> Gen2 MS3 General Discussion
Like Tree3Likes
 Old 07-17-2012, 02:28 AM   #1
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
Ltft & stft: basicly how much fuel your motor takes and adds to reach your targeted afr. These numbers vary but on an ots map should be +/- 8 of each other, on a custom tune will be generaly +/- 4. The closer these numbers are the better because your ecu is not going crazy trying to keep things in check. Envirment, wether and fuel quality are just some things that affect the numbers.
Bats: the temperature of the air as it is being ingested bu the motor. Gor the most art the colder the better. Upgrading intercoolers, shooting meth and using insulation will lower this number. No real constant number because it depend on your mods.
Iat: is the temp of the air getting sucked in. Explained up top
Wgdc: is how much your waste gate on the turbo opens and closes. It very basicly controls the boost levels by diverting the exahuat gases away from the turbo, more it opens the less gasses hit the turbo, the more it closes, the more gasses hit the turbo. The more gas that hots the fins the faster it spins and more boost is made. This is a percenatge from 1-100. 1 is open and 100 is closed.
Again these are very vague refrences and are just to give a basic idea of what each value is and represents. Like @NCZ13 knowing what they mean and having a general idea of the values go hand in hand and take alot of reading.
TEAM LUXURY
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f544/ultimate-guide-parameter-monitoring-119096/
It's been a minute: - DFW Mazdas This thread Refback 01-15-2015 11:05 PM
EGT monitoring shifter48 2010 MS3 - ECU Computer Tuning 2 01-18-2012 04:26 AM
Monitoring w/ AP AZSPEED3 MazdaSpeed 3/6 - ECU Computer Tuning 46 08-04-2010 05:15 PM
How to Change a Flat Tire: The Ultimate Guide Haltech Automotive News 0 06-14-2010 02:10 PM
Autoblog's Ultimate Toyota Recall Guide Haltech Automotive News 0 02-01-2010 10:20 AM
STOCK engine parameter recordings RocketScientist MazdaSpeed 3/6 - ECU Computer Tuning 0 12-29-2009 10:43 AM
Page generated in 0.25317 seconds with 21 queries
