Like Tree46Likes
 Old 08-31-2012, 03:23 PM   #81
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Replacement quad ring didn't really help me any. I still think the goal will be keeping oil out of the inside of the pump, or finding an oil with fewer issues/longer time between cleanings.
Honestly, I'd be ok with once a month. Once a day on the other hand....not so much.
 Old 08-31-2012, 03:33 PM   #82
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Had to search for it. Tons of information in the E85 section.
The O-ring I'm currently using is a 0.301x0.070" 70 Durometer Buna-N Quattro Seal. They can be purchased from McMaster-Carr.
I also have a regular toroidal O-ring stuffed in with the Quattro O-ring.
Tapadatass
Constantin (08-31-2012), Haltech (08-31-2012)
 Old 08-31-2012, 11:26 PM   #83
Constantin's Avatar
Posts: 3,907   (View Stats)
Constantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the worldConstantin is the leader of the world
Groaned at 18 Times in 16 Posts
Can you do a quick "how to"? That would help a lot!
2008 MS3 Tuned by rfinkle2 on 93 - 321whp / 365wtq
Cobb AP, SRI, TIH, DP, BPV | Autotech FP Internals | Treadstone TR8L + PG Pipe Kit | Grimmspeed EBCS | JBR TIGs, RSB, SSP & Bushings, EGR Delete, RMM (88dm), TMM (88dm), PMM (80dm) | MD OCC | KW V2 | SPC Camber Arms | GTSPEC Trunk Cage | Goodridge Break Lines + StopTech PowerSlot Rotors + Hawk HP+ | Whiteline End Links (front) | MOOG End Links (rear) | DDM 55w 5k Head Lights and Fog Lights | Speedline Mirrors
Constantin is offline   Reply With Quote
 Old 09-01-2012, 02:44 AM   #84
mrQQ's Avatar
Posts: 1,164   (View Stats)
mrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the worldmrQQ is the leader of the world
Yes, fill with mix, tune, make rape.
nice. What is the maximum mix that can be safely run without periodic cleanup?
mrQQ is offline   Reply With Quote
 Old 09-01-2012, 04:09 AM   #85
GODspeed7's Avatar
Posts: 3,456   (View Stats)
Will you please stop being lazy and read the fucking thread?!?! But since you will be butthurt after that I'll spoon you the answer. Greater than 50/50 will start causing problems.
2012 Mazdaspeed3 Black Mica
Enki (09-02-2012)
 Old 09-01-2012, 09:19 AM   #86
slw97's Avatar
Posts: 147   (View Stats)
slw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond reputeslw97 has a reputation beyond repute
This thread really is a good read. I have learned alot about E85 reading it. Hopefully we can figire this out.
Originally Posted by Ckmazdaspeed3 View Post
I don't know about you, but most of my races are impromptu. I'm not like, "hey dude, pull over so I can switch to my super special meth map" lol.
Originally Posted by TRex
"i don't care if it is a soccer mom in a mini van, if that whore launches on me im going at it like i'm racing a supra....just so i can bask in the sweet sweet tears of their defeat.
couple things to say...... first off the immaturity to be driving at those......ahhhhh shut up woman!!!!
2013 CWP MS3- CS 3" SRI, CS Catted DP, CS 80 Duro Race RMM, GFB BPV, CS STS, AutoTech FP Internals, CS FMIC piping w/TR-6 Core, Res Delete
304 Whp 371 Wtq DYNOJET 3 Gal E85
Purple Drank Tuned
2007 Ms3- Mazda speed CAI, gutted 2nd CAT, AccessPORT (SnailTooned), CorkSport RMM Inserts, flat black gen 1 wheels. 298 WHP 320 WTQ Sold but not forgotten
slw97 is offline   Reply With Quote
 Old 09-01-2012, 10:50 AM   #87
GODspeed7's Avatar
I agree and thank you for actually reading it. I may be a troll because I sit back and like to watch things unfold without speaking or asking dumb questions but trust me you will learn SO much from this site and especially everyone who posted in this thread by not asking dumb questions like that other guy.
 Old 09-11-2012, 12:45 AM   #88
Mchart's Avatar
Posts: 980   (View Stats)
Mchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the world
Groans: 54
Groaned at 42 Times in 32 Posts
I forgot to ask this earlier -
Are the seals being used in the pump Viton based seals? The seals look to be black in color so I assume not. (Viton seals are green)
Basically; Viton seals are far more heat resistant and are better at blocking oils/fuels/whatever. They are also more resistant to caustics.
