> 2010 MS3 - Build Diaries
Like Tree26Likes
 Old 10-04-2015, 07:58 PM   #1
Ziggyboy's Avatar
Posts: 239   (View Stats)
Ziggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the world
Default Ziggyboy's BNR S4 Build
So as most of you know the S4 is on its way to mazdaspeed homes next week. I was one of those people who couldn't wait for dyno sheets and info before dropping the money to RPM during the preorder sale. While I eagerly await its arrival, I decided to start my build thread that will take place over the winter due to my speed3 being a summer car only. I welcome any advice on parts or ideas towards the build, you guys are the experts so lets drop all the info we can. At this time I plan on staying stock block so lets keep that in mind so you guys don't talk me into a full motor build.
Lots of pictures to come throughout the build.
White Genpu
Miles 20,5xx
Current parts-
Purple Drank Tune
Speed Perf6rmanc3 Aux Fan Controller
Tanabe Front Strut Tower Bar
CPE Top Mount Intercooler (Sold)
Resonator Delete
Corksport Race Pipe (Sold)
Corksport Fuel Injector Seals
Prosport 52mm Halo Boost Gauge
Cobb Shift Knob
Cobb Rear Motor Mount
Cobb Air Box (Sold)
Cobb Short Ram Intake (Sold)
Cobb Access Port
Devils DVC-30 Water/Meth Injection
Vibrant Boost Manifold
JBR Rear Sway Bar
JBR Oil Restrictor Bolt (Sold)
JBR Boost Tubes (Sold)
JBR Catch Can
JBR Turbo Inlet Pipe (Sold)
JBR Turbo Bypass Hose
JBR EGR Delete
JBR Thermal Intake Insulating Gasket/Throttle Body
JBR Solid Shifter Bushings
JBR Short Shifter Plate
JBR 5mm Wheel Spacers
Auto Tech HPFP Internals
Dimple Dell Magnetic Drain Plugs Engine/Transmission
Parts to come-
BNR S4 (Purchased)
Cobb 3 Port Boost Controller (Purchased)
3 Bar Map (Purchased)
JBR 3.5 Intake (Purchased)
TR8 Core / CXRacing Piping (Purchased)
CPE Catted DP (Purchased)
CPE Cat Back Exhaust (Purchased)
SP63 Valve Cover Breather (Purchased)
Cobb BPV (Purchased)
Damond Mounts (Purchased)
51r Battery (Purchased)
AEM AFR Failsafe (Purchased)
2013 MS3 // Purple Drank Tune // BNR S4 // All the other shit to go along with it
Ziggyboy is offline   Reply With Quote
The Following 4 Users Say Thank You to Ziggyboy For This Useful Post:
Cevaes_64 (10-20-2015), InkedInspector (10-05-2015), ItsNox (10-06-2015), JgamB (10-05-2015)
 Old 10-04-2015, 08:00 PM   #2
skoski17's Avatar
Posts: 1,235   (View Stats)
In for results.
Too much for you
skoski17 is offline   Reply With Quote
 Old 10-04-2015, 08:05 PM   #3
Ziggyboy's Avatar
SnailD posted some dyno sheets with a speed3 making around 400 at 23psi. Anything close to 400 and I will be happy.
skoski17 and PurplFox like this.
The Following User Says Thank You to Ziggyboy For This Useful Post:
knocturnal (10-20-2015)
 Old 10-04-2015, 09:01 PM   #4
skoski17's Avatar
Nice! I recently as in a couple months ago was fully bolted on 5 gal of E spraying meth from 17lbs plus on a BNRS3 and was making 390... I wasn't impressed. So what you read in my signature is the results of the last 3 months going back to drawing bored and starting new. I thought the same thing thinking that would be enough but I was not satisfied.
Too much for you
 Old 10-04-2015, 09:15 PM   #5
Djohns's Avatar
Posts: 3,944   (View Stats)
This is the turbo I plan on running so I'm in for results!
2010 black mica speed3
Soon:built motor
 Old 10-04-2015, 09:24 PM   #6
Ziggyboy's Avatar
I chose not to go with the BNR S3 due to it being maxed out around 380 or so running e85 and meth. This way with the S4 if I'm not happy I can build the block and go crazy.
