> Gen2 MS3 General Discussion
Like Tree3Likes
 Old 04-10-2012, 09:59 AM   #1
Ezekiel81923's Avatar
Posts: 535   (View Stats)
Ezekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the world
Default Gauges / Gauge Pod
tl;dr Want gauages, want to run AP at same time, are dual aeroforces necessary then?
So I've been researching some gauges recently and saw a set up that @deadlandxtreme had that I really liked, but my research yielded some questions.
I like the SRTI boost gauge, might go Defi instead, doesn't seem to matter as they are both solid, but the price is what gets me. Likewise with the aeroforces. I'm going to do the 3-gauge a-pillar pod in my gen2 was leaning towards dual aeroforce + boost gauge. The aeroforces tap into the obd2 though, so you can't run the AP at the same time? And doesn't the AP log all that shit anyway. So the dual aeroforce set up + all the sensors is going to run me like $700 that is just wasteful spending, right?
I was leaning towards some glowshift gauages since they seem consistent and reliable if nothing else and that'd be the cheapest way to go, and the gauges come with the sensors, and I can run the AP full time still. Possible still a Defi or STRI boost gauge.
Am I on the right track? Any thing I'm missing here when it comes to installing/running gauges properly?
2011 VMR Mazdaspeed 3
Cp-e | Cobb | JBR | Freektune
Ezekiel81923 is offline   Reply With Quote
 Old 04-10-2012, 10:03 AM   #2
leon78's Avatar
Posts: 2,595   (View Stats)
3-gauge a-pillar pod will kill you if you blow your air bags!
2013 Scion FR-S (Whiteout)
Less parking more racing
The Following User Says Thank You to leon78 For This Useful Post:
m249saw (04-11-2012)
The Following 5 Users Say NO Thank You to leon78 For This Un-useful Post:
bertrand_CX_7 (04-14-2012), drknyte (04-13-2012), p057 (04-10-2012), rghispanic88 (04-10-2012), SofaKingAwesome (04-10-2012)
 Old 04-10-2012, 10:04 AM   #3
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
I don't know about the genpu, but gen 1 was fine with pillar pods
Sent from my LG-MS690 using Tapatalk
it's fun to do bad things
 Old 04-10-2012, 10:04 AM   #4
JLee1469's Avatar
Posts: 1,195   (View Stats)
JLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the world
Groaned at 27 Times in 21 Posts
What are you monitoring other than boost? You are correct you can only run 1 OBD device at a time.
JLee1469 is offline   Reply With Quote
 Old 04-10-2012, 10:11 AM   #5
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
You can run the aeroforce and ap at the same time using an obd-ii splitter. They draw info from different pins. I am actualy waiting on my defrost vent pod to arrive tomorrow to do the install this weekend. Honestly im adding a switch to the power of the af gauge just to make sure it doesn't interfere with logging and flashing maps. Btw @rfinkle2 is running the same setup. Im also installing a glowshift boost gauge.
TEAM LUXURY
The Following 2 Users Say Thank You to Sid3wayS For This Useful Post:
deadlandxtreme (04-10-2012), rfinkle2 (04-11-2012)
 Old 04-10-2012, 10:17 AM   #6
rghispanic88's Avatar
Posts: 3,131   (View Stats)
Groans: 263
NO, theres a video of the mazda 3 crash test and the pillars pop out toward the windshield instead of your face. it's on here look for it
2010 Black Mica
rghispanic88 is offline   Reply With Quote
The Following 4 Users Say Thank You to rghispanic88 For This Useful Post:
ASHMS3 (04-10-2012), deadlandxtreme (04-10-2012), leon78 (04-10-2012), SofaKingAwesome (04-10-2012)
 Old 04-10-2012, 10:20 AM   #7
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
This sounds like complete overkill to me. Your AP can monitor and log pretty much everything. Watching multiple parameters is nice but for the $700 I'd spend that elsewhere.
NATOR PA
The Following 2 Users Say Thank You to MS3-a(sore)ASS-rex For This Useful Post:
adlpb (04-10-2012), Scoobs (04-10-2012)
 Old 04-10-2012, 11:12 AM   #8
Do you guys even watch those pods when driving? When I track my car I just look ahead, if I had to peek from time to time at gauges I would be slow as shit.
 Old 04-10-2012, 11:40 AM   #9
deadlandxtreme's Avatar
Posts: 1,117   (View Stats)
Groans: 82
You're safe with the pod. But I will say, 3 is overkill for sure. It's nice to be able to see everything at a glance. Not needed really , but if you have the means at the time of the want, go for it.
An AP would get the job done if you were budget minded. I just wanted to be able to see exact boost and fuel pressure. The fact that I can see my BATs and Knock warning is a plus.
 Old 04-10-2012, 11:45 AM   #10
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
I run dual aeroforces and monitor KR, FP, Boost, and AFR.
