> Gen2 MS3 General Discussion
Like Tree3Likes
  • 2 Post By Code Monkey
  • 1 Post By Code Monkey
 Old 03-24-2016, 07:41 PM   #1
sfeldner's Avatar
Posts: 10   (View Stats)
sfeldner is an unknown quantity at this point
Default Balance shaft help
After I replaced the pistons on my engine I'm 90% sure I did not "retime" the BS correctly when I reinstalled it because my engine vibrates like crazy now. I'm going to just do the BSD and hopefully the vibrations will improve, but even if they don't, I would assume it would be better for the motor rather than having the BS not timed right, correct? Could it be harmful to the engine to drive with the BS not timed right?
sfeldner is offline   Reply With Quote
 Old 03-25-2016, 07:52 AM   #2
shamie's Avatar
Posts: 952   (View Stats)
Time it right or remove it ASAP.
 Old 03-25-2016, 08:08 AM   #3
sfeldner's Avatar
what damage can it do from driving with the BS not timed?
 Old 03-25-2016, 08:11 AM   #4
WetzMS3 and MS3Shadow like this.
KiwiFlavor (09-13-2017), MS3Shadow (03-25-2016), WetzMS3 (03-25-2016)
 Old 03-25-2016, 08:46 AM   #5
sfeldner's Avatar
face palm doesn't help me
 Old 03-25-2016, 08:48 AM   #6
How about two facepalms?
Lakespeed6 likes this.
KiwiFlavor (09-13-2017), speedfreak44 (03-25-2016), Tomas (03-25-2016), WetzMS3 (03-25-2016)
 Old 03-25-2016, 08:56 AM   #7
Lakespeed6's Avatar
Posts: 2,403   (View Stats)
1990 Nissan Skyline GTR
1991 White BMW 325ic
 Old 03-25-2016, 08:58 AM   #8
sfeldner's Avatar
enlighten me with your knowledge
 Old 03-25-2016, 09:26 AM   #9
Lakespeed6's Avatar
If the balance shaft is out of sync it will add extra stress and vibration to the motor and will potentially cause it to fail.
Buy a balance shaft delete kit, save on rotational mass, make bitches wet with vibrations that isn't harmful, and get extra oil capacity.
JBR DISI/Duratech Balance Shaft Delete Kit MS3/MS6
The Following User Says Thank You to Lakespeed6 For This Useful Post:
sfeldner (03-25-2016)
 Old 03-25-2016, 10:30 AM   #10
 Old 03-25-2016, 11:17 AM   #11
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
The two notches have to be pointing downward like this.
 Old 03-25-2016, 11:18 AM   #12
sent from my Nexus 6P
KiwiFlavor (03-30-2016)
Balance shaft question pekka83 MazdaSpeed 3 - Engine, Transmission & Driveline 22 11-30-2013 12:13 AM
How to - Balance shaft delete danesti MazdaSpeed 6 - How-To's 105 04-04-2012 07:49 PM
Balance Shaft Delete Smoker6 Mazdaspeed3/6 General Discussion 83 05-03-2009 09:42 PM
Page generated in 0.31279 seconds with 26 queries