 Old 10-05-2015, 09:15 AM   #7
Ziggyboy's Avatar
Weather sucks so I grabbed a few pics of the car in the garage. Just wanted to show you guys the current setup.
skoski17 likes this.
 Old 10-05-2015, 10:16 AM   #8
JgamB's Avatar
Posts: 2,566   (View Stats)
Which FMIC you planning to run, and are you considering clocking for under-routed piping?
 Old 10-05-2015, 10:27 AM   #9
Ziggyboy's Avatar
I'm leaning towards the JBR piping kit with a TR8 core. If I can find a good deal I will go with the under-routed setup. I'm a poor State employee so I have to find the best deals I can.
The Following 2 Users Say Thank You to Ziggyboy For This Useful Post:
5doorsoffury (10-20-2015), JgamB (10-05-2015)
 Old 10-05-2015, 10:40 AM   #10
Police
InkedInspector's Avatar
Groans: 312
Keep in mind the one Snail tuned is at altitude in Colorado, that set up would be making much more power if it could actually breath. I'm excited to see what you get out of this set up!
 Old 10-05-2015, 11:46 AM   #11
Ziggyboy's Avatar
I'm also at high altitude in Utah 4500-5000 FT. All I know is it has to be better then the K04.
 Old 10-06-2015, 02:55 PM   #12
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
Very nice setup.
I am currently tuning a car with an S4 here now.
Haven't turned up the boost yet, but it looks promising.
www.tunedbynishan.com
JgamB (10-06-2015), MD1032 (11-01-2015), SamiChicago (10-10-2015)
 Old 10-06-2015, 03:06 PM   #13
Ziggyboy's Avatar
Very nice setup.
Have you noticed any sort of boost creep like some of the larger GT30 sized turbos with IWG?
 Old 10-06-2015, 03:13 PM   #14
faeker's Avatar
Posts: 5,091   (View Stats)
Groans: 731
any particular reason you're running the jbr oil bolt?
Mods: stock
 Old 10-06-2015, 03:20 PM   #15
Ziggyboy's Avatar
I was attempting to avoid a smokey K04, even though they are kind of hit or miss with which ones have problems.
 Old 10-11-2015, 10:12 PM   #16
Ziggyboy's Avatar
10 done over at BNR Supercars, more to ship next week.
File Type: jpg 12096454_1041257242551077_8387431184365016232_n.jpg (88.2 KB, 137 views)
 Old 10-12-2015, 12:39 AM   #17
Nishan
I can now confirm that the BNRS4 holds perfect 16 PSI flat-line spring pressure.
Boost control is super smooth and easy to manage.
JgamB and PurplFox like this.
The Following 4 Users Say Thank You to ms3blackmica For This Useful Post:
HawkeyeGeoff (10-12-2015), hermz (10-25-2015), MD1032 (11-01-2015), taf0422 (10-12-2015)
 Old 10-12-2015, 03:57 PM   #18
PurplFox's Avatar
Posts: 352   (View Stats)
Definitely sounding like the go to option for me. looking forward to more info.
 Old 10-16-2015, 11:36 AM   #19
Ziggyboy's Avatar
So I'm still waiting on the turbo to arrive, but I was able to pick up a few parts in the meantime.
Thanks to the MSF for sale section, I was able to grab a TR8 Core with a CXRacing piping kit and a JBR 3.5 intake. Piping kit wasn't my first choice, but after doing a little research it should be fine. Will try to grab some more pics of the car this weekend cleaned up and outside of my garage.
 Old 10-20-2015, 03:01 AM   #20
SamiChicago's Avatar
Posts: 289   (View Stats)
SamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the worldSamiChicago is the leader of the world
@Ziggyboy; how long do you have to wait to get the BNR S4 turbo? I'm thinking of ordering one or rebuilding my S3. Not sure if upgrading S3 to S4 would make a huge difference.