Only ever hook up my AP to flash a map, which gets less frequent the closer you get to being dialed in.
The Following 4 Users Say Thank You to SofaKingAwesome For This Useful Post:
bertrand_CX_7 (04-14-2012), deadlandxtreme (04-10-2012), jack_hammer (04-10-2012), rfinkle2 (04-11-2012)
 Old 04-10-2012, 11:46 AM   #11
travis9935's Avatar
Posts: 371   (View Stats)
travis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond reputetravis9935 has a reputation beyond repute
Groaned at 41 Times in 24 Posts
Ultragauge in a windshield mount? Cheap and has alarms for low fp!
HT programmer, Mazdaspeed CAI, Turbosmart Dual port Bpv, Corksport Test pipe back exhaust, HTP TIP, Autotech CDFP internals, CP-E TMIC, Cobb Springs, Koni yellow struts, SU RMM, Ts shift plate, prosport bg, 10k headlights, 3k fogs, OZ Ultraleggera HLTs, Pioneer nav/dcs......On the way; Devils Own Stage 2
travis9935 is offline   Reply With Quote
 Old 04-10-2012, 11:52 AM   #12
Voltwings's Avatar
Posts: 3,713   (View Stats)
i have had an ultra gauge for a bout a year now. you can monitor 6 parameters at once so i have my home screen set to:
Engine Temp - IAT - STFT - LTFT - cat bank 1 temp - Timing advance. Its a sick little device, however it too uses the OBD so you cant run that with your AP.
my question is do you actually have an ultra gauge and are monitoring fuel pressure because mine only has an option for diesel fuel pressure, which reads like 1200 at WOT which i know is no where near right haha (before someone asks the stupid question, mods in sig).
deadlandxtreme likes this.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
 Old 04-10-2012, 01:14 PM   #13
I'd like a more accurate/easier to read boost gauge, and I wouldn't mind knowing Oil temp/pressure, voltage (in case I do any stereo upgrades), or AFR.
The plan being the AP, which will only show me one or two things at a time, can stay on and show me one or two other things/do data logs/flash new tunes.
Didn't know about this...is pretty cheap...wouldn't mind one if it was accurate/didn't fall off the windshield everytime I hit a bump.
Just looking for easy ways to keep an eye on the important stuff once I start tuning, just trying to get everything in place before tuning so I'm not behind the 8-ball on monitoring. And it'd be nice to not have to log/upload logs every so often just to see if my FP or AFR's were off.
 Old 04-10-2012, 05:00 PM   #14
Groans: 549
Monitoring with an ap is no good for me. I have the aerforce for live monitoring and it's great. I also have three gauges in my center dash.
 Old 04-10-2012, 06:26 PM   #15
travis9935's Avatar
Yeah it stays in the windshield, yes its under d rail pres, mine goes up to 1900 psi.
 Old 04-10-2012, 06:57 PM   #16
Is it a reliable boost gauage? Ever compared the ultragauge readings to the AP?
I'm taking a step back and thinking buying one of these guys is waaay easier/cheaper. I suppose if the boost gauge on it isn't great I can always do a single boost gauge/pod at that point.
Thanks for the info man.
 Old 04-10-2012, 07:18 PM   #17
Ckmazdaspeed3's Avatar
Posts: 2,077   (View Stats)
Groans: 134
$700!? Niggah you crazy. It's like $3XX Iirc Tom.
I love it cuz I love to monitor ltfts when I'm cruising around town. It's a great heads up if something is acting up. And genpu does not have the dash hawk option.
The Following User Says Thank You to Ckmazdaspeed3 For This Useful Post:
 Old 04-10-2012, 07:18 PM   #18
travis9935's Avatar
Yeah better than my prosport elec boost gauge, that thing is always on the higher side and doesn't zero out.
 Old 04-10-2012, 07:19 PM   #19
Groans: 134
Really, u r sure? U can monitor from both at the same time?
 Old 04-10-2012, 07:32 PM   #20
Sorry, last question...have you tried running this with an OBDII splitter cable so you can keep this and the AP hooked up at the same time? Someone above said you could with the aeroforce but I'm assuming there are differences among different products.
I found one on Amazon and am hoping it will work. Ideally, if the UG and the AP can run at the same time...I'm done.
Worst case scenario is I keep the UG hooked up all the time and only use the AP for logging/flashing...keep the cheaper piece in the car so if it's stolen I'm not out big $$
 Old 04-10-2012, 07:46 PM   #21
skeurton's Avatar
Posts: 745   (View Stats)
skeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the worldskeurton is the leader of the world
Here it is. Jump to about 1:15 to see exactly what the panel on the pillar does upon impact. It basically pops off and swivels toward the windshield. If you've ever taken that panel off, then you probably noticed that it's attached to the pillar itself via a strap at the top. This keeps it from becoming a projectile.