If the seal being used in the HPFP is a traditional seal then sourcing a Viton based equivalent would improve (Or potentially resolve) this situation IMO.
http://www.dupontelastomers.com/Prod...n/techInfo.asp
Also, I forgot where the thread was located but I remember someone on here (Phate?) doing some tests on the seals and with different fuels to see swell, etc. Was a Viton based gasket/seal used in this test?
Mods - Six (6) Kenny Loggins albums in each position in my 6 disc changer.
HOW-TO Tune a car - http://youtu.be/5ET9YXP1M04
Mchart is offline   Reply With Quote
The Following 2 Users Say Thank You to Mchart For This Useful Post:
Constantin (09-11-2012), dot584 (09-11-2012)
 Old 09-11-2012, 01:01 AM   #89
Mchart's Avatar
Groans: 54
I pulled a very relevant table of data from the product brief.
Unless i've entirely misconstrued the nature of the problem we are discussing; I beleive it to be worth switching to a Viton o-ring and seeing if that improves the situation or not.
If someone does go out and decide to use a Viton O-Ring make sure you actually get an official Viton o-ring. There are many o-rings out there that are 'Viton' but do not have the official Dupont formulation. Thus, they are inferior in real world usage. Official Viton rings are a solid green color, or black with green markings on it.
The Following User Says Thank You to Mchart For This Useful Post:
 Old 09-11-2012, 08:18 AM   #90
mazdafreak's Avatar
Posts: 2,610   (View Stats)
Groans: 124
^^ Good info..... Enki, spill valve started to take a shit....pretty sure I got about ~500 miles on it since Aug 23..... I don't drive the car that much, it does sit usually for 4 days every week, rest is going out over the weekend, going to the g.fs and w.e else.....plus I'm in need of another oil change, I'm still sure I have t6 in the motor still since I switched to vr1 oil.
713whp/569wtq!
10.72 @ 139.44! (10/1/2015)
10.43 @ 140.95! 10/9/2015
10.35 @ 140.86 (10/30/2015)
The Following User Says Thank You to mazdafreak For This Useful Post:
Enki (09-11-2012)
 Old 09-11-2012, 09:20 AM   #91
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
@Enki
Have you tried mmo yet? Lots of guys on BITOG live and die by it for lubrication
 Old 09-11-2012, 10:36 AM   #92
silvapain's Avatar
Groans: 136
Originally Posted by pzr2874 View Post
@Enki
MMO didn't do shit for me on E85.
Tapadatass
mazdafreak (09-11-2012)
 Old 09-11-2012, 10:37 AM   #93
silvapain's Avatar
Groans: 136
See if you can find quad rings in Viton in the size I posted above. I've had no luck.
Tapadatass
 Old 09-11-2012, 10:42 AM   #94
Mchart's Avatar
Groans: 54
Tapadatass
http://www.marcorubber.com/quad_rings.htm
This place looks like a good bet. You'd need to call them though. They offer x-rings in all the same standard sizes as their o-rings and all the same material choices as well.
Also, make *sure* you order the 'Viton Extreme'. I've looked at some more data and the Viton Extreme is able to withstand ethanol (Or any alcohol for that matter) far better then normal Viton types and Buna-N.
http://www.marcorubber.com/compatibility.htm
 Old 09-11-2012, 11:37 AM   #95
ms34m3's Avatar
Posts: 79   (View Stats)
ms34m3 has a reputation beyond reputems34m3 has a reputation beyond reputems34m3 has a reputation beyond reputems34m3 has a reputation beyond reputems34m3 has a reputation beyond reputems34m3 has a reputation beyond reputems34m3 has a reputation beyond reputems34m3 has a reputation beyond reputems34m3 has a reputation beyond reputems34m3 has a reputation beyond reputems34m3 has a reputation beyond repute
Great Work Dudes!
ms34m3 is offline   Reply With Quote
 Old 09-11-2012, 11:45 AM   #96
pzr2874's Avatar
Groans: 146
Tapadatass
Did you just put the shit in or start with a freshly cleaned pump?
 Old 09-11-2012, 11:48 AM   #97
silvapain's Avatar
Groans: 136
There's a huge thread about testing E85 with the HPFP. Read.
