> Gen2 MS3 General Discussion
 Old 03-09-2013, 08:51 AM   #1
Airman3454's Avatar
Posts: 567   (View Stats)
Airman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the worldAirman3454 is the leader of the world
Default Engine Stand Bolt Specs
I am trying to figure out the best way of mounting a spare block to a Harbor Freight engine stand. And tried and true mounting points you all have used and the associated bolt thread and pitch?
Thanks,
Brian
Sent from hell
Airman3454 is offline   Reply With Quote
bnoon oil restrictor bolt torque specs Chicagospeed6 MazdaSpeed 6 - Engine, Transmission & Driveline 7 11-11-2012 09:15 PM
Can someone tell me the specs on this bolt? zpele Mazdaspeed3/6 General Discussion 5 08-29-2012 10:58 AM
Engine specs viper1b2 MazdaSpeed 3 - Engine, Transmission & Driveline 6 05-09-2011 06:14 PM
engine stand ms3boost MazdaSpeed 3 - Engine, Transmission & Driveline 3 06-22-2009 09:29 AM
Engine/transmission build up stand? RocketScientist MazdaSpeed 3 - Engine, Transmission & Driveline 0 04-22-2009 10:15 PM
Page generated in 0.28040 seconds with 23 queries
