Like Tree11Likes
 Old 01-16-2012, 09:28 PM   #1
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Default Fuel mix cheat sheets
12-4-2014 UPDATE:
VersaTune cheatsheet added; it only uses FSG, at a higher rate to avoid having to do a scalar as well:
For mixes below 10%, just use the 10% value.
5-21-2014 UPDATE:
No more Google Docs version of the sheet. For the new, standalone HTML version, go here:
New Seasonal Blends by Region table (easier to use):
Seasonal Blends by Region - Mazdaspeed Forums Mazdaspeed 3/6 Wikispeedia
END UPDATE
Original Seasonal Blends by Region table:
Seasonal Blends By Region
For 70%, 75%, 80%, 85% seasonal blends of e85 (ethanol content by volume), also factoring in e10 pump gas. Please let me know if you guys want other blends of e85/e10 done up.
E85 beta scalar cheat sheet:
***NOTE*** This cheat sheet is based on the percentage of ethanol in the tank, NOT the percentage of e85 in the tank (ethanol content by volume). See below sheets for actual %E for use in the above table.
E70 mix cheat sheet:
E75 mix cheat sheet:
E80 mix cheat sheet:
E85 mix cheat sheet:
Actual spreadsheet (which can be modified for other seasonal blends and also has the scalar cheat sheet within it) is also attached now.
Last edited by Enki; 12-04-2014 at 04:01 PM. Reason: Update to OP for new links/information
The Following 69 Users Say Thank You to Enki For This Useful Post:
86AmishMs3 (10-15-2012), Agent_Orange (01-19-2014), Arnie1229 (03-20-2015), Big sugaaakane1 (10-13-2015), Bigeasy (10-10-2013), Bob-o (01-16-2012), BobbleHead (07-23-2012), Boosted Beluga (02-28-2012), Boost_creep (01-17-2012), BrianB6 (02-18-2013), ChimmyChong (06-11-2013), cshunter (12-17-2012), CWP_MS3 (03-11-2013), Dahouse702 (07-02-2012), Dano (02-28-2012), davychronic (06-25-2015), dead-zone (04-10-2013), Decepticon (03-23-2012), djuosnteisn (04-14-2012), donjohnk (03-24-2014), dougefresh_ (01-16-2012), DSIT995 (01-13-2013), eljefe62 (12-30-2012), El_Diablo (07-08-2013), FistPump20fo7 (05-27-2013), galens47 (07-19-2012), GoSpeed3Go (01-16-2012), Gr8Speed (09-17-2014), GrumpyMPS (05-17-2014), harryclay (03-04-2012), JacksonMS30 (04-25-2012), JeffroMS3 (09-17-2013), JgamB (09-01-2015), Juyoung (05-10-2013), k_kid (08-12-2013), mazdaspeed916 (08-21-2012), Mfinlay04 (03-01-2015), Micha (07-01-2012), Mike@Stratified (05-09-2013), mr_mazda329 (08-17-2013), ms3bamf (01-16-2012), ms3blackmica (11-08-2012), msfastashell (08-20-2014), Nataphen (02-28-2012), phate (08-14-2012), Pseud0logik (05-09-2012), rfinkle2 (02-28-2012), Rich990 (06-28-2015), RichieRichness (03-20-2012), Rokusek (03-19-2014), rxtasy7 (03-02-2017), Scribbles (01-16-2012), seshomaru7 (06-12-2013), shadesofgray19 (06-22-2012), Sid3wayS (02-28-2012), simply_pandora (01-05-2013), slickety (02-26-2016), speedy308 (10-18-2012), superskaterxes (02-29-2012), taf0422 (10-25-2012), tegxsi (07-07-2015), the public enemy (08-19-2015), tMC (07-08-2015), Tres3 (09-15-2014), Twofer (02-18-2013), udntknw (01-08-2014), warlord (07-26-2012), WetzMS3 (10-07-2013), wolly6973 (03-01-2012)
 Old 01-16-2012, 09:35 PM   #2
Enki's Avatar
The XLS for whomever wants more granularity, etc.
Made in OpenOffice, not sure if it will have issues with Excel or whatnot.
Edit: Use the XLS in the OP.
