> 2010 MS3 - Build Diaries
  • 1 Post By Thor Hammer
 Old 04-27-2018, 04:32 PM   #1
Alex.Marcil's Avatar
Posts: 12   (View Stats)
Alex.Marcil will become famous soon enoughAlex.Marcil will become famous soon enough
Default Its modding time
I bought a Speed3 2012 last mounth and now its time to mod that beauty.
I made a compression test and well, C1=95% C2=95% C3=80% C4=95%.
My mecano tells me to not worry he pretty sure the lost is from carbon dust in a valve.
The car is stock so it will be a long project which is starting right now 🙂
1 mod Mishimoto - oil catch can
2 mod RMM-COBB
3 mod Sprint Booster
4 Bushing and link kit
So what do you guys think i should go next???
My buddy say SF Intake system COBB--AP--Turbo inlet hose COBB--HPFP
Alex.Marcil is offline   Reply With Quote
 Old 04-27-2018, 09:01 PM   #2
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
what would be 100% compression?
94 M
MS6
IS350
 Old 04-27-2018, 09:08 PM   #3
greg08's Avatar
Posts: 480   (View Stats)
take the intake manifold off and walnut blast the shit out of the 3rd cylinder intake valves, make sure they are both closed though
 Old 04-27-2018, 09:40 PM   #4
kTaLgsTo's Avatar
Posts: 566   (View Stats)
Is your mecano Troy Mcclure??
 Old 04-27-2018, 10:31 PM   #5
MSMS3's Avatar
Posts: 2,830   (View Stats)
The car is stock so it will be a long project which is starting right now ��
Attachment 235634
2 mod RMM-COBB
Attachment 235637
Attachment 235636
Attachment 235635
Compression is measured in psi, not %.
If that is a leakdown test, it is measured in % loss. Get us some real numbers.
Your mechanic is probably full of shit.
Cylinder 3 is a trouble spot on our cars and tends to lose compression earlier than the others. While I cannot exclude carbon buildup preventing a valve from closing all the way, the carbon build up is usually on the back of the intake valves, inpeding air flow, and not on the face of the valve or inside the combustion chamber.
Sprint Booster is snake oil. It makes zero extra horsepower, nada, zilch. All it does is remap throttle and pedal position relationship. A simple intake picks up 15-20 hp. Much better investment.
Get a real tune. Even the simple plug and play Hypertech tune I run with intake and downpipe/racepipe with high pressure fuel pump upgrade raises hp about 80 over stock, pretty much maxing out the stock turbo on pump gas.
The Following 4 Users Say Thank You to MSMS3 For This Useful Post:
5doorsoffury (04-29-2018), Alex.Marcil (04-29-2018), Thor Hammer (04-30-2018), Vansquish (04-28-2018)
 Old 04-27-2018, 11:11 PM   #6
greg08's Avatar
The mechanic is probably referring to OEM spec and giving a %
 Old 04-28-2018, 12:43 PM   #7
Police - Grammarhead
Vansquish's Avatar
Those numbers are fairly meaningless without compression (PSI/kPa/bar) numbers.
Attachment 235636
Do NOT install this ^^. It is absolutely worthless, and will not add any performance of any kind to your car. If you want to tune the car, get a proper tuning solution (Cobb AP/Versatuner/etc.)
 Old 04-28-2018, 09:18 PM   #8
No worries i only bought the sprint booster for precision. The real tune is incoming in couple month XD all the intake AP tune hpfp all together But i need to fix my 3rd cylinder and the shop i go is kinda busy soooo
 Old 04-29-2018, 06:31 AM   #9
MSMS3's Avatar
Precision? Waste. Return it, it you can. If you can't, dump it on some unsuspecting idiot. Sorry. Lesson learned. Check here for what works BEFORE making the purchase.
When you get a real tune, it will have its own, correct throttle remapping that matches the choices of the tuner for when and how far the throttle body will open in relation to pedal position based on the tuner's choices for increased boost, fuel, air, and timing advance under different load and operating conditions.
