> 2010 MS3 - Build Diaries
  • 1 Post By pwdunmore
 Old 07-17-2013, 09:06 AM   #1
pwdunmore's Avatar
Posts: 368   (View Stats)
Default pwdunmore's 2012
So I finally decided to make a build thread after owning and being on here for 1 year... guess it’s better late than never!
Cliff notes:
2012 MS3
Autotech internals
Cobb AP
Forge BPV V2
JBR 3'' WP
CP-e TMIC
CP-e catted DP
Custom 3'' Exhaust
SP Stage 2 MAF Meth kit
JBR EGR delete + Coolant Bypass + TB TIG
JBR 88a Fully mounted
JBR SSB+ Shifter counter weight
17'' RPF1's with Toyo Proxe T1's 245/40/17's
315 HP 350 TQ
I got the car last April after I graduated college as my own present to myself (to help me get back and forth from my new job) It was a demo so it had 14,000km’s on it and all stocked out.
First mod was the shifter stuff, bushings and the SSP + heavy shifter from JBR. I am back to the stock shifter with the JBR shift weight which I like the feel of way more than the SSP, it just wasn’t for me, as the feel for the shifts weren’t ribbed for her pleasure.
After that I put in the RMM (JBR 88a) and got myself an AP which made life a crap load of fun!
Ordered an OCC after talking to Mspeed here in Toronto and installed it shortly after, it is exactly like the damond kits and has a nice check valve with it too.
Then came the intake...
1st intake K&N... meh
2nd intake 3.5 JBR... stock battery made everything rub (stock BPV rubbed so I got a forge v2 and it still skimmed it a bit and battery box rubbed the intake like crazy) so which I didn’t like either
3rd intake cobb... did the job but I wanted some headroom for power
4th and final intake JBR 3’’... Amazing build quality and great fitment, plus it could be used for a BNR down the road.
Then came the black Friday sale at edge so I bought myself the CP-e TMIC + DP + Autotech internals.
All of that went in with a bit of a struggle with the downpipe just because the oxygen sensor being a stubborn bitch and wiggling under a car with only a foot of clearance. So 12hours later all of those were installed and let the no traction mods begin lol...
I was really happy with this set up but as we all know when the mod bug bites it goes balls deep, which led to my custom 3’’ exhaust lol. One problem with it was the mid body brace vibrating where the resonator was so I had to get the shop to modify the fit and press the brace a tiny bit to make some clearance. Lots of people get this issue with the larger piping causing less clearance, plus our engine rocks back and forth like a mofo without side mounts.
You can probably tell where I am going with this... so I ordered the 88a JBR sidemount package along with EGR delete and coolant bypass/throttle body TIG. Those made the car feel amazing... I would recommend these to anyone who wants no wheel hop.
Then traction became a slight issue with the crappy stock tires and I wasn’t even tuned yet... Ordered some RPF1’s 17 x 9 45+offset, SPC adjustable camber arms and Toyo Proxe T1 tires which are pretty awesome since I didn’t want to pay the big bucks for Michelins.
Currently I am getting my Snow Performance MAF meth kit all hooked up so I can finally go for a tune to see what number she is gonna turn out!
I just wanted to thank everyone on here for all the knowledge that has been contributed over the years. Learning the way of the MSFer has been my calling for a long time lol.. glad I found this place and all you assholes
Hopefully I will get the tune soon so I can post up some numbers (just have a good MAF cal for now sitting at 0% - 0.8% LTFT, targeting 11.8 AFR WOT) but here are some pictures for now.
Stock:
K&N(didn't bother to put the heatshield because my OCC was easier to accesss):
JBR 3.5'':
Cobb intake (TMIC + DP installed):
JBR 3'' WP Full intake:
Valence Plastidipped + Rally Armor Mudflaps:
Custom Exhaust installed:
Meth Bracket: (ordered a remote filler spout from flambeaufluids so I can fill this easier)
Winter Rims without my winter tires:
Tires + Rims(summer):
The Following 4 Users Say Thank You to pwdunmore For This Useful Post:
cymen (07-17-2013), Mr Wilson (07-17-2013), rfinkle2 (07-17-2013), Thrizzl3 (07-17-2013)
 Old 07-17-2013, 12:18 PM   #2
Thrizzl3's Avatar
Posts: 147   (View Stats)
Thrizzl3 is the leader of the worldThrizzl3 is the leader of the worldThrizzl3 is the leader of the worldThrizzl3 is the leader of the worldThrizzl3 is the leader of the worldThrizzl3 is the leader of the worldThrizzl3 is the leader of the worldThrizzl3 is the leader of the worldThrizzl3 is the leader of the worldThrizzl3 is the leader of the worldThrizzl3 is the leader of the world
sweeeeet
2007 Black Mica MS3 - CP-e Nano SRI, CP-e TIH, CP-e HPFP, CP-e catted DP, CP-e RMM 75A, Saikou Michi oil catch can, TRZ TMM, JBR RSB, JBR PMM 80A, Mspeed Stuff, Cobb AP, Cobb XLE BPV, Cobb FMIC V2, Gold 17x9 Enkei RPF1, Hankook RS-3 255/40/17, DBA 4000 slotted rotors, Motul RBF600 brake fluid, Rotella T6 Engine oil, Prosport Boost/Oil temp/Pressure gauges, Other Assorted Rice...
