![]() Join Date: Mar 2014
Rep Power: 0 ![]() Thanks: 16
(Thread Starter) | Not Ranked : 0 score After my car has been in the garage all night and everything has cooled down, it will not let me shift into reverse(also first gear is extremely tough to get into). Once the car has warmed up and driven a bit it lets me shift to any gear without issue. Also my clutch pedal definitely feels like its engaging much closer to the bottom, and is a bit softer to press. Trying to gather as much info and or user experience before heading into a shop or dealer. Just moved to a new area so I have to try and find somewhere I can trust. I'm in NW Washington state if anyone has any recommendations. Thanks for any and all responses. |
(Thread Starter) | Not Ranked : 0 score Ok so day 4 of the problem and now the when I start the car with the clutch to the floor the car is in gear. Off to the shop it goes. Sad day. |
| Squealing noise in reverse cold start only | Jra2011speed3 | 2010 MS3 - Troubleshoot/Diagnostics | 2 | 07-10-2013 08:53 AM |
| Shift lever won't come up after pulling it from reverse | mituc | MazdaSpeed 3 - Engine, Transmission & Driveline | 15 | 11-12-2012 12:36 AM |
| Wont shift into reverse | LandonElf | 2010 MS3 - Troubleshoot/Diagnostics | 3 | 04-16-2011 08:53 AM |
| Refusing To Shift Reverse.. | Silver Ecstasy | 2010 MS3 - Engine, Transmission & Driveline | 9 | 02-25-2011 11:47 PM |
| What happens if you shift into Reverse while driving? | Haltech | Automotive News | 0 | 09-09-2009 06:20 AM |