 Old 04-29-2018, 09:01 AM   #10
ok i just read a lot on the sprint booster OMG well im gonna return that shit as soon as i can.Big thanks to you MSMS3 you just saved me 300$
https://outbackjoe.com/macho-diverti...s-it-worth-it/
The Following User Says Thank You to Alex.Marcil For This Useful Post:
MSMS3 (04-29-2018)
 Old 04-30-2018, 01:38 PM   #11
[QUOTE=Alex.Marcil;3143438]I bought a Speed3 2012 last mounth and now its time to mod that beauty.
I ask to my mecanic why he gave me the result in percentage and he told me that he made a leak-down test. So yea leak-down test result are in percentage
Reading results
No engine will have perfect sealing with 0 percent loss. Five to 10 percent loss indicates an engine in great to good running order. An engine between 10 and 20 percent can still run OK, but it’ll be time to keep an eye (or ear) on things. Above 20 percent loss and it may be time for a teardown and rebuild. Thirty percent? Major problems. The percent of leakage should also be consistent across the cylinders. Any great differences indicate a problem in that cylinder.
https://mobiloil.com/en/article/car-...-leakdown-test
MSMS3 (04-30-2018)
 Old 04-30-2018, 02:23 PM   #12
Db09ms3's Avatar
Posts: 536   (View Stats)
Very nice. I've been looking at that Mishimoto Catch Can too. Decent price.
Stockish
 Old 04-30-2018, 02:36 PM   #13
i guy test it on a camaro SS 1LE 2018 and after 1250 miles the catch can had 1/8 cup of oil
https://www.youtube.com/watch?v=vHeWp6jJb5M&t=390s
Db09ms3 (04-30-2018)
 Old 05-16-2018, 08:09 AM   #14
Cobb air intake 3" installation today, cleaning the valves and spark plug denso iridium
 Old 05-17-2018, 07:58 AM   #15
Code p2009 after the install of the cobb intake any idea guys?
 Old 05-17-2018, 11:55 AM   #16
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Not everyone has the codes memorized. It would help tremendously if you described what the code is and what you have done to troubleshoot. Same goes for your other thread with the four codes. We are not magicians. You have to put in some effort here.
Db09ms3 (05-17-2018)
 Old 05-17-2018, 12:05 PM   #17
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
Bro cmon, google that shit. It’s all over this forum you just need to search.
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
 Old 05-17-2018, 01:32 PM   #18
Problem fixed thx to f.castrillo
https://www.youtube.com/watch?v=JymY99T9pKc
yea i gotta push myself. Do the research and stop beign sooo scared of working myself on the car
Last edited by Alex.Marcil; 05-17-2018 at 01:32 PM. Reason: MSF Database - Automerged Doublepost
 Old 05-17-2018, 02:20 PM   #19
Jeff23spl's Avatar
Posts: 2,237   (View Stats)
Humm comparing the blow-by from an n/a V8 to a 2.3T with a 20% loss on #3 ...expect different results lol
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 05-18-2018, 09:24 AM   #20
Groans: 211
You can do it man. Once you fix a few things that challenge you the next one isn't so hard and your confidence will build.
Alex.Marcil likes this.
Alex.Marcil (05-18-2018)
 Old 05-18-2018, 09:59 PM   #21
ive clean the valves and now cylinder 1,2,4 are 95% and the 3rd is 97 % im soooo happy
First Time Modding MS3 07 - Are these craigslist part a good setup? Streetbl Mazdaspeed3/6 General Discussion 16 05-19-2016 03:05 PM
HELP WITH MODDING! Crasth 2010 MS3 - ECU Computer Tuning 27 04-12-2014 10:30 AM
JUST GOT A NEW 08 MS3, MODDING TIME? wes3id Mazdaspeed3/6 General Discussion 11 04-20-2009 04:52 PM
Page generated in 0.41900 seconds with 30 queries
