> Gen2 MS3 General Discussion
 Old 12-02-2017, 10:01 AM   #1
Jmoore's Avatar
Posts: 3   (View Stats)
Jmoore is an unknown quantity at this point
Default Need help with a boost problem
Last week I was on my way home on the highway and went to merge off the on ramp in 5th gear. Made it to about 3500-4000 rpm and shifted, after I shifted it refused to build any boost at all. I can hear the turbine spin but nothing happens. It's not throwing any codes at all and drives normal besides no boost ( drove it home) as far as I can tell it's only running rich which I assume is from the lack of air. I've checked the fmic (treadstone tr8), all the intercooler piping (jbr), wastegate seems to be fine(stock), boost controller is working (grimspeed), and the bov (gfb respons) is brand new. Any other ideas on what to check I'm barely making 0.5psi. other mods include hpfp internals (Autotech) Corksport down pipe and race pipe with stock catback and jbr sri along with a v3 access port on ots stage 3 93 octane. I know I need a tune but this comes first obviously.
Jmoore is offline   Reply With Quote
 Old 12-02-2017, 11:09 AM   #2
tom10122's Avatar
Posts: 116   (View Stats)
tom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to alltom10122 is a name known to all
Do a boost leak test.
tom10122 is offline   Reply With Quote
 Old 12-02-2017, 02:03 PM   #3
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
If you aren't making boost, it isn't driving normally.
As said, boost leak test.
Boost cut problem RedDevilMs3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 36 04-17-2019 09:13 AM
Boost problem BooSTed_Hatch 2010 MS3 - Troubleshoot/Diagnostics 2 07-02-2014 06:23 AM
ms6 boost problem...2 psi Stealthvr4 MazdaSpeed 3/6 - Turbo Induction 17 06-14-2014 01:36 AM
Had a boost problem :/ Evolution99 MazdaSpeed 3/6 - Turbo Induction 2 03-29-2013 05:43 PM
Page generated in 0.23941 seconds with 22 queries
