Like Tree46Likes
 Old 08-17-2012, 10:21 PM   #1
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Default Kings of Corn (HPFP + OIL)
OK for those of you running pure e85, what oil are you running and how long between HPFP/spill valve cleanings are you able to go (distance or time)?
I've been on Rotella T6 and can't go very long without having the spill valve go out on me.
Edit: I'll database responses in OP.
Oil and E responses:
Rotella T6 5-40:
Enki: Sticky and black death
Phate: Sticky and black death
GLORIFIEDBOZO: Sticky and black death; cleaned monthly
Silvapain: No issues (pending confirmation)
Metallemur: No issues
VR1 10-30:
Enki: Low mileage sticky death
Mazdafreak: No issues (pending long term testing)
GLORIFIEDBOZO: No issues
Mobil 1 10-30:
Khopwood77: No issues
Royal Purple 10-30:
Royal Purple 5-30 DEXOS1:
Enki: Sticky death, off and on; best oil I've tested yet (on full E85) Testing ended due to big turbo.
Pennzoil Platinum Full Syn 5-30:
Enki: Low mileage pressure drop; sticky and black deaths
Pennzoil Ultra 5-30:
littleloogy: < 500 miles Sticky and black deaths
rfinkle2 and GLORIFIEDBOZO like this.
The Following 19 Users Say Thank You to Enki For This Useful Post:
09speedaddict (09-11-2012), 86AmishMs3 (08-20-2012), atvfreek (08-20-2012), Constantin (08-21-2012), cyber-ms3 (07-29-2013), dead-zone (09-15-2012), Easter Bunny (08-20-2012), eljefe62 (01-12-2013), Fobio (03-21-2014), helmetface (08-20-2012), Ireland (02-23-2014), josurr (09-19-2013), mazdafreak (08-18-2012), phate (08-17-2012), radioflyer (08-20-2012), rfinkle2 (08-20-2012), Speed_j23 (09-22-2012), Tomas (07-13-2013), WetzMS3 (10-07-2013)
 Old 08-17-2012, 10:23 PM   #2
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Same. And it makes me sad.
-06 MS6
-Corn fed 07 MS3 - Sold
Enki (08-17-2012), rfinkle2 (08-20-2012)
 Old 08-17-2012, 10:38 PM   #3
chuckms6's Avatar
Posts: 1,618   (View Stats)
just curious as ive never looked at the spill valve, how would the type of oil affect the life of a fuel system component?
Megan Racing Coilovers
13.7@ 96 w/1.8 60ft (SRI, AP)
The Following User Says Thank You to chuckms6 For This Useful Post:
Enki (08-17-2012)
 Old 08-17-2012, 10:43 PM   #4
Enki's Avatar
It's less of a life issue and more of an issue with the chemical properties of the oil. My testing indicates that if you boil e85 with trace amounts of Rotella T6 in it (and yes, I actually did this), that the oil will leave a sticky residue behind. The fuel itself did not do this (after a half gallon) but the second I put some drops of oil in, shit got real.
And yes, e will boil inside your fuel pump.
rfinkle2 and Atticaz like this.
The Following 13 Users Say Thank You to Enki For This Useful Post:
atvfreek (08-20-2012), Boost_creep (08-19-2012), BrianB6 (12-19-2012), Constantin (08-21-2012), Easter Bunny (08-20-2012), Ms3_Miami (12-26-2012), MSP6 (08-19-2012), radioflyer (08-20-2012), rfinkle2 (08-20-2012), ScarMS3 (08-18-2012), silvapain (08-18-2012), SLOWHATCH (08-18-2012), Tokay444 (08-19-2012)
 Old 08-18-2012, 09:46 AM   #5
Speeden6's Avatar
Posts: 598   (View Stats)
Speeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the worldSpeeden6 is the leader of the world
Sub for more infor!
so when you say "Pure E85" you talking 100% mix? I have heard so many people talking about spill valve troubles with E85 it makes me worry, im running it without issues yet, have only 1K on the clock with it at a 30% mix. teach oh wise ones !
2007 MS6 -
CPE TMIC, CS HPFP Internals, CS Stage 2 Intake and Inlet, Turbo Smart 50/50 BPV / BOV, Catless DP
2006 Acura TL Fully bolted and Running Nitrous! 330WHP SOLD
SOLD 1992 Corrado VR6
268 Cams, air intake, cat back, upgrade plugs and wires, coilovers.
SOLD
2001 Audi Allroad
SOLD
2006 MS6 -
CAI, TIP, ETS TMIC, AutoTech Internals, TBE catless, E85 30%,
19PSI, Cobb AP, RMM, K04, HKS SSQ4 VTA,
TUNED BY LEX FOR 330 AWHP / 380 TQ
Custom tune by
The habits we form today are the ones that Define us tomorrow
Speeden6 is offline   Reply With Quote
 Old 08-18-2012, 10:47 AM   #6
Enki's Avatar
Yes, nothing but the purest.