The Following 5 Users Say Thank You to Enki For This Useful Post:
mr_mazda329 (05-06-2016), qkrthnu2 (08-05-2015), rfinkle2 (02-28-2012), RichieRichness (03-20-2012), Twofer (02-18-2013)
 Old 01-16-2012, 09:39 PM   #3
GoSpeed3Go's Avatar
Posts: 493   (View Stats)
GoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the world
Groaned at 27 Times in 8 Posts
cool man. was wondering where my 2/5 was.
https://www.facebook.com/NorCalTintZone
instagram: sharpdetails
GoSpeed3Go is offline   Reply With Quote
 Old 01-16-2012, 09:42 PM   #4
Enki's Avatar
Looks like about 19% on winter blend.
 Old 01-17-2012, 10:43 AM   #5
GoSpeed3Go's Avatar
i dont think they switch in cali because of the mild weather.
 Old 01-16-2012, 10:00 PM   #6
Enki's Avatar
I Just realized I should probably post up my method for filling up; the rule of 3.
MS3 has 14.5 gallon tank, but reads E at about 2 gallons; I figure each quarter tank is 3 gallons, making 50/50 mix 1.5 gallons per quarter tank or .75 gallons per 1/8th, with half a tank obviously being 3 each and 3/4 fill-up being 4.5.
While you may not fill all the way up to the neck with this method, you are less likely to fuck up your mix when doing so.
BLURSPORTS likes this.
 Old 02-28-2012, 12:30 PM   #7
Enki's Avatar
Added E85 beta scalar cheat sheet.
Ireland (03-16-2014), MindCrimes (02-28-2012), mr_mazda329 (08-17-2013), rfinkle2 (02-28-2012)
 Old 02-28-2012, 12:48 PM   #8
Enki's Avatar
Everything now in the OP for ease of perusal.
 Old 02-28-2012, 12:51 PM   #9
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
Sweet thank you.
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
Hoyoman (03-31-2013)
 Old 02-29-2012, 08:35 AM   #10
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
This should be stickied.
thanks Enki!
Enki (02-29-2012)
 Old 02-29-2012, 08:43 AM   #11
SRTie4k's Avatar
Posts: 1,715   (View Stats)
SRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the worldSRTie4k is the leader of the world
Groaned at 68 Times in 44 Posts
I might help to change your vocabulary in the first post a little to specify "by volume" as opposed to "by ratio of ethanol to gas".
Otherwise, very helpful, thanks!
08.5 Mazdaspeed 3 - Cobb AP w/ Boost Targetting at 17psi, CP-E Nano SRI, ETS 3.25" TMIC, SU Test Pipe, CP-E RMM, Bilstein Sports, Cobb Springs, Progress RSB, Short Shift Plate, SU Solid Shifter Bushings, Dashhawk, Gold 18x8.5 Rota G-Force's, 235/40/18 Hankook Ventus V12's
253WHP/274WTQ on a Mustang Dyno before tune, 282WHP/318WTQ in VD after tune
97 Suzuki TL1000S Naked - LeoVince Slip-Ons, K&N Filter, PCII, fully custom naked setup
89 Kawasaki 650SX Stand-Up Jetski
SRTie4k is offline   Reply With Quote
The Following User Says Thank You to SRTie4k For This Useful Post:
Enki (03-20-2012)
 Old 02-29-2012, 08:49 AM   #12
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
stuck
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
The Following 4 Users Say Thank You to superskaterxes For This Useful Post:
Boosted Beluga (02-29-2012), Dano (02-29-2012), Enki (02-29-2012), mrmonk7663 (02-29-2012)
 Old 03-12-2012, 11:35 AM   #13
Enki's Avatar
Updated OP with link to seasonal blends by region information for more accurate calculation of mixes based on date.
 Old 07-19-2012, 11:15 AM   #14
Mfinlay04's Avatar
Posts: 827   (View Stats)
Great thread. This shit is priceless.
2006 MS6 Titanium Grey
Tuned with
The Following User Says NO Thank You to Mfinlay04 For This Un-useful Post:
RichieRichness (07-19-2012)
 Old 07-19-2012, 11:38 AM   #15
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
Originally Posted by Mfinlay04 View Post
Great thread. One noob question, just to clarify if one has their MAF tables calibration correctly for pump gas. If we wanted to run some mix of e85 we would just multiple the entire MAF table by X. Whereas X is the value in your tables which relates to the ratio we will be running?