'07 MS6: HTP 3 Inch Intake.Cobb AP.CorkSport CBE.ATP DP.FMIC.AutoTech Internals.Bosch 3 Bar map sensor.GRIMMSPEED 3 PORT EBCS. BNR S4.WISECO 9:5 pistons. Manley H-Beam rods. Keyed Crank by APEX. SouthBend Stage 3 clutch kit. Bilstein shocks. H&R Springs.
SamiChicago is offline   Reply With Quote
 Old 10-20-2015, 06:00 AM   #21
knocturnal's Avatar
Posts: 266   (View Stats)
Subbed so i can see the results when i get back. Plan on going S4 with a D010 nozzle tuned by @snailD;
My car and right foot loves his tunes
Mods:
Stratified Tuned Stage 2 OTS+
273whp/330wtq
SnailD Tuned on Meth
316whp/359wtq
412whp/373wtq
 Old 10-20-2015, 06:35 AM   #22
you don't really need a small battery box/51R battery tray. both the ECU and the 51R Battery will fit inside of the stock battery box.
Ziggyboy (10-20-2015)
 Old 10-20-2015, 07:20 AM   #23
Ziggyboy's Avatar
Mine should be here on Friday. BNR is getting caught up on orders so hopefully some of our vendors will be keeping them in stock. I think you will be able to get more out of the S4 without having to push it near as hard.
Yeah, I have been looking at a few threads with info on making everything fit. Waiting on getting everything mocked up before I make the decision on what I want to do.
Last edited by Ziggyboy; 10-20-2015 at 07:23 AM. Reason: MSF Database - Automerged Doublepost
MS3Shadow (10-20-2015), SamiChicago (10-20-2015)
 Old 10-20-2015, 07:24 AM   #24
Yeah I have been looking at a few threads with info on making everything fit. Waiting on getting everything mocked up before I make the decision on what I want to do.
i can take a picture of mine if you want. it's more easier than you think. you make a small cut just so the ECU cables can fit and that's it. the battery and ecu would be covered unlike using battery tray and saves you over $100+
 Old 10-20-2015, 08:21 AM   #25
Ziggyboy's Avatar
Please do.
 Old 10-20-2015, 09:07 AM   #26
Please do.
Battery box opened
batttery box closed
aaronsleeps (05-05-2016), Ziggyboy (10-20-2015)
 Old 10-20-2015, 09:12 AM   #27
The only issue I could see, is if the battery fails or shorts and leaks, pops, etc.
 Old 10-20-2015, 09:29 AM   #28
Djohns's Avatar
I bought JBRs battery tray off here and I do hate how the ecu isn't covered. Of course I haven't installed it yet but I'm gunna try and make a custom cover to cover both the battery and ECU
Soon:built motor
 Old 10-20-2015, 09:34 AM   #29
i do have a rubber piece in between them, i might put a bigger piece to cover it from the battery.
 Old 10-20-2015, 11:28 AM   #30
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
Go with the battery in the trunk. Makes working in the engine bay so much easier all the time.
The Following 4 Users Say Thank You to g00s3y For This Useful Post:
iguardflorida (05-10-2016), ItsNox (10-21-2015), John596 (12-07-2015), neganox (10-20-2015)
 Old 10-20-2015, 04:45 PM   #31
Ziggyboy's Avatar
Over the weekend I began tearing out the parts that are going to be replaced. Everything took about 4 hours including a trip to Harbor Freight to pick up an oxygen sensor socket. A bunch of parts should be rolling in this week so I can start putting things back together.
 Old 10-20-2015, 05:38 PM   #32
Ziggyboy's Avatar
I was able to extend the coolant hose that can cause some issues with larger intakes. This may seem like common sense to most, but there are some that may need a little more info on how its done. Total cost was $7.00 and any local parts store should have everything.
Gates 5/8" Hose Connector- Part #28604
3" of 5/8" Heater Hose
HoseClamps
Find the coolant line that runs directly beneath the EGR valve and connects to the firewall behind the turbo.
Use something to clamp the line to prevent a large loss of engine coolant. I used a pair of channel-locks and a rag to soak up the fluid that came out. Find something to plug the line you pull the hose off, so you don't loose a bunch of fluid from that as well.
