 Old 10-11-2014, 12:00 AM   #1
stockms3's Avatar
Posts: 840   (View Stats)
Groans: 74
Default Anyone got a FP out of the car that could check something?
I'm posting here because a lot of you guys taken fuel pumps apart. I took mine apart to clean and all was going well till one of the torx stripped. I eventually got it out but fucked up and didn't pay close attention to one of the metal washers.
So there is one ring that goes on the bottom with the lip down then there is a another metal ring then plate and wavy washer. I know the order; however, the metal ring is different on both sides and I'm not sure which side should face the pump.
Here's one side
Here's the other
If you have a pump laying around PLEASE help a brotha out
I searched and watched install videos but couldn't find an answer.
 Old 10-11-2014, 12:12 AM   #2
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
Pretty sure that goes under the plate :/ I can't remember without having one out.
@Enki; @littleloogy;
 Old 10-11-2014, 12:36 AM   #3
stockms3's Avatar
Groans: 74
You are correct sir I'm not sure which side faces the plate
 Old 10-11-2014, 12:43 AM   #4
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
If memory serves, its actually fairly obvious if you put them together. There's a lip that helps center the puck on one side.
Also, that section of the pump pretty much *NEVER* needs to come apart, unless something blew up in your ITFP and you have shrapnel rattling around in there.
 Old 10-11-2014, 01:09 AM   #5
stockms3's Avatar
Groans: 74
I agree my pump was pretty filthy but that part was super clean and I would not take it apart again.
I think I know the way it goes in, but I wouldn't want to have issues. I think the first image faces away from the pump but I would love to verify it.
Check out my log for me? maisonvi MazdaSpeed 3/6 - ECU Computer Tuning 11 10-24-2012 02:33 PM
Check my log plz LatinKraze MazdaSpeed 3/6 - ECU Computer Tuning 2 01-03-2012 02:40 PM
Page generated in 0.24990 seconds with 22 queries