No, the purpose of this thread is to dial in your Injector Control Tables.
The Following 2 Users Say Thank You to RichieRichness For This Useful Post:
Enki (07-19-2012), Mfinlay04 (07-19-2012)
 Old 07-19-2012, 11:35 AM   #16
Enki's Avatar
 Old 07-19-2012, 11:50 AM   #17
Mfinlay04's Avatar
As yes after reading the thread on the computer I see there is a FSG and Scalar for the percent of ethanol used.
Tuned with
The Following User Says Thank You to Mfinlay04 For This Useful Post:
 Old 08-14-2012, 12:45 PM   #18
sidekick's Avatar
Posts: 3,093   (View Stats)
Some people may also find THIS calculator helpful.
The Following 3 Users Say Thank You to sidekick For This Useful Post:
Ferdball (05-15-2014), speeding3 (06-25-2013), Zoorah12 (08-17-2012)
 Old 08-14-2012, 01:00 PM   #19
Enki's Avatar
Unfortunately, that site won't tell you the scalars for the AP, and the mileage shit doesn't apply because we can tune for MUCH better mileage on e85 than a normal, un-tuned flex-fuel vehicle can get (basically close to stock mileage if you keep your foot out of it).
Bucker (08-15-2012), RichieRichness (08-15-2012)
 Old 08-15-2012, 01:41 PM   #20
sidekick's Avatar
It's very useful for figuring out your ethanol mix though.
 Old 08-15-2012, 08:45 PM   #21
Enki's Avatar
Ok...
But the screenshots up top are pretty much laid out so you don't have to type anything into a calculator.
Bucker (08-15-2012)
 Old 10-25-2012, 05:56 PM   #22
Enki's Avatar
Default Fuel Mix Cheat Sheets v.2
Cheat sheets version 2!
Those of you with Google Drive can save this document locally, export it, or run it directly on your Android device! I've tested this from my Android phone and it does work, though you do have to manually refresh so the calculated values update.
My requirements:
1. If you go to use it and see someone else is changing values, please let them finish before you input your own. There is an integrated chat for Google Docs so you can find out how much longer the other person(s) will be.
2. Don't fuck up the maths on this thing or deface it with ascii cocks or anything. I may not be available to fix or reload it; if this gets to be a consistent problem, I'll probably wind up taking it down.
With that out of the way, on to the good shit!
Here is what it looks like:
Some quick notes:
1. The seasonal blend information is editable in the table to the right, and is also included as images embedded directly into the file; these images are also embedded at the end of this post.
2. The manual mix output uses the %Ethanol values you specify in the sheet up top; the seasonal mix output uses the lookup table at the right for minimum ethanol content in said e85 (instead of using the %E value in B1).
3. The "Reblend gallons" value is for when you have a partial tank of mix and have to get fuel from some place that doesn't have corn available. Specify your remaining fuel quantity using the E85 and Pump gallons sections (make sure the manual mix value matches what you are running) and then play with the reblend gallons value to see how much adding pump gas to your existing mix will change your overall percentage.
4. That is all.
Here's the link to the spreadsheet; try not to fuck it up:
https://docs.google.com/spreadsheet/...0lmUjcwR3R2Ync
Seasonal blend information:
This version replaces the older one, still available here:
Rokusek and Caligula like this.
The Following 9 Users Say Thank You to Enki For This Useful Post:
Caligula (10-25-2012), Dano (10-25-2012), Dimenus (06-11-2013), Pu Manchu (10-25-2012), Rokusek (03-19-2014), TiGraySpeed6 (10-26-2012), Twofer (02-18-2013), WetzMS3 (10-21-2013), wolly6973 (10-25-2012)
 Old 10-25-2012, 06:05 PM   #23
5000lbs of voiceless fury
Caligula's Avatar
Posts: 3,140   (View Stats)
Caligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the world
Groans: 185
Groaned at 124 Times in 81 Posts
good deal.
