> 2010 MS3 - Build Diaries
Like Tree26Likes
 Old 11-13-2015, 12:30 PM   #81
waited two years to post that :p
 Old 11-13-2015, 12:47 PM   #82
Ziggyboy's Avatar
Posts: 239   (View Stats)
Ziggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the worldZiggyboy is the leader of the world
Sorry for the lack of updates over the last couple weeks, I've been busy with a new addition to the family. I was able to get the DP installed, along everything under the car buttoned back up. COBB BPV and valve cover breather are on, and now I'm looking into a vented OCC from Damond Motorsports along with a set of his mounts.
SamiChicago likes this.
2013 MS3 // Purple Drank Tune // BNR S4 // All the other shit to go along with it
Ziggyboy is offline   Reply With Quote
The Following 3 Users Say Thank You to Ziggyboy For This Useful Post:
Code Monkey (11-13-2015), neganox (12-07-2015), va7kpt (11-14-2015)
 Old 11-16-2015, 06:27 PM   #83
Ziggyboy's Avatar
I got the idea stuck in my head that I needed a second OCC. Thought about getting a Damond OCC, but decided I wanted to tinker around and make something. I wanted to give a shout out to Damond Motorsports. Matt was cool enough to take some of his Mario Cart time at home, and talk with me about mounts and OCC's.
I had a Mishimoto OCC sitting around from another project that is long gone, and decided to make it work. A small strip of aluminum, couple of brass fittings, and a drain valve were all that was needed to get the project finished. Getting to the drain valve is easy, even with the battery box in. I also put a new drain valve on my JBR OCC due to the other valve being stuck. Let me know if you guys see any issues with the set up.
The Following User Says Thank You to Ziggyboy For This Useful Post:
Fonsi (12-02-2015)
 Old 11-20-2015, 09:15 PM   #84
Ziggyboy's Avatar
I finished up a couple of things this week. Damond mounts went in, along with a 51r battery. Fabricated a aluminum battery strap, due to the factory strap sitting across the harness wires. I'm still waiting on getting my crash bar back, then I can finish up installing the intercooler.
 Old 11-20-2015, 09:59 PM   #85
Djohns's Avatar
Posts: 3,944   (View Stats)
I'm envious of your mounts sir.
2010 black mica speed3
Soon:built motor
 Old 11-20-2015, 10:02 PM   #86
Ziggyboy's Avatar
I'm excited to try them out, everybody seems to swear by them. I didn't get the RMM, ended up staying the COBB RMM for now.
 Old 11-20-2015, 10:04 PM   #87
Djohns's Avatar
Yea ill be switching out my JBR mounts for Damond. First one to go is passenger.
Soon:built motor
 Old 11-22-2015, 01:53 AM   #88
Ziggyboy's Avatar
So I figured I've made it this far in the build and might as well get a catback exhaust. Purchased the CPE Triton through @EdgeAutosport.com tonight. I should have waited and purchased my CPE DP now instead of at the beginning of this month, could have saved 15%.
 Old 11-22-2015, 05:29 AM   #89
pwdunmore's Avatar
Posts: 368   (View Stats)
They have a 30 day "exchange" policy, you may want to look into that because they could help you out if you ask nicely
You could "technically" exchange the downpipe for an on sale downpipe
My car thread:
 Old 11-22-2015, 06:34 AM   #90
Djohns's Avatar
Or he can just switch to geico and save 15%. Just throwin out options
Soon:built motor
MS3Shadow (11-22-2015), Ziggyboy (11-24-2015)
 Old 11-22-2015, 02:37 PM   #91
superman's Avatar
Posts: 288   (View Stats)
superman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond reputesuperman has a reputation beyond repute
did you order one with the extra muffler? and what tips did you get? I noticed there isn't an option for polished tips on edge's website.
Power: Powered by Purple Drank, BNRS3, JBR 3.5, Grimspeed EBCS, 3-bar map, CP-e FMIC, Autotech HPFP, Forge V2 BPV, VTCS delete, DM OCC, Empire water pump pulley, BSD, JBR pan baffle, ebay downpipe, CP-e CBE, NGK step colder plugs, TIGs, CP-E Safe seals, DM EGR delete, etc. Handling: Eibach prokit, SPC camber arms, RX8 wheels, 235/40/18, Goodridge Stainless brake lines, EBC redstuff, mazda 5 rear brakes, Custom mid chasis brace, WR front strut brace, TB traction bar, TB trunk brace, JBR rear sway bar, Moog links, DM RMM, OEM poly filled PMM, CS TMM insert, JBR solid shifter bushings, AP shift hammer, Other: Android Stereo running torque pro, MZ style lip, Corksport LED lights, HIDs, lots of other random stuff
superman is offline   Reply With Quote
 Old 11-22-2015, 02:42 PM   #92
Ziggyboy's Avatar
No on the extra muffler and it is the titan finish.
