Like Tree43Likes
 Old 01-05-2012, 04:13 AM   #41
hamptotl's Avatar
Posts: 677   (View Stats)
hamptotl is the leader of the worldhamptotl is the leader of the worldhamptotl is the leader of the worldhamptotl is the leader of the worldhamptotl is the leader of the worldhamptotl is the leader of the worldhamptotl is the leader of the worldhamptotl is the leader of the worldhamptotl is the leader of the worldhamptotl is the leader of the worldhamptotl is the leader of the world
Are you running meth too, or just the e mix?
For this I only ran E I turned meth off for the simple fact that for me it's more of a safety and cleaning thing so I wanted to see where I could be with out it and I am very happy there.
NatorVA07 1995 Miata M
Sway bars end links butterfly brace bilsteins with sleeves and Jackson Racing Header.
hamptotl is offline   Reply With Quote
The Following 3 Users Say Thank You to hamptotl For This Useful Post:
atvfreek (01-05-2012), djuosnteisn (01-05-2012), phate (01-05-2012)
 Old 01-05-2012, 05:30 AM   #42
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Originally Posted by hamptotl View Post
Alright Today was a Dyno day for this guy.
Got the car on the rollers to find out what power was looking like. I tuned my timing today and I have to say the car feels great. I will now shut up and get to the good stuff.
Mods. DP, CAI, TP ETS TMIC, and KMD internals. No catback, intake or exhaust mani.
Running a 5/7 E85 to 93 mix. I got these numbers by pushing timing to MBT and then backing them off 2 degrees.
from 2500 they are as follows:
-6.09, -1.90, 3.50, 8.00, 13.00, 15.00, 17.00, 18.00, 20.00, 21.00
Also I run 20 PSI tapering to 16.5 by redline and an 11.8 AFR
Final numbers of the day: 316WHP and 350 FT/LBS No complaints coming from this guy
Just to clarify a very important point...
Are you sure your 2500-4000 RPM values are actually -2° from MBT? They seem very, very conservative compared to other peoples findings.
From 4500 RPMs and up it looks like you pushed timing much closer to what Phate had identified as MBT with similar mods.
Bucker likes this.
The Following 6 Users Say Thank You to cld12pk2go For This Useful Post:
atvfreek (01-05-2012), Bucker (01-05-2012), djuosnteisn (01-06-2012), rfinkle2 (01-05-2012), RichieRichness (01-05-2012), wolly6973 (01-08-2012)
 Old 01-05-2012, 06:47 AM   #43
hamptotl's Avatar
@cld12pk2go I didnt push for MBT from 2500-4000. That RPM range frankly scares the shit out of me and I am not concerned with it because thats when I am spooling anyways. I could push it much higher I have before on street tuning and the car was fine I just didnt feel it was needed for what I am looking for. From 4500-RL is where I wanted to make my timing power. My Little bitty turbo does a good job for me from 2500-4000. Also I wanted to add my graphs so they could be seen. Not all runs of the day I did something close to 21 pulls but this is the sheet I had in the car.untitled.JPG
The Following 6 Users Say Thank You to hamptotl For This Useful Post:
atvfreek (01-05-2012), cld12pk2go (01-05-2012), djuosnteisn (01-05-2012), phate (01-05-2012), rfinkle2 (01-05-2012), RichieRichness (01-05-2012)
 Old 01-05-2012, 09:11 AM   #44
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Originally Posted by Bucker View Post
DJ,
I have run into a few that get spurts of KR in the .3-.5x region several degrees before what I would expect to be close to MBT even with a 50/50 mix of e85. Interesting phenomenon.
Man, 99% of the time, i don't even consider anything below 1.0. It's more likely motor noise than anything IMO.
Bucker likes this.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
The Following 4 Users Say Thank You to djuosnteisn For This Useful Post:
atvfreek (01-05-2012), Bucker (01-05-2012), cld12pk2go (01-05-2012), rfinkle2 (01-05-2012)
 Old 01-05-2012, 12:53 PM   #45
hamptotl's Avatar
Yeah I see a .35 or .7 every now and again but its whatever to me. As long as I dont see above 1.xx then I really dont care lol.
