> 2010 MS3 - Build Diaries
Like Tree49Likes
 Old 06-19-2015, 06:15 AM   #121
when in doubt....
MS3XY's Avatar
Posts: 225   (View Stats)
MS3XY has a reputation beyond reputeMS3XY has a reputation beyond reputeMS3XY has a reputation beyond reputeMS3XY has a reputation beyond reputeMS3XY has a reputation beyond reputeMS3XY has a reputation beyond reputeMS3XY has a reputation beyond reputeMS3XY has a reputation beyond reputeMS3XY has a reputation beyond reputeMS3XY has a reputation beyond reputeMS3XY has a reputation beyond repute
@Putin 2.3T;
I absolutely love the purple turbo, good choice!
Realgib3 and Putin 2.3T like this.
MS3XY is offline   Reply With Quote
 Old 07-04-2015, 10:45 AM   #122
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
File Type: jpg 11705304_10153080623476775_7327382998389050914_n (1).jpg (50.5 KB, 790 views)
PUGENE and Putin 2.3T like this.
The Following 7 Users Say Thank You to aaronc7 For This Useful Post:
Easter Bunny (08-09-2015), Mauro_Penguin (08-10-2015), MS3Shadow (08-10-2015), NCspecV81 (07-04-2015), PUGENE (07-31-2015), Putin 2.3T (07-08-2015), WetzMS3 (08-10-2015)
 Old 08-09-2015, 05:37 PM   #123
Putin 2.3T's Avatar
Posts: 1,040   (View Stats)
Surely he shall and he has! I have an update... the build is getting shut down. I'm moving on with another project that has had my attention for a while now.
I finally finished the fuel setup. I went with an ATL Well Cell in the 12 gallon variety for the rear with a Radium Engineering Fuel Cell Surge Tank system. I will be using three AEM 50-1200 E85 pumps. One for a feed for the surge, and two to feed the PI. Each one of these fuel pumps is good for around 700-750hp. Pictures will be coming up as soon as I have it arrive. For the moment the fuel cell mounts will not be very.. special. Budget cuts and time constraints have forced me to move with using tow-straps, haha! Ghetto as it may be, it WILL hold. I assure you of that. When I get a little more money I will go with something a little more fancy.
- Along with this comes the change to the FPR setup. All the components remain, but I've decided to go returnless to keep the system a little simpler. By returnless I mean that the FPR will be mounted at the rear with the fuel cell. A singular -8an line will feed the fuel injectors. No fuel will return from the fuel rail. I will have a gauge in the back with the FPR and a digital gauge up front to ensure that the pressures are good. This also means the FPR will be run static. With the Bosch 2200cc injectors @ 43.5psi, they are MORE then enough to feed not only the PI but also the entire motor safely to 700+hp.
I've also decided to go with an Odyssey PC680 battery and relocating the battery into the front fender wheel well. No real specific reason for that other then to allow the 4.5" intake that is being fabricated by (censored due to outside non-vendor) to have some room to breathe. On top of that I'll be using the current battery tray (JBR) to mount my BWR VTA Oil-Catch can. Should look pretty bitching once I get everything set up and ready.
Pictures coming soooooon..
2011 Mazdaspeed 3 [Sold]
The Following 7 Users Say Thank You to Putin 2.3T For This Useful Post:
aaronc7 (08-09-2015), Easter Bunny (08-09-2015), GARRETHEXTREME (08-09-2015), ItsNox (08-10-2015), Mauro_Penguin (08-10-2015), TRBLSM (08-09-2015), WetzMS3 (08-10-2015)
 Old 08-09-2015, 06:13 PM   #124
You probably know this but you need to look at net fuel pressure. Ie if boost is 30 and fuel pressure is 45 you only have a differential of 15 psi across the injector.
 Old 08-09-2015, 07:36 PM   #125
Putin 2.3T's Avatar
I did think about it briefly, but must have passed it off for another more pressing issue. Not a hard fix, just means I've either gotta run a 3an line under my car to the manifold, or move the FPR up front and run a 6an line under the car for a return. Both are do'able. I originally decided on static because the system would be turning on only at WOT. Rising-rate is best when the fuel system needs to adjust between vacuum-boost at whatever load. But now that I think about it, even if I were to increase the fuel pressure to overcome the added boost pressure, it would still leave my fuel setup in a level of unpredictability that I want to avoid. Particularly when coming in to boost where it might see 60+psi of fuel but only 5-10psi of boost. At that point it would be rich as high hell up until when the boost builds. Sure that additional fuel could be tuned out via the DI injectors, but why make it harder on my tuner? Right? Haha!
The Following User Says Thank You to Putin 2.3T For This Useful Post:
 Old 08-09-2015, 07:39 PM   #126
865ms3's Avatar
Posts: 2,602   (View Stats)
But then my issue...all these horsepowers but no traction.
What's your plan there? I'm getting tires asap.