 Old 11-24-2015, 11:36 AM   #93
Ziggyboy's Avatar
Crash bar is back and mounted up. Added a little paint to make things look nice.
superman and ItsNox like this.
The Following 2 Users Say Thank You to Ziggyboy For This Useful Post:
Fonsi (12-02-2015), neganox (12-07-2015)
 Old 12-07-2015, 02:58 AM   #94
brand0llaz's Avatar
Posts: 62   (View Stats)
brand0llaz is a name known to allbrand0llaz is a name known to allbrand0llaz is a name known to allbrand0llaz is a name known to allbrand0llaz is a name known to allbrand0llaz is a name known to all
how did you fabricate the battery tie down? im going to do that too, i dont have the battery cover though lol. And Im new here, i cant find the forsale section anywhere.
08 MS Tres
Cobb SF- CS TIH- CS hpfp internal-DM rmm- Down tunnel to straight 3 inch-Cobb XLE-
CS OCC
Changed oil 12+ times within 2 weeks
FoMoCocoCocoCo
brand0llaz is offline   Reply With Quote
 Old 12-07-2015, 07:19 AM   #95
Djohns's Avatar
Need to donate to access the for sale section
Soon:built motor
 Old 12-07-2015, 04:20 PM   #96
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
Im pretty sure CPE has a 2 week policy
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
 Old 12-07-2015, 08:25 PM   #97
Ziggyboy's Avatar
You don't need a cover, only the bottom portion of the battery box is needed. I picked up the aluminum from Lowes for under 10 bucks. Using a bench vice will help bend the aluminum. I made the strap slightly smaller in height to the battery so when everything is bolted down it has some tension. Let me know if this helps.
Aluminum Flat Bar Link
ItsNox (12-07-2015), JgamB (12-09-2015)
 Old 12-07-2015, 09:13 PM   #98
Ziggyboy's Avatar
Update time. Car is moving under its own power with no major issues, leaks, or hardware problems. The CPE exhaust was a little loud for my liking, so I ended up having a MF Performance muffler welded in. Hypnotic Tune is in progress, currently on the second revision. Shout out to @rfinkle2 for answering all of my questions and responding extremely fast. Decided to run 100% Meth and will be upgrading to AN lines on my Devils Own setup. Just need everybody to keep calm for a little bit longer while I compile logs, video, pictures, and data.
ItsNox (12-08-2015), Jeremy M (12-07-2015), JgamB (12-09-2015)
 Old 12-08-2015, 07:21 AM   #99
ItsNox's Avatar
Posts: 3,076   (View Stats)
100% meth is the only way to run meths!
'06 Mazdaspeed 6 GT
- Miltuned
Georgia Motherfucking Nator
The Following 2 Users Say Thank You to ItsNox For This Useful Post:
JgamB (12-09-2015), MS3Shadow (12-08-2015)
 Old 12-08-2015, 09:47 AM   #100
blackms3_71's Avatar
Posts: 2,250   (View Stats)
An lines are the only way man. No issues since i upgraded.
Ziggyboy (04-08-2016)
 Old 12-14-2015, 10:24 PM   #101
superman's Avatar
How is the exhaust compared to stock after adding the muffler?
 Old 12-14-2015, 11:21 PM   #102
Ziggyboy's Avatar
During cold starts its loud as shit, much louder than stock. During idle its about the same, just a little deeper in tone. While driving around I find it to be just right, its louder but you can still enjoy a conversation in the car without yelling. Highway drone is very minimal, and of course when you go WOT it will make other drivers know you are next to them. If I had to do it again, I would get the muffler added from CPE. It is loud as fuck without one. Hope this helps.
superman likes this.
 Old 01-03-2016, 08:38 PM   #103
Djohns's Avatar
Updates?
Soon:built motor
blackms3_71 (01-03-2016)
 Old 01-03-2016, 09:30 PM   #104
Sleepin6's Avatar
Posts: 99   (View Stats)
Sleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to beholdSleepin6 is a splendid one to behold
Default In for updates also...
Dyno #'s and what not...
MS6 GT...REBUILD IN PROGRESS
BOLTED AND BOOST PROVIDED BY...
SPEED1/CORKSPORT...
Sleepin6 is offline   Reply With Quote
 Old 01-05-2016, 06:14 PM   #105
Ziggyboy's Avatar
Updates?
