> Gen2 MS3 General Discussion
 Old 12-22-2012, 01:07 PM   #1
JSmith's Avatar
Posts: 707   (View Stats)
Groans: 106
Default SWAS question.
Does anyone know what years have the same 6 pin SWAS connector as the Gen 2 speed 3? I am trying to avoid cutting the wiring harness AND have no electronic nannies.
A wreck would be easiest, but they want like 300 bucks for the sensor and the harness.
 Old 12-22-2012, 01:09 PM   #2
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Why not cut the wire? It's very simple.
I assume you're putting in a switch? There are several how to's
 Old 12-22-2012, 01:13 PM   #3
Dmurray06's Avatar
Posts: 3,279   (View Stats)
Just unplug it. Or wire it to a toggle switch. Pretty simple if you feel the need for a SWAS on/off.
 Old 12-22-2012, 01:13 PM   #4
JSmith's Avatar
Groans: 106
The how-to isn't the issue. Its finding the parts to make an insert for all the wires.
Desoldering the female connector from the donor SWAS and reapplying it to the donor pigtail was my plan.
SWAS - How to disable Dano MazdaSpeed 3/6 - ECU Computer Tuning 208 06-09-2016 08:21 PM
SWAS on 2010 harryclay 2010 MS3 - ECU Computer Tuning 20 03-21-2016 04:11 PM
SWAS - How to disable Dano MazdaSpeed 3 - How-To's 213 07-27-2015 05:25 PM
WTF is happening? SWAS? jordan11b 2010 MS3 - ECU Computer Tuning 31 05-01-2012 08:39 PM
swas sensor help! madvillain Mazdaspeed3/6 General Discussion 1 01-20-2009 04:15 PM
Page generated in 0.25640 seconds with 22 queries
