> Gen2 MS3 General Discussion
 Old 09-14-2019, 06:35 PM   #1
sd_e30er's Avatar
Posts: 56   (View Stats)
sd_e30er has much to be proud ofsd_e30er has much to be proud ofsd_e30er has much to be proud ofsd_e30er has much to be proud ofsd_e30er has much to be proud ofsd_e30er has much to be proud ofsd_e30er has much to be proud ofsd_e30er has much to be proud ofsd_e30er has much to be proud of
Default oil leak? front of engine?
2012, 130k.
just noticed a drop on the ground after about an hour. jacked the car up and the oil filter, filter housing (bottom and top) and the coolant pipe that runs across the engine had dirt and oil on them. i wiped everything down and am gonna try looking for the source.
any ideas? oil filter housing? or the gasket? motor has never been apart, biggest maintenance items so far were egr and a coolant expansion tank replacement
edit: i searched and found plenty of threads with leaky oil coolers on gen won cars. however IIRC they had a different oil filter housing? not the spin on style gen 2?
sd_e30er is offline   Reply With Quote
 Old 09-18-2019, 05:50 AM   #2
sd_e30er's Avatar
Update. Took a look under the car and it was clearly the oil cooler gasket leaking. Looks like a slow leak for at least a year. Pulled the belly pan off, got the filter block and sensor off, the gasket was clearly flattened and torn. Cleaned it up real good and put it back together with 8 bucks in gaskets and it’s dry and clean. Glad I could save a few hundred bucks and do it myself.
The Following 2 Users Say Thank You to sd_e30er For This Useful Post:
Db09ms3 (09-18-2019), MSMS3 (09-18-2019)
Engine/Transmission Leak??? HELP! thatkidrjay MazdaSpeed 3 - Engine, Transmission & Driveline 3 05-09-2015 03:53 PM
Brownish leak from engine kippo 2010 MS3 - Engine, Transmission & Driveline 7 02-15-2015 10:20 PM
Transfer Case/Front differential leak opinions Dasleeper MazdaSpeed 6 - Engine, Transmission & Driveline 4 11-10-2013 06:13 PM
Front Passenger Axle leak question GTK7 MazdaSpeed 6 - Engine, Transmission & Driveline 0 06-11-2013 08:06 AM
2007 CX7 engine oil leak Sorrento CX-7 > Issues & Troubleshooting 0 05-14-2013 09:51 PM
Page generated in 0.23230 seconds with 20 queries