Still tuning with Mr. Finkle. I have had horrible weather and logs have been few and far between. We are still working on a 91 oct tune and soon will be starting meth. Sorry for the delay on numbers.
Sleepin6 likes this.
 Old 02-23-2016, 03:06 PM   #106
ryguy 3's Avatar
Posts: 353   (View Stats)
Any updates on this?
 Old 02-25-2016, 12:25 AM   #107
Ziggyboy's Avatar
Getting close to being finished. I have been chasing boost leaks, upgrading to SS meth lines, and waiting for weather to allow for logs. 91 Octane tune is done and we are currently working on the meth tune.
 Old 02-25-2016, 07:41 AM   #108
Castillo817's Avatar
Posts: 745   (View Stats)
What were your numbers on 91?
2013 VRM MS3
Ambit RE82 18x9.5 +38 255/35
-v8 swap in progress-
1994 Miata
-Sold-
-Sold-
 Old 03-20-2016, 10:30 AM   #109
knocturnal's Avatar
Posts: 266   (View Stats)
Ziggy I just want to let you know that I am out to sea and I am waiting for these numbers so that I can make a decision on buying this turbo or not lol. let me know how its going. your input is much appreciated!
Mods:
Stratified Tuned Stage 2 OTS+
273whp/330wtq
SnailD Tuned on Meth
316whp/359wtq
412whp/373wtq
 Old 03-20-2016, 10:59 AM   #110
impossible's Avatar
Posts: 733   (View Stats)
Groans: 30
Month later.. any updates?
 Old 03-20-2016, 09:57 PM   #111
Ziggyboy's Avatar
This has been the never ending tuning session. I have had to track down boost leaks, replace a brand new BPV, and now move to a larger nozzle size. On top of all this, Utah whether is crazy, one min its 70 degrees outside then it's snowing. Mr. Finkle has been awesome through the whole process. Rob let me know that around 400 HP will be possible, we just need to get some more octane into the system. D12 nozzle is in the mail.
I would love to post logs but I want to provide accurate information. Remember that I'm at high altitude (5500 FT) with 91 octane gas. Straight 91 will put me in area of 320 safely. With meth we should dial things in right around 400 HP. As soon as these bugs are straightened out I will post up some accurate logs.
These are the last numbers before running out of octane on a D07 nozzle. The car is hitting 20 PSI by 3300 RPM and 25 PSI by 4200 RPM.
ItsNox and SCSI15 like this.
ItsNox (03-21-2016), speedfreak44 (03-21-2016)
 Old 04-08-2016, 10:44 AM   #112
Ziggyboy's Avatar
So I guess when you have shit 91 gas and high altitude, its takes e85 and meth to take advantage of my S4. I will give this a shot and see what happens.
 Old 04-08-2016, 10:53 AM   #113
superman's Avatar
I have the same problem. 5000' and 91 here is like 89 in other places. No e85 available either.
 Old 04-08-2016, 10:56 AM   #114
Ziggyboy's Avatar
I have to travel 45 miles round trip to get my e85. We shall see what happens on a two gallon mix of e85 and a d12 nozzle of 100% meth.
 Old 04-08-2016, 10:57 AM   #115
superman's Avatar
You are still on the stock block right?
 Old 04-08-2016, 11:03 AM   #116
Ziggyboy's Avatar
Yes. Not trying to do anything too crazy just end up in the high 300 HP range.
 Old 04-08-2016, 11:17 AM   #117
Ziggyboy's Avatar
Attached is two runs from my final 91 octane map.
 Old 04-09-2016, 01:36 AM   #118
Damn thats pretty weak. I male more with my ko4 with a d10 nozzle.
 Old 04-09-2016, 10:06 AM   #119
superman's Avatar
The difference from 5000' elevation to sea level for me is almost 40 HP. @Ziggyboy; I don't think that's weak for Utah 91 at your elevation.
Ziggyboy likes this.
The Following User Says Thank You to superman For This Useful Post:
Ziggyboy (04-11-2016)
 Old 04-10-2016, 12:30 AM   #120
Oh, i didnt relize you where so high up
Build me a BIG Turbo Build for MS3 NCspecV81 2010 MS3 - Big Turbo Builds 14 04-15-2013 02:16 PM
Report: Fiat to build Alfa Romeo SUV alongside Jeeps in America, build small car in Italy Haltech Automotive News 0 09-02-2011 07:20 AM
Theory: Build before Build demonspeed MazdaSpeed 6 - Engine, Transmission & Driveline 5 02-10-2009 06:52 PM
Page generated in 0.57716 seconds with 34 queries