2015 Telsa Model S 85D - Delivered 10/21/2015 FYEN!
SOLD!!! 2007 Mazda MS6 - //AWD//BNR S3//cp-e TMIC//cp-e CDFP//Cobb AP//Cobb TIH//Cobb EBCS//Bosch 845 3 Bar//MS-CAI//Custom DP//TS Kompact BPV//Magnaflow CBE//AWR RMM//JBR Stage 3 SSP Kit//JBR EGR Delete//H&R Springs//
Caligula is offline   Reply With Quote
 Old 10-25-2012, 05:57 PM   #24
Enki's Avatar
Mods please un-sticky; has been replaced by new version:
 Old 10-25-2012, 07:04 PM   #25
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
I think the original thread is too valuable to un-sticky, so they're merged
The cheat sheets are a seriously nice quick reference. I use them often when I'm out and don't want to calc this stuff, haha.
-06 MS6
-Corn fed 07 MS3 - Sold
Dano (10-25-2012), Enki (10-25-2012), TiGraySpeed6 (10-26-2012)
 Old 12-17-2012, 01:39 PM   #26
Jh8909's Avatar
Posts: 1,457   (View Stats)
Groans: 130
Groaned at 8 Times in 7 Posts
What I don't get about this is that even though the MS6 has a 16 gallon tank, it never will fill up 16 gals at the pump. The charts are all based on if you literally put 16 gallons in the tank which I think is impossible. Unless I'm doing something wrong I don't think I've ever filled up past 14 gallons when I take the car till the gas light comes on.
and I have everyone telling me that 3 gallons of E85 is all I will ever need. Ok thats great.
The problem is partial fill ups. There are going to be times where I can't wait to take the car down till the gas light comes on to fill up. So how do I know for sure what of each type of fuel to put in when I go to the station to partially fill up?
 Old 12-18-2012, 09:05 PM   #27
dantes5823's Avatar
Posts: 6,576   (View Stats)
You need to realize that if your off by some nothing bad is gonna happen. if you start pumping and walk away and come back with a full tank of eth then possibly. But even then its not an OMG MY CAR IS GONNA DIE. If you cant fill up close to e one day then just flash back to a none eth tune. Your trims will go wonky for a bit and you'll be fine. You will never be perfect. Unless you completely drain the tank and the line and measure it out it will always be off by a hair.
The Following 2 Users Say Thank You to dantes5823 For This Useful Post:
Jh8909 (12-18-2012), RichieRichness (12-19-2012)
 Old 12-17-2012, 02:26 PM   #28
Groans: 35
Just eye ball it dude. This shit is not an exact science.
The Following 3 Users Say Thank You to RichieRichness For This Useful Post:
Enki (12-18-2012), Jh8909 (12-18-2012), phate (12-17-2012)
 Old 12-17-2012, 02:28 PM   #29
Eth Fiend
phate's Avatar
Just remember to err on the high side of ethanol. The little bit of leanness you mightbutprobablywont encounter will be offset by the increase in effective octane.
-06 MS6
Jh8909 (12-18-2012), RichieRichness (12-17-2012), wolly6973 (12-17-2012)
 Old 12-18-2012, 09:51 AM   #30
Enki's Avatar
Or if you know how many gallons actually fit, you could always *use the cheatsheets* to figure out how much to use for the mix.
Jh8909 (12-18-2012), phate (12-18-2012), wolly6973 (12-18-2012)
 Old 04-16-2013, 10:03 AM   #31
Roddiy's Avatar
Posts: 5,388   (View Stats)
Groans: 279
@Enki;
The Injector Scalar table in AP is rounding my value of 1.0266 to 1.03, is that ok?
2010 LSM Speed3
#BakeryTuned
 Old 12-19-2012, 12:52 PM   #32
Trail of Fail
Dano's Avatar
What you don't want to do is continue to use the "top off" method. Your E concentration will continue to move one way or another depending on which fuel you top off with.
