Like Tree43Likes
 Old 01-29-2013, 10:17 AM   #121
sidekick's Avatar
Posts: 3,093   (View Stats)
I had a speed 6 on the dyno recently and we didn't gain hardly any power above 14* at 6k. It's very important to keep run conditions and road the same if street tuning an aggressive timing curve, and I would still stay a little conservative.
Sent from your couch
What mix was that on?
rfinkle2 (01-29-2013)
 Old 01-29-2013, 11:01 AM   #122
atvfreek's Avatar
Posts: 7,787   (View Stats)
That wasn't even with e85 in the tank. Just running 100% meth, d07 nozzle and obviously zero kr.
Edit: Another note that is an important detail on this tune, is that he had a warranty engine replacement a few months ago, and it's likely the crank sensor is slightly off.
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 3 Users Say Thank You to atvfreek For This Useful Post:
Boost_creep (01-29-2013), rfinkle2 (02-06-2013), sidekick (01-29-2013)
 Old 02-02-2013, 10:40 AM   #123
ABSpeed3's Avatar
Posts: 698   (View Stats)
ABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the worldABSpeed3 is the leader of the world
Groans: 133
Groaned at 7 Times in 4 Posts
Originally Posted by ABSpeed3 View Post
so I followed the advice from you guys..made timing 15* @ RL and changed the 3500 and 4000 values to 6 and 8 respectively. Is there room for more boost on a 2.5gal mix? This is my vdyno from last night, weight is 400 because both myself and friend were in the car as well as a 5 gal tank of e85 and a subwoofer box that takes up my entire trunk.
08.5 CWP MS3 GT
PG Intake, TIP | Forge BPV | M2 Catless DP | HKS Catback | Cp-e FMIC| Autotech Internals | Self Tune | Bilstein Shocks | SPC Camber Arms | H&R Springs | Progress RSB | JBR SSP, Bushings, PMM | TWM Shift Knob | TRZ RMM, TMM | TRM C3 17x9| Dunlop Star Spec ZII (245/40) | Matt Damon OCC
ABSpeed3 is offline   Reply With Quote
 Old 02-14-2013, 02:27 PM   #124
Familyguy427's Avatar
Posts: 1,476   (View Stats)
Familyguy427 is the leader of the worldFamilyguy427 is the leader of the worldFamilyguy427 is the leader of the worldFamilyguy427 is the leader of the worldFamilyguy427 is the leader of the worldFamilyguy427 is the leader of the worldFamilyguy427 is the leader of the worldFamilyguy427 is the leader of the worldFamilyguy427 is the leader of the worldFamilyguy427 is the leader of the worldFamilyguy427 is the leader of the world
Groaned at 22 Times in 12 Posts
Occ. Weight 400lbs??????????????????
Familyguy427 is offline   Reply With Quote
 Old 02-14-2013, 03:09 PM   #125
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
RCP.
ABSpeed3 (02-14-2013), Familyguy427 (02-14-2013)
 Old 02-14-2013, 04:10 PM   #126
I totally missed that part. LMFAO!!!!!!!!
The Following User Says Thank You to Familyguy427 For This Useful Post:
 Old 02-14-2013, 08:00 PM   #127
ABSpeed3's Avatar
Groans: 133
i never got around to getting a different setup I just pulled it straight out of my truck thing is no joke ha
08.5 CWP MS3 GT
 Old 05-15-2013, 12:36 PM   #128
superdave2335's Avatar
Posts: 924   (View Stats)
superdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the worldsuperdave2335 is the leader of the world
Groaned at 9 Times in 6 Posts
so being as this is mostly about timing is anyone against discussing timing on meth since i dont have access to e85 up here in anchorage alaska...i will be jumping on a dyno very soon. using VD as my help i was actually able to hit Phates timing and still showed power being made. my timing is exactly as Phates is in OP up top. im running 90oct (the highest avail in alaska) along with 50/50 meth. i run a 1gal/hr nozzle pre turbo and 6gal/hr pre throttle body. vd numbers showed 325hp/410 iirc. im going to drop timing back down since yall fuckers making me nervous and go up all over again on the dyno.
since im at work ill post this log just to tide yall over until i can post a vd
if this is not ok to post here feel free to delete.
08' MS3 ESK-EMO Tuned!!!
