Like Tree11Likes
 Old 05-17-2014, 02:16 PM   #41
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Got tired of fixing shit once a week, so everyone gets to use the static sheets until I can figure out how to turn the calculator into a wiki page.
Boosted Beluga (05-18-2014), littleloogy (05-18-2014), Micha (12-29-2015)
 Old 05-21-2014, 03:28 AM   #42
Enki's Avatar
Quick and dirty basic calc in html format. Should work on all browsers/platforms, though I couldn't figure out how to open the html with my browser on my phone; gave up after 30 seconds.
File Type: zip Enkiworks_CornCalc.zip (672 Bytes, 344 views)
The Following 7 Users Say Thank You to Enki For This Useful Post:
andrewz17 (05-29-2014), Ireland (05-21-2014), littleloogy (12-09-2014), Micha (12-29-2015), qkrthnu2 (08-05-2015), shaneski (05-21-2014), WetzMS3 (05-21-2014)
 Old 05-21-2014, 04:05 AM   #43
shaneski's Avatar
Posts: 506   (View Stats)
Brilliant work, came up looking like an unknown file in chrome but it opens fine and works a treat, the cheat sheets etc in this thread are priceless with how easy it is to mix/tune...Thank you sir
The Following User Says Thank You to shaneski For This Useful Post:
Enki (05-21-2014)
 Old 05-21-2014, 10:42 AM   #44
Enki's Avatar
I'll eventually improve the looks and functionality and whatnot in this file, but for now, it's better input wise than the static sheets.
monkey.bones.007 (05-21-2014)
 Old 05-21-2014, 10:48 AM   #45
Enki's Avatar
OP updated.
littleloogy (05-22-2014)
 Old 05-30-2014, 11:08 AM   #46
swd120's Avatar
Posts: 126   (View Stats)
swd120 has a reputation beyond reputeswd120 has a reputation beyond reputeswd120 has a reputation beyond reputeswd120 has a reputation beyond reputeswd120 has a reputation beyond reputeswd120 has a reputation beyond reputeswd120 has a reputation beyond reputeswd120 has a reputation beyond reputeswd120 has a reputation beyond reputeswd120 has a reputation beyond reputeswd120 has a reputation beyond repute
Downloaded file is corrupt for me... Alternate link anyone?
Edit: Nevermind - Winzip thinks its corrupt, 7zip work fine. My dumbass company uses winzip for a default.
swd120 is offline   Reply With Quote
 Old 12-04-2014, 04:00 PM   #47
Enki's Avatar
VersaTune cheatsheet added to OP.
Mfinlay04 likes this.
GrumpyMPS (12-27-2014), littleloogy (12-04-2014), Mfinlay04 (03-01-2015), phate (12-04-2014)
 Old 12-22-2015, 05:22 PM   #48
BuddySpeed3's Avatar
Posts: 479   (View Stats)
Groaned at 7 Times in 4 Posts
Would these cheat sheets work for 1 gallon of methanol in the tank?
I know ethanol and methanol have differences in their stoichiometry
 Old 12-22-2015, 05:37 PM   #49
Enki's Avatar
1 gallon will trim out to almost nothing; probably not needed to tune for it.
 Old 12-23-2015, 10:06 AM   #50
I guess I'll try using the same fuel gravity and injector scalar values for 1 gallon of ethanol and see how it goes. Also, how do you tell if the values are off? Will the LTFT's be out? Or will AFR at WOT be out? Sorry I'm new with fueling stuff, Thanks
 Old 12-23-2015, 10:23 AM   #51
Enki's Avatar
You don't need to tune for a gallon of methanol in the tank. It will be more of a headache than it's worth.
 Old 12-23-2015, 04:43 PM   #52
Okay gotcha, but out of curiosity, would not tuning the Fuel Gravity and Scalars make my Actual AFR's read slightly leaner due to the added oxygen content from the methanol? Or would the ECU compensate by adding more fuel,
making my LTFT's more positive. I can understand that running much larger percentages of alcohol in the tank would require Fuel gravity and Scalars to be modified as the variance in the MAF Curve would be out of spec to the
point of triggering the check engine light. Does it sound like I have the right idea? Cheers
 Old 12-23-2015, 04:45 PM   #53
littleloogy's Avatar
Posts: 4,005   (View Stats)
Originally Posted by BuddySpeed3 View Post
Ok gotcha, but what would change in my logs if I don't tune for it?
You will notice more positive LTFT's. I would not sweat over a one gallon mix.
 Old 12-23-2015, 05:38 PM   #54
Okay thank you. Do you think I will be knock limited with only 1 gallon in the tank? I'm just wondering if I should street tune it, or take it to a dyno.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f567/fuel-mix-cheat-sheets-102438/
E70 This thread Refback 12-30-2015 12:28 PM
b00stedmica93's Tuning - Page 5 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 03-04-2014 01:35 PM
Going to try E30 today This thread Pingback 01-20-2014 09:40 AM
What happened to the e85 blend thread? - Page 4 This thread Refback 01-08-2014 06:44 PM
What happened to the e85 blend thread? - Page 3 This thread Pingback 01-08-2014 11:28 AM
93 GMC Typhoon - Page 16 - Motorgen - Automotive Events, Meets, Cruises and Forums This thread Refback 03-19-2012 09:16 AM
Mazda whips the sheets off of MX-5 Miata Miyako for UK market Haltech Automotive News 0 06-30-2010 08:00 AM
18 psi DynoJet Dyno Sheets 18psiWhiteMS3 MazdaSpeed 3/6 - Big Turbo Builds 13 04-08-2010 09:59 AM
Overstock. com - 5% Off Storewide & Free Shipping on Sheets at Overstock.com Haltech Hot Deals Section 0 04-15-2008 07:40 AM
New SmartBargains Coupon Codes - Extra 25% Off Select Luxury Sheets at SmartBargains Haltech Hot Deals Section 0 04-14-2008 01:50 PM
Page generated in 0.36290 seconds with 25 queries
