, as these cars have monster torque, and mixed with low RPM make a stressed engine.
This is not an e-tune, (yet). Should not need to be anal about KR, but it should not hit above 1.0, watch your logs. Uness you got serious engine issues, on the OTS map, you should only see small numbers infrequently.
I set AP to RPM, alarm at 6,200 as there is an ECU and human delay.
Download for this site: "Abilor's Tuning Guide_V1.0_6_21_2011" very helpful for us noobs....er blind people.
Learn the feel of the car, have fun. Be sure your cane is completly inside the car before closing the door.
Blind guy.
 Old 11-19-2012, 01:49 PM   #48
Groans: 549
Blind guy.
i'm just telling you how to do it right. it's funny that you mention abilor's guide. this is copied from it:
Get her up to speed,and settle into third or fourth gear. From there, you want to FLOOR IT from 2500 RPM to 6500 RPM.
it's whatever this guy wants to do. i don't give a shit. but to tell me i need to "read up" on how to do a data log is laughable because, if you read, you'll see that no one recommends starting at 3400 except for you.
Easter Bunny (11-19-2012), Hush (11-19-2012), sidekick (02-13-2013)
 Old 11-19-2012, 02:02 PM   #49
Hush's Avatar
Groans: 156
Does...not...have...hpfp...internals....
 Old 11-19-2012, 02:11 PM   #50
Please stop giving advice until you know what you are talking about
Hush (11-19-2012), jack_hammer (11-19-2012)
 Old 11-19-2012, 02:24 PM   #51
Hush's Avatar
Groans: 156
Rides into sunset....
Its all yours.
The Following User Says Thank You to Hush For This Useful Post:
 Old 11-19-2012, 02:37 PM   #52
HardHitter's Avatar
Ok guys, let's just keep this on topic. Really do appreciate all of your knowledge and help on this.
Anyway, today I spent about 10 minutes and put in my RMM.
First thing I noticed was the "vibrations" at lower RPMs when easing off the clutch. Nothing that is earth shattering and nothing someone should complain about if you're modding cars.
Overall, it seems pretty solid on initial drive.
Car has 230 miles on it now.
 Old 11-19-2012, 07:48 PM   #53
Hush's Avatar
Groans: 156
Nice!
I wish I got the chrome-Molly, but got a scared off by the supposed vibes and did the 70 duro.
Listen to my two new experienced friends, they know tons more than me (like you had any doubt!). And I will refrain for overstepping my very limited knowledge. I just get a little too wound-up, and that can lead to over-confidence. Lesson learned.
Did you get window working again?
 Old 11-19-2012, 07:51 PM   #54
HardHitter's Avatar
Nice!
Windows got working. Followed the instructions in a few posts above and like magic it was working again
The Following User Says Thank You to HardHitter For This Useful Post:
Hush (11-19-2012)
 Old 12-22-2012, 03:19 PM   #55
HardHitter's Avatar
So it's been a while since I've made a post.
I've just been driving the car and enjoying it.
I ended up picking up the SURE Shortcut and Counterweight from a user on here and just got around installing it today. No problems on the install. I sat in the car and went through the shifts and seems slightly different. I haven't driven the car yet, but maybe I expected shorter shifts then what it is now.
Car now has close to 600 miles
Here are some pics
Hush (12-23-2012)
 Old 12-23-2012, 07:15 PM   #56
galens47's Avatar
Posts: 1,616   (View Stats)
galens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the worldgalens47 is the leader of the world
Groaned at 19 Times in 10 Posts
Looks nice! Good job on your mod plan.
Cheers,
G
Sent from my sortasmart HTC
2008 Toyota Prius Grand Touring. Slow, no mods. Saving $600/month - Fuck off you judgmental Assholes. I miss the fuck out of my speed3 way more than the mustang. Alas I'm waiting for the next one.
2014 Mustang GT Premium, Deep Impact Blue. Boss 302 Steering wheel (Alcantara), SR Shift bracket, Roush Axelback -sold
2010 ms3 Black Mica Tech Package -sold
Internals are easy. Who the fuck thought it would be a good idea to point the genjuan's valve cover recirc tube at the EGR?