GT3076r EWG
Manley rods, cp-e stage 2 pistons, arp studs, fullRace exhaust mani,PNP stock IM, TurboXS catless DP/TP/CBE, TurboXS FMIC, hybrid boost control setup using MBC/EBCS, HTP 4" intake system w/MAF block off plate, 3.5" blow thru system fabbed by me,3 bar map, SNOW Stage 2 W/Direct port meth, HKS SSQV4 full vta, JBR 80duro RMM/TMM/PMM, JBR Stage2 OCC, EGR delete, TWM Full Replacement, perm butt plug knob, JBR SB, KMD V2, NGK's, perm pcv plate.
shout outs to -Rob, DJ, Nishan, William, John. couldn't have done it with out your guys advice and assistance. thanks.
superdave2335 is offline   Reply With Quote
 Old 05-15-2013, 01:01 PM   #129
That is quite aggressive. More aggressive than what I feel comfortable with especially not being on a real dyno.
86AmishMs3 (05-18-2013)
 Old 05-15-2013, 01:07 PM   #130
I completely understand as well that's why I'm gonna drop it down some until u get back on a dyno. I don't get how I don't knock though. Motor is built and I'm sure ambient temps along with being at sea level has an effect on this. We just recently got a decent dyno in anchorage though and guy said I can make as many pulls for 100$ so I'm gonna take that deal and see what I come up with. Vd pisses me off these days.
Shooting this ISH from my iPhone using forCUMrunner
Thanks for chiming in as well lex
GT3076r EWG
Last edited by superdave2335; 05-15-2013 at 01:07 PM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to superdave2335 For This Useful Post:
ArcticSpeed3 (05-15-2013), rfinkle2 (05-15-2013)
 Old 05-15-2013, 02:09 PM   #131
Backed off about 4* through whole range and dropped boost as well. Gonna get on the dyno this weekend. How are you guys finding your power points? Are you adding a degree on top of baseline run to find benefits and then adjusting accordingly? Just want to have some tips and tricks to use when I go this weekend. Thanks guys
GT3076r EWG
 Old 05-15-2013, 02:12 PM   #132
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
You can add timing until power plateaus (sans knock). That last point where you pick up power is MBT.
-06 MS6
-Corn fed 07 MS3 - Sold
rfinkle2 (05-15-2013), superdave2335 (05-15-2013)
 Old 05-15-2013, 02:14 PM   #133
Ok roger that. Then back off a degree or so from what I've seen. I've got too much damn money in this bus to fuck it up. I appreciate the help lex/phate/dj. I still don't know how to tag ppl in this shit. I know. I'm such a brownie!!!
GT3076r EWG
 Old 05-15-2013, 02:43 PM   #134
atvfreek's Avatar
Something is going crazy with your maf g/s and volts. Make sure you don't have a meth leak spraying at your air filter. Seen that a few times.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
 Old 05-15-2013, 02:48 PM   #135
I actually run a blow thru maf and pre turbo meth. But will remove it tonight because I seen the fluctuating maf as well. Even before pre turbo meth I can seem to get the damn afr's to flatline. Figured it was because I was boost based. Would you recommend going maf based instead? Come on at around 3.4-3.5 volts and go max around 4.3-4.4?
GT3076r EWG
 Old 05-15-2013, 04:27 PM   #136
atvfreek's Avatar
Ahhh the meth spray is hitting the maf because the pre turbo meth. If you go back to a standard maf setup, that should clean it up. Or pull the pre turbo meth nozzle
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
 Old 05-15-2013, 04:39 PM   #137
at in front of the username, semi colon afterwards.
@ superdave2335 ;
@superdave2335;
Take it easy on those forged internals man. You are running some big timing down low.
atvfreek (05-15-2013), lilred (05-15-2013)
 Old 05-15-2013, 05:25 PM   #138
Thanks @rfinkle2; I turned the timing down. Wayyyy down. Gonna hit the dyno next weekend and do it correctly and accurately. Thanks for the heads up guys.