2011 MAZDASPEED 3
BNR: 352 hp / 342 ft-lbs
K04: 296 hp / 343 ft-lbs
BNR Supercars Stage 3 Turbo Aquamist HFS-4 Alcohol Injection Cobb Tuning AccesPORT • AccessTUNER Race KMD Tuning HPFP Internals v2.2 NGK 6510 Spark Plugs Bosch 3-Bar MAP Sensor Saikou Michi Oil Catch Can Grimmspeed 3-Port EBCS JBR TIGs • EGR Delete • Rear Sway Bar • RMM • PSMM • TMM HTP 3" TIP • Battery Tray SURE Motorsports 3" MAF • Shortcut • CounterShift • Anchors • AGS 621g Shift Knob Ultimate Racing Catted Downpipe • Test Pipe • Cat-Back Exhaust CP-e FMIC • SAFEseals Turbosmart Dual Port BOV PTP Injector Seal Studs EBC RedStuff Brake Pads • UPR Rotors Swift Spec R Springs Bilstein B8 Shocks SPC Performance Rear Camber Arms Tanabe Sustec Strut Tower Brace TWM Performance Full Replacement Shifter 5zïgen ZR+ 18x7.5 (Ceramic Bronze) Nitto NeoGen Tires Rally Armor Mud Flaps Morimoto 6000K HID Replacement Bulbs DDM Tuning 3000K HID Fog Lights Headlight Armor Yellow Fog Overlays Qualir QL-MZD723 Headunit Glowshift Mechanical Boost Gauge • A-Pillar Gauge Pod Aeroforce Dual Interceptor Gauges
skeurton is offline   Reply With Quote
The Following 4 Users Say Thank You to skeurton For This Useful Post:
ASHMS3 (04-10-2012), rfinkle2 (04-11-2012), rghispanic88 (04-10-2012), SLOWHATCH (04-10-2012)
 Old 04-10-2012, 08:14 PM   #22
ASHMS3's Avatar
Posts: 1,362   (View Stats)
Groans: 126
Glowshift gives a warning, but I am sure it's just to cover their ass.
 Old 04-10-2012, 08:19 PM   #23
Sid3wayS's Avatar
Groans: 97
I know finkle was running this set up and he assured me on his 2010 ms3 (same as mine) he was able to use both at the same time. He hadn't tried flashing or logging thou. Ive got my guage in today and according to ups should have my obdii splitter tomorrow along with my pod. This weekend I will install everything and report back. I'll also be installing a 12v switch to turn power on and off to the AF just to make sure it does not mess with the ap when Im logging.
TEAM LUXURY
Ckmazdaspeed3 (04-10-2012), rfinkle2 (04-14-2012)
 Old 04-10-2012, 08:28 PM   #24
ASHMS3's Avatar
Groans: 126
Referring back to when most of us were kids....knowledge is power. Aeroforce gauges are knowledge, therefore power.
EDIT: CHEAP RUM HAS SPOKEN!!!
 Old 04-10-2012, 08:32 PM   #25
Groans: 224
Lol he said he wanted two Keith
NATOR PA
 Old 04-10-2012, 09:25 PM   #26
Groans: 134
I guess $700 means dual aeroforce, boost gauge and extra aeroforce shit, like oil or egt or something, cuz dual aeroforce is $400. And IF u really can run it and the AP at the same time, with the egt and oil pressure additions, that would fucking rock! I was about to sell mine because I hated hooking and unhooking it for the ap. but if I can install a switch and just turn it off to log, than I am really happy w it.
I mean to have oil pressure and egts on one gauge would be a great space saver.
MS3-a(sore)ASS-rex (04-11-2012)
 Old 04-11-2012, 06:54 AM   #27
The splitter will work with the AP and at least one Aeroforce gauge, and I would assume that it would work with the dual set-up as well. The Aerforce dual set up links the 2 together as 1 gauge, so I believe it will function the same as with 1 gauge.
The guages are cool because you can set alerts for them as well in the case that a certain pid reaches a threshold of your choice.
I agree it isn't necessary to have a million gauges, but it is nice to have the Aeroforce gauges if you want to set a few warnings / monitor simultaneously.
As far as the airbags go, Skeurton posted the vid that makes me comfortable saying that although bruises are inevitable if your side airbags deploy, I don't think there will be any significant injury due to gauges being mounted there.
Ckmazdaspeed3 (04-11-2012), deadlandxtreme (04-11-2012), skeurton (04-11-2012)
 Old 04-11-2012, 06:58 AM   #28
Groans: 82
^ Agreed. Thanks for chiming in.