“It is the mark of an educated mind to be able to entertain a thought without accepting it.” --Aristotle
galens47 is offline   Reply With Quote
 Old 12-31-2012, 01:49 PM   #57
HardHitter's Avatar
Nothing new for the Mazdaspeed3, but I got something nice for Christmas that will benefit all my cars.
Santa brought me some nice race ramps. I was worried about "low profile" cars not being able to get up on the ramps. I tested it with my Miata and I had no problem at all. I am pretty amazed at how high this thing is able to get the car off the ground. Easy DIY oil changes now.
jack_hammer (01-04-2013)
 Old 01-01-2013, 06:48 AM   #58
MazdaBoy2.3's Avatar
Posts: 5,797   (View Stats)
Groans: 51
Nice ramps. I need a garage...
 Old 01-01-2013, 02:10 PM   #59
ImGryssLOL's Avatar
Posts: 783   (View Stats)
ImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the worldImGryssLOL is the leader of the world
Nice ramps!
If you ever need help with any installs I am just up the 880.
We got our cars a few days apart. I just hit 1500 miles and I'm trying to get bolted and tuned by 3k! Just waiting for shit to come in at this point.
Good luck with the build.
Darthspeed3 likes this.
2013 CWP W/ Tech" LS/VTEC swap running 9's
ImGryssLOL is offline   Reply With Quote
The Following User Says Thank You to ImGryssLOL For This Useful Post:
 Old 01-01-2013, 09:11 PM   #60
Darthspeed3's Avatar
Posts: 292   (View Stats)
Darthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the world
Originally Posted by ImGryssLOL View Post
Nice ramps!
ls/vtec....haha watch your nos timing. nice sig.
Gen1 - Built and sleeved block, some headwork, Gen2 6266, FJ turbo kit, JMF with PI.
Darthspeed3 is offline   Reply With Quote
 Old 01-04-2013, 09:26 AM   #61
Groans: 549
Originally Posted by HardHitter View Post
Here are some pics
there's no way i would have installed those rusted ass bolts on my car.
 Old 02-13-2013, 12:39 AM   #62
HardHitter's Avatar
Well it's been a while since I've updated this thread because I haven't done much with the car.
Just passed 1000 miles on the car the other day.
Looking to pickup internals and maybe go after some suspension depending upon my tax returns.
 Old 02-13-2013, 11:22 AM   #63
90210's Avatar
Posts: 271   (View Stats)
90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world90210 is the leader of the world
Are you driving up on those ramps, or jacking car and putting ramps under?
90210 is offline   Reply With Quote
 Old 02-13-2013, 11:30 AM   #64
HardHitter's Avatar
You push the ramps to your wheels and then you get in your car and just drive straight up.
 Old 02-13-2013, 11:34 AM   #65
sidekick's Avatar
Posts: 3,093   (View Stats)
I want a set of those raceramps! I just wish they weren't so expensive. Haha. Glad to see another speed owner in San Jose. Hopefully I'll see you around man.
btw, if you need any help tuning/have any questions about it, feel free to PM me and I'll help you out.
 Old 03-29-2013, 09:20 PM   #66
HardHitter's Avatar
It has been a good while since I last updated the thread. Haven't done much with the car.
I had ordered internals about a month ago but Edge had been on back order for a month. Well they are finally on their way and it should be here tomorrow.
I was bored so I decided to Plasti-dip the emblems and my fog bezels.
It was actually a lot easier than I thought but I'm going to re-do my rear center emblem because some of it peeled off. It got dark so I'm going to have to do it another time.
 Old 04-13-2013, 01:26 PM   #67
HardHitter's Avatar
I can't believe it's already been over 6 months since I bought the car. The car still has around 1700 miles on it and nothing much has changed. I got my internals but haven't had the time to get them installed yet.
It was a good day today, so I took her to get washed and snapped some quick pictures.
Enjoy!
 Old 11-12-2013, 02:13 PM   #68
HardHitter's Avatar
Wow,
it has been a long time since I've done anything to the car. It has been a year since I bought my car and I have just over 3500 miles on the car. Had my first oil change a couple of weeks ago.
