View Poll Results: If Available Would You Buy it
Yes 39 82.98%
No 4 8.51%
Need More Info 4 8.51%
Voters: 47. You may not vote on this poll
Like Tree24Likes
 Old 01-05-2016, 02:00 PM   #41
Gr8Speed's Avatar
Posts: 5,702   (View Stats)
Timing is too important on these engines to let software manage it.
Plenty of other platforms (Focus ST and BMW in my own experience) compensate timing based on other variables with success. Timing is important on all engines, not just these. I agree failsafes would need to be implemented, but not tuning ignition for different mixes of fuel is just silly. We have knock sensors for a reason. Obviously user input would need to be in primary control (maximum ignition advance per cell table) Personally, I'd advocate having a map-able matrix to control this based on input sensor voltage and just smooth between given inputs (basically at ethanol content X, user input dictates this ignition advance, and at ethanol content Y, user input dictates a given ignition advance- interpolate between the given values). There should be relatively simple ways to implement a control loop based on a given failsafe parameter (knock sensor voltage for example). I'm not sure the ins and outs of how Versatune operates, but a PI controller probably could be set up to do the job.
TL;DR it won't be easy, but it should be able to be done safely.
 Old 01-06-2016, 09:32 AM   #42
ArmanRus's Avatar
Posts: 1,566   (View Stats)
Groans: 42
Maybe something similar to the AEM EMS on Evos where a separate table defines the relationship between the pump gas table and E85 table.
 Old 01-06-2016, 11:46 AM   #43
So my next question for @Steve@VersaTune; is when is the next sale on VT?
 Old 01-06-2016, 11:47 AM   #44
Steve@VersaTune's Avatar
Posts: 432   (View Stats)
There is nothing planned at this point. A group buy might be in order when this launches.
nindoja and Mazdazilla6 like this.
Steve
Lead Tuner
The Following 2 Users Say Thank You to Steve@VersaTune For This Useful Post:
Enki (01-06-2016), Mazdazilla6 (01-06-2016)
K1 Rods able to Support 30R? MS3SHITBOX MazdaSpeed 3 - Engine, Transmission & Driveline 16 06-20-2010 01:47 AM
Page generated in 0.27971 seconds with 25 queries