The Following 2 Users Say Thank You to hamptotl For This Useful Post:
 Old 01-05-2012, 02:15 PM   #46
Eth/Meth Junkie
cld12pk2go's Avatar
@cld12pk2go I didnt push for MBT from 2500-4000. That RPM range frankly scares the shit out of me and I am not concerned with it because thats when I am spooling anyways. I could push it much higher I have before on street tuning and the car was fine I just didnt feel it was needed for what I am looking for. From 4500-RL is where I wanted to make my timing power. My Little bitty turbo does a good job for me from 2500-4000. Also I wanted to add my graphs so they could be seen. Not all runs of the day I did something close to 21 pulls but this is the sheet I had in the car.Attachment 48761
FYI,
You are giving up about 50-100 ft-lbs of torque from 2500-4000 RPMs from what you could easily achieve, but I understand if you desire a bit of caution.
Hell, traction in 4th gear is nice occasionally.
atvfreek (01-05-2012), Bucker (01-05-2012), djuosnteisn (01-06-2012), hamptotl (01-05-2012), Nliiitend1 (01-05-2012), rfinkle2 (01-05-2012)
 Old 01-05-2012, 08:11 PM   #47
hamptotl's Avatar
Oh I am totally aware of the power I am missing out on lol it is just as you said though a little bit of a caution and safety net. I really don't want boom boom lol
 Old 01-06-2012, 09:28 AM   #48
Captain
FYI,
I guess this was surprisingly accurate, hahaha. Tommy will be posting up shortly.
www.permtuning.com
atvfreek (01-06-2012), cld12pk2go (01-06-2012), hamptotl (01-08-2012), phate (01-06-2012), rfinkle2 (01-06-2012)
 Old 01-06-2012, 10:04 AM   #49
hamptotl's Avatar
Alright guys so I was feeling like I left something unattended and incomplete by putting dyno verified numbers up for only 4.5-rl.
So I went back to the dyno and tuned from 2.5-4 to make things happier through my torque curve, needless to say @cld12pk2go It was scary how spot on you were LOL.
I have to pick up a copy of my graphs later today because they were having problems with their printer. Anyways here is my Full DYNO VERIFIED timing curve from 2.5 to redline.
1.00 4.00 6.00 9.00 12.00 16.00 17.00 18.00 20.00 22.00
These were found by reaching MBT(no longer increased torque by adding a degree) and then backing off two degrees.
New gains are as follows( i wrote them down before leaving LOL.)
2000 RPM before:175 after:200 3000 B:277 A:320 3500 B:300 A:330 4000 B:325 A:353 All in All no complaints here and it really does make a hell of a differance.
Oh yeah and Dustin its still super smooth LOL even smoother actually.
And according to the VD I am at 383 and 406 on a dynojet lol Silly VD
The Following 10 Users Say Thank You to hamptotl For This Useful Post:
atvfreek (01-06-2012), cld12pk2go (01-06-2012), djuosnteisn (01-06-2012), Familyguy427 (12-14-2012), Lex (01-06-2012), Nliiitend1 (01-06-2012), phate (01-06-2012), rfinkle2 (01-06-2012), RichieRichness (01-06-2012), wolly6973 (01-08-2012)
 Old 01-06-2012, 11:37 AM   #50
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Thanks for the info. VD puts me ~390hp and 490lb/ft at dynojet correction, so you aren't too far off on the hp I just ramp in shit tons of boost as soon as possible coupled with a ton of timing, lol. That low end torque makes the car really fun to drive. I'm presuming you had mostly flat horsepower from like 4k, on up? [Link us to your results!!]
OP updated.
-06 MS6
-Corn fed 07 MS3 - Sold
atvfreek (01-06-2012), djuosnteisn (01-06-2012), hamptotl (01-08-2012)
 Old 01-06-2012, 11:43 AM   #51
hamptotl's Avatar
IMG_1785.JPGGraph as promised this is the best look at it. Basically from start yesterday to finish today and I am very happy with it. Oh yeah it was very nice and smooth I will get some graphs up as soon as possible gotta swing by the shop to get them this afternoon.
The Following 5 Users Say Thank You to hamptotl For This Useful Post:
atvfreek (01-06-2012), djuosnteisn (01-06-2012), phate (01-06-2012), rfinkle2 (01-06-2012), wolly6973 (01-08-2012)
 Old 01-06-2012, 05:44 PM   #52
atvfreek's Avatar
Posts: 7,787   (View Stats)
Attachment 48850Graph as promised this is the best look at it. Basically from start yesterday to finish today and I am very happy with it. Oh yeah it was very nice and smooth I will get some graphs up as soon as possible gotta swing by the shop to get them this afternoon.
