> Gen2 MS3 General Discussion
  • 1 Post By ASHMS3
 Old 06-02-2012, 01:36 PM   #1
Dumyz's Avatar
Posts: 402   (View Stats)
Dumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the worldDumyz is the leader of the world
Groans: 27
Groaned at 6 Times in 2 Posts
Default Looking around for Downpipes
Recently put in almost all of my mods (see signature). I'm considering getting a downpipe, catless or catted, not sure yet. I'm assuming the catless would provide more power, due to less restriction... But also with emissions checks every 3 years (I believe), having to pay a shop to take out the aftermarket one and put in the OEM just to pass the test, would be troublesome/expensive. So... Are there any CHEAP downpipes out there? Also not a long pipe, considering I have a UR test pipe already.
2010 Mazdaspeed 3 - Sold
New: 2008 Toyota Tundra
Dumyz is offline   Reply With Quote
 Old 06-02-2012, 01:57 PM   #2
Steven's Avatar
Posts: 634   (View Stats)
Steven is the leader of the worldSteven is the leader of the worldSteven is the leader of the worldSteven is the leader of the worldSteven is the leader of the worldSteven is the leader of the worldSteven is the leader of the worldSteven is the leader of the worldSteven is the leader of the worldSteven is the leader of the worldSteven is the leader of the world
http://www.mazdaspeedforum.org/forum/foru...-thread-99627/
2012 Mazdaspeed3 w/tech
Electronics: Cobb AP - Ultragauge - CS EBCS - Bosch 3 Bar
Engine: Autotech HPFP - Sure Aeros - Sure Return - HTP TIP - CS BPV - CS DP + RP - NGK 1 Step Colder Plugs
Steven is offline   Reply With Quote
The Following 5 Users Say Thank You to Steven For This Useful Post:
BPASPEED (06-02-2012), Dumyz (06-02-2012), Sid3wayS (06-03-2012), smoogs12 (06-02-2012), Voltron (06-03-2012)
 Old 06-02-2012, 02:03 PM   #3
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
Does the UR TP use a flat flange or a crush bent flange on the end that mates to the dp?
If it is a crush bent I would stay away from the ATP dp. It has a flat flange and no ability to accept a doughnut gasket. You will have exhaust leaks.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 06-02-2012, 02:26 PM   #4
Zdraveca's Avatar
Posts: 3,888   (View Stats)
Groans: 145
Ebay. /thread
Sent from my T-Mobile G2
2011 MS3"Princess GRU"
GT2876r
E85 FREEKTUNE
The Following User Says Thank You to Zdraveca For This Useful Post:
ArcticSpeed3 (06-03-2012)
 Old 06-02-2012, 02:57 PM   #5
Dumyz's Avatar
Groans: 27
Originally Posted by Zdraveca View Post
Ebay. /thread
I've looked on ebay, but I really don't know which ones will be compatible with the 2010 Speed.. If someone knows which ebay ones will work on the car, could I get a link?
 Old 06-02-2012, 03:11 PM   #6
smoogs12's Avatar
Groans: 423
gen 1 and gen 2 use the same shit. Did you read the sticky?
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
Zdraveca (06-03-2012)
 Old 06-02-2012, 03:15 PM   #7
Dumyz's Avatar
Groans: 27
Yes I read the sticky. I just question what people put on ebay... When you see something that says "Mazda 3 / Ford Focus Downpipe 'etc'... (Fits Mazdaspeed 3)" I'm not 100 % convinced.
 Old 06-02-2012, 03:43 PM   #8
smoogs12's Avatar
Groans: 423
07 08 09 Mazda Mazdaspeed 3 Turbo 3" Down Pipe Downpipe | eBay
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 06-03-2012, 07:37 AM   #9
Zdraveca's Avatar
Groans: 145
http://http://www.ebay.com/itm/Mazda...d52edd&vxp=mtr
thats the one you need if you dont want the long one
GT2876r
E85 FREEKTUNE
 Old 06-02-2012, 03:04 PM   #10
BPASPEED's Avatar
Posts: 1,891   (View Stats)
Groans: 60
Just save $ and get the UR one. Problem solved.