Shitty part about going back to standard draw thru is the fact that my JBR intake dosent have the recirc tube. My blow thru works well and I haven't had any issues with it. Even before when I was draw thru my meth would skew afr's. just want to find a more accurate approach to spray and keep afr's straight. That's why I mentioned trying maf based setup
GT3076r EWG
Last edited by superdave2335; 05-15-2013 at 05:25 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to superdave2335 For This Useful Post:
 Old 05-17-2013, 11:38 PM   #139
Mfinlay04's Avatar
Posts: 827   (View Stats)
Well spraying meth before the MAF sensor is basically throwing that sensor off. Wiki how a MAF sensor works if you don't know yet but the meth droplets won't play nice with the hot wire. I'm kinda surprised youve never had any cuts with this setup.
Try spraying post MAF
2006 MS6 Titanium Grey
Tuned with
 Old 05-17-2013, 11:52 PM   #140
I actually spray both. Ended removing this setup for the risk. Never had issues but just wanted to be cautious. If I was not blow thru I would smash meth down the turbos throat!
GT3076r EWG
 Old 06-12-2013, 04:37 PM   #141
seshomaru7's Avatar
Posts: 182   (View Stats)
seshomaru7 is a name known to allseshomaru7 is a name known to allseshomaru7 is a name known to allseshomaru7 is a name known to allseshomaru7 is a name known to allseshomaru7 is a name known to all
How is that blow thru MAF working out? I've read the sensor doesn't respond consistently to that setup.
Need a way to mount your Devil's Own methanol kit? Find my F/S thread for a custom made mount kit with all hardware included!
seshomaru7 is offline   Reply With Quote
 Old 06-12-2013, 09:38 PM   #142
It can be a little tricky the maf can seem to act finicky but as long as you take your time on maf cal it works just fine. And vta is always fun. I got a jbr wp intake with out recirc so that's another reason I opted to do it.
GT3076r EWG
 Old 06-13-2013, 08:07 AM   #143
seshomaru7's Avatar
Wow. I've also heard something like people only using the MAP with no MAF or something like that. Any idea what I am talking about?
 Old 06-13-2013, 09:26 AM   #144
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
Its called Speed Density and we dont yet have the ECU logic to run it.
Tappin
 Old 06-13-2013, 10:02 AM   #145
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
Speed Density is a little advanced Factory speed density vs factory mass air....speed desnsity makes more power generally....start modding and the car goes to shit without a custom tune.....I converted cars from speed density to mass air simply for the ease of tuning and forgiveness of the mass air system. Speed density + mods is a game for the big power guys!!!
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
 Old 06-13-2013, 03:52 PM   #146
seshomaru7's Avatar
That's what it was! Now what vehicles were those? Subies?
 Old 06-13-2013, 04:08 PM   #147
Speed density from what I have seen here in Alaska is difficult when the weather changes and it goes from 80* outside to 0* lol.
GT3076r EWG
 Old 06-13-2013, 05:09 PM   #148
Trail of Fail
Dano's Avatar
Topic for another thread but yes as VE changes so to must the tune if it expands beyond the table limits.
MAF is much easier and more forgiving to hardware changes.
SD is Robbing Peter to pay Paul IMO.
Tappin
The Following 5 Users Say Thank You to Dano For This Useful Post:
atvfreek (06-13-2013), phate (06-13-2013), silvapain (06-15-2013), smoogs12 (06-15-2013), WetzMS3 (04-13-2016)
 Old 06-13-2013, 07:26 PM   #149
mrmonk7663's Avatar
Old fox body mustangs....87 and 88 had speed density from the factory...except the California models...they got mass air in 88 I believe. Anyway, back on topic
 Old 06-15-2013, 02:03 PM   #150
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Actually MAF is newer and more advanced than speed density.
 Old 06-15-2013, 02:20 PM   #151
But in recent turbocharged cars such as the Ecoboost they went back to speed density with some very advanced modelling techniques.
Why? Speed density response is faster than MAF especially if the MAF sensor is so far upstream from the throttle plate.
All the speed density does is it translates pressure into airflow for the engine. You can run a simple table translator such as this:
MAP-ECU3 - Performance Motor Research : Performance Motor Research
Plug it into your MAF harness instead of the MAF and make sure you map the VE table correctly.
 Old 06-15-2013, 07:48 PM   #152
mrmonk7663's Avatar
By Advanced, I meant to tune...not the technology. The typical armchair tuner would have quite a bit to learn tuning a modified speed denisity setup.
