> Gen2 MS3 General Discussion
  • 1 Post By bvbull200
 Old 07-03-2013, 10:22 PM   #1
doctavus's Avatar
Posts: 1,728   (View Stats)
Default Only 10psi
Ok, so I installed internals, CS SRI, CPE Catted DP and an ETS TMIC.
I did the internals, CS SRI and AP at same time, got custom tuned and noticed a huge increase.
Install downpipe with same tune, felt slower, which was fine because of the tune wasn't setup for it. Oh, also installed NGK 11's plugs at .26-.28.
Got the TMIC on and got the tune setup for that, holy fuck did I notice a HUGE difference, this was at 18psi.
Next day I flashed a new tune for 19.5 and car only did 10psi. Now car only does 10psi.
I have, flashed back to older tune, uninstalled AP and removed battery connection. Flashed back to stock, same shit, no more than 10psi.
I have since added a full gasket that fits on the flange for the BPV, no change. I then checked for tight connections, they were fine.
Tomorrow I plan on removing the ETS and placing factory TMIC to see if I can get back the lost boost.
I am at a loss and very bummed. I am still getting a P0137 code from the downpipe install, I will be having the o2 sensor tested on Friday but car ran fine with code.
Any hints?
2012 MS3.
 Old 07-03-2013, 10:40 PM   #2
ms6mil's Avatar
Posts: 4,972   (View Stats)
Groans: 307
Before you remove the TMIC, try doing boost leak test first if you haven't done already. pretty common to have a leak from a shitty BPV seal. You can disable the P0137 through ATR, I believe that is the one usually pops up after a DP. what maps are you using?
"Here am I. Send me!"
GT3076 - 393/380 3/9 e85
PTE5862 - TBD
 Old 07-03-2013, 10:57 PM   #3
doctavus's Avatar
I'm using a local tuner that has done a hand full of tunes with good success and has a well tuned 2010.
Well we did but the coupler didn't fit worth a shit, we also cut out a gasket from a perrier box to put on the flange for now to see if it would make any difference.
 Old 07-03-2013, 11:08 PM   #4
ms6mil's Avatar
Groans: 307
this stuff here works for pretty good for a gasket. Your tuner "should" be able disable the cel from aftermarket dp. Seriously get a good boost leak check. First thing to check if you aren't hitting boost targets. Get with DFW Nator guys for help.
PTE5862 - TBD
The Following User Says Thank You to ms6mil For This Useful Post:
doctavus (07-03-2013)
 Old 07-03-2013, 11:25 PM   #5
doctavus's Avatar
Cool, thanks for the link, I am going to try finding a better sized coupler tomorrow for the boost leak test. Just not much to look at with a top mount.
But a boost leak makes sense if it was fine the night before and not next day. Just where, lol!
The Following User Says Thank You to doctavus For This Useful Post:
ms6mil (07-03-2013)
 Old 07-03-2013, 11:32 PM   #6
ms6mil's Avatar
Groans: 307
Good luck mang. I was able to pick up rubber reducers from lowes or homedepot, and made my boost leak tester check here.
PTE5862 - TBD
 Old 07-04-2013, 01:20 PM   #7
bvbull200's Avatar
Posts: 452   (View Stats)
bvbull200 is the leader of the worldbvbull200 is the leader of the worldbvbull200 is the leader of the worldbvbull200 is the leader of the worldbvbull200 is the leader of the worldbvbull200 is the leader of the worldbvbull200 is the leader of the worldbvbull200 is the leader of the worldbvbull200 is the leader of the worldbvbull200 is the leader of the worldbvbull200 is the leader of the world
Is this tuner a member of this site? If so, is he allowed to post? Does he have a Celestial Blue 2010 MS3?
I'm not saying that the tune is the specific cause of THIS problem, but you may find that some folks with experience from the same tuner as you will suggest you look elsewhere to get your car tuned properly.
rolanblack likes this.
2010 MazdaSpeed 3 - Non-Tech - Celestial Blue - Cobb AP - KMD internals - JBR 70a Duro RMM - WOLO 417 Horns
2011 Chevrolet Cruze Eco - Ice Blue Metallic / Black - Stock
bvbull200 is offline   Reply With Quote
The Following 2 Users Say Thank You to bvbull200 For This Useful Post:
Cheapspeed (07-04-2013), ms6mil (07-04-2013)
 Old 07-04-2013, 01:24 PM   #8
Cheapspeed's Avatar
Posts: 4,481   (View Stats)
Stay away from Zack's tuning experiments.
only reading 10psi 2006MS6 Mazdaspeed3/6 General Discussion 18 03-03-2012 04:24 AM
Boosting at 10psi sucks....possible solutions? ESB Jiu JItsu MazdaSpeed 6 - Engine, Transmission & Driveline 17 11-15-2011 01:34 PM
Installed CAI and now only have 10psi of boost dbrier MazdaSpeed 3/6 - Turbo Induction 2 06-08-2009 01:57 PM
Only boosting 10PSI ?? glocK23 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 6 05-18-2009 02:35 PM
took off mbc and only seeing 10psi b-ron MazdaSpeed 3/6 - Turbo Induction 2 07-29-2008 11:01 PM
Page generated in 0.29296 seconds with 23 queries
