> Gen2 MS3 General Discussion
 Old 10-27-2014, 11:55 AM   #1
HiFiSpeed's Avatar
Posts: 48   (View Stats)
HiFiSpeed has much to be proud ofHiFiSpeed has much to be proud ofHiFiSpeed has much to be proud ofHiFiSpeed has much to be proud ofHiFiSpeed has much to be proud ofHiFiSpeed has much to be proud ofHiFiSpeed has much to be proud ofHiFiSpeed has much to be proud ofHiFiSpeed has much to be proud ofHiFiSpeed has much to be proud of
Default Melted Bushing
Does anyone know if this bushing can be replaced or if the entire assembly would need to be replaced & what this piece is called? I toasted it with my dump tube by accident. This pic is just for reference and not my car. Im not refering to the RMM itself but the solid metal piece with the black bushing that attaches to the motor.
2013 Pearl White MS3 - Stratified Tuned, ~Stratified Guardian Angel~ , Stratified 3 Port EBCS, JBR 88A DURO TRILOGY , JBR Widepath 3.5, 51R Battery box/battery, JBR Oil Pan Baffle & Balance Shaft Delete, JBR EGR Blockoff, JBR Coolant bypass, JBR Solid Shifter Bushings COBB V3, COBB XLE BPV, COBB FMIC, COBB Shift Weight Autotech Internals, Denso ITV 22, -3" Custom Mandrel Bent Exhaust w/ 3" Borla Muffler- Snow Performance Methanol Injection System w/ Devil's Own D10 Nozzle & Mishimoto Coupler, , Speed Performance Valve Cover Breather , AC Vent Gauge Pod with AEM Methanol Flow Meter, Bosch 3 bar MAP w/ harness, ATP GT3071R , TiAL 38mm MV-S & Dump Tube, Full Race Exhaust Manifold.
HiFiSpeed is offline   Reply With Quote
 Old 10-27-2014, 12:43 PM   #2
shamie's Avatar
Posts: 952   (View Stats)
Looks like ~$30 2009 Mazda 3/M Parts - Online Mazda Parts unless you can find a custom one to get pressed in.
The Following User Says Thank You to shamie For This Useful Post:
HiFiSpeed (10-27-2014)
Has your Dashboard Melted? SpencerC Mazdaspeed3/6 General Discussion 25 11-23-2014 06:39 AM
MS6 Bushing/Link Set? Knight F Mohawk MazdaSpeed 3/6 - Suspension & Brakes 2 04-28-2014 06:11 PM
Another JBR SSP and bushing review jguthrie03 Gen2 MS3 General Discussion 19 08-07-2013 06:45 PM
Shifter Bushing NickyBIGBallz CorkSport 19 06-03-2013 02:33 PM
Page generated in 0.23481 seconds with 21 queries