The Following User Says Thank You to mrmonk7663 For This Useful Post:
silvapain (06-16-2013)
 Old 06-15-2013, 10:28 PM   #153
Enki's Avatar
Don't you have to retune for changes in altitude on SD?
 Old 06-15-2013, 10:49 PM   #154
mrmonk7663's Avatar
You have to retune for everything with SD. Stock for stock a speed density car tends to make more power than a Maf Car. This is seen by numerous dynos with the 88 Mustang GT...this is my reference and experience with speed density. Anyway, as soon as you started modding the speed density system, car would react negatively. In order to reel it back in you had to piggyback the ECU and custom tune it. On the other end, the mustang with a MAF was much more forgiving. Heads/cams/intakes/headers/exhaust/superchargers...and the only thing that was needed to change were fuel pumps, fuel injectors, and maf housing...the maf housing was needed to be changed not for size but to complement the injectors.....these kinds of mods were not possible without extensive piggyback ecu tuning on a speed density setup.
 Old 04-12-2016, 12:59 PM   #155
BuddySpeed3's Avatar
Posts: 479   (View Stats)
Are there any dyno proven values for in tank methanol? I'm running 1 gallon and was able to get away with 16* at 6k rpm holding 18.5 psi on k04. I tuned for what was in the tank and used WMI for more safety and consistency. Weird thing though, I recently turned off the WMI to verify my tune doesn't knock and I started seeing knock values at 5K. Idk why it would suddenly start doing that when it didn't when I was tuning for it. Also I've always been putting a full gallon in every fill up at empty, so there would always be residual meth in tank so I was usually just slightly over 1 gallon.
 Old 04-12-2016, 09:49 PM   #156
Eth Fiend
phate's Avatar
Not really, but I suspect that once you have sufficient octane with any fuel type, that MBT values on a given engine will be within a degree or two. The big takeaway from this thread, to me, is that there is HUGE variance in MBT curves between engines. I would take the lowest values and use them as a guideline until you are able to tune on a dyno and sufficiently quantify what a degree or two of timing does for power. Street tuning is not accurate enough for that fine of tuning.
I would go back and have a look at those data logs for comparison, specifically temperatures. Agreed with Enki, this part of your post is best found in a new thread.
Thanks @SofaKingAwesome!
-06 MS6
Last edited by phate; 04-13-2016 at 11:41 AM. Reason: MSF Database - Automerged Doublepost
Enki (04-13-2016), SofaKingAwesome (04-13-2016), WetzMS3 (04-13-2016)
 Old 04-13-2016, 06:27 AM   #157
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
In-tank meth to WMI to in-tank meth tuning woes
The Following 3 Users Say Thank You to SofaKingAwesome For This Useful Post:
Enki (04-13-2016), phate (04-13-2016), WetzMS3 (04-13-2016)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f567/e85-e85-mix-ignition-timing-database-100743/
VersaTuner: ????????, ??????????, ????? ?????? This thread Refback 12-28-2015 04:14 AM
What happened to the e85 blend thread? - Page 3 This thread Refback 01-08-2014 09:41 PM
What happened to the e85 blend thread? - Page 4 This thread Refback 01-08-2014 06:44 PM
BNR Tuning - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 06-19-2013 10:24 PM
SpeedyD's Tooning Thread This thread Refback 06-04-2012 06:16 PM
rough tune on e85 = 338/364 - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 05-23-2012 09:20 AM
Fuel Mixtures - SWFL Racing This thread Refback 02-21-2012 12:11 PM
Brakes Database MS3/MS6! jax ms3gt MazdaSpeed 3/6 - Suspension & Brakes 103 09-23-2017 01:14 AM
HOW-TO DATABASE MS6 MATT DAMOND MazdaSpeed 6 - How-To's 42 11-21-2016 07:07 AM
HOW-TO DATABASE MS3 MATT DAMOND MazdaSpeed 3 - How-To's 39 07-15-2015 07:29 AM
Any harm in leaving the ignition timing stock? Qtip MazdaSpeed 3/6 - ECU Computer Tuning 2 03-30-2010 11:30 AM
who's played with there ignition table / timing ?? Wenis Prinkle MazdaSpeed 3/6 - ECU Computer Tuning 5 11-26-2009 04:40 PM
Page generated in 0.58477 seconds with 36 queries