Thrizzl3 is offline   Reply With Quote
 Old 07-24-2013, 01:05 PM   #3
pwdunmore's Avatar
Meth installed, added a How-to and pictures.
How to: Methanol Install (SP meth kit)
 Old 07-24-2013, 07:18 PM   #4
pwdunmore's Avatar
Tune is done! 315HP 350 TQ (rounded totals because we always like to round up!)
I would like the thank Mspeed for all the help and support over the last 1.5 years. I am really happy with the results and the drivability it's amazing for a little go-kart
Maybe BT will go in once the K04 has had it or I have had it of the K04 lol...
Mod List:
JBR Solid Shift bushings
JBR Shifter Weight
JBR 88A Rear Motor Mount
JBR 88A Transmission Mount
JBR 80A Passenger Side Mount
JBR 3'' WP Silicone Intake
Cobb AccessPort
Saiko Oil Catch Can (Mspeed version)
Autotech internals
Cp-e TMIC
Cp-e 3'' Downpipe
Custom 3'' Exhaust
Snow Performance Stage 2 MAF Methanol Injection
Denso ITV22's
The Following 3 Users Say Thank You to pwdunmore For This Useful Post:
Fobio (07-24-2013), MS3CB (08-08-2013), Thrizzl3 (07-24-2013)
 Old 08-14-2013, 11:58 AM   #5
john.e.stoner's Avatar
Posts: 172   (View Stats)
john.e.stoner is the leader of the worldjohn.e.stoner is the leader of the worldjohn.e.stoner is the leader of the worldjohn.e.stoner is the leader of the worldjohn.e.stoner is the leader of the worldjohn.e.stoner is the leader of the worldjohn.e.stoner is the leader of the worldjohn.e.stoner is the leader of the worldjohn.e.stoner is the leader of the worldjohn.e.stoner is the leader of the worldjohn.e.stoner is the leader of the world
How early did you go with a Cp-e TMIC (in relation to your other mods) and do you plan to go FMIC? With these mods do you notice a lot of heatsoak with the TMIC?
2013 Speed 3 w/ Tech Package. built long block/BNRS3 - no dyno yet on new set-up
Before zzb: 282 HP / 330 lb·ft torque - Absolute Proformance 4 OCT 13
Sent While Stratified
john.e.stoner is offline   Reply With Quote
 Old 08-14-2013, 12:23 PM   #6
pwdunmore's Avatar
I went TMIC when I got my DP, did them both at the same time and flashed a stage 2 OTS map.
There is heat soak in stop and go traffic(+20 degrees ambient atleast) but as soon as I start moving the BATs drop and with the meth it dips even more once I go into boost. (BAT and IAT are almost the same when WOT)
I probably get more power from the TMIC + meth than from just a FMIC alone.
FMIC + meth would be ideal but I already had a TMIC when I decided to get meth. And for the K04, I am sure the TMIC and meth is plenty.
That being said, if I have $1000 laying around I would get a FMIC (cobb) that didn't need me taking out/modifying the crash bar.
 Old 08-14-2013, 12:26 PM   #7
Cool. I don't think I want to do Meth. I put a ton of miles on my car. Guess I'll see how happy I am once I get the AP and tuning done (soon!, should be here any day!). I am thinking of sticking with slightly larger TMIC....so many mods, and I didn't win the powerball! lol
 Old 02-06-2017, 11:27 AM   #8
pwdunmore's Avatar
Sold the MS3 last week because I needed something better on gas to drive for work... got a little slow turd... sorry guys
No plans for it as it will be my winter car and maybe a secondary. I still have the MS6 and don't intend on selling it, as it is my summer fun car but we all know they like to visit the mechanic.
My car thread:
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f542/pwdunmore-s-2012-a-150456/
pwdunmore's 2012 Mazdaspeed3 - Page 6 This thread Refback 07-17-2013 09:26 AM
2012 Mini Cooper S Roadster vs. 2012 Mazda MX-5 Miata Special Edition Haltech Automotive News 0 08-22-2012 10:30 AM
Comparo: 2012 Hyundai Genesis Sedan vs. 2012 Chrysler 300S [w/video] Haltech Automotive News 0 02-29-2012 10:30 AM
2012 Ford Focus ST vs 2012 Mazdaspeed 3 Fantasma Gen2 MS3 General Discussion 165 11-24-2011 10:31 PM
Official: 2012 Volkswagen Passat named Motor Trend 2012 Car of the Year Haltech Automotive News 0 11-16-2011 01:50 PM
2012 civic si vs 2012 mazdaspeed3 ms6zoey Mazdaspeed3/6 General Discussion 7 09-29-2011 08:00 PM
Page generated in 0.33106 seconds with 22 queries