Tappin
Enki (12-19-2012), polishlanman (01-27-2013)
 Old 04-16-2013, 10:30 AM   #33
Enki's Avatar
Yeah.
phate (04-16-2013), Roddiy (04-16-2013)
 Old 06-12-2013, 04:26 PM   #34
seshomaru7's Avatar
Posts: 182   (View Stats)
seshomaru7 is a name known to allseshomaru7 is a name known to allseshomaru7 is a name known to allseshomaru7 is a name known to allseshomaru7 is a name known to allseshomaru7 is a name known to all
Good stuff. I should be going BNR S3 soon and have one gas station 2 miles away with 100% pure gas (91 octane) and another 2 miles away currently with E70 (E85 Winter blend.) Mixing 5.25 gal of E70 and 7 gallons of pure gas should give me an E30 mix!
Need a way to mount your Devil's Own methanol kit? Find my F/S thread for a custom made mount kit with all hardware included!
seshomaru7 is offline   Reply With Quote
 Old 08-24-2013, 05:01 PM   #35
Enki's Avatar
I've added a secondary tab to the Google Docs spreadsheet calc which has the lambda/afr/max power (lean and rich) info in it across a very wide range; hopefully someone finds it useful, though it isn't specifically required for tuning our cars.
El_Diablo (08-26-2013)
 Old 10-24-2013, 02:16 PM   #36
Enki's Avatar
Third tab added for new version of the calculator which makes for easier blending math:
https://docs.google.com/spreadsheet/...nc&usp=sharing
Rokusek likes this.
The Following 8 Users Say Thank You to Enki For This Useful Post:
El_Diablo (10-24-2013), JeffroMS3 (10-24-2013), josurr (10-24-2013), maxspeed (10-24-2013), Rokusek (03-19-2014), simply_pandora (10-31-2013), WetzMS3 (10-24-2013), wolly6973 (10-24-2013)
 Old 03-28-2014, 11:39 PM   #37
Enki's Avatar
Whoever the stupid shit(s) is(are) that keeps editing cells they shouldn't is going to get the spreadsheet taken down.
Just sayin.
Boosted Beluga (03-29-2014), Jap11g (03-28-2014), littleloogy (03-29-2014), Mulenax (03-29-2014)
 Old 03-29-2014, 02:12 AM   #38
Mulenax's Avatar
Posts: 34   (View Stats)
Mulenax is a jewel in the roughMulenax is a jewel in the roughMulenax is a jewel in the roughMulenax is a jewel in the rough
wow, Im gunna make some print outs of this and hand them out at the next meet after choppin' some heads. Awesome thread enki!
Mulenax is offline   Reply With Quote
 Old 03-29-2014, 08:28 AM   #39
littleloogy's Avatar
Posts: 4,005   (View Stats)
Just tell them where to find it. Plagiarism pisses me off. Unless you put MSF on the cards, then I guess it would be OK.
Sent from a Galaxy far far away...
Mulenax (03-29-2014), Vansquish (09-28-2015)
 Old 03-29-2014, 02:11 PM   #40
Mulenax's Avatar
trust me, they know im far to old and tarded to figure this kind of stuff out on my own. ENKI will get full credit for sure...
The Following User Says Thank You to Mulenax For This Useful Post:
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f567/fuel-mix-cheat-sheets-102438/
E70 This thread Refback 12-30-2015 12:28 PM
b00stedmica93's Tuning - Page 5 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 03-04-2014 01:35 PM
Going to try E30 today This thread Pingback 01-20-2014 09:40 AM
What happened to the e85 blend thread? - Page 4 This thread Refback 01-08-2014 06:44 PM
What happened to the e85 blend thread? - Page 3 This thread Pingback 01-08-2014 11:28 AM
93 GMC Typhoon - Page 16 - Motorgen - Automotive Events, Meets, Cruises and Forums This thread Refback 03-19-2012 09:16 AM
Mazda whips the sheets off of MX-5 Miata Miyako for UK market Haltech Automotive News 0 06-30-2010 08:00 AM
18 psi DynoJet Dyno Sheets 18psiWhiteMS3 MazdaSpeed 3/6 - Big Turbo Builds 13 04-08-2010 09:59 AM
Overstock. com - 5% Off Storewide & Free Shipping on Sheets at Overstock.com Haltech Hot Deals Section 0 04-15-2008 07:40 AM
New SmartBargains Coupon Codes - Extra 25% Off Select Luxury Sheets at SmartBargains Haltech Hot Deals Section 0 04-14-2008 01:50 PM
Page generated in 0.60723 seconds with 37 queries
