> 2010 MS3 - Build Diaries
 Old 10-13-2015, 11:26 AM   #81
Shwa's Avatar
Posts: 322   (View Stats)
Sooo....Progress?
 Old 10-13-2015, 12:35 PM   #82
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
Yea some sucky progress. 50 miles into it the cyl 3 rod bearing decided to shit itself. Still tearing down to see what happened.
One huge thing I noticed after pulling the spark plugs was that the ceramic part on top of the plugs were cracked all the way down. EVERY SINGLE PLUG, which screams mishandled to me but I babied them quite a bit so I can not say what happened.The whole build was assembled by me so that may be the issue but I was very OCD about specs, measurements, cleanliness, etc. I washed all parts until my fingers were blistered. I am putting together a parts list to rebuild and started breaking it down this week. Hopefully I will have it back up and running in a couple of weeks. I am going to take a week off from the build because I am expecting my second kid this week.
One last side note, 4 manley h-beam rods with bolts = $360 BUT 1 manley rod and new bolts for the other 3 = $393 (quote from Edge AutoSports). Looks like 3 good manley rods and 1 black one will be up for sale soon LOL. Im just going to have to order a new set of 4.Ill post some pictures later when I get a chance.
 Old 10-14-2015, 09:01 AM   #83
Shwa's Avatar
Congratulations on the little one, that'll take some time from the build understandably. Or not, we need numbers
What a bummer. Best of luck putting it back together man. This sort of thing makes me want to sacrifice a small Asian child and drink unicorn blood to keep my stock block healthy for as long as possible.
Makes sense, just lame for the buyer.
The Following User Says Thank You to Shwa For This Useful Post:
jdmage_mx5 (10-14-2015)
 Old 10-18-2015, 06:26 PM   #84
jdmage_mx5's Avatar
Found the problem and there is no one to blame but myself. Thankfully tokay caught it quick in another thread. I installed the rod cap backwards like an idiot. So Wednesday I'll finish the break down and clean up then start the rebuild process. I was so worried about other things that I smooth glazed over that part of the install I guess.
Picture of butchered bearing next to a good bearing.
The Following 4 Users Say Thank You to jdmage_mx5 For This Useful Post:
btstarcher (10-18-2015), Easter Bunny (10-19-2015), Pu Manchu (10-18-2015), Shwa (10-18-2015)
 Old 10-18-2015, 08:02 PM   #85
btstarcher's Avatar
Posts: 4,852   (View Stats)
It happens. Just sucks that it happened to you.
Sent from my XT875 using Tapatalk
SnailTune in progress
 Old 10-18-2015, 08:12 PM   #86
jdmage_mx5's Avatar
You live, you learn. No one to blame but myself. Hopefully I will be up and running again soon.
 Old 10-18-2015, 08:46 PM   #87
nojjy's Avatar
Posts: 238   (View Stats)
nojjy is the leader of the worldnojjy is the leader of the worldnojjy is the leader of the worldnojjy is the leader of the worldnojjy is the leader of the worldnojjy is the leader of the worldnojjy is the leader of the worldnojjy is the leader of the worldnojjy is the leader of the worldnojjy is the leader of the worldnojjy is the leader of the world
You'll be back up and running in no time, if not, can i have your exhaust manifold?
GTX3071R IWG, HTP 3.5" Cs cbe, jbr 80 duro trilogy, autotech internals, cp-e tmic and DP.
E33 Freektune 387 hp, 366 lb/ft .
nojjy is offline   Reply With Quote
The Following User Says Thank You to nojjy For This Useful Post:
jdmage_mx5 (10-18-2015)
 Old 10-18-2015, 09:43 PM   #88
jdmage_mx5's Avatar
Thats not funny!
 Old 10-18-2015, 09:47 PM   #89
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
most guys go out of their way to avoid blaming themselves, you got a bright future.
94 M
MS6
IS350
The Following User Says Thank You to Pu Manchu For This Useful Post:
jdmage_mx5 (10-19-2015)
 Old 10-18-2015, 09:59 PM   #90
jdmage_mx5's Avatar
At 30 years old and tons of screw ups in my life, I have learned to accept fault when it is mine and use it as a lesson on how NOT to do something.
 Old 10-19-2015, 09:54 AM   #91
jdmage_mx5's Avatar
Well good news, I sourced the rod bolts after comparing specs on ARP site. If anyone needs to order new rod bolts the part number is 200-6207. I should have all of my parts ordered this week and start the rebuild next week.