 Old 06-02-2012, 03:59 PM   #11
pcvang's Avatar
Posts: 111   (View Stats)
pcvang is the leader of the worldpcvang is the leader of the worldpcvang is the leader of the worldpcvang is the leader of the worldpcvang is the leader of the worldpcvang is the leader of the worldpcvang is the leader of the worldpcvang is the leader of the worldpcvang is the leader of the worldpcvang is the leader of the worldpcvang is the leader of the world
First emissions is in 5 years and then every 2 years after that. Why would u even consider paying a shop every 2 years to uninstall and install. The benefits are not worth it. I would imagine an uninstall and install of a dp would cost somewhere around $800 (6-8 hours of labor). That's crazy! And all that for 5-10 whp? I would recommend UR catted dp since u already have ur tp. U will have fitment problems when mix and matching dp, tp, and cbe.
pcvang is offline   Reply With Quote
The Following User Says Thank You to pcvang For This Useful Post:
 Old 06-02-2012, 08:25 PM   #12
Voltwings's Avatar
Posts: 3,713   (View Stats)
i have the UR catted dp, install was a breeze, and honestly cat less dp is worth next to no hp gain over catted and negligible torque as well. My buddy has same mods/tune as me, except he has the ATP?? catless dp. At any rate its catless, and he doesnt jump me at all, he may have a slightly stronger top end but honestly its so close its really a drivers race. Now my car sounds sexy with Catted DP, 3" resonator and no muffler. His shits catless and straight pipe the whole way out, and i can hear his car over my own... its loud as hell. If you want noise go catless, if you want to put it in once and never worry about it again, catted. Power is the same.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
Acedelgado (06-02-2012), Mrzoomzoom (11-02-2015)
 Old 06-03-2012, 09:22 AM   #13
Red
Red's Avatar
Posts: 113   (View Stats)
Red has a reputation beyond reputeRed has a reputation beyond reputeRed has a reputation beyond reputeRed has a reputation beyond reputeRed has a reputation beyond reputeRed has a reputation beyond reputeRed has a reputation beyond reputeRed has a reputation beyond reputeRed has a reputation beyond reputeRed has a reputation beyond reputeRed has a reputation beyond repute
Groaned at 3 Times in 1 Post
Ill be removing my short Turbo xs downpioe next week and posting it for sale right after... just saying
2012 Velocity Red Mica w/Tech / JBR rear motor mount & SSP with weight / Cobb AP w/ CS stage 2 intake / auto tech internals / eBay one piece down pipe race pipe / turbo smart BPV / raceland coilovers / Motegi 18x8 et 40 with 235-40-18 tires
Red is offline   Reply With Quote
 Old 06-03-2012, 09:29 AM   #14
backward_0's Avatar
Posts: 773   (View Stats)
backward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the world
i just went UR catless DP to UR TP to Stock CBE w/ res. delete. It sounds so sexy. i was thinking of a muffler delete but it would probably shake pictures off the wall on cold start. That said my buddy has the axle back with muffler cut out and i haz the ramps in my hatch.
2013 WRX Stock as Fuck.
1997 Eclipse GSX
The Red Rocket, 2011 MS3 Some other bastards problem now.
backward_0 is offline   Reply With Quote
 Old 06-03-2012, 12:40 PM   #15
Dumyz's Avatar
Groans: 27
Too bad catted downpipes are a lot more expensive... Options, options, options...
 Old 06-03-2012, 05:24 PM   #16
smoogs12's Avatar
Groans: 423
Just go catted man. Do it once, do it right.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
ASHMS3 (06-03-2012)
 Old 06-03-2012, 05:29 PM   #17
Dumyz's Avatar
Groans: 27
Regretting your catless?
 Old 06-03-2012, 05:37 PM   #18
smoogs12's Avatar
Groans: 423
lol. Well I have to go for emissions this week. So we shall see.
But other than that, no I don't regret it at all.
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
 Old 06-03-2012, 06:06 PM   #19
Dumyz's Avatar
Groans: 27
Hmmmm. Putting OEM back in, or going in catless?
 Old 06-03-2012, 05:01 PM   #20
ASHMS3's Avatar
Posts: 1,362   (View Stats)
Groans: 126
Catted are more expensive, but so is paying a muffler shop to install and remove is for emissions.
Mazdalover01 likes this.
Downpipes, which did you go with? infeKteDx 2010 MS3 - Engine, Transmission & Driveline 5 01-05-2012 06:10 AM
Downpipes Matx MazdaSpeed 6 - Engine, Transmission & Driveline 8 06-13-2010 07:38 PM
Downpipes, which one should I get? julioroman 2010 MS3 - Turbo Induction 16 05-13-2010 04:21 PM
Downpipes dkspeed MazdaSpeed 3 - Engine, Transmission & Driveline 50 02-26-2010 06:25 PM
CPE downpipes phailerider Custom Performance Engineering (cp-e.com) 27 11-25-2008 10:58 AM
Page generated in 0.40739 seconds with 29 queries