Assemble 3" of hose and the 5/8" Gates connector. Place this between the hose and metal line, then tighten everything back up.
 Old 10-20-2015, 05:57 PM   #33
superman's Avatar
Posts: 288   (View Stats)
superman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond repute
Does your intake push on the battery box and are you still on the stock turbo? Maybe the S3 shifts the intake over more than the ko4 does. I like how you did your box. I thought about positioning the ECU like that, but decided not to to avoid adding any stress to the wires.
Power: Powered by Purple Drank, BNRS3, JBR 3.5, Grimspeed EBCS, 3-bar map, CP-e FMIC, Autotech HPFP, Forge V2 BPV, VTCS delete, DM OCC, Empire water pump pulley, BSD, JBR pan baffle, ebay downpipe, CP-e CBE, NGK step colder plugs, TIGs, CP-E Safe seals, DM EGR delete, etc. Handling: Eibach prokit, SPC camber arms, RX8 wheels, 235/40/18, Goodridge Stainless brake lines, EBC redstuff, mazda 5 rear brakes, Custom mid chasis brace, WR front strut brace, TB traction bar, TB trunk brace, JBR rear sway bar, Moog links, DM RMM, OEM poly filled PMM, CS TMM insert, JBR solid shifter bushings, AP shift hammer, Other: Android Stereo running torque pro, MZ style lip, Corksport LED lights, HIDs, lots of other random stuff
superman is offline   Reply With Quote
 Old 10-20-2015, 06:14 PM   #34
superman's Avatar
@Ziggyboy; I would recommend some additional improvements to your motor mounts. At least a corksport insert for the TMM. I poly filled my stock PMM and it isn't too loud, but definitely helps (and was cheap). If your car is down for a bit it would be a good time to try it. Also, I think I found you on KSL. Since I don't live near any other speeds you are one of the most "local" to me.
The Following User Says Thank You to superman For This Useful Post:
 Old 10-20-2015, 06:18 PM   #35
Ziggyboy's Avatar
I'm definitely going to purchase mounts, just need to decide on what brand. Yeah thats me on KSL, trying to raise some funds to keep this build going.
 Old 10-20-2015, 07:34 PM   #36
Intake is some space to the battery box. And There's no stress on the ECU
Since that's how stock was but a bit closer.
As for mount. No reason to not go with Diamond Motorsports Trio. RMM/TMM/PMM.
Will keep the engine rock solid and with minimal NVH.
sent from my Nexus 6P
Deldran (10-24-2015), Ziggyboy (10-21-2015)
 Old 10-21-2015, 02:55 PM   #37
Ziggyboy's Avatar
JBR 3.5" Intake arrived today along with a few misc parts. Should be able to have the turbo installed this weekend. Wanted to thank everybody for ideas and information so far.
ItsNox (10-21-2015)
 Old 10-21-2015, 04:35 PM   #38
ItsNox's Avatar
Posts: 3,076   (View Stats)
If you want race car vibes go with JBR.
If you want less vibes with the same mounted benefit, Damond seems to be the way to go.
Sent from my big ass Note 4 using shitty Tapatalk.
'06 Mazdaspeed 6 GT
- Miltuned
Georgia Motherfucking Nator
 Old 10-21-2015, 04:53 PM   #39
Ziggyboy's Avatar
I will be going with Damond but haven't decided if I should also replace my Cobb RMM.
 Old 10-21-2015, 09:30 PM   #40
Yeah, you should replace it,
I'm going to replace my CPE stage 2 RMM with a DM RMM
MD1032 (11-01-2015)
Build me a BIG Turbo Build for MS3 NCspecV81 2010 MS3 - Big Turbo Builds 14 04-15-2013 02:16 PM
Report: Fiat to build Alfa Romeo SUV alongside Jeeps in America, build small car in Italy Haltech Automotive News 0 09-02-2011 07:20 AM
Theory: Build before Build demonspeed MazdaSpeed 6 - Engine, Transmission & Driveline 5 02-10-2009 06:52 PM
Page generated in 0.58694 seconds with 35 queries