I have cleaned my HPFP more times than many on here have wiped their asses.
Tapadatass
dead-zone likes this.
The Following 6 Users Say Thank You to silvapain For This Useful Post:
codykemmet (09-21-2012), Enki (09-11-2012), GLORIFIEDBOZO (09-20-2012), Haltech (09-20-2012), mazdafreak (09-11-2012), pzr2874 (09-11-2012)
 Old 09-11-2012, 05:27 PM   #98
mazdafreak's Avatar
Groans: 124
Okay, this is weird.....So my fuel pressure dropped going to work on the highway, and got fuel pressure back after I got off the highway......I parked the car, since I had to work.....I went home, and my fuel pressure has not dropped for at least 30 miles so far.
So wtf happened?? I haven't had a chance to pull the spill valve yet....But I'm holding pressure.
713whp/569wtq!
 Old 09-11-2012, 05:55 PM   #99
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Sounds like what I've experienced. Pressure would come and go, but it will eventually gum up enough that it renders the spill valve inoperable.
-06 MS6
-Corn fed 07 MS3 - Sold
Enki (09-11-2012), mazdafreak (09-11-2012), Ms3_Miami (09-11-2012), silvapain (09-11-2012)
 Old 09-13-2012, 09:43 AM   #100
mazdafreak's Avatar
Groans: 124
^^Ahh makes sense.....I guess the vr1 oil works good.....When I ran t6, fp would drop right away and be gunked up.
This is the pic of the spill valve.....It wasnt super sticky, just a tad bit, it looked/felt like that gummy/sticky shit from a sticker.
713whp/569wtq!
 Old 09-15-2012, 03:21 PM   #101
dead-zone's Avatar
Posts: 442   (View Stats)
dead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the worlddead-zone is the leader of the world
Groaned at 53 Times in 17 Posts
That looks way better.
dead-zone is offline   Reply With Quote
The Following User Says Thank You to dead-zone For This Useful Post:
mazdafreak (09-15-2012)
 Old 09-20-2012, 09:15 PM   #102
mazdafreak's Avatar
Groans: 124
@phate @Enki this is my buddies @justinspeed3 spill valve on 50/50 on t6 for maybe half the summer till now. He was having problems with afr going crazy and would randomly full cut, ap clint said to check spill valve, and well, u can see the results. I'm on 100% and my spill valve never looked this bad lol.
713whp/569wtq!
The Following 2 Users Say Thank You to mazdafreak For This Useful Post:
dead-zone (09-21-2012), phate (09-20-2012)
 Old 09-20-2012, 09:49 PM   #103
Enki's Avatar
Fuck man MINE never looked that bad. Most of that is either from before adding corn (not cleaned prior to going mid-mix; probably should be a requirement, really) or hes right on the edge of ratio that causes issues.
How is he calculating his mix? Is he putting in the same amount of e85 to 91 per tank or just the same amount of corn each tank and topping off?
 Old 09-20-2012, 10:03 PM   #104
mazdafreak's Avatar
Groans: 124
Yeah same here, mine has NEVER looked that bad, and I'm on 100% E lol.....I don't kno the exact details, but I kno he fills up at every half a tank and puts ~6/6 gallons of 85/93. Idk if he adds a lil more 85 or not....Maybe @justinspeed3 can help answer??
So I think 50/50 down the road actually gunks up, or its the t6 oil.... I see nothing but problems with ppl running E and t6.
713whp/569wtq!
 Old 09-20-2012, 10:14 PM   #105
Enki's Avatar
Could be the gas. I use 91.
Ultimately, he should make a thread on it.
 Old 09-20-2012, 11:14 PM   #106
Eth Fiend
phate's Avatar
Yeah same here, mine has NEVER looked that bad, and I'm on 100% E lol.....I don't kno the exact details, but I kno he fills up at every half a tank and puts ~6/6 gallons of 85/93. Idk if he adds a lil more 85 or not....Maybe justinspeed3 can help answer??
I think I can give some background on this car:
Tuned on 5050 MONTHS ago by yours truly. So I talked to him about this today and got some info, which is why the spill valve was pulled
He hasn't switched back to 93 since the 5050 tune, which is a ton of miles for him - I would guess 7-10k miles. Way back when we did the tune, he wanted to always top off the car because he drives it so much. I told him to always err on the high side with E85, which is exactly what he was doing. Over time, this has led to a higher than intended concentration.
