> Gen2 MS3 General Discussion
 Old 11-13-2013, 10:20 AM   #1
analbumcover's Avatar
Posts: 152   (View Stats)
analbumcover has a brilliant futureanalbumcover has a brilliant futureanalbumcover has a brilliant futureanalbumcover has a brilliant futureanalbumcover has a brilliant futureanalbumcover has a brilliant futureanalbumcover has a brilliant futureanalbumcover has a brilliant futureanalbumcover has a brilliant futureanalbumcover has a brilliant futureanalbumcover has a brilliant future
Default block heater
Anyone using one? Know where one can be found?
Seems like there's is one that fits behind the exhaust manifold but there's no real clear guide.
Thanks
analbumcover is offline   Reply With Quote
 Old 11-13-2013, 10:32 AM   #2
jambisgone696's Avatar
Posts: 93   (View Stats)
jambisgone696 has a reputation beyond reputejambisgone696 has a reputation beyond reputejambisgone696 has a reputation beyond reputejambisgone696 has a reputation beyond reputejambisgone696 has a reputation beyond reputejambisgone696 has a reputation beyond reputejambisgone696 has a reputation beyond reputejambisgone696 has a reputation beyond reputejambisgone696 has a reputation beyond reputejambisgone696 has a reputation beyond reputejambisgone696 has a reputation beyond repute
yeap there's one model for 2.3L turbo...I installed one on my speed6. I'll update my post with part number and price when I'll be back at work!
If you want, I could check if I have the oem installation guide or I could write a "How to"
...let me know!
part# 0000-88-23TB-CA 55.95$ (CAN std price)
Mazdaspeed 6 2007 Velocity Red
//Cobb AP//CS SRI-TIP//Forge BPV V2//CS Boost/recirc.hoses//Magnaflow CB//Custom Testpipe//CS OCC//EGR delete//CS RMM+TMM Insert//TurbineTech diff.bushing//CS Mudflap//CS Short shift//CS SS clutch line//Oilfilter convertion//OEM Blockheater..lol//
//Custom vent Boost gauge//6000k Foglight//AUX input//
Next://CP-E safe seal//JBR IM Thermal gasket//CS hpfp//
jambisgone696 is offline   Reply With Quote
The Following User Says Thank You to jambisgone696 For This Useful Post:
analbumcover (11-13-2013)
 Old 11-13-2013, 11:18 PM   #3
a how-to would be awesome!
thanks for the part number, now i just need to track it down.
 Old 11-14-2013, 06:42 PM   #4
No time till next wednesday (20 nov.) for dismentle and pictures...sorry!
But I'll put it all together and come back with the How-to. Because of the lack of space between the engine/turbo, tools are very important...
 Old 11-20-2013, 04:42 PM   #5
Don't have a lot of pictures (not enought time to dismentle all the parts) but I hope it will help...Let me know if you have some questions!
-Drain the coolant (3-4L)
-Remove: -battery/rack
-air cleaner box/hoses/pipe (everything up to the turbo)
-move wiring harnes next to intake pipe for more room
-EGR valve
-You have to remove the first exhaust manifold stud. Loose the nut than the stud
I use a snap-on E7 key for the stud.
Now you have enought room to unscrew the plug with a 14mm allen-key and ratchet wrench
you can put the block-heater in the plug hole with 15/16 head-wrench and 3/8 ratchet
I use Tye-rap for the block-heater wire(already have heat wraping) to secure from manifold/turbo heat. Put everything in place. Be carefull to not over-tork the stud, EGR valve with new gasket...fill with new coolant
The Following 4 Users Say Thank You to jambisgone696 For This Useful Post:
analbumcover (11-23-2013), AwAfrican (04-16-2019), jack_hammer (01-05-2014), SlghtlyMeltdSkttle (01-05-2014)
 Old 11-23-2013, 04:09 PM   #6
awesome! thanks!
 Old 11-23-2013, 04:27 PM   #7
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
How To: Wolverine Oil Pan Heater
Nator is what it does.
jambisgone696 (11-24-2013)
 Old 11-24-2013, 08:33 AM   #8
the weather is not cold enough so I won't try it till 1-2 weeks. I'll leave some data (outside/coolant temp.) as soon as I try the blockheater.
 Old 01-05-2014, 04:19 PM   #9
SlghtlyMeltdSkttle's Avatar
Posts: 7   (View Stats)
SlghtlyMeltdSkttle will become famous soon enough
thank you jamb for taking time to do this write up
SlghtlyMeltdSkttle is offline   Reply With Quote
 Old 09-07-2016, 11:12 PM   #10
DAYTEK's Avatar
Posts: 2   (View Stats)
DAYTEK is an unknown quantity at this point
First off, sorry for reviving an old thread... just saved a speed6 from its previous owners and I just realized that it needs a block heater, it will definitely not survive a winter where I live.
Really I'm just curious if there are any new tips/tricks that anybody has for this install since my dealer plans to charge me $500 in labour to install it... that and any torque specs you guys have would be more than handy! Or maybe an official install guide? I like to have many views of the installs I do
Thanks and sorry for the revival again... not exactly much information on this topic that I could find
DAYTEK is offline   Reply With Quote
 Old 12-10-2019, 08:08 AM   #11
AwAfrican's Avatar
Posts: 1,038   (View Stats)
Moving out to area where temps hit -50, time for a block heater called mazda and 0000-88-23TB-CA is discontinued, cant seem to find one online. Any one have any ideas?
2013 Black MS3
 Old 12-10-2019, 08:13 AM   #12
DAYTEK's Avatar
This summer I actually installed one on my ms6, I went to the dealer and they gave me a plug that's used for the regular 2.3L since it's a similar block. The parts guy had to do some parts cross referencing. It installed nicely, was a pita though with where the frost plug is... Haven't used it yet, but it's not leaking from there either hahaha
 Old 12-11-2019, 10:12 AM   #13
Jeff23spl's Avatar
Posts: 2,235   (View Stats)
i was going to look for an universal in hose heater for mine. I would install it on the bottom hose as close as possible to the bloc.
Opening a frost plug is some kind of a pita and recipe for leaks but it get better heating results....
I just endedup replacing the fuse of my remote car starter...
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 12-16-2019, 08:19 AM   #14
AwAfrican's Avatar
Got one ordered, managed to find it at a dealership that had one on the parts shelf. Comes with sealant on the plug, just screw the block heater in the same depth as the frost plug + quarter turn and should be fine.
Gas smell with heater on Deldran Mazdaspeed3/6 General Discussion 40 04-25-2013 03:22 PM
How To: Wolverine Oil Pan Heater labikesrcool MazdaSpeed 3 - How-To's 22 10-24-2012 11:03 AM
Does your A/C compressor kick on with the heater? Wishbone MazdaSpeed 3 - Engine, Transmission & Driveline 13 12-15-2009 07:16 PM
Engine Block Heater, Sticking Gas Pedal, Clunking Noise on F-150 Truck, Ford Explorer Engine Dies at Idle: Mike Allen's Haltech Automotive News 0 03-13-2009 03:30 PM
Page generated in 0.33680 seconds with 26 queries