Hell ya man, that's awesome gains in a day. Lol. Tuning e-85 for the win!!!
Tappin
hamptotl likes this.
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
hamptotl (01-08-2012), rfinkle2 (01-06-2012)
 Old 01-06-2012, 05:57 PM   #53
Ziggo's Avatar
Posts: 3,843   (View Stats)
So this is my advance table, which gives me small counts of knock up top using a 3/9 E85 mixture. I live with them though because it is not 100% consistent, and I can live with the motor pulling 1-2deg of timing in the rare instance I run it out over 6000rpm.
Also attached are two logs, the "knock" log uses the above timing. The no knock log was identical except it was .5* less timing.
Ask Me About My:
The Following 8 Users Say Thank You to Ziggo For This Useful Post:
atvfreek (01-06-2012), djuosnteisn (01-09-2012), Enki (01-06-2012), LatinKraze (06-03-2013), Lex (01-07-2012), radbrad (03-28-2012), rfinkle2 (01-06-2012), Twofer (02-18-2014)
 Old 01-06-2012, 06:29 PM   #54
Eth/Meth Junkie
cld12pk2go's Avatar
When I stated the 50-100 ft-lbs left on the table, I was envisioning pushing the K04 to ~22 PSI in the 3000-4000 RPM range where it could support it to get closer to the 100 ft-lbs gain level.
I had a pretty good idea on this as I gained ~80 ft-lbs by adding ~5° at 3000 RPM with +1 PSI this summer.
The change was epic.
Glad you are enjoying.
I need to get to the dyno before too long. I just wish I could get a good solid load tune (damn load cap v2™), but I am at least getting the boost tune decently setup (21.5 PSI now)...
The Following 4 Users Say Thank You to cld12pk2go For This Useful Post:
atvfreek (01-06-2012), Dano (01-06-2012), phate (01-06-2012), rfinkle2 (01-06-2012)
 Old 01-06-2012, 06:43 PM   #55
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
damned if you do and damned if you don't....boost tune that is
....where is that TC3.....lol.....
absolutely kidding.
djuosnteisn (01-09-2012), phate (01-06-2012), rfinkle2 (01-08-2012)
 Old 01-07-2012, 07:21 PM   #56
After multiple consistent pulls with a 2.5 gallon E85 mix with a customer I see very similar timing to what you posted where KR starts to show up when BATs get close to 100. This is on the K04.
Boost_creep (01-08-2012), djuosnteisn (01-09-2012), phate (01-08-2012), rfinkle2 (01-07-2012)
 Old 01-08-2012, 07:06 PM   #57
Bucker's Avatar
Posts: 2,856   (View Stats)
Groans: 451
Lex, 368WHP? What the hell man! I'm loving it!
403whp/451ft/lb Dry Shot
Lex (01-08-2012)
 Old 01-08-2012, 07:16 PM   #58
Bucker's Avatar
Groans: 451
On that note, here is a recent result... Not dyno tuned, etune exclusively. NOTHING was adjusted on the dyno.
Dyno with Dizzy tune.
Timing numbers:
Mods are:
50/50 e85/93. Cobb SRI, TIP, Downpipe, ETS TMIC
rfinkle2 and kritz like this.
The Following 2 Users Say Thank You to Bucker For This Useful Post:
kritz (01-10-2012), phate (01-09-2012)
 Old 01-10-2012, 10:58 AM   #59
Also take this with a grain of salt in that running 400 ft lbs of torque on the stock motor is not something everyone is comfortable with. Any way you slice it that is a lot of load for the stock motor to take.
phate (01-10-2012), wolly6973 (01-10-2012)
 Old 01-10-2012, 12:08 PM   #60
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Jesus. Am I the only one that could do 18° of advance at RL on pump gas with the K04 and not knock?
Bucker (01-10-2012), littleloogy (01-06-2014)
 Old 01-10-2012, 12:15 PM   #61
How cold was it? How much boost? Some cars do better than others - could also be slight alignment of crank sensor.
atvfreek (01-11-2012)
 Old 01-10-2012, 12:16 PM   #62
That car that Lex is tuning is holding some serious boost @ redline.