 Old 08-18-2012, 11:36 AM   #7
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
I ran T6 on E85 the whole time. I'm going to try something different on the new engine (not sure what yet).
Tapadatass
defprun likes this.
Enki (08-18-2012), Ms3_Miami (12-26-2012), rfinkle2 (08-20-2012)
 Old 08-18-2012, 11:42 AM   #8
mazdafreak's Avatar
Posts: 2,610   (View Stats)
Groans: 124
I run the vr1 racing oil....I clean my spill valve about every week just so fp doesn't drop when I'm cruising somewhere, just to be on safe side and I have pulled my pump, and it has been spotless clean....both the spill valve and hpfp are spotless after pulling pump....I have had no problem at all on the vr1 oil!
I uploaded pics of me finally pulling the pump after 1500+ on the other thread and it was spotless, barely any spec of black, that was just between the treads tho.
713whp/569wtq!
10.72 @ 139.44! (10/1/2015)
10.43 @ 140.95! 10/9/2015
10.35 @ 140.86 (10/30/2015)
The Following User Says Thank You to mazdafreak For This Useful Post:
Enki (08-18-2012)
 Old 08-18-2012, 12:28 PM   #9
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,719   (View Stats)
Groans: 70
That's just way overly anal and unnecessary to clean it every week. Maybe at 1k intervals. Ive been on 50 50 for almost 5k now and FP is the same since my first fill. And I am using T6 as well.
The Following 2 Users Say Thank You to forcedinduktion For This Useful Post:
Enki (08-18-2012), radioflyer (08-20-2012)
 Old 08-18-2012, 01:50 PM   #10
Enki's Avatar
Just so you guys know, this thread is about people running extremely high (>50%) to full on e85; not cut with gas.
@silvapain: Is your post in reference to running pure e85?
@mazdafreak: Do you have any buildup of sticky residue? What ratio of city to highway driving do you do? Also, even if your pressure does drop out, you won't hurt the motor; if you could run it twice as long before next cleaning and report the results, I'd (and the community) would appreciate it greatly. As for losing pressure: trust me; both Phate and myself have had it happen at WOT. On a secondary side note, it is possible to hit freeway speeds with only ITFP pressure; you just accelerate slow as balls.
Sickspeed3 likes this.
 Old 08-18-2012, 04:08 PM   #11
mazdafreak's Avatar
Groans: 124
It takes me 5 mins to clean my spill valve, and I do it just cause I don't want my fp to drop like over the weekend cruising around etc.....it doesn't bother me at all...and I have not seen one problem running 50/50... Spill valve only takes a shit on 100% from what I have seen/read.
Yes, I run 100% e85! I am about to attach pics of what my pump looked like after 1500+ miles without a cleaning, i just cleaned the spill valve every other week just cause I didn't want pressure to drop....and I have had my pressure drop a lot when I was running t6, had to clean every week since fp would drop to 50 psi just cruising and at WOT, not fun when it happens lol......I switched to vr1 oil and no problems yet.
And after Friday, I will not clean anything till fp drops, since I'm going to the drag strip on Friday.
713whp/569wtq!
The Following 4 Users Say Thank You to mazdafreak For This Useful Post:
Constantin (08-21-2012), Easter Bunny (08-20-2012), Enki (08-18-2012), rfinkle2 (08-20-2012)
 Old 08-18-2012, 05:03 PM   #12
Enki's Avatar
Is any of that sticky like glue? If not, your not going to have spill valve issues.
 Old 08-18-2012, 05:20 PM   #13
Voltwings's Avatar
Posts: 3,713   (View Stats)
A buddy and i were talking about this the other day and threw out the idea that perhaps different internals are effected differently? It seems the majority of people are running Autotechs / KMD's but theres still the CP-E and others out there, there have to be other variables than simply the motor oil you're using... I am by no means an expert on this subject nor running high amounts of e85, just found it ironic we were just on this subject the other day and thought id throw it out there.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
 Old 08-18-2012, 05:55 PM   #14
mazdafreak's Avatar
Groans: 124
Umm, tell u the truth, I don't remember all that much, been a lil while, plus I switched back to 93 for awhile and seafoamed the tank....but from what I recall, it wasn't super sticky, just a tad bit tho.
