  • 2 Post By btstarcher
 Old 09-01-2014, 03:56 AM   #1
EmPeEs6's Avatar
Posts: 642   (View Stats)
EmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the worldEmPeEs6 is the leader of the world
Default No power gains from E85 mix!?
Yesterday I added 3-4 gallons E85 so I currently run a 25% E-mix.
Without having done any maf-recal my max calculated load jumped up from 2.3 to 2.5x and max maf increased by 40-50 g/s, so there are gains in air flow of roughly 10%.
What I don't understand is that I don't notice any gains in tq / hp in VD!?
Since there's much more air entering the combustion chamber I should also get more hp or am I totally wrong?
I use VersaTuner as tuning tool (and thus lambda-tuning), so I do not necessarily have to adjust my fuel tables, moreover boost and timing are already set quite high (up tp 24-25 psi / 20°).
Reported afr is varying around 11.5, but this is of course an internally transformed value based on pump gas assumptions.
Do I have to increase / lean out target afr further (~12.0), and where's my expected, additional power? May this be due to insufficient fuel supply...?
Mods: BNR S4, 3" Ray cb, CP-E catted dp, CS 3" intake, CP-E tmic, D06-wmi, itv22/NGK IX plugs, Forge bov, hpfp-upgrade, JBR ebcs, 3 bar map sensor, egr block off kit, ACT 6 pad clutch with SL flywheel, Wiseco oem compression pistons, Manley H-Beam connecting rods, reworked head, CP-E SafeSeal injector seals, no E85, Cosworth thermostat
EmPeEs6 is offline   Reply With Quote
 Old 09-01-2014, 03:58 AM   #2
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
Groaned at 8 Times in 4 Posts
Guessing versatuner does MAF based fuel scaling rather than doing injector scaling... @Lex;?
 Old 09-01-2014, 04:49 AM   #3
btstarcher's Avatar
Posts: 4,852   (View Stats)
Why would you see any power gain just by adding e85? The gains come from allowing for more advanced timing. Also the load and AFR are off because the fuel density is different. You're not getting more air.
calizoomzoom and Ozynigma like this.
SnailTune in progress
The Following 3 Users Say Thank You to btstarcher For This Useful Post:
chaser27 (10-01-2014), Easter Bunny (09-01-2014), ItsNox (09-01-2014)
 Old 09-01-2014, 05:16 AM   #4
Mistersix's Avatar
Posts: 2,585   (View Stats)
Try doing the runs all back to back adding a degree of timing each time. Use the same stretch going the same direction. Once you notice minimal gains or a little knock use the previous map. It's not gonna do miracles, but it's an easy 20hp.
The Following User Says Thank You to Mistersix For This Useful Post:
btstarcher (09-01-2014)
 Old 09-01-2014, 06:32 AM   #5
EmPeEs6's Avatar
This was an epic fail: I used an old E85-map as template which had the maf cal already adjusted by 10% - I just didn't notice this fact...
So, no miracles at all and everything as expected ;-)
The Following User Says Thank You to EmPeEs6 For This Useful Post:
 Old 09-01-2014, 11:28 AM   #6
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
You may flow more air due to the cooling effect, but alcohols burn slower, thus requiring more timing in order to make the same or more power.
btstarcher (09-01-2014), EmPeEs6 (09-01-2014), Mistersix (09-01-2014)
 Old 09-01-2014, 03:27 PM   #7
EmPeEs6's Avatar
Well, that was my original intention - since I already ran extremely aggressive values, as mentioned above up to 25 psi and 18° (on pump gas!) there's not much headroom for power gains from boost and/or timing...
 Old 12-22-2014, 06:16 PM   #8
BuddySpeed3's Avatar
Posts: 479   (View Stats)
Groaned at 7 Times in 4 Posts
Wow 25 psi and 18 degrees at redline on pump gas? Is that even possible?
I'm using 94 octane and in the process of dialing in a nice pump gas tune but still want to be safe.
What's your approach to dialing timing in on pump gas?
 Old 12-23-2014, 09:43 AM   #9
EmPeEs6's Avatar
This was on 95 (US) octane (=102 EU octane), i.e. the best fuel quality avaiable.
Now, using 93 octane gas + ~4-5 gallons E85, I can run up to 27 psi and 20° at redline.
 Old 12-23-2014, 10:10 AM   #10
Snip's Avatar
Posts: 329   (View Stats)
Yup, that RON 102 octane is amazing stuff, glad we have that quality of fuel over here in europe, costs a fair dime (currently ~1.80 euro per liter ), but worth every penny in my opinion.
Starting from my RON98 octane tune, i could easily add 5* timing up top.
Still no knock to be found untill now.
MazdaSpeed3 GT '07
AccessPort V2 Self tuned
 Old 12-23-2014, 10:35 AM   #11
SpeedRebirth's Avatar
Posts: 685   (View Stats)
Groans: 33
Well, you ran a 102 octance fuel. Then went back to (US93/EU98??) + E85...
E85 has a EU octane of 104. Mixing that with EU98 might get you ~100 octane
So your current octane is actually lower than before. The only advantage now is that E85 cools your chamber better. But octane is actually worse
I don't see that there is much gain to be had. I.E you need a bigger turbo
Mazdaspeed6 -06
Tuned with by Alex@Stratified
290 AWHP / K04
370 AWHP / GTX3076 @ 23 psi
 Old 12-23-2014, 10:37 AM   #12
Enki's Avatar
Not even remotely close/true. E100 has an *effective* octane rating closer to 160 on DI engines.
SpeedRebirth (12-23-2014)
 Old 12-23-2014, 11:02 AM   #13
Gr8Speed's Avatar
Posts: 5,702   (View Stats)
Noticing your mods this is probably pretty irrelevant- but I have observed MBT on limited flow setups at 14-15* at the low end as opposed to the "norm" of 20ish* with an e40 mix. An example is a car that only had an intake and test pipe (HPFP internals also of course).
Enki (12-23-2014)
Power gains from hf downpipe EmPeEs6 MazdaSpeed 3/6 - ECU Computer Tuning 2 01-30-2013 05:25 PM
Acura RDX gains power, loses weight for '13 Haltech Automotive News 0 02-07-2012 09:40 PM
Are power gains cumulative with bolt on's? ganderson 2010 MS3 - Engine, Transmission & Driveline 9 03-01-2011 06:34 AM
Ford leads Detroit 3 quality gains over rivals, J.D. Power says Haltech Automotive News 0 06-17-2010 10:10 PM
Power gains with just an air intake and catback. 06kr Mazdaspeed3/6 General Discussion 7 09-09-2008 03:09 PM
Page generated in 0.33853 seconds with 28 queries