Sick plot Lex. !
Oh, and Silvapain, 18* is pretty good for 93 octane.
kritz (01-10-2012)
 Old 01-10-2012, 12:19 PM   #63
silvapain's Avatar
Groans: 136
It was in the summer, and I was maxing out at 18psi boost on 93 octane (this was prior to HPFP internals). I would get knock at more than 18° advance.
The logs are on another laptop; I'll have to see if I can find them.
 Old 02-03-2012, 02:12 PM   #64
dturboman's Avatar
Posts: 1,174   (View Stats)
dturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the worlddturboman is the leader of the world
I used to run 18-19 on the K.... Running as high as 22.5 now on a gt3071 on pump with meth.
dturboman is offline   Reply With Quote
The Following User Says Thank You to dturboman For This Useful Post:
rfinkle2 (02-07-2012)
 Old 02-11-2012, 05:06 PM   #65
Eth Fiend
phate's Avatar
OP has been updated!!!
-06 MS6
cld12pk2go (02-11-2012), mrmonk7663 (02-11-2012), rfinkle2 (02-12-2012)
 Old 02-15-2012, 09:48 AM   #66
Eth Fiend
phate's Avatar
The dyno was a dynojet 224xLC. This is the same model I tune on in Chicago
We went in with the following timing curve - Blue line - Run 001:
3.0 5.5 7.5 9.5 11.5 13 14.5 16 17.5
We came out with the following curve - Bold Green line - Run 011:
4.0 6.5 8.5 10.5 13.0 16.0 18.0 20.0 22.5
We had a peak (close to MBT) timing of - Red line - Run 008:
6.0 8.5 10.5 12.5 15.0 18.0 20.0 22.0 24.5
Uncorrected Power
SAE Correction
rfinkle2 and nextgenerationx1 like this.
-06 MS6
The Following 9 Users Say Thank You to phate For This Useful Post:
cld12pk2go (02-15-2012), kritz (02-15-2012), Lex (02-15-2012), Nataphen (02-16-2012), nextgenerationx1 (02-15-2012), Nliiitend1 (02-15-2012), rfinkle2 (02-15-2012), RichieRichness (02-27-2012), wolly6973 (02-15-2012)
 Old 02-15-2012, 10:19 AM   #67
That is uncorrected WHP^ so uncorrected so uncorrected WTQ must've been significantly higher.
 Old 07-19-2012, 09:31 PM   #68
Trail of Fail
Dano's Avatar
Thread Tools~Subscribe.
Tappin
The Following 5 Users Say Thank You to Dano For This Useful Post:
atvfreek (07-29-2012), NoLeftTurn (07-26-2012), phate (07-25-2012), silvapain (07-20-2012), wolly6973 (07-20-2012)
 Old 07-20-2012, 04:49 AM   #69
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
i need to get on a dyno and find where my MBT is as well but ill be waiting till the fall when its not 100+ degrees out lol
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
phate (07-25-2012), rfinkle2 (07-20-2012)
 Old 07-20-2012, 07:39 AM   #70
I'd split the cost of the dyno time with you if you go. LOL. I really could use some known good values and back it off a few degrees for high boost applications and an e85 mix for e-tunes.
I totally appreciate the k04 information shared here and Driver's 22 psi ignition map, but it would be soooo valuable to have some sort of guidlelines to work from for high load / high boost cars.
The Following 5 Users Say Thank You to rfinkle2 For This Useful Post:
atvfreek (07-20-2012), Boost_creep (07-20-2012), cld12pk2go (07-20-2012), phate (07-25-2012), RichieRichness (07-20-2012)
 Old 07-25-2012, 08:57 PM   #71
Eth Fiend
phate's Avatar
OP updated.
Take note of mazdafreak's two dyno sessions with drastically different setups.
-06 MS6
atvfreek (07-26-2012), Lex (07-25-2012), rfinkle2 (07-26-2012)
 Old 07-25-2012, 09:10 PM   #72
OP updated.
Was temperature different between the runs? The K04 is very much affected by inlet temps.
phate (07-25-2012)
 Old 07-25-2012, 09:14 PM   #73
Eth Fiend
phate's Avatar
No, it was roughly the same time of year, so temps weren't drastically different. His hard parts setup was drastically different, but I don't think that is a great explanation for the reduced timing requirement.