Brent
-Built Block-5858-Meth
Dragon Slayer Setup
FreekTuned
 Old 08-09-2015, 07:55 PM   #127
Putin 2.3T's Avatar
Scroll back a ways in the thread, I think I have some M&H's pictured. Those should solve my problems. For D/D I'm planning to run 255-wide R888s.
The Following 4 Users Say Thank You to Putin 2.3T For This Useful Post:
865ms3 (08-09-2015), impossible (01-18-2016), Mauro_Penguin (08-10-2015), tastysi2004 (08-09-2015)
 Old 08-10-2015, 01:09 PM   #128
Realgib3's Avatar
Posts: 2,443   (View Stats)
So your 12 gal cel is going to be feeding both DI and PI injectors then correct? Like you're replacing you stock tank with this fuel cell, mounted in the spare tire well?
 Old 08-10-2015, 01:15 PM   #129
Putin 2.3T's Avatar
That is the end goal. Because of time, it will just be feeding PI for now.
 Old 08-10-2015, 01:31 PM   #130
Realgib3's Avatar
Shouldn't require much more time to start out that way and won't cost more either.
Mount your regulator in the hatch, near the fuel cell. Then, run -8 from cell to one port on the reg, -6 from 2nd port on reg back to the cell as your return line, then run a vac line and one, -8 line to the surge, then from the surge to the passenger side of your secondary rail, then -8 to your HPFP.
This will keep it as a return setup, only makes you have to run one line to the front of the car, and allows you to run the proper 1:1 boost ref on the regulator.
The only thing you'll have to figure out either way is if you want your pumps to be all fancy and wired in with relays and everything or if you just wanna put them on switches to start. If you decide on the switched option to start, I'd put your primary (to surge tank) and one secondary on a keyed 12v, which will turn on and run under normal driving, then put your other secondary on a hobbs switch to turn on once you're under some boost.
Again, shouldn't take any more time or money to do it all this way and it'll be much better than running two very large fuel tanks, a dead head rail, and a static regulator.
ItsNox and Putin 2.3T like this.
The Following 4 Users Say Thank You to Realgib3 For This Useful Post:
865ms3 (08-10-2015), Easter Bunny (08-10-2015), Mauro_Penguin (08-10-2015), Putin 2.3T (08-10-2015)
 Old 08-10-2015, 01:49 PM   #131
Putin 2.3T's Avatar
Sounds so easy! Lol! My only issue would be finding a way to attach a -8an line to the low-pressure fuel line on the HPFP. Another issue is that I plan to run 100% M5 in the fuel cell. I don't know how well the HPFP internals will like that stuff. I was going to experiment after the motor was in and running.
 Old 08-10-2015, 07:10 PM   #132
Realgib3's Avatar
Well yeah if you're planning on running meth to the secondaries then yeah you'll always have to have both tanks.
As for the hpfp, you just get a fuel line to -8 adapter fitting. This is exactly how I've run my systems in the past.
The Following 2 Users Say Thank You to Realgib3 For This Useful Post:
Mauro_Penguin (08-20-2015), Putin 2.3T (08-10-2015)
 Old 08-12-2015, 09:34 AM   #133
Putin 2.3T's Avatar
The only question I have in my mind right now is... why didn't I buy this sooner? Radium Engineering for the freakin' win!
The Following 3 Users Say Thank You to Putin 2.3T For This Useful Post:
Mauro_Penguin (08-20-2015), WetzMS3 (08-19-2015), Yatta (08-12-2015)
 Old 08-12-2015, 11:37 AM   #134
Pictar is broken.
 Old 08-12-2015, 11:41 AM   #135
Putin 2.3T's Avatar
Fixed, I hope.
 Old 08-12-2015, 11:49 AM   #136
England15j's Avatar
Posts: 1,910   (View Stats)
Fancy
 Old 08-12-2015, 01:34 PM   #137
ItsNox's Avatar
Posts: 3,076   (View Stats)
Its beautiful!
'06 Mazdaspeed 6 GT
- Miltuned
Georgia Motherfucking Nator
 Old 08-17-2015, 02:18 PM   #138
865ms3's Avatar
when is this going to be done??? dammmmnnnnn
can we post cats yet??
i like seeing your progress on this crazy build. keep it up.
Brent
Dragon Slayer Setup
FreekTuned
The Following 2 Users Say Thank You to 865ms3 For This Useful Post:
Easter Bunny (08-18-2015), Mauro_Penguin (08-20-2015)
 Old 08-17-2015, 02:20 PM   #139
Putin 2.3T's Avatar
I don't know man. Compared to a lot of the other crazy builds on here, I'd say mine is pretty mild.
The Following 2 Users Say Thank You to Putin 2.3T For This Useful Post:
865ms3 (08-17-2015), Mauro_Penguin (08-20-2015)
 Old 08-19-2015, 08:22 AM   #140
Quit playing around and get that dyno queen rolling, Russian!