 Old 04-11-2012, 03:47 PM   #29
Do you have the Classic or EM? Not sure when the EM came out but it monitors a lot more, I'm hoping FP in regular gasoline cars is something added to the EM and that FP can be monitored accurately. If not I'll the use the AP to.
That said, have you tried use the UG with an OBDII splitter? I'd like to run the AP and UG together If I could.
 Old 04-11-2012, 03:53 PM   #30
cabrone's Avatar
Posts: 529   (View Stats)
cabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the worldcabrone is the leader of the world
same. I find it annoying to use and cumbersome to hold and has limited mounting solutions.
08.5 CWP MS3 GT
AP Stage 2 S-OTS+ | Cobb Catted DP | Magnaflow CBE | JBR SRI | Cobb TIP | JBR 70 Duro RMM |NGK Iridiums | Autotech Internals | Lamin-X Yellow Fog Overlays
cabrone is offline   Reply With Quote
The Following User Says Thank You to cabrone For This Useful Post:
SofaKingAwesome (04-12-2012)
 Old 04-11-2012, 05:08 PM   #31
Voltwings's Avatar
the $75 one, not sure which it was, i didnt even know there was two so if the new one has come out within the past year or so i have the old one. Apparently its fail on my part though because it says diesel but as someone pointed out to me its still accurate. I have not used an OBD splitter because i monitor boost on a separate gauge and have all my other information on my ultra gauge. The only thing i'm not currently able to view that i would like is AFR but really i just check that every couple of weeks to make sure everything is running right.
Past:
-Sold-
-Sold-
Current:
 Old 04-11-2012, 05:13 PM   #32
skeurton's Avatar
The new EM version can read boost and AFR. If you have the old one, you can send it in to them and get it flashed to the newer version for $10.
UltraGauge EM upgrade [UltraGauge_EM_Upgrade] - $10.00 : UltraGauge, OBD II Scan Tool & Information Center
2011 MAZDASPEED 3
The Following 2 Users Say Thank You to skeurton For This Useful Post:
rfinkle2 (04-14-2012), Voltwings (04-11-2012)
 Old 04-11-2012, 05:22 PM   #33
That's the one I just ordered...along with an AP. Hoping mounting them on either side of me and finding a way to run them at the same time will tell me all I need to know.
 Old 04-11-2012, 07:00 PM   #34
Voltwings's Avatar
NICE! thanks a lot haha i almost dropped money on a separate wideband
Past:
-Sold-
-Sold-
Current:
 Old 04-13-2012, 04:27 PM   #35
Groans: 134
Alright guys, I got my splitter today and it will not work w the ap. I tried both 1 and 2 gauges but my ap can not communicate to monitor anything. I do not have a separate power wire for the aeroforce if that matters. I just have it plugged straight into the obdll
 Old 04-13-2012, 04:39 PM   #36
franz's Avatar
Posts: 1,258   (View Stats)
franz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the worldfranz is the leader of the world
Well that sucks because I plan on doing the same thing, but I havent bought the splitter yet. Which splitter did you use? I know the dashhawk and ap work on a splitter with no issues.
2007 MS3 Black Mica. Stock. 235whp/244wtq Dynojet
FREEKtuned 277/316 Dynojet
Corksport SRI/TIP/FMIC/GFB BPV/AT Internals/EBCS/Gutted 2nd Cat
Bilstein B8/Swift Spec-R/ST120s/Nitto 555
JBR 70dur. RMM-TMM-PMM/SSP+Bushings/TIGs/OCC
franz is offline   Reply With Quote
 Old 04-13-2012, 04:44 PM   #37
Groans: 134
I just went to amazon and typed obdll splitter
 Old 04-13-2012, 05:52 PM   #38
Sid3wayS's Avatar
Groans: 97
@Ckmazdaspeed3
In the back of the af there is a tiny fuse, pull it out and it will not draw power through the obdii port. Try it like that. What year do you have?
TEAM LUXURY
The Following User Says Thank You to Sid3wayS For This Useful Post:
Ckmazdaspeed3 (04-13-2012)
 Old 04-13-2012, 06:02 PM   #39
foodtime's Avatar
Posts: 225   (View Stats)
Hey boss. Since your dreams of using the OBD splitter doesn't work, willing to sell your guage to me? I'm finally ready to buy an aeroforce. I was so close to hit "check out" at the aerofoce website.
 Old 04-13-2012, 06:11 PM   #40
Does this mean it won't work with the UltraGauge/AP combo as well? I'm tempted to try anyway but wasting $25 on a cable I can't use would be annoying.
CPE Triple Gauge Pod with Prosport gauges finished asall667 Appearance - COSMIC BLUE 23 05-31-2015 09:52 AM
Gauge Pods. Which Gauges? Reap3rVIRUS MazdaSpeed 3/6 - Appearance 13 05-01-2009 08:35 AM
Page generated in 0.60373 seconds with 38 queries