Power production was within 2-4hp over the entire mid and upper rpm range between the two sessions, as well. On the bottom end, we picked up some power with higher boost. We pulled a few degrees before he swapped all of the parts, and walked it back up from there. The new curve was surprising.
Edit: to clarify the temp change statement: IAT's would have been higher (not by much), but the BAT's would have been lower (20+° lower). His Cobb FMIC is a CHAMP!
-06 MS6
 Old 07-25-2012, 09:24 PM   #74
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
So basically, the more bolted you are the less timing you need to hit peak power/airflow...?
phate (07-25-2012), rfinkle2 (07-26-2012)
 Old 07-25-2012, 09:33 PM   #75
Eth Fiend
phate's Avatar
I actually don't see a trend like that. I was thinking it for a while, but then I had a few more cars on.
If you look, JTMS3 and mazdafreak have a shit ton of parts. JTMS3's car took a TON of timing, mazdafreaks not so much with the extra parts.
But, my car and forcedinduktion's car have very few parts and they have drastically different timing curves.
Point being - stay conservative until you can get on a dyno. Think I've been saying this for a long time now
-06 MS6
The Following 7 Users Say Thank You to phate For This Useful Post:
atvfreek (07-26-2012), cld12pk2go (07-26-2012), Dano (07-26-2012), Enki (07-25-2012), forcedinduktion (07-25-2012), IshiKage (07-26-2012), rfinkle2 (07-26-2012)
 Old 07-25-2012, 10:40 PM   #76
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,719   (View Stats)
Groans: 70
I haz low powahh!
JK Clint got my shit running good
The Following User Says Thank You to forcedinduktion For This Useful Post:
phate (07-25-2012)
 Old 07-25-2012, 11:11 PM   #77
Ur moms boyfriend
Groans: 70
So it looks pretty consistent that the k04 will hold no more than 17 at redline.
 Old 07-25-2012, 11:51 PM   #78
Mine holds 20psi if IATs stay below 85*
Too many variables to talk about here but if you want airflow, do the following:
1. As large an intake as possible.
2. A clean dryflow filter.
3. As cold air as possible.
The above can be worth well over 30whp depending on setup.
 Old 07-26-2012, 12:46 AM   #79
Enki's Avatar
Also move to below sea-level.
phate (07-26-2012), rfinkle2 (07-26-2012)
 Old 07-26-2012, 05:10 AM   #80
atvfreek's Avatar
Do you happen to have mazdafreaks dyno files. I like to see roughly what he made 2 degrees below that final curve, and the power at mbt itself. Even that curve is pretty aggressive. Just curious to see of its even worth pushing to within two degrees of mbt on a DD driven map. Haha
Freekn tappin
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f567/e85-e85-mix-ignition-timing-database-100743/
VersaTuner: ????????, ??????????, ????? ?????? This thread Refback 12-28-2015 04:14 AM
What happened to the e85 blend thread? - Page 3 This thread Refback 01-08-2014 09:41 PM
What happened to the e85 blend thread? - Page 4 This thread Refback 01-08-2014 06:44 PM
BNR Tuning - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 06-19-2013 10:24 PM
SpeedyD's Tooning Thread This thread Refback 06-04-2012 06:16 PM
rough tune on e85 = 338/364 - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 05-23-2012 09:20 AM
Fuel Mixtures - SWFL Racing This thread Refback 02-21-2012 12:11 PM
Brakes Database MS3/MS6! jax ms3gt MazdaSpeed 3/6 - Suspension & Brakes 103 09-23-2017 01:14 AM
HOW-TO DATABASE MS6 MATT DAMOND MazdaSpeed 6 - How-To's 42 11-21-2016 07:07 AM
HOW-TO DATABASE MS3 MATT DAMOND MazdaSpeed 3 - How-To's 39 07-15-2015 07:29 AM
Any harm in leaving the ignition timing stock? Qtip MazdaSpeed 3/6 - ECU Computer Tuning 2 03-30-2010 11:30 AM
who's played with there ignition table / timing ?? Wenis Prinkle MazdaSpeed 3/6 - ECU Computer Tuning 5 11-26-2009 04:40 PM
Page generated in 0.63919 seconds with 35 queries
