| MazdaSpeed 3/6 - E85 Fueling Learn more about feeding your car corn |
![]() | | #321 | ![]() |
![]() Join Date: Aug 2012 Location: Ripon, CA
Rep Power: 2958 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,390
Yes, they come standard with a hard plastic oil scraper and and spring loaded o-Ring. Similar to the seals in the IE retaining nut, just a smaller size (AT, Corksport, Ect) Sent from a Galaxy far, far away... | |
| The Following User Says Thank You to littleloogy For This Useful Post: | Enki (02-07-2016) |
![]() | | #322 | ![]() |
| Not Ranked : 0 score So are those seals are what was keeping the spill valve clean with the IE internals?
![]() | | #323 | ![]() |
| Not Ranked : 0 score If they are effectively keeping the oil out of the pump, then yes.
__________________ |
![]() | | #324 | ![]() |
![]() Join Date: Oct 2011 Location: FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 601
Groans: 106
![]() | | #325 | ![]() |
| Not Ranked : 0 score Good shit, but we need to correlate it to death production; it might be that using (and I say this while cringing) a pressure cooker to see what temps develop death with specific oils, and then working to prevent the temp of the HPFP from reaching that high. Edit: Using a pressure cooker will prevent the e85 from boiling off into the air and thus allow much better control of temperature for reproduction of the issue; I'm positive it's not boiling in the pump until after the engine is shut off and begins venting excess pressure back into the tank. Bearing that in mind, perhaps I'll manage to work a small cooling circuit into the mount that the HPFP bolts to, either feeding it cool oil or integrating a water cooling passage (oil would likely be more effective, as it will cool the internals directly, though).
![]() | | #326 | ![]() |
Groans: 106
| Not Ranked : 0 score That is exactly where I was going with the data collection. Determining what the highest temperatures that the HPFP, and thereby fuel, experiences and working to reduce it. Interesting point in that graph is the temperature reduction after a long idling shutdown at 17:15 and the spikes seen twice afterwards. Afterwards was a non WOT, but spirited drive home. edit. I have AP logs for these too if anyone sees value in comparing them to this. |
![]() | | #327 | ![]() |
| Not Ranked : 0 score How did you pull this data, by the way? I'm planning to integrate a Megasquirt into my build and this might be something I can look into monitoring long term.
![]() | | #328 | ![]() |
Groans: 106
| Not Ranked : 0 score I have a 3 port datalogger that I have calibrated at work. All ports are +2 deg F. 5 second recording interval. Looking for link now. Was like $300 something. Edit: Has an RS232 port as well, for remote monitoring. |
| The Following 3 Users Say Thank You to JSmith For This Useful Post: |
![]() | | #329 | ![]() |
Groans: 143
| Not Ranked : 0 score Bump. I might be in the market for some new internals soon. Any progress on either nitriding the CS/AT internals or finding a way to reduce the weight of the IE internals, or upgrade the cam follower?
| The Following 2 Users Say Thank You to MD1032 For This Useful Post: | Mauro_Penguin (06-22-2016), WetzMS3 (06-20-2016) |
![]() | | #330 | ![]() |
![]() Join Date: Jul 2014 Location: San Antonio, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 97
| Not Ranked : 0 score Sorry to resurrect this thread after about a year... I'm interested in going full E soon and testing out some hardware fixes for the issues. I just swapped my HPFP internals to IE ones and replaced the cam follower with a brand new one. The old follower looked worn but then again, my car has just over 80k miles on it. This will let us know definitively whether or not the IE internals are causing this advanced wear of the cam follower or not. I'll pull the cam follower out after a few thousand miles and then post the results on here. Pics of the old follower (right) compared to the new follower (left): ![]() ![]()
__________________ 2012 MazdaSpeed3 with Tech Stock AF |
| The Following 2 Users Say Thank You to stoickiwi For This Useful Post: | Mauro_Penguin (04-09-2017), thrisnospork (04-08-2017) |
![]() | | #331 | ![]() |
| Not Ranked : 0 score Nah mine looks like that with only ever having used Autotechs.
![]() | | #332 | ![]() |
| Not Ranked : 0 score Good to know mine looks normal for using AT's. It'll be interested to see if @littleloogy;'s wear results are replicated when I pull the pump in a while. Sent from my iPhone using Tapatalk
__________________ 2012 MazdaSpeed3 with Tech Stock AF Last edited by stoickiwi; 04-11-2017 at 02:06 PM. |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f567/ie-hpfp-internals-e85-188283/ | ||||
| E85 map build - Page 3 | This thread | Pingback | 05-21-2015 03:25 PM | |
| First log with HPFP internals | oOfactoryOo | 2010 MS3 - ECU Computer Tuning | 11 | 03-23-2014 12:12 PM |
| HPFP internals or new HPFP? | JAGspeed6 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 11 | 11-26-2011 02:34 PM |