He is approaching 13:1 AFR's on his current tank, due to too much ethanol. In terms of AFR's, it's fine, that's why we tune them conservatively (target 11.48). BUT, I think this extra ethanol put him in the 'danger zone' for black death build up. Couple that with lots of miles, and bam, you have buildup and the E85 woes we've come to know and love.
@justinspeed3 - can you verify the miles?
@mazdafreak - thanks for posting those pics.
-06 MS6
Enki (09-20-2012), justinspeed3 (09-21-2012), Nliiitend1 (09-23-2012)
 Old 09-20-2012, 11:21 PM   #107
GLORIFIEDBOZO's Avatar
Posts: 1,928   (View Stats)
GLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the worldGLORIFIEDBOZO is the leader of the world
This thread makes me miss my car
"Intelligence isn't the ability to store information, but to find it" - Albert Einstein
"When I read about the evils of drinking, I quit reading" - Henry Youngman
GLORIFIEDBOZO is offline   Reply With Quote
The Following 4 Users Say Thank You to GLORIFIEDBOZO For This Useful Post:
Enki (09-20-2012), justinspeed3 (09-21-2012), mazdafreak (09-21-2012), silvapain (09-21-2012)
 Old 09-20-2012, 11:38 PM   #108
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
you guys and your high concentration E85...lol
good thread...will need to read up. I am currently running E42/5050 but am not seeing any gains over E35 as of yet. The 42 needs about .5* more timing to reach the same WHP so IDK what I think yet.
zero issues with FP...well if you don't count pegging the FP sensor with a PTP 2150 RV...lol
note to self...put 1850RV back in while motor is torn down for oiling issues.
 Old 09-21-2012, 12:21 AM   #109
Bah, its just that damn OCC you got.. Get the replacement pieces from Matt and you will be in business
Dano (09-21-2012)
 Old 09-21-2012, 12:33 AM   #110
Trail of Fail
Dano's Avatar
isn't' it your bedtime?
 Old 09-21-2012, 07:48 AM   #111
mazdafreak's Avatar
Groans: 124
Np clint, I'm awesome . I was surprised to see that, I was like Wtf!
Anyways, idk if this matters, but justin says he's overdue for an oil change by like 4000 miles...pretty sure he changes it every ~3000....Guess t6 is starting to break down, idk, which I would guess why the oil is so black/dark......Just something to figure in too I guess.
713whp/569wtq!
 Old 09-21-2012, 07:53 AM   #112
Eth Fiend
phate's Avatar
The high concentrations will be put to better use soon enough
-06 MS6
The Following 8 Users Say Thank You to phate For This Useful Post:
Dano (09-21-2012), Enki (09-21-2012), GLORIFIEDBOZO (09-21-2012), mazdafreak (09-21-2012), Ms3_Miami (12-26-2012), rfinkle2 (12-26-2012), silvapain (09-21-2012), Todd98SE (09-21-2012)
 Old 09-21-2012, 10:24 AM   #113
Enki's Avatar
In before new stock turbo record.
 Old 09-21-2012, 06:52 PM   #114
justinspeed3's Avatar
Posts: 161   (View Stats)
justinspeed3 is the leader of the worldjustinspeed3 is the leader of the worldjustinspeed3 is the leader of the worldjustinspeed3 is the leader of the worldjustinspeed3 is the leader of the worldjustinspeed3 is the leader of the worldjustinspeed3 is the leader of the worldjustinspeed3 is the leader of the worldjustinspeed3 is the leader of the worldjustinspeed3 is the leader of the worldjustinspeed3 is the leader of the world
if i had to guess ive put 9 to 10 k on the car maybe alittle less since ive been on e85 only time ive not been on 85 is when i went to the dealer and switched to my 93 tune.... when shawn took everything apart and i saw all the sludge i was def shocked.... like clint said my afr are high and im dropping fuel pressure at times at low rpm's and been feeling the effects of fuel cut latley for the past 2 days lol.... im at a half tank and going to run the rest out and switch back to 93 prolly by sunday.
Justinspeed3 is a huge faggot with a slow car!!!