I found a great deal on a UR catback system and I spent 2 hours getting it installed today. Surprisingly quiet from the inside as it still sounds stock. When I listen to this video though, it definitely is a lot louder than stock.
Enjoy
SpeedLife (11-12-2013)
 Old 02-13-2014, 11:26 AM   #69
ImGryssLOL's Avatar
Jeez we bought our cars around the same time. I just hit 27,000 miles...
 Old 03-18-2014, 02:28 AM   #70
musclespeed3's Avatar
Posts: 3   (View Stats)
musclespeed3 is an unknown quantity at this point
Wow,
Enjoy
YouTube
Sounds sick any new additions????!!
musclespeed3 is offline   Reply With Quote
 Old 03-18-2014, 11:53 PM   #71
HardHitter's Avatar
No new additions to the Mazdaspeed3. My focus has been on finding a RT/10 Viper.
The car is close to 6000 miles as of today. It'll be getting its second oil change ever this month
 Old 03-19-2014, 07:30 AM   #72
duffman04's Avatar
Posts: 65   (View Stats)
duffman04 has much to be proud ofduffman04 has much to be proud ofduffman04 has much to be proud ofduffman04 has much to be proud ofduffman04 has much to be proud ofduffman04 has much to be proud ofduffman04 has much to be proud ofduffman04 has much to be proud ofduffman04 has much to be proud ofduffman04 has much to be proud of
I've got a 1994 RT/10. I am sure you've looked into things to look out for but going to reiterate the head gaskets. If its a gen1 look out for the paper ones not being changed. Otherwise great cars for the money!
duffman04 is offline   Reply With Quote
 Old 05-18-2014, 11:32 AM   #73
HardHitter's Avatar
Not much work done to the Mazdaspeed3. I've owned the car for almost 2 years and have almost 7,000 miles on it. No problems so far *knock on wood*. Still have those internals that I haven't got around to installing primarily because I've been paying attention to modding this
Hush (05-18-2014)
 Old 05-18-2014, 01:29 PM   #74
duffman04's Avatar
Very nice! Congrats on the purchase. If I was to do it over again I would probably have went with a GTS. The RT/10's are nice but nothing on the road looks like a GTS.
Here is mine (and my nephew)
2013 Mazdaspeed3: CPE Stage 2 RMM, AP, JBR SRI, HTP TIP, Konig Oversteer - 18x8 +35.
2010 Honda Fit Sport: Stock.
1994 Dodge Viper RT/10: Drop in filters with straight tubes, Lemke 3pc hardtop.
1981 Corvette: Slowly became a restomod.
 Old 05-18-2014, 01:48 PM   #75
HardHitter's Avatar
Thanks! I'll end up with a RT/10 someday. Can't beat driving a Viper topless.
 Old 10-23-2016, 12:23 PM   #76
HardHitter's Avatar
Over 2 years since my last update. Pretty crazy. Been daily driving it and it has been a great car but thinking about switching it up for something else (no idea what)
Almost getting close to 30,000 miles on it.
 Old 12-10-2018, 07:43 AM   #77
HardHitter's Avatar
Man, so much has changed from a car perspective haha.
Its now December 2018 and I just passed 33K miles on the car. Since that time I've owned a 1997 Dodge Viper and a 2007 Porsche 911 Turbo as my toy cars. Both of those are sold for now and I am going to be putting my Mazdaspeed3 up for sale as I just bought a RS7 to replace it for the daily driving duties.
The Speed3 has been great, but time to move on.
Tech Package? Dungmaggot Mazdaspeed3/6 General Discussion 10 05-29-2012 10:46 AM
2012 speed3 DDM hid kits for non tech package CornBread Mazdaspeed3/6 General Discussion 5 04-05-2012 07:26 PM
Clock not updating?? - 2012 w/Tech Package TheRealDefman Gen2 MS3 General Discussion 16 03-18-2012 11:58 PM
Tech Package/MID jellowood 2010 MS3 - Car Audio & Electronics 5 02-03-2010 08:03 AM
Page generated in 0.58040 seconds with 33 queries