Yeah, I wondered the same, I run the cpe pump and haven't had as many problems as some have, idk what different things cpe uses or what, but idk.....but I also don't think I have been running it as long as some...I'm probably round 7000+ miles on 100% 85.
713whp/569wtq!
 Old 08-18-2012, 06:49 PM   #15
Voltwings's Avatar
im using the Cp-E as well, was wondering if people having the issues had autotechs because i know the CP-E has a larger spring and plunger after doing a few installs with autotechs???
Past:
-Sold-
-Sold-
Current:
 Old 08-18-2012, 07:18 PM   #16
mazdafreak's Avatar
Groans: 124
Exactly what I saw....its a 20mm to take the cpe internals out....and 18 all for autotech.....hmmm, I guess something to factor in?
713whp/569wtq!
 Old 08-18-2012, 07:54 PM   #17
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
has the idea of a fuel cooler ever been brought up?
The Following User Says Thank You to dooderek For This Useful Post:
Enki (08-19-2012)
 Old 08-19-2012, 12:26 AM   #18
Enki's Avatar
Yes, and the best way would actually be tigs on the pump most likely, however, that would only temporarily reduce temps, as there's hot head oil splashing the pump constantly.
As for fuel cooling, the best way would be to tap into the rail return line and split a separate line off that as an actual return line for a return style fuel system (taking the regulator out of the fuel pump basket for an external one probably...Maybe.
Either way, it's going to be a lot of custom work, and not what this thread is about.
rfinkle2 (08-20-2012), Voltwings (08-19-2012)
 Old 08-19-2012, 03:07 PM   #19
MSP6's Avatar
Posts: 1,246   (View Stats)
Enki you mentioned the residue left by the T6 when boiled along with the E85. With mazdafreak having some success with his VR1, have you considered smaller scale boil offs with multiple grades/brands etc of oil? Then if you did find a winner, or considerably better performer we could figure out whats different between them. Just a thought though I'm sure it's been covered or mused over already I'm probably just not seeing it.
The Following 3 Users Say Thank You to MSP6 For This Useful Post:
G26 (08-20-2012), mazdafreak (08-19-2012), Neverlift (08-20-2012)
 Old 08-19-2012, 04:46 PM   #20
Enki's Avatar
The t6 testing resulted in fire.
While I *could* continue testing like that, the temps needed to duplicate the result with t6 will probably result in more boiling fuel fires.
Easter Bunny (08-20-2012), GLORIFIEDBOZO (08-19-2012), v8killer (08-29-2012)
 Old 08-19-2012, 05:01 PM   #21
mazdafreak's Avatar
Groans: 124
I am replacing my itfp with the new 265 pump on hopefully Thursday.....So ill have pics up of what the filter looks like!
713whp/569wtq!
 Old 08-19-2012, 06:28 PM   #22
khopwood77's Avatar
Posts: 245   (View Stats)
khopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the worldkhopwood77 is the leader of the world
Well I'll chime in with my experience thus far on 100% e85. My 2010 has about 38k miles of mainly highway commutes to work. I have been on e85 for 25k miles and haven't cleaned the spill valve for many months (at least 5). I have been using moble1 since the first oil change.
After the initial switch to 100% from partial mixes, I had the normal issues that all the others mentioned. Cleaning my pump and spill valve would return my pressure to normal levels. I didn't mind going through this hassle as my car would remind me when its time to clean with low fuel pressure and little to no pressure on startup.
Fast forward to ptp rail valve... I haven't had a single issue since I changed it out months ago. My stock rail valve was leaky and the car had only 15k miles on it. I don't know if it was a factory defect because I never ran pressures over 1700. Now with the ptp rail valve I have been commanding much higher pressures and still my spill has yet to let me know it needs to be cleaned.
Sent from my Nexus 7 using Tapatalk 2
2010 Black Mica MS3 (Daily Driver) - self-tuned with the help of Lex www.mazdaspeedforum.org/forum/forum/f426/k06-log-86437/
K04 Hybrid, Nitto NT01s, JMF Manifold, 4 Port Meth, 100% E85, 3 Bar MAP, HTP 3.5, Cobb DP, ETS TMIC, KMD Internals, PTP RV, OCC, Forge BPV, CP-E Mounts, JBR Thermal Intake & Throttle Body Gaskets, JBR Shifter Plate & Bushings
2006 Mustang GT - www.vortechsuperchargers.com/global_item.php?gik=348
Built Motor, 675 RWHP 560 lb/ft T-Trim 21PSI Non-Intercooled
1993 Mustang LX - www.youtube.com/watch?v=WiCCvodp6CU
Budget 349 Stroker
khopwood77 is offline   Reply With Quote
The Following 6 Users Say Thank You to khopwood77 For This Useful Post:
Enki (08-19-2012), FistPump20fo7 (06-30-2013), GLORIFIEDBOZO (08-19-2012), mazdafreak (08-19-2012), phate (08-19-2012), rfinkle2 (08-20-2012)
 Old 08-19-2012, 07:16 PM   #23
Enki's Avatar
What mobile 1, specifically?
