> Gen2 MS3 General Discussion
 Old 01-04-2014, 10:44 PM   #1
Brendanb's Avatar
Posts: 203   (View Stats)
Brendanb has much to be proud ofBrendanb has much to be proud ofBrendanb has much to be proud ofBrendanb has much to be proud ofBrendanb has much to be proud ofBrendanb has much to be proud ofBrendanb has much to be proud ofBrendanb has much to be proud ofBrendanb has much to be proud of
Groaned at 37 Times in 7 Posts
Default Boost leak test
Been out to sea and been really busy lately so i haven't had a whole lot of time to do anything with my car. anyways though, i got around to doing the boost leak test today and I had to tighten up quite a bit. Once I got everything tight, I was getting about 20psi and I had air coming out of my crankcase. This was using a pvc cap with tire stem into my turbo inlet pipe. Is this normal and does this mean all my connections are good?
Brendanb is offline   Reply With Quote
 Old 01-04-2014, 10:49 PM   #2
Spectrix's Avatar
Posts: 332   (View Stats)
Groaned at 7 Times in 3 Posts
That's not normal. Where exactly was the air coming out?
2008 Gen1 MS3
Self tuned on E85
 Old 01-04-2014, 10:51 PM   #3
Brendanb's Avatar
well i thought it was coming out of my oil cap but it was the connection right below it. When I opened up the oil cap, all the pressure released through it.
 Old 01-05-2014, 12:18 AM   #4
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
Subbing because the last boost test I did had the same results. Loss of pressure near the sensor below oil cap. Wondering if PCV is shot.
 Old 01-05-2014, 12:26 AM   #5
ms6mil's Avatar
Posts: 4,972   (View Stats)
Groans: 307
Cap the valve cover vent line while testing. or just run the boost leak test from the first hotpipe and not from the intake.
The valve cover PCV valve is designed to block air from being sucked back into the crankcase, it is not designed to block air from being blown into the crankcase from the intake because that area never sees boost.
Boost leak at this sensor by oil cap??
"Here am I. Send me!"
GT3076 - 393/380 3/9 e85
PTE5862 - TBD
 Old 01-05-2014, 12:32 AM   #6
ledfootrob's Avatar
Posts: 195   (View Stats)
ledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the worldledfootrob is the leader of the world
If you do it from the end of your intake (just by removing filter) you need to block where ur intake connects to the valve cover breather or your pressurising ur valve cover and thats why air is leaking out.
Sent from my GT-I9300 using Tapatalk
2012 Black Mazda 3 MPS
CP-E Stage 2 Pistons - Manley Rods - BNR S3 - HTP 3" TIP + 3" BTM - Corksport Airbox - Cobb FMIC
2XS Exhaust Manifold - Snow Performance Meth Kit - HKS SSQIV - HPFP Internals - CPE Catted Downpipe - Perm PCV Plate
OBX Catback - CPE Stage 2 RMM - JBR Side Mounts - SURE AGS Shiftknob + Shortcut + Anchors
Cobb Accessport V3 - Saikou Michi OCC - Damond OCC - Corksport Springs - Bilstein B8 Shocks
Versus Eurolace 19 x 8 +45 - Hankook RS3
Built & Tuned by Rob
Track Setup - 18 x 8.5 Lenso Spec E - Nitto NT-01 245/40/18
DBA T3 Rotors - Carbotech XP10 Brake Pads
ledfootrob is offline   Reply With Quote
The Following User Says Thank You to ledfootrob For This Useful Post:
doctavus (01-05-2014)
 Old 01-05-2014, 12:49 AM   #7
jdmage_mx5's Avatar
Yea blah. I didn't do that. I was in a hurry and tired from trouble shooting a leaky BPV.
Trying to test for boost leak, could use some help ChavesB1 Mazdaspeed3/6 General Discussion 6 03-31-2013 08:11 AM
Boost leak test Laloosh Mazdaspeed3/6 General Discussion 17 07-06-2008 08:48 AM
Page generated in 0.27799 seconds with 24 queries
