 Old 09-24-2014, 09:16 AM   #1
Gr8Speed's Avatar
Posts: 5,702   (View Stats)
Default Clear/Yellow Death on e48 Mix
Well, got another case of the "clear death" on a 50/50 mix. I just switched over to 93 last week after running the mix for the spring/summer. Last night the car was idling at 700+ HPFP Actual Pressure and making some funny mechanical noises (like the ticking but deeper and more random) along with the normal ticking noise. Pulled the pump to find everything was sticky icky and there was clear/yellow film where it was sticky. There was also a bit of black buildup. Cleaned everything up and it made the mechanical noises again for a few minutes and then it went away. Drove the car to work and did a WOT pull. 1900-2000 at WOT and 420-430ish at idle now. So *crosses fingers* back to normal now.
 Old 09-24-2014, 09:42 AM   #2
Jtaylor's Avatar
Posts: 656   (View Stats)
Are you running an upgraded RV? Just wondering.
If only we had E85 readily available here..
08 MazdaSpeed3
 Old 09-24-2014, 09:42 AM   #3
Gr8Speed's Avatar
Yup. PTP.
Jtaylor (09-24-2014)
 Old 09-24-2014, 09:54 AM   #4
littleloogy's Avatar
Posts: 4,005   (View Stats)
What was the brand of E you were using?
Sent From a Galaxy, Far Far Away...
 Old 09-24-2014, 09:55 AM   #5
Gr8Speed's Avatar
Kwik Trip e85 with Kwik Trip 10% eth 89 octane- was also running Rotella. I am now running BP 93 octane (as of last week) and PP 5w30 (as of ~1-2 months and 2000 miles ago).
 Old 09-24-2014, 10:47 AM   #6
Yeah Rotella and e don't mix very well together. If you change oils to royal purple you will have better luck running a 50/50 mix. We are Woking on a pump mod so everyone can experience the joys of running any amounts of E desired whenever they want with any oil they want. We are still in the testing stages though.
The Following 4 Users Say Thank You to littleloogy For This Useful Post:
chaser27 (09-24-2014), CWP_MS3 (09-24-2014), Jansi (09-28-2014), JgamB (09-25-2014)
 Old 09-24-2014, 10:50 AM   #7
Gr8Speed's Avatar
I've followed your thread a bit and have seen what you're doing. I'm definitely interested. I'll be off the corn sauce until next spring now though.
 Old 09-24-2014, 10:59 AM   #8
By then it could be figured out. Thanks for the info.
Gr8Speed (09-24-2014)
 Old 09-24-2014, 11:35 AM   #9
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
I've been running 50/50 with Pennzoil Platinum for almost 2 years, with only a month on 93 and haven't had any issues other than failing fuel level senders (because pu fail).
I've definitely noticed a complaint pattern with Rotella.
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
 Old 09-24-2014, 11:45 AM   #10
Jtaylor's Avatar
But I thought Rotella was gods gift to lubrication?
08 MazdaSpeed3
 Old 09-24-2014, 11:47 AM   #11
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Well is seems to do really well with our UOAs, but like anything with our cars, we can only have so much win without inevitable fail.
Rich Tuned
330WHP and 363TQ
The Following 3 Users Say Thank You to CWP_MS3 For This Useful Post:
Gr8Speed (09-24-2014), Jtaylor (09-24-2014), littleloogy (09-24-2014)
 Old 09-24-2014, 11:49 AM   #12
darth_speeder's Avatar
Posts: 653   (View Stats)
darth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the worlddarth_speeder is the leader of the world
is it the Pennzoil platinum 5w-30 full synthetic? i noticed the rottella pattern in diffrent threads as well, i'm switching it up next oil change
[SIGPIC][/SIGPIC] Corn Fed//Richtuned
darth_speeder is offline   Reply With Quote
 Old 09-24-2014, 11:53 AM   #13
I ran Pennzoil Ultra and 50/50 for many moons without a problem. I just know from experience RP was the most resistant to death.
Enki (09-24-2014)
 Old 09-24-2014, 12:03 PM   #14
Gr8Speed's Avatar
Yup. Seems to be a lot cleaner after 2k miles than the Rotella too, which is potentially positive or negative. My concern with it is that it doesn't have the detergent quality of Rotella.
darth_speeder (09-24-2014)
 Old 09-24-2014, 10:05 PM   #15
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
The most important question to ask here is how you do your 50/50 fills...
phate (09-25-2014)
 Old 09-25-2014, 06:06 AM   #16
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
whatchumean?
Rich Tuned
330WHP and 363TQ
 Old 09-25-2014, 10:37 AM   #17
Enki's Avatar
Anyone that is shooting for an exact mix and puts x amount in of either corn or pump then tops it off with the other is doing it very, very wrong.
Gr8Speed (09-25-2014)
 Old 09-25-2014, 10:42 AM   #18
Gr8Speed's Avatar
No. I never top off. 5/5 gallons usually. If I'm really empty I'll do 6/6.
Enki (09-25-2014)
 Old 09-25-2014, 10:48 AM   #19
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
I have no other choice at the moment, because I don't have a functioning level sender. I do the best I can to estimate. Generally I'm very close; within .3 of a gallon. Sometimes its more. Depends on what happened that week.
But to say that its always perfect, would be untrue. So I don't think that has anything to do with your gunk of death or whatever you call it.
Rich Tuned
330WHP and 363TQ
 Old 09-25-2014, 11:08 AM   #20
MazdaBoy2.3's Avatar
Posts: 5,797   (View Stats)
Groans: 51
Is this driven by the fact you are at a 50/50 mix?
Ive been on a 4 gal mix and now a 3 gal mix with the bt for about 12 - 15k and haven't had any issues yet.
Key word --> "yet"
 Old 09-25-2014, 11:25 AM   #21
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Who is that question directed to?
If its me, I'm not sure I understand what you're asking.
Rich Tuned
330WHP and 363TQ
 Old 09-25-2014, 11:57 AM   #22
Groans: 51
More towards op. I'm just curious how much of a difference in the clear sticky we see when comparing a 25% mix too a 50% mix.
 Old 09-25-2014, 11:59 AM   #23
Gr8Speed's Avatar
No clue honestly. I'm just reporting my experience on a 50% mix. I've never run 25%. From my understanding it's a non-issue on 25% and relatively rare on 50%, though I've seen more of it lately.
MazdaBoy2.3 (09-25-2014)
 Old 09-25-2014, 12:31 PM   #24
Groans: 51
I'd agree. Although, I think the increase is in part caused by the corn sauce being used by more of us. I'll Prob take a look at mine this winter.
50/50 e85 clear death?? Ireland MazdaSpeed 3/6 - E85 Fueling 47 03-29-2014 02:04 AM
Chicago: 2014 Volkswagen Beetle GSR is black and yellow, black and yellow Haltech Automotive News 0 02-07-2013 12:00 PM
Anybody have 3M clear bra? mtlms3 Mazdaspeed3/6 General Discussion 8 07-14-2011 03:01 PM
clear bra? iracer7 MazdaSpeed 3/6 - Appearance 6 07-23-2010 12:12 AM
Clear Bra FastAttack MazdaSpeed 3/6 - Appearance 21 06-10-2008 11:47 AM
Page generated in 0.42075 seconds with 26 queries