 Old 08-19-2012, 07:37 PM   #24
khopwood77's Avatar
Mobil 1 5W-30 full synthetic
Budget 349 Stroker
The Following 2 Users Say Thank You to khopwood77 For This Useful Post:
calizoomzoom (12-27-2013), Enki (08-19-2012)
 Old 08-19-2012, 07:46 PM   #25
dot584's Avatar
Posts: 426   (View Stats)
dot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the world
Is there any way having higher commanded pressure with the upgraged valve could keep the black from sticking on the internals? Or could the ptp valve be of a better design that doesn't stick?
Sent from my ADR6300 using Tapatalk 2
CP-E TIP and Cai - Corksport 3" catless DP - Magnaflow CBE - KMD fuel pump internals - Cobb AP - Fat Cat Motorsports Coilovers!
dot584 is offline   Reply With Quote
 Old 08-19-2012, 07:56 PM   #26
khopwood77's Avatar
I'm running a ptp rail valve not a ptp spill valve. I'm still using the factory pump and spill valve with the addition of KMD internals.
I don't think higher pressure has anything to do with it. I'm still using close to factory values in the lower load ranges.
Although I do spend most of my driving at highway speeds over 1k psi on my 35 mile trip to work.
Budget 349 Stroker
 Old 08-19-2012, 09:27 PM   #27
Enki's Avatar
1. My idle pressure has been bumped to 750 from the 4xx that stock/OTS use and is linearly scaled past that, so that wouldn't apply here.
2. The rail valves only open when pressure is exceeded (in case of stock, 1850 if memory serves).
Also, this isn't just about the spill valve, but also pertains to the internals getting caked with black death (vs sticky death on the spill valve). If you don't get one, it is likely that you won't get the other either; it also stands to reason that the type of internals you use matters little as well, unless there's some sort of clearance issues which prevent/allow oil into the retaining nut that otherwise wouldn't (but this is extremely unlikely as if there's enough room for movement, there's enough room for oil to leak by).
 Old 08-19-2012, 10:55 PM   #28
GLORIFIEDBOZO's Avatar
Posts: 1,928   (View Stats)
GLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the world
RP 10-30, 5k miles, no issues.
RT6 5-40, 4.5k miles, cleaned once a month
VR1 10-30, 1.5k, no issues
In that order. Mileage is on the ish.
"Intelligence isn't the ability to store information, but to find it" - Albert Einstein
"When I read about the evils of drinking, I quit reading" - Henry Youngman
GLORIFIEDBOZO is offline   Reply With Quote
The Following 3 Users Say Thank You to GLORIFIEDBOZO For This Useful Post:
Enki (08-20-2012), rfinkle2 (08-20-2012), silvapain (08-20-2012)
 Old 08-20-2012, 12:11 AM   #29
Enki's Avatar
@GLORIFIEDBOZO:
Couple questions for you:
1. Whole pump teardown once a month, or just spill valve?
2. Sticky and black deaths?
Also, this thread is beginning to take shape nicely. Need more input though; perhaps I'll try VR1 again now that I understand exactly what's going on with my oil pressure gauge.
 Old 08-20-2012, 12:15 AM   #30
radioflyer's Avatar
Posts: 729   (View Stats)
radioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the world
Groaned at 22 Times in 12 Posts
Subbed, running 50 / 50 for the record.
-2007 MS3 - Sold
-2015 BMW m235i - Painfully stock and incredibly comfortable.
radioflyer is offline   Reply With Quote
 Old 08-20-2012, 12:58 AM   #31
Enki's Avatar
2 things:
Originally Posted by radioflyer View Post
Subbed
Top of page, thread tools -> subscribe. Don't need to post.
running 50 / 50
This thread is for much higher than 50/50 concentrations of E.
Okay, back on topic.
 Old 08-20-2012, 02:52 AM   #32
@GLORIFIEDBOZO:
Whole pump, sticky ass black gunk covering everything. However, I didn't lose fuel pressure often.