Mauro_Penguin and Putin 2.3T like this.
Easter Bunny (08-19-2015), Mauro_Penguin (08-20-2015), monkey.bones.007 (08-19-2015), Putin 2.3T (08-19-2015)
 Old 08-20-2015, 01:31 PM   #141
England15j's Avatar
I demand a update to your madness
 Old 08-20-2015, 02:00 PM   #142
Putin 2.3T's Avatar
 Old 09-25-2015, 06:59 AM   #143
speed3 britz's Avatar
Posts: 1,155   (View Stats)
So Uh... why the part out...?
The Following User Says Thank You to speed3 britz For This Useful Post:
maisonvi (09-25-2015)
 Old 09-25-2015, 07:09 AM   #144
@Putin 2.3T; going for his 1,000hp goal:
The Following 11 Users Say Thank You to WetzMS3 For This Useful Post:
Easter Bunny (09-25-2015), impossible (11-24-2016), InkedInspector (09-25-2015), maisonvi (09-25-2015), Mauro_Penguin (09-25-2015), MS3Shadow (09-25-2015), NCspecV81 (09-25-2015), Pu Manchu (09-25-2015), sh4d0w (09-25-2015), sho (09-25-2015), speed3 britz (09-25-2015)
 Old 09-25-2015, 07:23 AM   #145
Police
InkedInspector's Avatar
Groans: 312
Can't believe this project got aborted. Third trimester style.
The Following 6 Users Say Thank You to InkedInspector For This Useful Post:
Easter Bunny (09-25-2015), Mauro_Penguin (09-25-2015), MS3Shadow (09-25-2015), NCspecV81 (09-25-2015), speed3 britz (09-25-2015), WetzMS3 (09-25-2015)
 Old 09-25-2015, 08:22 AM   #146
pirate steve's Avatar
Posts: 248   (View Stats)
pirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the worldpirate steve is the leader of the world
Putin's got to pay for that military aid he's giving to Syria somehow.
Easter Bunny and MS3Shadow like this.
2011 grey MS3: HTP TIP, COBB SRI, HPFP internals, CS TMIC, Dammond EGR delete, Dammond OCC, M2 full DP all of the cats deleted, freektune OTS+, denso ITV22, Maisonvi turbo bolt, CP-e S2 RMM
pirate steve is offline   Reply With Quote
The Following 4 Users Say Thank You to pirate steve For This Useful Post:
Easter Bunny (09-25-2015), InkedInspector (09-25-2015), Mauro_Penguin (09-25-2015), MS3Shadow (09-25-2015)
 Old 09-25-2015, 12:31 PM   #147
Putin 2.3T's Avatar
The ruble has tanked. I'm not in a very stable situation financially, so had to think smart. The Syrians are cheap bastards. I gave them top of the line weapons and they pay me with cash and herd animals. What use do I have for herd animals? The goats look very used.
The Following 5 Users Say Thank You to Putin 2.3T For This Useful Post:
Easter Bunny (09-25-2015), impossible (01-18-2016), InkedInspector (09-25-2015), Mauro_Penguin (09-25-2015), pirate steve (09-25-2015)
 Old 09-25-2015, 12:36 PM   #148
skoski17's Avatar
Posts: 1,235   (View Stats)
It's those muslims! Get rid of them and your goats will not be abused anymore
Too much for you
skoski17 is offline   Reply With Quote
 Old 09-25-2015, 01:32 PM   #149
MSP611's Avatar
Posts: 2,291   (View Stats)
what happened @Putin 2.3T; ???
In progress:
 Old 01-18-2016, 05:53 PM   #150
impossible's Avatar
Posts: 733   (View Stats)
Groans: 30
Sucks to see things didn't pan out due to financial constraints.. This was gonna be a godly build :/
skoski17 likes this.
 Old 02-27-2019, 11:22 PM   #151
bimbybugz's Avatar
Posts: 4   (View Stats)
bimbybugz can only hope to improve
How did you route your hoses from your fuel cell? I have mine like this but having a hard time figuring it out lol.
bimbybugz is offline   Reply With Quote
 Old 03-01-2019, 03:39 PM   #152
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Quoting these necro posts most likely....99% chance.....will go un-noticed by the OP. Good luck!
 Old 03-01-2019, 10:08 PM   #153
aaronc7's Avatar
Groans: 370
andale927 (03-02-2019)
Dartz Red Russian is a Putin-spec Mercedes G63 AMG 6x6 Haltech Automotive News 0 06-10-2014 08:30 AM
Vladimir Putin's all-Russian limo revealed Haltech Automotive News 0 05-08-2014 11:40 AM
Russian PM Putin reportedly tells Renault to put up or get out Haltech Automotive News 0 10-26-2009 04:00 PM
Putin Power: Even Russian automakers to get a bailout? Haltech Automotive News 0 03-31-2009 04:50 PM
Page generated in 0.51846 seconds with 37 queries
