> Gen2 MS3 General Discussion
  • 1 Post By sandersjosh12
 Old 04-18-2019, 11:06 PM   #1
sandersjosh12's Avatar
Posts: 5   (View Stats)
sandersjosh12 is an unknown quantity at this point
Default Metallic Noise
Been searching around the forums couldn't find any answers, my 2013 Mazdaspeed3 has high pitched metallic noise when I rev the car in neutral or anytime it has load in any gear. You can hear it a lot more when you drive next to other cars, a wall, or a curb the noise echoes and bounces off them. It kind of sounds like a skateboard bearing but more metal sounding spinning along with my engine note together.
elmacanonprieto97 likes this.
sandersjosh12 is offline   Reply With Quote
 Old 04-19-2019, 04:54 AM   #2
ABOSWORTH's Avatar
Posts: 467   (View Stats)
ABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the worldABOSWORTH is the leader of the world
Does it go away or sound different if the clutch pedal is pressed to the floor? How many miles on the car?
Sent from my SM-G975U using Tapatalk
2012 Speed3 - Velocity Red Mica
Current Mods
JBR Solid Shifter Bushings: Corksport Stage II SRI/TIP: CP-E Stage II Rear Motor Mount: AutoTech Internals: Cobb AccessPort V3: UR Test Pipe: Cobb 3" Catback Exhaust: JBR Boost Tubes: ETS TMIC: Denso ITV22s: JBR EGR Block Off Kit: JBR RSB: TS Kompact BPV: Tuned by Rob
ABOSWORTH is offline   Reply With Quote
 Old 04-19-2019, 10:02 AM   #3
Db09ms3's Avatar
Posts: 536   (View Stats)
zzb
Stockish
 Old 04-19-2019, 12:26 PM   #4
Pressing clutch pedal doesn’t change anything. I can rev in neutral and it comes on with clutch depressed and in gear.
But if your going on boost then out into neutral on highway the noise stops, but revving in neutral it comes back, in gear also. Basically only when you touch accelerator anytime it comes on.I have 52k miles no mods, been doing since 46k miles hasn’t gotten any louder since then.
Took to a mechanic today he couldn’t source the issue, saying it was my turbo or it could be a pulley free spinning and needs to be replaced. But if it was my turbo how come I can hit full boost then neutral and it goes away wouldn’t it spool down and keep making the noise before I add any more engine load so it comes back?
 Old 04-19-2019, 12:43 PM   #5
crankshaft's Avatar
Posts: 576   (View Stats)
crankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the worldcrankshaft is the leader of the world
Groaned at 12 Times in 7 Posts
I doubt it's the turbo. It's speed varies greatly compared to engine RPM...so any noise from it would be variable by comparison.
Traded in: 2012 MS3, CWP
2019 Dodge Charger Scat Pack
1986 Buick T-Type, square
crankshaft is offline   Reply With Quote
 Old 04-19-2019, 12:43 PM   #6
Found video of some guys speed3 from 6-9 seconds at start mine makes same metallic noise 24/7 when I drive. https://youtu.be/PuXtm8y9Yh0 I bought this car used is it just normal then? All of my friends and the mechanics I’ve seen say it’s not.
 Old 04-19-2019, 01:05 PM   #7
crankshaft's Avatar
I don't hear any strange noises in that video. Are you talking about the rush of air when he stabs the throttle?
 Old 04-19-2019, 01:09 PM   #8
Bertospeed3's Avatar
Posts: 149   (View Stats)
Bertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant future
I didnt hear anything either, unless hes talking about the super faint rotating kinda sound after the 3rd rev.
2010 MS3 - Tuned By Nishan
Autotech Fuel Pump Internals
OBX R Custom Exhaust
Cobb SF Intake & TIH w. Blitz Filter
CP-e TMIC
Corksport Dual VTA BPV
JBR 88 Duro RMM
Bertospeed3 is offline   Reply With Quote
 Old 04-19-2019, 01:54 PM   #9
I’m not sure, I can hear a metal chain spinning sounds when he revs at start slowly with air sounds and engine sounds with it. I tried to get my own video of mine but it’s too hard to hear in the video. But that noise is closest that resembles my issue right now.
I can only hear it in the video mainly from 6-9 seconds after that his car got to loud.
 Old 04-19-2019, 02:07 PM   #10
Found this old thread too same issue I believe: annoying high pitch noise
 Old 04-23-2019, 11:57 AM   #11
Mazda3Blog's Avatar
Posts: 35   (View Stats)
Mazda3Blog is a name known to allMazda3Blog is a name known to allMazda3Blog is a name known to allMazda3Blog is a name known to allMazda3Blog is a name known to allMazda3Blog is a name known to all
That chain-like rotating noise is normal, I know exactly what you're describing. More noticeable when driving close to a wall like a drive thru for example.
It probably has something to do with our HPFP, my car has made that sound since new. The Speed6 has an even louder "chain" sound.
Engine shroud quiets it down, if you go FMIC or TMIC with no shroud it will get louder.
2010 Black MS3 (autocross/track duty)
Stratified tune, Accessport, Corksport HPFP, Corksport TMIC, Ultimate Racing test pipe, K&N intake, E-focus RMM, Corksport RSB, Corksport steering wheel + ebrake handle, solid shifter bushings, RE-71R tires
2007 Black Speed6 (daily driver)
Freektune, Accessport, Autotech HPFP, CPE TMIC, Ultimate Racing test pipe, Cobb intake + TIP, Corksport rear diff mount, CPE xflex RMM, Corksport rear brake pads, Matt Damond rear caliper bushings, solid shifter bushings, X-ice3 / AS3+ tires
Mazda3Blog is offline   Reply With Quote
Metallic jangling in rear? streetskater MazdaSpeed 3/6 - Suspension & Brakes 6 07-03-2017 07:57 AM
07 MS6 macadamia metallic iTygarin MazdaSpeed 3/6 - Build Diaries 78 09-05-2015 03:26 AM
Advan RS Dark Gun Metallic 18's randyb559 2010 MS3 - Wheels & Tires 61 11-03-2014 10:17 AM
Metallic Green Mazda2 triplejumper18 Car Detailing 3 07-13-2012 01:43 PM
metallic black Palms Appearance - BLACK 1 04-17-2010 07:46 PM
Page generated in 0.30639 seconds with 25 queries