The Following 3 Users Say Thank You to jdmage_mx5 For This Useful Post:
Boost_creep (10-19-2015), btstarcher (10-19-2015), Shwa (10-19-2015)
 Old 10-19-2015, 01:00 PM   #92
Shwa's Avatar
Good news. Best of luck with the rebuild
 Old 10-19-2015, 01:04 PM   #93
btstarcher's Avatar
Let me know if you need an extra set of eyes. I'm assuming you're going by the book, following step-by-step?
 Old 10-19-2015, 02:33 PM   #94
jdmage_mx5's Avatar
Thanks, yep page by page. I was just an idiot on this one thing. Tis life I guess. Everything else is fine. And honestly every thing mic as it should so honestly I would probably be sitting at 1000 miles had I not made this one dumb mistake.
btstarcher (10-19-2015), nojjy (10-19-2015), Shwa (10-20-2015)
 Old 11-14-2015, 04:11 PM   #95
nojjy's Avatar
So, updates?
 Old 11-15-2015, 08:24 AM   #96
jdmage_mx5's Avatar
So far so good. Have about 120 miles on re-rebuild. Everything is running good. I'll drive it normal until 1000 miles, if all is still well then tuning will start.
btstarcher (11-17-2015), nojjy (11-17-2015), Pu Manchu (11-15-2015), Shwa (11-15-2015)
 Old 12-14-2015, 06:10 AM   #97
jdmage_mx5's Avatar
I had a couple of free minutes this morning so that's a perfect time to update the tread.
Car is running good and is at 550 miles (it's taking forever to hit 1000). I started working on rerouting my cold pipe and radiator hose for the newest addition. I will be installing this week a Snow Performance Stage 2 kit with a MD throttle plate (cooling and octane boost) as well as a Kozmic 5th/6th port kit (for fueling).
I'm also in the process of breaking in new MD side mounts and cleaning up the install of the AEM AFR/boost failsafe gauge.
Pictures to come soon.
TRBLSM likes this.
btstarcher (12-14-2015)
 Old 12-16-2015, 11:09 PM   #98
jdmage_mx5's Avatar
Getting ready for some extra fuel. Kozmic 5th/6th port kit and Snow Performance nozzle #6 . I had a local welder tig the boss onto my already existing cold pipe
I was able to basically turn the whole cold pipe backwards which moved the BPV closer to the intercooler quite a bit, and after reversing the radiator hose ends I am completely clear of that also I'm pretty satisfied with the way the piping ended up. Installed pictures should be posted this weekend or shortly after.
Boost_creep (12-17-2015), btstarcher (12-17-2015), Shwa (12-17-2015)
 Old 12-20-2015, 06:29 PM   #99
jdmage_mx5's Avatar
Started the installation process today. Got the meth lines safely ran and tied up. All the intercooler piping rerouted. And started the wiring.
Also not shown is a short box style structure I made to protect the meth tank and pump from objects that will get thrown in the hatch. I sprayed it with a rubberized spray paint (think fender wells, not plastidip). ImageUploadedByTapatalk1450661337.735355.jpgImageUploadedByTapatalk1450661357.360714.jpg
TRBLSM likes this.
Easter Bunny (12-21-2015)
 Old 12-21-2015, 08:41 AM   #100
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
why are you running 5th port + meth ? Do you not have an E85 station handy?
I personally would love to dump my WMI but don't want to spend the money/time/effort to get a 5th port up an running.
 Old 12-21-2015, 09:42 AM   #101
jdmage_mx5's Avatar
Figured it couldn't hurt. I already had the meth kit when I found a good deal on the 6th port. Meth will be backup, cooling, and octane boost.
We bought the wife a new CX-9 so I migrated over to driving our Kia Sportage as a daily.
 Old 12-21-2015, 11:48 AM   #102
Trail of Fail
Dano's Avatar
O I C, looks like a fun project.
 Old 02-19-2016, 07:38 AM   #103
Boost_creep's Avatar
Posts: 829   (View Stats)
Updates?
Bullet Bitten, wallet empty. GTX3076R project begins Chimmike MazdaSpeed 3/6 - Big Turbo Builds 102 10-13-2011 06:25 AM
Saab aims at its core N.A. customer's heart, brain and wallet Haltech Automotive News 0 07-07-2011 10:00 PM
Barrett-Jackson 2011: Grab your wallet for a Grabber Blue Boss 302 Haltech Automotive News 0 01-22-2011 08:10 PM
Page generated in 0.42985 seconds with 27 queries