--mazdafreak was here.
justinspeed3 is offline   Reply With Quote
 Old 09-21-2012, 06:58 PM   #115
i just seen this one.... as stated before i usually fill up at a half of tank or whenever i pass by a gas station with e85 bc the closest one too me is 9 miles away so if im near one il top it off.... at a half of tank i put 3.5 and 3.5 before if i had alittle more to go like a gallon or half a gallon id add the rest e85 so if i had to top it is only be a gallon more... im not the smartest guy around lol. clint said when i add e85 my afr and fuel dropping issue should be taken care of.
The Following 2 Users Say Thank You to justinspeed3 For This Useful Post:
mazdafreak (09-21-2012), rfinkle2 (12-26-2012)
 Old 09-21-2012, 07:53 PM   #116
@silvapain 400hp stock turbo
 Old 09-21-2012, 10:28 PM   #117
silvapain's Avatar
Groans: 136
Always the optimist.
If we were NA, I would only expect about a 2-3% increase in WHp. With FI and E85 I don't know what to expect.
We'll find out soon enough though. Pistons are at the shop.,.
Tapadatass
The Following 5 Users Say Thank You to silvapain For This Useful Post:
Dano (09-22-2012), Enki (09-22-2012), GLORIFIEDBOZO (09-22-2012), mazdafreak (09-22-2012), Nliiitend1 (09-23-2012)
 Old 12-09-2012, 06:17 AM   #118
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Back to the original topic...
I would gum up my spill valve in ~50 miles when trying to run 7.5-8 gal/tank E85 (~E50) when using Walmart SuperTech 5w-30 synthetic. I could reduce the E85 concentration to 6-7 gal/tank and clean the spill valve in place enough to control again.
This was repeatable as it checked it 2-3 times.
I have never had any issues with this oil at E20-E40 during the past 1.5 years.
The Following 3 Users Say Thank You to cld12pk2go For This Useful Post:
Enki (12-09-2012), Nliiitend1 (12-09-2012), rfinkle2 (12-26-2012)
 Old 12-23-2012, 04:35 PM   #119
Mattcinnc1's Avatar
Posts: 573   (View Stats)
Mattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the worldMattcinnc1 is the leader of the world
u didnt have to clean spill valve either between E20-E40 either? for u atlease
2006 Mazdaspeed 6 WWP
Mods: Cobb ap, Freektune ots+, rebuilt ko4(hhskinny), Autotechs, AEM CAI, ETS tmic, Sure sidewinder, JBR RMM, Cpe diff mount, sure charge tubes, Corksport strut tower, catless test pipe, Magnaflow CBE, Forge BPV(v1), JBR shift bushings, corksport rear sway bar, VTCS delete, Dba 4000 slotted rotors, ebc red stuff
Interior: Block Vent pod, Prosport boost gauge, Redline leather boots, Mazdaspeed E-brake, Ipod integration, Corksport LEDs
Looks: 15% tint all around, 40% entire windshield, Corksport LED fogs, Corksport stub
Fluids: Rotella T6, Motorcraft XT-M5-QS, Redline 75w90
waiting to install (in garage):
Cpe catted dp
Mattcinnc1 is offline   Reply With Quote
 Old 12-23-2012, 08:50 PM   #120
Eth/Meth Junkie
cld12pk2go's Avatar
Correct, zero issues below E50.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f567/kings-corn-hpfp-oil-122082/
2014 Ford Fiesta ST project - Page 9 This thread Refback 08-03-2014 08:28 AM
What happened to the e85 blend thread? - Page 4 This thread Refback 02-15-2014 09:29 PM
What happened to the e85 blend thread? - Page 3 This thread Refback 01-08-2014 09:42 PM
BNR Stage 3 Turbo Upgrade - Page 7 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 02-01-2013 03:06 PM
Resolving HPFP corn woes (black death/sticking spill valve) Enki MazdaSpeed 3/6 - E85 Fueling 467 10-26-2014 03:50 AM
Another Corn Fed PU trf5000 2010 MS3 - ECU Computer Tuning 73 08-12-2012 09:07 AM
2 gal's of corn + chinacharger dooderek MazdaSpeed 3/6 - ECU Computer Tuning 15 01-10-2012 01:52 AM
Make hate part 10ish. - negative camber kings check in IshiKage MazdaSpeed 3/6 - Suspension & Brakes 30 05-02-2010 11:08 PM
Dale Earnhardt lives on... as 305-foot roller coaster at Kings Dominion?! [w/VIDEO] Haltech Automotive News 0 08-21-2009 09:20 AM
Page generated in 0.62136 seconds with 38 queries
