 Old 02-16-2012, 04:54 PM   #1
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Default HOWTO: Spill Valve SST
Step 1:
Obtain 12 POINT 32mm socket from local or online shop. Make sure it's got some depth to it, like this one:
Step 2:
Cut a box out of it with a Dremel or equivalent, preferably at the thin points on the socket wall (so it doesn't take as long):
Note 1:
You may want to bevel the cut made at the top of the socket so it doesn't touch the plastic connector on the top of the spill valve. If it does touch and your socket isn't beveled there, no worries; just be aware not to put as much vertical pressure on it.
Note 2:
If it doesn't line up right for some reason, don't be afraid to cut another tooth out of the wall of the socket. you only need slightly more than half of the socket wall to get a good bite, as the spill valves are not torqued to a high degree.
When done, it should look similar to this (note that mine is not beveled):
The Following 7 Users Say Thank You to Enki For This Useful Post:
ak_spray (04-14-2012), forcedinduktion (02-16-2012), JTMS3 (05-01-2012), Mizzle (02-16-2012), mrmonk7663 (02-16-2012), phate (02-17-2012), TiGraySpeed6 (02-17-2012)
 Old 02-16-2012, 04:58 PM   #2
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,719   (View Stats)
Groans: 70
Great write up! Nice little tool. I just used channel locks.
 Old 02-16-2012, 04:59 PM   #3
Enki's Avatar
I have a 32mm box end, but was still managing to mar the fuck out of my pump.
 Old 02-16-2012, 05:52 PM   #4
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
Thank you for this
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
 Old 02-16-2012, 06:02 PM   #5
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
Why not a wrench?
 Old 02-16-2012, 07:50 PM   #6
Enki's Avatar
Have you seen a 32mm box end? It's over a foot long.
 Old 02-16-2012, 07:59 PM   #7
Must Have Teh 10's!
superskaterxes's Avatar
Posts: 10,442   (View Stats)
adjustable wrench?
First K04 in the 12's
First MS6 in the 11's
Certified RichTune E-Tuner
 Old 02-16-2012, 08:01 PM   #8
Mizzle's Avatar
Groans: 324
That's what she said.
The Following User Says Thank You to Mizzle For This Useful Post:
karl-hungus (02-17-2012)
 Old 02-16-2012, 08:44 PM   #9
Enki's Avatar
Still get occasional clearance/marring issues even with an adjustable wrench.
 Old 02-17-2012, 09:07 AM   #10
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Handy- Thanks for this!
340hp / 371tq
HOW TO: Remove & Disassemble HPFP Spill Valve silvapain MazdaSpeed 3/6 - E85 Fueling 139 04-09-2018 04:02 AM
Spill valve spring mod Enki MazdaSpeed 3/6 - E85 Fueling 15 02-02-2014 11:01 AM
How's about HOWTO videos? bertrand_CX_7 Website Help/Feedback 0 04-28-2011 08:22 AM
Page generated in 0.30877 seconds with 26 queries