 Old 08-20-2012, 03:49 AM   #33
Mchart's Avatar
Posts: 980   (View Stats)
Mchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the world
Groans: 54
Groaned at 42 Times in 32 Posts
Sounds like we just need to throw a pool together and have someone buy a quart of every oil we can imagine and do said test.
Mods - Six (6) Kenny Loggins albums in each position in my 6 disc changer.
HOW-TO Tune a car - http://youtu.be/5ET9YXP1M04
Mchart is offline   Reply With Quote
The Following 2 Users Say Thank You to Mchart For This Useful Post:
Enki (08-20-2012), G26 (08-20-2012)
 Old 08-20-2012, 04:07 AM   #34
MSP6's Avatar
I was wondering about that lol. You're initial post on the testing made it sound so much smoother. Yeah don't do that, don't want to be breathing in that crap.
I'd imagine also that its less about the pressure and likely largely to do with the cooling of the mixture that is left inside the valve once the car is turned off and sitting.
The Following User Says Thank You to MSP6 For This Useful Post:
Enki (08-20-2012)
 Old 08-20-2012, 04:39 AM   #35
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
I'll boil the ethanol so James doesn't have to put his life on the line again haha.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
The Following 3 Users Say Thank You to 86AmishMs3 For This Useful Post:
Enki (08-20-2012), rfinkle2 (08-20-2012), SofaKingAwesome (08-20-2012)
 Old 08-20-2012, 07:46 AM   #36
Eth Fiend
phate's Avatar
It's occurring whether the car is running or not. We have seen a number of instances where someone will run their tank to empty, then fill with E85. They drive 30-40 miles and suddenly it's a stuck spill valve, nasty crap everywhere.
I am more inclined to think it is the condition of the O-Ring which has the greatest effect on how often things need cleaned. Oil type may help, though.
-06 MS6
 Old 08-20-2012, 08:11 AM   #37
In for this if it is safe healthwise for Enki to do and he is willing / feels it will provide definitive results.
Enki (08-20-2012)
 Old 08-20-2012, 08:14 AM   #38
MSP6's Avatar
Well then my brownie brain is out of ideas lol so I'll stop cluttering the thread. Subbed for further info.
Enki (08-20-2012)
 Old 08-20-2012, 10:24 AM   #39
Enki's Avatar
I don't mind doing it again, I'll just need to take extra precautions.
The best way for me to perform the tests on other oils is probably by having people ship me samples for testing (I don't actually need a whole lot; buying a full quart for this testing would be *extremely* wasteful).
I need to do some other research regarding this to figure out if the fuel ignited due to natural autoignition or if some boiled out and hit the glowing hotplate coil.
At any rate, let's keep this thread going.
phate (08-20-2012), rfinkle2 (08-20-2012)
 Old 08-20-2012, 10:30 AM   #40
Enki's Avatar
It is likely more a function of pump temperature; during my testing, just after adding a few drops of oil, I boiled fuel for a good long while and there was no change. It wasn't until after I turned the heat up that I got a sticky result.
It's OK man; I have a hotplate and pan specifically for this purpose collecting dust in the garage. In fact, they are still sticky and need to be cleaned with lighter fluid.
G26 (08-20-2012), rfinkle2 (08-20-2012)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f567/kings-corn-hpfp-oil-122082/
2014 Ford Fiesta ST project - Page 9 This thread Refback 08-03-2014 08:28 AM
What happened to the e85 blend thread? - Page 4 This thread Refback 02-15-2014 09:29 PM
What happened to the e85 blend thread? - Page 3 This thread Refback 01-08-2014 09:42 PM
BNR Stage 3 Turbo Upgrade - Page 7 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 02-01-2013 03:06 PM
Resolving HPFP corn woes (black death/sticking spill valve) Enki MazdaSpeed 3/6 - E85 Fueling 467 10-26-2014 03:50 AM
Another Corn Fed PU trf5000 2010 MS3 - ECU Computer Tuning 73 08-12-2012 09:07 AM
2 gal's of corn + chinacharger dooderek MazdaSpeed 3/6 - ECU Computer Tuning 15 01-10-2012 01:52 AM
Make hate part 10ish. - negative camber kings check in IshiKage MazdaSpeed 3/6 - Suspension & Brakes 30 05-02-2010 11:08 PM
Dale Earnhardt lives on... as 305-foot roller coaster at Kings Dominion?! [w/VIDEO] Haltech Automotive News 0 08-21-2009 09:20 AM
Page generated in 0.62826 seconds with 37 queries
